  3. Serial Gateway halt!
12 Posts 4 Posters 5.6k Views 3 Watching
  • D
    D
    dzairo
    Hi. I play today with Serial Gateway and my sensor .. and gateway after few packet halt .. and I must restart gateway. Have anybody this problem?
    Best regards
    • N
      N
      niccodemi
      can you post screenshot of Mysensors plugin? you have to give us more information ie controller type. you should connect serial gateway to computer and check serial monitor in arduino ide.
      • D
        D
        dzairo
        Hi. sorry.. I forgot ..
        Here is serial data from gateway (with date time stamp) and debug serial data from sensor .
        Serial Gateway
        and
        Sensor
        sensor.odt
        in this data you can see :
        13:24:15 but gateway record last data : 13:29:49 so the gateway halt after this last packet...
        I use standard code from example directory .. and use last ARduino IDE..
        regards...
        • N
          N
          niccodemi
          which controller do you use?
          • D
            D
            dzairo
            sorry.. I not use controller .. only serial port monitor..
            really I need controller? can't serial gateway stand alone?
            regards
            N 1 Reply Last reply
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
              wrote on last edited by BulldogLowell
              which sensor sketch are you using?
              • D dzairo
                regards
                N
                N
                niccodemi
                @dzairo I believe it is possible to use it stand-alone but with very limited functionality and possibly code modification. See this and this thread for more info.
                • D
                  D
                  dzairo
                  Hi.I use example from source code . Serial gateway and binary switch with sleep.I don't want use serial gateway stand alone like controller. Now I want only received data and understand how it work.. If my gateway halt then controller will not working too.
                  What is it ? : st=ok or st=false from my report..
                  regards
                  • epierreE
                    epierreE
                    epierre
                    same issue here after months of good working, I rebooted the cubie exploiting it and no more communications... reboot, same, reflash: same...
                    I guess I'll have top go back in debug mode....
                    z-wave - Vera -> Domoticz
                    • D
                      D
                      dzairo
                      Ehm... IF try my own code (GCC + AVR Studio 4.19) then I can send thousand packet (with ACK) from more sensor in same time ..and receiver still receive .. nRF24L01+ is stable IC and work good .. I don't know why not working in MySensor ..
                      I must write own sensor network code ..
                      MySensor is writed for Arduino then is too hard emulate in AVRStudio .. is it possible .. but ..
                      regards.
                      • epierreE
                        epierreE
                        epierre
                        I updated my git repository, re flashed the gateway and we're back ....
                        • D
                          D
                          dzairo
                          Hi. I do same what you ... but still not working ...
                          BUt then I use different gateway PCB board .. and right now working .. may be hardware problem..
                          OK.. I will test it .. and will see..
                          best regards..
