  3. My Slim 2AA Battery Node
498 Posts 71 Posters 586.8k Views 69 Watching
  • K
    K
    Komaandy
    Do you mean running the node without the PIR ?
    I thought about, I guess i will test it.
    You think the PIR freezes the node ?
    • K Komaandy
      sundberg84S
      sundberg84S
      @Komaandy - Yes and Yes :)
      Its a good way to debug, remove not crucial stuff to see if it works... one by one and you will figure it out.
      The PIR (depending on which one and what kind of power you are using) might be the problem but hard to say without knowing your setup.
      • AWIA AWI
        @Komaandy please don't double post. Please continue in the other thread
        m26872M
        m26872M
        m26872
        wrote on last edited by m26872
        #416
        @AWI said in My Slim 2AA Battery Node:
        @Komaandy and @sundberg84 Once again; Please continue in the other thread! Especially since @Komaandy now confirmed that it is this far NOT a generic Slim Node issue. Also, I haven't got any feedback on my reply there, but I assume it didn't work?
        • siodS
          siodS
          siod
          Hi @Komaandy ,
          unfortunately I must report that I made the same expiriences you made. I am running 5 "My SLim 2AA Battery Node" Sensors from which only 2 really work. The others keep freezing after an hour, a day, are sometimes after a few days. I have still no idea why this is happening, but because of this I stopped building more of the "My SLim 2AA Battery Node" sensors, which is very sad, because it´s an ingeniuous design.
          I am using MQTT and therefore I installed NRF24L01 modules. Some of them are really weak, so I thought that´s the problem: The node does not freeze, it´s just the NRF24L01 that is not sending any info anymore. So I attached a LED to my node to see if it is still alive. Whenever I opened a window the LED must lid. So when I did not got any info from the node I checked if the node is still operational by opening a window and there I noticed when the LED did not lid, that the node was completely frozen. So It was not a wireless connection problem, but the NRF24L01 of course could still be the problem.
          A lot of my investigastions was about figuring out what is happening when entering the sleep mode, because I thought (and still believe) the node is just not waking up from sleep anymore. Unluckily I still did not find a solution.
          Anywhere you said that the none battery driven nodes are working flawlessly, that´s another point I was thinking about. I have one MQTT Arduino Nano device in the basement which is directly powered over USB and I never had problems with it, also the MQTT / NRF24L01 range is awesome.
          But I have no oscillator or anything to check if it a power problem with the "My Slim 2AA Battery Node".
          Maybe you´ll find a solution for your problems which could help me, too. I´m looking forward hearing from you.
          still learning...
          m26872M 1 Reply Last reply
          • siodS siod
            Hi @Komaandy ,
            m26872M
            m26872M
            m26872
            @siod Thanks for your report. Could you please share some more info. Hw/sw versions, nRF-batches, sensors, configs/settings, sketches etc. @Komaandy could only confirm issues with a PIR eqiupped node, but you have a door-switch so I guess it's a potential generic problem then. Let's hope for other reports as to help us narrow down the search.
            I have not yet migrated to MySensors 2.x :flushed: , but it's hopefully coming soon. My Slim Nodes from the start of this thread (~ 10 pcs) are still in flawless production.
            sundberg84S siodS 2 Replies Last reply
            • m26872M m26872
              sundberg84S
              sundberg84S
              #419
              @m26872 - I made myself a slim node with a light sensor and a uv-sensor last weekend. Its running latest dev branch and has been working flawless atleast 1 week now.
              • m26872M m26872
                siodS
                siodS
                siod
                @m26872 First of all: I already got so much help and I am very grateful for that, awesome community!
                I don´t think I will ever find the problem with those sensors and because of the lack of time I have (familiy, work...) I think looking for the problem would take longer than just build a new sensor. And that´s what I will do next: I will just build another node, one step after the other and so I can validate if it maybe is a hardware problem or a code problem. BTW my whole sketch is just a few posts above this one...
                So I will come back after I started over...
                still learning...
                • K
                  K
                  Komaandy
                  @m26872
                  Hi there,
                  im still into troubleshooting, and what i did last was create a "mock up temperatursensor slim node " with this sketch
                  , so its really only the node and batteries. But it still freezes :(
                  Hardware i use is :
                  -Atmega328p 1Mhz bootloader. // Burnt the bootloader with one Arduino UNO as master and another Arduino UNO on which I replaced the Atmega328p as slave // Arduino as ISP // with the latest Arduino IDE (1.8.2)
                  • after burning the bootloader on the bare ATMEGA´s i assemble them on the node and transfer the sketch via FTDI232
                  Furthermore i use
                  -generic Capacitors and restistors ( specs from your BOM)
                  • Kuman nRF24L01 batches ( bought like 30 in a bulk once, but other "nonslimnodes" are working)
                    -fresh batteries
                  Any help is very aprreciated :) :)
                  * MockMySensors
                  #define MY_NODE_ID 123
                  #define RADIO_TX_LED_PIN    13  // the PCB, on board LED
                  // Wait times
                  #define LONG_WAIT 500
                  #define SHORT_WAIT 50
                  #define SKETCH_VERSION "v0.5"
                  // Define Sensors ids
                     S_SCENE_CONTROLLER
                  // one at a time.
                  #define ID_S_TEMP              7
                  //#define ID_S_BARO              9
                  //// Lib 1.5 sensors
                  //#define ID_S_SPRINKLER         29
                  // Global Vars
                  unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                  bool metric = true;
                  long randNumber;
                  #ifdef ID_S_ARMED
                  bool isArmed;
                  #ifdef ID_S_LIGHT
                  bool isLightOn=0;
                  #ifdef ID_S_DIMMER
                  int dimmerVal=100;
                  #ifdef ID_S_COVER
                  #ifdef ID_S_TEMP
                  #ifdef ID_S_HUM
                  #ifdef ID_S_BARO
                  MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
                  #ifdef ID_S_WIND
                  #ifdef ID_S_RAIN
                  #ifdef ID_S_UV
                  #ifdef ID_S_WEIGHT
                  #ifdef ID_S_POWER
                  #ifdef ID_S_HEATER
                  float heater_setpoint=21.5;
                  //  float heater_temp=23.5;
                  //  bool heater_status=false;
                  #ifdef ID_S_DISTANCE
                  #ifdef ID_S_LIGHT_LEVEL
                  #ifdef ID_S_LOCK
                  bool isLocked = 0;
                  #ifdef ID_S_IR
                  long irVal = 0;
                  #ifdef ID_S_WATER
                  #ifdef ID_S_AIR_QUALITY
                  #ifdef ID_S_DUST
                  #ifdef ID_S_SCENE_CONTROLLER
                  char *scenes[] = {
                     (char *)"Good Morning",
                     (char *)"Clean Up!",
                     (char *)"All Lights Off",
                     (char *)"Music On/Off"
                  int sceneVal=0;
                  int sceneValPrevious=0;
                  #ifdef ID_S_RGB_LIGHT
                  String rgbState="000000";
                  //RGB light V_RGB, V_WATT
                  #ifdef ID_S_RGBW_LIGHT
                  String rgbwState="00000000";
                  #ifdef ID_S_COLOR_SENSOR
                  //Color sensor	V_RGB
                  #ifdef ID_S_HVAC
                  //Thermostat/HVAC device
                  // NOT IMPLEMENTED YET
                  #ifdef ID_S_MULTIMETER
                  // V_VOLTAGE	38	Voltage level
                  // V_CURRENT	39	Current level
                  #ifdef ID_S_SPRINKLER
                  #ifdef ID_S_WATER_LEAK
                  #ifdef ID_S_SOUND
                  #ifdef ID_S_VIBRATION
                  #ifdef ID_S_MOISTURE
                  #ifdef ID_S_CUSTOM
                     // Random SEED
                     randomSeed(analogRead(0));
                     wait(LONG_WAIT);
                     Serial.println("GW Started");
                     Serial.print(SKETCH_NAME);
                     wait(LONG_WAIT);
                     Serial.print("Get Config: ");
                     wait(LONG_WAIT);
                     // Init Armed
                  #ifdef ID_S_ARMED
                     isArmed = true;
                  #ifdef ID_S_DOOR
                     Serial.println("  S_DOOR");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_MOTION
                     Serial.println("  S_MOTION");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_SMOKE
                     Serial.println("  S_SMOKE");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_LIGHT
                     Serial.println("  S_LIGHT");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_DIMMER
                     Serial.println("  S_DIMMER");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_COVER
                     Serial.println("  S_COVER");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_TEMP
                     Serial.println("  S_TEMP");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_HUM
                     Serial.println("  S_HUM");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_BARO
                     Serial.println("  S_BARO");
                     present(ID_S_BARO,S_BARO," Air pressure");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_WIND
                     Serial.println("  S_WIND");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_RAIN
                     Serial.println("  S_RAIN");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_UV
                     Serial.println("  S_UV");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_WEIGHT
                     Serial.println("  S_WEIGHT");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_POWER
                     Serial.println("  S_POWER");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_HEATER
                     Serial.println("  S_HEATER");
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                  #ifdef ID_S_LOCK
                     Serial.println("  S_LOCK");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_IR
                     Serial.println("  S_IR");
                     wait(SHORT_WAIT);
                  #ifdef ID_S_WATER
                     Serial.println("  S_WATER");
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                  #ifdef ID_S_DUST
                     Serial.println("  S_DUST");
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                  #ifdef ID_S_HVAC
                     Serial.println("  HVAC");
                     wait(SHORT_WAIT);
                     wait(SHORT_WAIT);
                  #ifdef ID_S_SOUND
                     wait(SHORT_WAIT);
                  #ifdef ID_S_CUSTOM
                     Serial.println("  S_CUSTOM");
                     wait(SHORT_WAIT);
                     Serial.println("");
                     Serial.println("");
                     Serial.println("");
                     randNumber=random(0,101);
                     Serial.println(randNumber);
                     // Send fake battery level
                     sendBatteryLevel(randNumber);
                     wait(LONG_WAIT);
                     // Request time
                     requestTime();
                     wait(LONG_WAIT);
                     //Read Sensors
                  #ifdef ID_S_DOOR
                     door();
                  #ifdef ID_S_MOTION
                     motion();
                  #ifdef ID_S_SMOKE
                     smoke();
                  #ifdef ID_S_LIGHT
                     light();
                  #ifdef ID_S_DIMMER
                     dimmer();
                  #ifdef ID_S_COVER
                     cover();
                  #ifdef ID_S_TEMP
                     temp();
                  #ifdef ID_S_HUM
                     hum();
                  #ifdef ID_S_BARO
                     baro();
                  #ifdef ID_S_WIND
                     wind();
                  #ifdef ID_S_RAIN
                     rain();
                  #ifdef ID_S_UV
                     uv();
                  #ifdef ID_S_WEIGHT
                     weight();
                  #ifdef ID_S_POWER
                     power();
                  #ifdef ID_S_HEATER
                     heater();
                     distance();
                     light_level();
                  #ifdef ID_S_LOCK
                     lock();
                  #ifdef ID_S_IR
                     ir();
                  #ifdef ID_S_WATER
                     water();
                     air();
                  #ifdef ID_S_DUST
                     dust();
                     scene();
                     rgbLight();
                     rgbwLight();
                     color();
                  #ifdef ID_S_HVAC
                     hvac();
                     multimeter();
                  #ifdef ID_S_SOUND
                     moisture();
                  #ifdef ID_S_CUSTOM
                     custom();
                     wait(SHORT_WAIT);
                  //void door(){}
                  #ifdef ID_S_DOOR
                  void door()
                     Serial.print("Door is: " );
                     if (randNumber <= 50) {
                     	Serial.println("Open");
                     	Serial.println("Closed");
                  #ifdef ID_S_ARMED
                     Serial.print("System is: " );
                  #ifdef ID_S_MOTION
                  void motion()
                     Serial.print("Motion is: " );
                     	Serial.println("Active");
                     	send(msg_S_MOTION_T.set(1));
                     	Serial.println("Quiet");
                     	send(msg_S_MOTION_T.set(0));
                  #ifdef ID_S_ARMED
                  #ifdef ID_S_SMOKE
                  void smoke()
                     Serial.print("Smoke is: " );
                     	send(msg_S_SMOKE_T.set(1));
                     	send(msg_S_SMOKE_T.set(0));
                  #ifdef ID_S_ARMED
                  #ifdef ID_S_LIGHT
                  void light()
                     Serial.print("Light is: " );
                  #ifdef ID_S_DIMMER
                  void dimmer()
                     Serial.println(dimmerVal);
                  #ifdef ID_S_COVER
                  void cover()
                     Serial.print("Cover is : " );
                     if (coverState == 1) {
                     	Serial.println("Opening");
                     	send(msg_S_COVER_U.set(1));
                     	Serial.println("Closing");
                     	send(msg_S_COVER_D.set(0));
                     	Serial.println("Idle");
                     	send(msg_S_COVER_S.set(-1));
                  #ifdef ID_S_TEMP
                  void temp()
                  #ifdef ID_S_HUM
                  void hum()
                  #ifdef ID_S_BARO
                  void baro()
                     long pressure = map(randNumber,1,100,870,1086);// hPa?
                     int forecast = map(randNumber,1,100,0,5);
                     Serial.print("Atmosferic Pressure is: " );
                     Serial.println(pressure);
                     send(msg_S_BARO_P.set(pressure));
                     Serial.print("Weather forecast: " );
                     send(msg_S_BARO_F.set(weather[forecast]));
                  #ifdef ID_S_WIND
                  void wind()
                  #ifdef ID_S_RAIN
                  void rain()
                  #ifdef ID_S_UV
                  void uv()
                  #ifdef ID_S_WEIGHT
                  void weight()
                     Serial.print("Weight is: " );
                  #ifdef ID_S_POWER
                  void power()
                     Serial.print("Watt is: " );
                     Serial.print("KWH is: " );
                  #ifdef ID_S_HEATER
                  void heater()
                     //  String heatState="Off";
                  void distance()
                  void light_level()
                  #ifdef ID_S_LOCK
                  void lock()
                     Serial.print("Lock is: " );
                  #ifdef ID_S_IR
                  void ir()
                     Serial.println(irVal);
                     send(msg_S_IR_S.set(irVal));
                     send(msg_S_IR_R.set(irVal));
                  #ifdef ID_S_WATER
                  void water()
                  void air()
                  #ifdef ID_S_DUST
                  void dust()
                  void scene()
                     Serial.print("Scene is: " );
                     	sceneValPrevious=sceneVal;
                  void rgbLight()
                     Serial.println(rgbState);
                  void rgbwLight()
                     Serial.println(rgbwState);
                  void color()
                     String colorState;
                     Serial.println(colorState);
                  #ifdef ID_S_HVAC
                  void hvac()
                     Serial.println(hvac_Speed);
                  void multimeter()
                     Serial.println(impedance);
                     Serial.println(volt);
                     Serial.println(amps);
                  #ifdef ID_S_SOUND
                  void moisture()
                  #ifdef ID_S_CUSTOM
                  void custom()
                     switch (message.type) {
                  #ifdef ID_S_ARMED
                     case V_ARMED:
                     	isArmed = message.getBool();
                  #ifdef ID_S_DOOR
                     	door();//temp ack for door
                  #ifdef ID_S_MOTION
                     	motion();//temp ack
                  #ifdef ID_S_SMOKE
                     	smoke();//temp ack
                     case V_STATUS: // V_LIGHT:
                  #ifdef ID_S_LIGHT
                     		light(); // temp ack
                     	//    #ifdef ID_S_HEATER
                     	//    #endif
                  #ifdef ID_S_DIMMER
                     case V_DIMMER:
                     	dimmerVal= message.getInt();
                     	dimmer();// temp ack
                  #ifdef ID_S_COVER
                     case V_UP:
                     	coverState=1;
                     	Serial.println("V_UP");
                     	cover(); // temp ack
                     case V_DOWN:
                     	coverState=-1;
                     	Serial.println("V_DOWN");
                     	cover(); //temp ack
                     case V_STOP:
                     	coverState=0;
                     	Serial.println("V_STOP");
                     	cover(); //temp ack
                     case V_HVAC_SETPOINT_HEAT:
                  #ifdef ID_S_HEATER
                     		heater();//temp ack
                  #ifdef ID_S_HVAC
                     		hvac();//temp ack
                     case V_HVAC_FLOW_STATE:
                  #ifdef ID_S_HEATER
                     		heater();//temp ack
                  #ifdef ID_S_HVAC
                     		hvac();//temp ack
                  #ifdef ID_S_LOCK
                     case V_LOCK_STATUS:
                     	lock(); //temp ack
                  #ifdef ID_S_IR
                     case V_IR_SEND:
                     	irVal = message.getLong();
                     	ir(); // temp ack
                     case V_IR_RECEIVE:
                     	ir(); // temp ack
                     case V_SCENE_ON:
                     	sceneVal = message.getInt();
                     	Serial.println(" On");
                     	scene();// temp ack
                     case V_SCENE_OFF:
                     	Serial.println(" Off");
                     	scene();// temp ack
                     case V_RGB:
                     	rgbState=message.getString();
                     	rgbLight(); // temp ack
                     case V_RGBW:
                     	rgbwLight();
                  #ifdef ID_S_HVAC
                     //  hvac_SetPointHeat
                     //  hvac_SetPointCool
                     //  hvac_FlowState
                     //  hvac_FlowMode
                     //  hvac_Speed
                     case V_HVAC_SETPOINT_COOL:
                     	hvac();//temp ack
                     case V_HVAC_FLOW_MODE:
                     	hvac();//temp ack
                     case V_HVAC_SPEED:
                     	hvac();//temp ack
                     default:
                     	Serial.println(message.type);
                    can you try to add the watchdog timers and see what happens? Try using a different bootloader? Different power source or using a small booster or an additional AA battery and a LDO. I am just throwing ideas and see what you can do with the stuff you may have at home.
                    • K
                      K
                      Komaandy
                      @gohan said in My Slim 2AA Battery Node:
                      LDO
                      @gohan
                      Hi, i added a WDT now into the MotionSensorSketch.
                      Well at least i guess i did. I just read about it , never used it before. Does the 1Mhz Optiboot boatloaders support this ?
                      Unfortunalty I didnt recieve my 3,3V boosters yet and i dont have LDO´s around.
                      Concerning the bootloaders. Do you have a suggestion which one to use ? As I read that sticking to 1Mhz is important when using only 2AA batteries because of instability when voltage goes belowe certian values.
                      Obviously i could use more batteries, but then i cant supply the nRF2401 from the board right ?
                      // Enable debug prints
                      #define MY_NODE_ID 40
                      #include <avr/wdt.h>
                      // Initialize motion message
                      	wdt_enable(WDTO_2S);
                      	sendSketchInfo("Motion Sensor", "AndyWasHere");
                      	present(CHILD_ID, S_MOTION);
                      	// Read digital motion value
                      	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                      	Serial.println(tripped);
                       wdt_reset();
                        Actually you would have to put wdt_enable(WDTO_8S); right after Loop() and wdt_disable(); before calling the sleep (this is what I copied from another sketch). The wdt_reset you cold use in the middle of the loop in case you have a function that could take long time to execute and it may trigger the WD timer so you can reset the timer (you can play with the length of the timer according to your needs)
                        K 1 Reply Last reply
                          K
                          K
                          Komaandy
                          @gohan
                          maybe like this ?
                          wdt_disable();
                            that's what I found. You could also use wdt_enable(WDTO_2S) I think. I haven't done any test yet on this.
                            • K Komaandy
                              @m26872
                              Hi there,
                              Hardware i use is :
                              Furthermore i use
                                -fresh batteries
                              * MockMySensors
                              // Wait times
                                 S_SCENE_CONTROLLER
                              // one at a time.
                              #define ID_S_TEMP              7
                              // Global Vars
                              bool metric = true;
                              long randNumber;
                              #ifdef ID_S_ARMED
                              bool isArmed;
                              #ifdef ID_S_LIGHT
                              bool isLightOn=0;
                              #ifdef ID_S_DIMMER
                              int dimmerVal=100;
                              #ifdef ID_S_COVER
                              #ifdef ID_S_TEMP
                              #ifdef ID_S_HUM
                              #ifdef ID_S_BARO
                              #ifdef ID_S_WIND
                              #ifdef ID_S_RAIN
                              #ifdef ID_S_UV
                              #ifdef ID_S_WEIGHT
                              #ifdef ID_S_POWER
                              #ifdef ID_S_HEATER
                              #ifdef ID_S_LOCK
                              bool isLocked = 0;
                              #ifdef ID_S_IR
                              long irVal = 0;
                              #ifdef ID_S_WATER
                              #ifdef ID_S_DUST
                              char *scenes[] = {
                              int sceneVal=0;
                              #ifdef ID_S_HVAC
                              #ifdef ID_S_SOUND
                              #ifdef ID_S_CUSTOM
                                 // Random SEED
                                 wait(LONG_WAIT);
                                 wait(LONG_WAIT);
                                 wait(LONG_WAIT);
                                 // Init Armed
                              #ifdef ID_S_ARMED
                                 isArmed = true;
                              #ifdef ID_S_DOOR
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_MOTION
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_SMOKE
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_LIGHT
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_DIMMER
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_COVER
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_TEMP
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_HUM
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_BARO
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_WIND
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_RAIN
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_UV
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_WEIGHT
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_POWER
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_HEATER
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_LOCK
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_IR
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_WATER
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_DUST
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_HVAC
                                 wait(SHORT_WAIT);
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_SOUND
                                 wait(SHORT_WAIT);
                              #ifdef ID_S_CUSTOM
                                 wait(SHORT_WAIT);
                                 Serial.println("");
                                 Serial.println("");
                                 Serial.println("");
                                 wait(LONG_WAIT);
                                 // Request time
                                 requestTime();
                                 wait(LONG_WAIT);
                                 //Read Sensors
                              #ifdef ID_S_DOOR
                                 door();
                              #ifdef ID_S_MOTION
                                 motion();
                              #ifdef ID_S_SMOKE
                                 smoke();
                              #ifdef ID_S_LIGHT
                                 light();
                              #ifdef ID_S_DIMMER
                                 dimmer();
                              #ifdef ID_S_COVER
                                 cover();
                              #ifdef ID_S_TEMP
                                 temp();
                              #ifdef ID_S_HUM
                                 hum();
                              #ifdef ID_S_BARO
                                 baro();
                              #ifdef ID_S_WIND
                                 wind();
                              #ifdef ID_S_RAIN
                                 rain();
                              #ifdef ID_S_UV
                                 uv();
                              #ifdef ID_S_WEIGHT
                                 weight();
                              #ifdef ID_S_POWER
                                 power();
                              #ifdef ID_S_HEATER
                                 heater();
                                 distance();
                                 light_level();
                              #ifdef ID_S_LOCK
                                 lock();
                              #ifdef ID_S_IR
                                 ir();
                              #ifdef ID_S_WATER
                                 water();
                                 air();
                              #ifdef ID_S_DUST
                                 dust();
                                 scene();
                                 rgbLight();
                                 rgbwLight();
                                 color();
                              #ifdef ID_S_HVAC
                                 hvac();
                                 multimeter();
                              #ifdef ID_S_SOUND
                                 moisture();
                              #ifdef ID_S_CUSTOM
                                 custom();
                                 wait(SHORT_WAIT);
                              //void door(){}
                              #ifdef ID_S_DOOR
                              void door()
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_MOTION
                              void motion()
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_SMOKE
                              void smoke()
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_LIGHT
                              void light()
                              #ifdef ID_S_DIMMER
                              void dimmer()
                              #ifdef ID_S_COVER
                              void cover()
                              #ifdef ID_S_TEMP
                              void temp()
                              #ifdef ID_S_HUM
                              void hum()
                              #ifdef ID_S_BARO
                              void baro()
                              #ifdef ID_S_WIND
                              void wind()
                              #ifdef ID_S_RAIN
                              void rain()
                              #ifdef ID_S_UV
                              void uv()
                              #ifdef ID_S_WEIGHT
                              void weight()
                              #ifdef ID_S_POWER
                              void power()
                              #ifdef ID_S_HEATER
                              void heater()
                              void distance()
                              void light_level()
                              #ifdef ID_S_LOCK
                              void lock()
                              #ifdef ID_S_IR
                              void ir()
                              #ifdef ID_S_WATER
                              void water()
                              void air()
                              #ifdef ID_S_DUST
                              void dust()
                              void scene()
                              void rgbLight()
                              void rgbwLight()
                              void color()
                                 String colorState;
                              #ifdef ID_S_HVAC
                              void hvac()
                              void multimeter()
                              #ifdef ID_S_SOUND
                              void moisture()
                              #ifdef ID_S_CUSTOM
                              void custom()
                              #ifdef ID_S_ARMED
                                 case V_ARMED:
                              #ifdef ID_S_DOOR
                              #ifdef ID_S_MOTION
                                 	motion();//temp ack
                              #ifdef ID_S_SMOKE
                                 	smoke();//temp ack
                              #ifdef ID_S_LIGHT
                                 	//    #endif
                              #ifdef ID_S_DIMMER
                                 case V_DIMMER:
                              #ifdef ID_S_COVER
                                 case V_UP:
                                 	coverState=1;
                                 case V_DOWN:
                                 	coverState=-1;
                                 	cover(); //temp ack
                                 case V_STOP:
                                 	coverState=0;
                                 	cover(); //temp ack
                              #ifdef ID_S_HEATER
                                 		heater();//temp ack
                              #ifdef ID_S_HVAC
                                 		hvac();//temp ack
                              #ifdef ID_S_HEATER
                                 		heater();//temp ack
                              #ifdef ID_S_HVAC
                                 		hvac();//temp ack
                              #ifdef ID_S_LOCK
                                 case V_LOCK_STATUS:
                                 	lock(); //temp ack
                              #ifdef ID_S_IR
                                 case V_IR_SEND:
                                 	ir(); // temp ack
                                 case V_IR_RECEIVE:
                                 	ir(); // temp ack
                                 case V_SCENE_ON:
                                 	scene();// temp ack
                                 case V_SCENE_OFF:
                                 	scene();// temp ack
                                 case V_RGB:
                                 case V_RGBW:
                                 	rgbwLight();
                              #ifdef ID_S_HVAC
                                 //  hvac_FlowState
                                 //  hvac_FlowMode
                                 //  hvac_Speed
                                 	hvac();//temp ack
                                 	hvac();//temp ack
                                 case V_HVAC_SPEED:
                                 	hvac();//temp ack
                                 default:
                              m26872M
                              m26872M
                              m26872
                              @Komaandy Try to remove all your Serial.print.
                              • JonAndersenJ
                                JonAndersenJ
                                JonAndersen
                                wrote on last edited by JonAndersen
                                #428
                                1. Has anyone used NRF24L01+ + PA + LNA on these modules ?
                                2. Any reason why it shouldnt work out of the box ( does AA batteries give enough power to drive them on LOW settings? )
                                3. What type of battery monitoring is recommended on these ones? The resistance or the library way?
                                I just got 90 PCBs, beautiful, fast shipping ( i think under 2 weeks to Norway ) and looks well made.
                                I'll drop one in each beehive I have ( 7 ) and see how long they last
                                • K
                                  K
                                  Komaandy
                                  So, it seems i made some progress.
                                  After changing to the @GertSanders bootloader ( https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62) all the PIR nodes seem to be stable.
                                  Wish me luck :)
                                  • K Komaandy
                                    Wish me luck :)
                                    m26872M
                                    m26872M
                                    m26872
                                    #430
                                    @Komaandy Yes, using 8MHz instead of 1MHz is perhaps a good idea. Stable enough at room temperature, well proven and will e.g. solve a "Serial.print()" interrupt loop issue. Just remember that you'll lose ~25uA if you'll leave BOD enabled.
                                    Nca78N 1 Reply Last reply
                                    • m26872M m26872
                                      @m26872 said in My Slim 2AA Battery Node:
                                      No, on ATMega328 MySensors disables BOD before going to sleep.
                                      So extra consumption from BOD will only exist when node is active and in that case it's negligible.
                                      • Nca78N Nca78
                                        m26872M
                                        m26872M
                                        m26872
                                        @Nca78 Ok. Thanks. Since ever, or only from 2.x ?
                                        • m26872M m26872
                                          @m26872 no idea I started MySensors with 2.x :P
