  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.8k Views 20 Watching
  • EfflonE Efflon
    @warmaniac You dont need mqtt/mosquitto. Just follow the guide at https://www.domoticz.com/wiki/MySensors for adding a "MySensors Gateway with LAN interface (Ethernet)" then follow the ethernet sketch here https://www.openhardware.io/view/318/Sonoff-relay-using-MySensors-ESP8266-wifi-or-mqtt-gateway
    warmaniacW
    warmaniacW
    warmaniac
    wrote on last edited by warmaniac
    #28
    @Efflon
    Tried LAN sketch after adding new hardware in domoticz this error occurs
    2017-04-06 06:28:07.230 MQTT: Connecting to 192.168.2.209:5003
    2017-04-06 06:28:07.335 Error: MQTT: disconnected, restarting (rc=2)
    after that Sonoff blik twice. What may be wrong ?
    Edit:
    Understand now , it is added as classic mysensor LAN gateway , now working fine ! I tried to do it complicated way , but it was easy :D
    2017-04-06 06:30:29.756 MySensors: trying to connect to: 192.168.2.209:5003
    2017-04-06 06:30:30.757 MySensors: connected to: 192.168.2.209:5003
    2017-04-06 06:30:30.758 MySensors: Gateway Ready...
    2017-04-06 06:30:30.762 MySensors: Node: 0, Sketch Name: Sonoff ethernet
    2017-04-06 06:30:30.763 MySensors: Node: 0, Sketch Version: 1.0
    2017-04-06 06:30:30.769 (MQTT) Light/Switch (Light)
    2017-04-06 06:30:31.778 MySensors: Gateway Version: 2.1.1
    2017-04-06 06:30:31.779 MySensors: Gateway Version: 2.1.1
    2017-04-06 06:31:11.939 User: Admin initiated a switch command (87/Sonoff-1/On)
    2017-04-06 06:31:11.942 (MQTT) Light/Switch (Sonoff-1)
    2017-04-06 06:31:12.789 (MQTT) Light/Switch (Sonoff-1)
    EfflonE 1 Reply Last reply
    • warmaniacW warmaniac
      @Efflon
      Edit:
      EfflonE
      EfflonE
      Efflon
      @warmaniac Excellent!
      • BrydenB
        BrydenB
        Bryden
        Does anyone know how I can request the current state of the relay via MQTT.
        Eg HASS has rebooted, forgotten what state the switch was previously in, then it wont work untill power is cycled to the sonoff.
        I want to send an MQTT message to the sonoff to get its current state. Tried looking over the forums and page and cant seem to see anything about requesting a state from a binary switch / relay actuator
        • BrydenB Bryden
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Bryden
          If you're using the mysensors component in home assistant, you can activate persistence to load devices and last known state when home assistant restarts.
          Another option is to use the retain flag when publishing mqtt messages from the gateway. Support for this has been added in mysensors dev branch:
          https://github.com/mysensors/MySensors/pull/793
            Matthew Ohlson de Fine
            How do you load the relay sensor in Vera after connecting the Sonoff as a wifi gateway as described?
            • warmaniacW
              warmaniacW
              warmaniac
              After electricity plugged off , it stops working / not connecting to wifi router, but on manual click it turns on and of , it is problem because I don't use haas config ? I dont know where can I place them, can you help me ? :) thanks
              • U
                U
                user2684
                Hi, I see in the instruction a note about not being tested against 220v so just to confirm it is working fine, I've uploaded the sketch to one of those with the power socket plug embedded and I'm able to control it remotely. Great job!
                As a side note, I'd copy and paste the "Sonoff specific details" instructions from the sketch also into the build page. My bad because I've missed them and had to google a bit on how to upload the sketch but maybe also others may experience the same.
                • U user2684
                  EfflonE
                  EfflonE
                  Efflon
                  @user2684 Thanks for reporting. I have updated the instructions with the Sonoff details.
                  • B
                    B
                    betonishard
                    Great work!
                    I was wondering if some of you already know if Espeasy supports the pow versions power usage reporting. I checked the github and couldn't find it. I know Espurna supports it (as a domoticz MQTT). However when I check the REST API of Esputna there is nothing noted about the power consumption (only humidity and temp) requests.
                    Any help is much appreciated.
                    Regards, and keep up the good work.
                    • U
                      U
                      user2684
                      Hi, I have a sonoff device running this sketch since a few weeks now and everything is working great :-) However I've noticed that when the wireless network goes off and then is restored back again the sonoff results still unreachable. When I unplug and plug it again the connection it comes back online. Is this a known behavior? Thanks
                        is it reachable via IP or is it totally unresponsive?
                        warmaniacW 1 Reply Last reply
                        • U
                          U
                          user2684
                          Totally unresponsive like once disconnected from the wifi (I turn it off from time to time), it is no more able to reconnect. I still need to understand if it happens every time so I was wondering if this was somehow expected or not :)
                            warmaniacW
                            warmaniacW
                            warmaniac
                            @gohan said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                            I had same problem too.. When is longer not turned on, Sonoff disconnects from wifi , that ip is not in client list, in my case I only turn sonoff on throught black button on the top and than it is okay about day-two.
                            • Nca78N
                              I have few sonoff and I just installed one with this script to replace a dead 433 device. So thank you very much for the script and the tutorial.
                              Reports of regular wifi connection losses are what kept me away from sonoff until now. Maybe the script could check wifi connection regularly and force a reconnect. Something like in the link below ?
                              http://www.esp8266.com/viewtopic.php?f=32&t=8286
                              • BrydenB
                                BrydenB
                                Bryden
                                Another I have had these running posts.
                                I have had 3 Sonoff relays running on 240v 50Hz for 2-3 months straight.
                                2 of them in IP67 outdoor lights with Phillips LED Lamps, switch on and off several times per day, Not a single hardware issue.
                                best $6 ever
                                Nca78N 1 Reply Last reply
                                • E
                                  E
                                  Ed1500
                                  @betonishard ESPeasy I am not sure, but supposedly Tasmota does
                                  B 1 Reply Last reply
                                  • BrydenB Bryden
                                    best $6 ever
                                    @Bryden said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                                    best $6 ever
                                    Yes over one month and very reliable, but with Domoticz is not integrating very well with my old 433MHz remote controls (that I use for my remaining 433MHz module until they are replaced).
                                    Making me think about a small plugin board to control the sonoff through serial port, so it would make a real MySensors node for 10$ and avoid all the power supply, relay etc etc soldering and not rely on wifi.
                                      I remember reading non to connect any other serial device while the Sonoff is connected to mains or it would get damaged.
                                      E Nca78N 2 Replies Last reply
                                        E
                                        E
                                        Ed1500
                                        @gohan The only time you would need to connect a serial device is I guess when you are flashing the software. There is no needTheThe only time you need to connect a serial device is when you are flashing the software. There is no need to connect it to the mains grid then. Whether it would damage anything i do not know but it is unnecessary and therefore absolutely not recommended to do it. Avoid working on anything that is connected to mains, especially if there is no need to have it connected
                                          I was referring to what @Nca78 said about controlling the sonoff through serial port.
