  3. Serial Gateway halt!
12 Posts 4 Posters 5.5k Views 3 Watching
  • D Offline
    dzairo
    Hi. I play today with Serial Gateway and my sensor .. and gateway after few packet halt .. and I must restart gateway. Have anybody this problem?
    Best regards
    • N Offline
      N Offline
      niccodemi
      can you post screenshot of Mysensors plugin? you have to give us more information ie controller type. you should connect serial gateway to computer and check serial monitor in arduino ide.
      • D Offline
        dzairo
        Hi. sorry.. I forgot ..
        Here is serial data from gateway (with date time stamp) and debug serial data from sensor .
        Serial Gateway
        and
        Sensor
        sensor.odt
        in this data you can see :
        13:24:15 but gateway record last data : 13:29:49 so the gateway halt after this last packet...
        I use standard code from example directory .. and use last ARduino IDE..
        regards...
        • N Offline
          N Offline
          niccodemi
          which controller do you use?
          • D Offline
            dzairo
            sorry.. I not use controller .. only serial port monitor..
            really I need controller? can't serial gateway stand alone?
            regards
            N 1 Reply Last reply
            • B Offline
              B Offline
              BulldogLowell
              which sensor sketch are you using?
              • D dzairo
                regards
                N Offline
                N Offline
                niccodemi
                @dzairo I believe it is possible to use it stand-alone but with very limited functionality and possibly code modification. See this and this thread for more info.
                • D Offline
                  dzairo
                  Hi.I use example from source code . Serial gateway and binary switch with sleep.I don't want use serial gateway stand alone like controller. Now I want only received data and understand how it work.. If my gateway halt then controller will not working too.
                  What is it ? : st=ok or st=false from my report..
                  regards
                  • E Offline
                    E Offline
                    epierre
                    same issue here after months of good working, I rebooted the cubie exploiting it and no more communications... reboot, same, reflash: same...
                    I guess I'll have top go back in debug mode....
                    z-wave - Vera -> Domoticz
                    • D Offline
                      dzairo
                      Ehm... IF try my own code (GCC + AVR Studio 4.19) then I can send thousand packet (with ACK) from more sensor in same time ..and receiver still receive .. nRF24L01+ is stable IC and work good .. I don't know why not working in MySensor ..
                      I must write own sensor network code ..
                      MySensor is writed for Arduino then is too hard emulate in AVRStudio .. is it possible .. but ..
                      regards.
                      • E Offline
                        E Offline
                        epierre
                        I updated my git repository, re flashed the gateway and we're back ....
                        • D Offline
                          dzairo
                          Hi. I do same what you ... but still not working ...
                          BUt then I use different gateway PCB board .. and right now working .. may be hardware problem..
                          OK.. I will test it .. and will see..
                          best regards..
                          12.1k
