  3. RS485 network not running... please help!
21 Posts 5 Posters 6.5k Views 7 Watching
  • kduinoK
    kduinoK
    kduino
    Hi, I tried different Max485 modules but it was just the same. Finally I directly connected the two machines over RX->TX and TX->RX, then it is working fine. So I go in further investigation now where to find the problem on RS485 ;-)
    K 1 Reply Last reply
    • kduinoK kduino
      K
      K
      kimot
      @kduino
      Try
      #define MY_NODE_ID 23
      before
      not after.
      Try RS485 examples from MySensors library - "MotionSensorRS485"
      only add
      before
      It works.
      • kduinoK
        kduinoK
        kduino
        unfortunately it is not working. I have two R200 resistors at the end of my 3 cm long track, I changed the position of MY_NODE_ID...
        I will look on the RS485 network closer the next days. Thank you for your help!
        Have a nice weekend.
          Try with a lower resistance. But what cable are you using?
          • kduinoK
            kduinoK
            kduino
            wrote on last edited by kduino
            For testing I just put the two max485 bricks on a strip board and bridged a->a and b->b, 2-3 cm long jumper wire :-)
            I will use a cable instead in the afternoon together with two r100.
            I also tested different max bricks to rule out malfunction. Without success.
            • kduinoK
              kduinoK
              kduino
              @kimot
              I started with the examples. Then I introduced soft serial and as far as I consider the direct connection via serial it works. So I checked the de pins, they go active while sending. All good in this part... but together with the max485 the node still doesn't get the gateways response. We will see. Need another evening to try.
              • P
                P
                pjr
                wrote on last edited by pjr
                "Writing multiple SOH"
                Most likely not the problem what AP has but I think its good to mention also in this thread: https://forum.mysensors.org/post/56960
                • kduinoK
                  kduinoK
                  kduino
                  ok I started the next run, I checked the voltage levels (Multimeter is showing a differential of A&B of 0.2 V and is going up during sending.
                  The Breadboard has no short circuit potential, the wire is now 2x2x0.3 and about 50 cm long, I added R100 to each end...
                  Then I copied the sketches of the rs485 stresstest posted in the forum...
                  But it is not working though... ;-(
                  Any ideas?
                  Thank you.
                  This is what the node prints now:
                  621470 TSM:FPAR
                  4621471 TSM:FPAR:STATP=0
                  4621474 TSM:ID
                  4621475 TSM:ID:OK
                  4621477 TSM:UPL
                  4621488 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  4623496 TSM:UPL
                  4623506 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  4625513 TSM:UPL
                  4625523 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  4627530 TSM:UPL
                  4627540 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  4629548 !TSM:UPL:FAIL
                  Is there any place where I can look up the abbreviations?
                  gohanG K 2 Replies Last reply
                  • kduinoK kduino
                    Any ideas?
                    Thank you.
                    621470 TSM:FPAR
                    4621474 TSM:ID
                    4621475 TSM:ID:OK
                    4621477 TSM:UPL
                    4623496 TSM:UPL
                    4625513 TSM:UPL
                    4627530 TSM:UPL
                    @kduino main site, look for log parser
                    • kduinoK kduino
                      Any ideas?
                      Thank you.
                      621470 TSM:FPAR
                      4621474 TSM:ID
                      4621475 TSM:ID:OK
                      4621477 TSM:UPL
                      4623496 TSM:UPL
                      4625513 TSM:UPL
                      4627530 TSM:UPL
                      K
                      K
                      kimot
                      @kduino
                      We can see debug info from your node.
                      It is through USB port on Arduino?
                      Because I can see:
                      #define MY_RS485_HWSERIAL mySerial
                      In your node code example.
                      HW serial on Arduino is connected to serial-USB converter normally.
                      You cannot use it for both - debug through USB and RS485 at the some time.
                      But I think, it is mistake only, because on the start of the code you define:
                      #include <SoftwareSerial.h>
                      SoftwareSerial mySerial(8, 9);
                      Try delete HW serial definition.
                      According debug info, it seems, that your node can sending and gateway is receiving his messages,
                      but node do not receive messages from gateway.
                      Or, if your communication works with direct TX-RX connection, try drivers for CAN bus instead of MAX485 ones. It eliminates possible problems with DEpin.
                      gohanG 1 Reply Last reply
                      • kduinoK
                        kduinoK
                        kduino
                        Hi Kimot,
                        thank you for your message. I have already built several nodes which don't have the right pinout since I didn't come across mysensors at this time. I asked here in the forum and @hek wrote, I can use SoftwareSerial as well defining it via MY_RS485_HARDWARESERIAL. It will fallback to AltSoftSerial if it doesn't work correctly...
                        As I mentioned I used this configuration also connecting RX-TX and TX-RX directly and it worked fine. So I assume something is wrong with the RS485 part of my setting. Unfortunately I don't have some Can driver at home.
                        The DE-Pins are working correctly. Each of them I connected to Led and they are flashing while sending (I assume). So there is somehow a connection, but only in one direction.
                        My next step is to change the input output pins on the node arduino, sometimes one have bad luck and is struggling for weeks on a problem and the simple result is one burned pin...
                        Thank you again I keep you updated,
                        kduino
                        • kduinoK
                          kduinoK
                          kduino
                          @gohan Thank you, the main message is:
                          Status: OK (OK=success, NACK=no radio ACK received)
                          So I have to investigate the RX channel of my node.
                          By kduino
                          • K kimot
                            @kduino
                            Because I can see:
                            @kimot can you really swap rs485 with a can bus driver and everything would still work without changing code?
                            • kduinoK
                              kduinoK
                              kduino
                              Trank you all for your support. I got in running finally.
                              I reassembled the complete thing on the breadboard. Then I connected the wires directly (rx-tx and tx-rx). After changing the position of the inclusion of mysensors.h for some times and using the standard pins and the preset node id it worked.
                              Then I went further to test software serial lib which worked great. Then I extended the model to use the rs485 and after some adaptation of the wires (it's always the wires after some frustrating nights) it worked.
                              For understanding I integrated also two led to signaling the sending via the de pin. This helped a lot.
                              As this was working correctly I turned up the speed. Ok, 250.000 bps were too much, but 115.200 were running without any complaints. On a breadboard though but without any cable adaption or resistor as final terminator.
                              So for this topic we can conclude that if rs485 is not even running on 9600 bps on a breadboard, it's not because of the cable or the terminating resistors. In this setting it should work anyway. Unless you have no bug somewhere else....
                              So for all my followers again thank you very much. I can only suggest to myself to reassemble the test unit completely to rule out any wrong connections....
                              Bye kduino
                              • kduinoK
                                kduinoK
                                kduino
                                @hek
                                I used some time to get further. As my tests show I can easily use the Arduino nano on pin 8 and 9, but the strategy of using SoftwareSerial you mentioned is not working.
                                See what I did below. The problem is now as follows:
                                If I state the HW_SERIAL command before the inclusion of mysensors.h the hardware serial is somehow not initialized and therefore throws an error on compilation. Only hardware serial ports are allowed.
                                If I state the HW_SERIAL command after the inclusion of mysensors.h the inlcusion has no effect, thus the defined pins are not rx and tx.
                                Do you know any advice for that?
                                Thank you so much for your support!
                                By kduino
                                Part of my ino file:
                                // Enable RS485 transport layer
                                #define MY_RS485
                                // Define this to enables DE-pin management on defined pin
                                #define MY_RS485_DE_PIN 3
                                // Set RS485 baud rate to use
                                // node Id:
                                #define MY_NODE_ID 5
                                SoftwareSerial mySerial(4, 2); // RX, TX
                                // Enable this if RS485 is connected to a hardware serial port
                                Part of the error:
                                This line is marked yellow:
                                Error description:
                                MySTestSensorRS485_working__2017-06-20_vRS485_1:68: error: invalid initialization of reference of type 'HardwareSerial&' from expression of type 'SoftwareSerial'
                                /Users/macmuc/Documents/Arduino/libraries/MySensors-master/core/MyTransportRS485.cpp:97:24: note: in expansion of macro 'MY_RS485_HWSERIAL'
                                 HardwareSerial& _dev = MY_RS485_HWSERIAL;
                                exit status 1
                                • kisse66K
                                  kisse66K
                                  kisse66
                                  Note about RS485:
                                  I've had (non-MySensors) issues with RS485 with some setups due to the fact that while the bus is not driven (no one sends anything) it's floating and not in idle state. This makes receivers pick random garbage. To make it stable you'd need to add pullup to the A line and pulldown to the B line (hope I remember polarity right way). Those will make sure the line stays idle. With two 120R terminators (both ends) the pullup/down needs to be quite small to create enough voltage across 60R. One could calculate (I think spec says 200mV), but I've used 470..680R with 5V system. Some interface modules may have these or similar current source on board.
                                  Termination with low speeds and short lines seems not so critical in practise.
                                  • kduinoK
                                    kduinoK
                                    kduino
                                    Hi Kisse66,
                                    thank you very much for this advice. Most of the forum writers are pointing on the terminating resistors, but in my experience they are not the key.
                                    I put two 680R from B to GND and A to 5V and the reliability I experienced has improved tremendously!
                                    Thank you for the hint.
                                    Another question I have: The gateway is receiving the messages now but there is no ACK. How can I ask for an ack for security relevant messages?
                                    Thank you
                                    By kduino
                                    12.5k
