  2. Announcements
  3. 💬 Soil Moisture Sensor
99 Posts 33 Posters 51.3k Views 32 Watching
  • Martin TellblomM Martin Tellblom
    There is something in the sketch I do not understand
     * Connection:
     * D6, D7: alternative powering to avoid sensor degradation
     * A0, A1: alternative resistance mesuring
      // initialize the digital pins as an output.
      // Pin 6,7 is for sensor 1
      // initialize the digital pin as an output.
      // Pin 6 is sense resistor voltage supply 1
      pinMode(6, OUTPUT);
      // Pin 7 is sense resistor voltage supply 2
     pinMode(7, OUTPUT);
    What is this for?
    @Martin-Tellblom the pins on the sensor can corrode by electrolysis. By alternating polarity, corrosion might be prevented (I am not sure that it makes a difference in practice though).
    Some discussion on the topic is available in https://forum.mysensors.org/topic/2147/office-plant-monitoring/ (very long thread with lots of information)
    As @FotoFieber points out, the alternating polarity is for a different sensor than the one shown in the wiring guide. We should decide which version to use and stick to one version in the example. I'm not sure which one we should use though.
    • Patrik SöderströmP
      Patrik SöderströmP
      Patrik Söderström
      Is there any updated sketch to use with the Soil Moisture Sensor shown in the pictures?
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        The moisture sensor should be presented as S_MOISTURE not S_HUM.
        • R
          R
          Rene046
          Dous this sketch belong to this sensor ? pin 6,7 and a1 or a0 are not connected.....
          • edsteveE
            edsteveE
            edsteve
            Yeah. It would be great if someone can tell us about the hardware and wiring used in this sketch.
            • clivecC
              clivecC
              clivec
              Henrik
              Yes could you please confirm how the nano is connected to the sensors ,soil sensors please ,yes 5+ 0- pin 3 ?? or in your sketch pin 6 7 ? to were
              or a0 a1 please how?? pin 6 to pin 3 on nano ?? it just not clear ??
              • alowhumA
                alowhumA
                alowhum
                For some people it might be worthwhile to look at the Mi Flora sensor, a pretty awesome $10 bluetooth sensor that measures moisture, soilhealth, light and temperature, and lasts a year on one coin cell battery. Its protocol has been reverse engineered, and now a lot of scripts offer all kinds of integrations, including connecting it to MQTT servers or Domoticz.
                https://www.aliexpress.com/item/Original-Xiaomi-Flora-Monitor-Digital-Plants-Grass-Flowers-Soil-Water-Light-Smart-Tester-Sensor-for-Aquarium/32701321129.html
                https://github.com/marcelrv/miflora
                korttomaK 1 Reply Last reply
                • alowhumA alowhum
                  korttomaK
                  korttomaK
                  korttoma
                  @alowhum Thanks for the info. I have one of these and I would like to somehow integrate it with my other sensors. Maybe it would be possible to build a MySensors Bluetooth GW node to connect to the Mi Flora.
                  • Tomas
                  • Bas RutjesB
                    Bas RutjesB
                    Bas Rutjes
                    For those who are using the analogue soil moisture sensor in combination with a nano
                    Connect the output of the sensor to the A0 of the nano
                    connect the gnd of the sensor to the gnd on the nano
                    connect th vcc of the sensor to 3v3 on the nano
                    the sketch that works for me:
                    #define CHILD_ID 0
                    // Here we are setting up some water thresholds that we will
                    // use later. Note that you will need to change these to match
                    // your soil type and environment. It doesn't do much for me because I'm using domoticz
                    int thresholdUp = 400;
                    int thresholdDown = 075;
                    MyMessage msg(CHILD_ID, V_LEVEL);
                    unsigned long SLEEP_TIME = 30000;
                    // We are setting up the pin A0 on the redboard to be our sensor
                    // pin input:
                    int sensorPin = A0;
                    present(CHILD_ID, S_MOISTURE);
                    int sensorValue;
                    sensorValue = analogRead(sensorPin);
                    //send back the values
                    send(msg.set(sensorValue));
                    // delay until next measurement (msec)
                    sleep(SLEEP_TIME);
                    • R
                      R
                      RobKuipers
                      wrote on last edited by RobKuipers
                      My two cents. A soil moisture sensor that requires no extra hardware (not counting electric wire). Highly inspired by everything I've read in this thread. Comments welcome.
                      Excuse the long post.
                       Created:	5/25/2017 1:04:35 PM
                       Author:	Rob
                       Soil moisture measuring by using stainless steel rods (or any other conductor).
                       Probably the simplest project ever, since only a MySensors-node and some wire is needed to set things up.
                       The sketch alternates current during measuring to prevent corrosion of the rods due to electrolyses.
                       Odd readings may occur when starting (eg. increasing soil moisture for no apparent reason), please just allow the electrodes to settle down in the soil.
                       No extra hardware needed.
                       I use an Arduino Mini 3V3, powered on two AA cells. It is suggested you set the fuses for a lower Brown Out Detection (BOD). But anything goes.
                       Just tie D4 and A0 together to one rod, and D5 and A1 to another rod. This is sensor one.
                       For the second sensor tie D6 and A2 together to one rod, and D7 and A3 to another rod.
                       Connect a pushbutton between GND and D3 if you need a button that makes the node report immediately (can be omitted)
                       Measurement are taken every minute and send to the gateway if different from the previous reading.
                       In case of no changes, the node reports itself every four hours.
                       The output is between 0 (dry) and 100 (wet).
                       Can also be used as a depth moisture sensor with three sensor zones; in that case use one (common) long rod and three smaller sensors along
                       the height of the rod and configure the sketch accordingly.
                      	 sensors[0] = { 4, A0, 5, A1, -1, false };
                      	 sensors[1] = { 4, A0, 6, A2, -1, false };
                      	 sensors[2] = { 4, A0, 7, A3, -1, false };
                      #include "Header.h"
                      // Enable debug Serial.prints to serial monitor
                      #if defined MY_DEBUG
                      #define Sprintln(a) (Serial.println(a))
                      #define Sprint(a) (Serial.print(a))
                      #define Sprintln(a)
                      #define Sprint(a)
                      #define MY_RADIO_RFM69
                      #define MY_RFM69_FREQUENCY RF69_868MHZ
                      #define MY_IS_RFM69HW
                      // Use PA_LOW for RF24+PA (Power Amplifier)
                      //#define MY_RF24_PA_LEVEL RF24_PA_MAX
                      #define MY_NODE_ID 4
                      #define ACK 0        // = false
                      #define CHILD_ID 1
                      #define REPORTNOWSWITCH_PIN 3    // Arduino Digital I/O pin for button/reed switch (must be an interrupt pin!)
                      #define NUM_MOISTURE_SENSORS 2
                      #define CHILD_ID_TEMPERATURE (CHILD_ID+NUM_MOISTURE_SENSORS+1)
                      #define SENSOR1_ROD1_DIGITAL 4
                      #define SENSOR1_ROD1_ANALOG A0
                      #define SENSOR1_ROD2_DIGITAL 5
                      #define SENSOR1_ROD2_ANALOG A1
                      #define SENSOR2_ROD1_DIGITAL 6
                      #define SENSOR2_ROD1_ANALOG A2
                      #define SENSOR2_ROD2_DIGITAL 7
                      #define SENSOR2_ROD2_ANALOG A3
                      #define SLEEP_IN_MS 60000		// every minute a new measurement
                      #define EVERY_15_MINUTES (3600000/4/SLEEP_IN_MS)
                      #define EVERY_4_HOURS (3600000*4/SLEEP_IN_MS)
                      #define NUM_READS (int)10		// Number of sensor reads for filtering
                      int countLoops;
                      int8_t interruptedBy = -1;
                      int oldBatLevel;
                      float oldTemperature;
                      int output_value;
                      /// Included in Header.h:
                      //typedef struct {
                      //	int digital_input_a;
                      //	int analog_input_a;
                      //	int digital_input_b;
                      //	int analog_input_b;
                      //	int level;
                      //	bool connected;
                      //} sensorWiring;
                      sensorWiring sensors[NUM_MOISTURE_SENSORS];
                      MyMessage msgMoistureSensor(CHILD_ID, V_LEVEL);
                      MyMessage msgChipTemp(CHILD_ID_TEMPERATURE, V_TEMP);
                      void before()
                      	// All buttons as input-pullup as per ATMEGA recommendation to use less power (and more safety)
                      	// (http://electronics.stackexchange.com/questions/43460/how-should-unused-i-o-pins-be-configured-on-atmega328p-for-lowest-power-consumpt)
                      	for (int i = 1; i <= 8; i++)
                      		pinMode(i, INPUT_PULLUP);
                      	// Now explicity set pins as needed
                      	// Setup report-now switch, activate internal pull-up
                      	pinMode(REPORTNOWSWITCH_PIN, INPUT_PULLUP);
                      	// Initialize sensor variables
                      	// Connect Digital pin 4 to Analog input A0 and a metal rod
                      	// Connect Digital pin 5 to Analog input A1 and another metal rod.
                      	sensors[0] = { SENSOR1_ROD1_DIGITAL, SENSOR1_ROD1_ANALOG, SENSOR1_ROD2_DIGITAL, SENSOR1_ROD2_ANALOG, -1, false };
                      	// Connect Digital pin 6 to Analog input A2 and a metal rod
                      	// Connect Digital pin 7 to Analog input A3 and another metal rod.
                      	sensors[1] = { SENSOR2_ROD1_DIGITAL, SENSOR2_ROD1_ANALOG, SENSOR2_ROD2_DIGITAL, SENSOR2_ROD2_ANALOG, -1, false };
                      	for  (int i = 0; i<NUM_MOISTURE_SENSORS; i++)
                      		sensors[i].connected = testSensorConnections(sensors[i]);
                      	sendSketchInfo("Moisture Sensor", "1.1", ACK);
                      	for (int i = 0; i < NUM_MOISTURE_SENSORS; i++)
                      		if (sensors[i].connected) present(CHILD_ID+i, S_MOISTURE, ACK);
                      	present(CHILD_ID_TEMPERATURE, S_TEMP);
                      	bool reportNow = (interruptedBy == digitalPinToInterrupt(REPORTNOWSWITCH_PIN));
                      	if (reportNow)
                      		// Little trick for debouncing the switch
                      		attachInterrupt(digitalPinToInterrupt(REPORTNOWSWITCH_PIN), debounce, RISING);
                      		wait(500);
                      		Sprintln(F("Report now switch pressed"));
                      		countLoops = 0;
                      			output_value = measure(sensors[i]);
                      			if ((sensors[i].level != output_value) || reportNow)
                      				sensors[i].level = output_value;
                      				send(msgMoistureSensor.setSensor(CHILD_ID+i).set(output_value), ACK);
                      	// Every fifteen minutes; poll temperature
                      	if (countLoops%EVERY_15_MINUTES==0 || reportNow)
                      		float newTemp = readTemp();
                      		if (oldTemperature != newTemp || reportNow)
                      			send(msgChipTemp.set(newTemp, 1), ACK);
                      			oldTemperature = newTemp;
                      		int batLevel = getBatteryLevel();
                      		if ((oldBatLevel != batLevel) || reportNow) // ...but only when changed, or when button is pressed;
                      			sendBatteryLevel(batLevel, ACK);
                      			oldBatLevel = batLevel;
                      	// So you know I'm alive
                      	if (countLoops == EVERY_4_HOURS)
                      		sendHeartbeat(ACK);
                      		countLoops = 0;
                      	countLoops++;
                      	interruptedBy = sleep(digitalPinToInterrupt(REPORTNOWSWITCH_PIN), FALLING, SLEEP_IN_MS);
                      // Connect Digital pin 'digital_input_a' to Analog input 'analog_input_a' and a metal rod,
                      // do the same for b
                      long measure(sensorWiring sensor)
                      	long total = 0;
                      	int reading_a = 0;
                      	int reading_b = 0;
                      	for (int i = 0; i<NUM_READS; i++) {
                      		// Left to right
                      		reading_a = measureOneDirection(sensor.digital_input_a, sensor.digital_input_b, sensor.analog_input_a);
                      		// Right to left
                      		reading_b = measureOneDirection(sensor.digital_input_b, sensor.digital_input_a, sensor.analog_input_b);
                      		total += reading_a + reading_b;
                      	return map(total / (2 * NUM_READS), 1023, 0, 0, 100);
                      long measureOneDirection(int digital_input_1, int digital_input_2, int analog_input_1)
                      	pinMode(digital_input_2, OUTPUT);
                      	digitalWrite(digital_input_2, LOW);
                      	pinMode(digital_input_1, INPUT_PULLUP);
                      	delayMicroseconds(100);
                      	long reading = analogRead(analog_input_1);
                      	//delayMicroseconds(25);
                      	pinMode(digital_input_1, INPUT);     // High impedance
                      	pinMode(digital_input_2, INPUT);     // High impedance
                      	delay(1);
                      	Sprint(F("measureOneDirection - Reading "));
                      	Sprintln(reading);
                      	return reading;
                      // test the connections of both rods of a sensor
                      boolean testSensorConnections(sensorWiring moistureSensor)
                      	return (testSensorConnection(moistureSensor.digital_input_a, moistureSensor.analog_input_a) && testSensorConnection(moistureSensor.digital_input_b, moistureSensor.analog_input_b));
                      //  test if digital pin is connected to correct analog pin
                      boolean testSensorConnection(int digital_input, int analog_input)
                      	pinMode(digital_input, OUTPUT);
                      	digitalWrite(digital_input, HIGH);
                      	long reading_1 = analogRead(analog_input);
                      	digitalWrite(digital_input, LOW);
                      	long reading_2 = analogRead(analog_input);
                      	pinMode(digital_input, INPUT);     // High impedance
                      	delay(1);
                      	Sprint(F("testSensorConnection - Reading1 "));
                      	Sprintln(reading_1);
                      	Sprint(F("testSensorConnection - Reading2 "));
                      	Sprintln(reading_2);
                      	bool correct = ((reading_1 == 1023) && (reading_2 == 0));
                      	return correct;
                      float readTemp()
                      #if defined (xxMY_RADIO_RFM69) && !defined(MY_RFM69_NEW_DRIVER)
                      	return _radio.readTemperature(-3);
                      	// Read 1.1V reference against MUX3
                      	return (readMUX(_BV(REFS1) | _BV(REFS0) | _BV(MUX3)) - 125) * 0.1075f;
                      long readMUX(uint8_t aControl)
                      	long result;
                      	ADMUX = aControl;
                      	delay(20); // Wait for Vref to settle
                      	noInterrupts();
                      	// start the conversion
                      	ADCSRA |= _BV(ADSC) | _BV(ADIE);
                      	set_sleep_mode(SLEEP_MODE_ADC);    // sleep during sample
                      	interrupts();
                      	sleep_mode();
                      	// reading should be done, but better make sure
                      	// maybe the timer interrupt fired
                      	while (bit_is_set(ADCSRA, ADSC));
                      	// Reading register "ADCW" takes care of how to read ADCL and ADCH.
                      	result = ADCW;
                      	return result;
                      // Battery measure
                      int getBatteryLevel()
                      	int results = (readVcc() - 2000) / 10;
                      	if (results > 100)
                      		results = 100;
                      	if (results < 0)
                      		results = 0;
                      	return results;
                      } // end of getBandgap
                      // when ADC completed, take an interrupt
                      EMPTY_INTERRUPT(ADC_vect);
                      long readVcc() {
                      	long result;
                      	result = readMUX(_BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1));
                      	result = 1126400L / result; // Back-calculate AVcc in mV (1024 steps times 1100 mV (1.1V) = 1126400L)
                      	return result;
                      // Utter nonsense, but needed for attaching an interrupt to...
                      void debounce() {
                      ร 1 Reply Last reply
                      • E
                        E
                        Ed1500
                        The greatest problem with these sensors is electrolysis and subsequent oxidation, due to the DC current flowing through the sensor in a humid environment.
                        There are some solutions: Most of the circuits that supposedly feed the sensor with A are bogus as it is apulsed DC at best..
                        One could try a capacitive sensor...... in theory very good but in practice plagued by issues.
                        What I have done is to remove constant current from the sensor by feeding it from a transistor that I can switch on and off. I take a measurement every 2-6 hrs and switch the current off in between. Makes a huge difference
                        • rollercontainerR
                          rollercontainerR
                          rollercontainer
                          wrote on last edited by rollercontainer
                          Next logic step is flipping polarity like here: http://gardenbot.org/howTo/soilMoisture/
                          E 1 Reply Last reply
                          • rollercontainerR rollercontainer
                            E
                            E
                            Ed1500
                            @rollercontainer That is definitely a good solution too, but I think gardenbot approaches it a bit too complicated from the software side when he points out that you get two readings with different values that 'need to be smoothed'
                            I'd say do this:
                            Both pins LOW when you are not taking a reading. That restperiod can be hours.
                            When you are ready to take a reading:
                            make one pin HIGH, take a reading and discard that one
                            Flip the voltage, take another reading (to balance the time) and use that one
                            Both pins LOW again
                            R 1 Reply Last reply
                            • E Ed1500
                              I'd say do this:
                              Both pins LOW again
                              R
                              R
                              RobKuipers
                              @Ed1500 This is exactly what I've done with the sketch I posted earlier in this thread.
                              Use two inputs per sensor. Flip polarity for every reading and then rest in a high impedance state so as not to corrode the measuring rods (just some copper wire in my case). This has the added benefit of using the least power.
                              Has been working like a charm for a couple of months now. Still planning to make a couple extra for the garden.
                              • R RobKuipers
                                E
                                E
                                Ed1500
                                @RobKuipers sensible, good sketch. Truthfully, with just the very short reading alone (I do say a milisecond or less per 4 hours), the sensor hardly corrodes. I have two galvanized nails that I have in the soil for 4 seasons. Yes, not silky smooth anymore but really no trace of electrolysis, even one made from a clotheshanger that still is doing well
                                • peternilsson75P
                                  peternilsson75P
                                  peternilsson75
                                  Did this sketch / wiring / sensor work for anyone? I read that more than I had questions about the pin 6 and 7 but those pins aren't connected in the wiring diagram. If anyone have any ideas on what to change to get it working it would be great to know!
                                    manutremo
                                    The sketch does not correspond to the sensor shown in the images. It is much better to use the 2-pin sensors and drive them directly using digital outputs. Search for FC28 (better) or YL-69 in ebay or amazon. I use a voltage divider with a 10k resistor
                                    I've been using the alternating polarity approach on about 20 sensors, with perfect results and no signs of corrosion after around 6 months. I run some tests to determine the effect of measuring time and finally came up with 5ms with no averaging. The batteries last for months; I'm not sure how many since I haven't yet had to replace any (status led removed from 3.3v arduino mini pro board).
                                    As a reference, I tested a rain sensor (same principle) with no alternating current and as soon as a drop of water touched the tracks, small bubbles were produced with indicated that electrolysis was taking place. The effect could be seen on the tracks after just a couple of minutes.
                                    I'm attaching my sketch below. It reports battery level in addition to moisture. It uses the development branch of the mysensors library in order to use the new version of the rfm69 drivers with RSSI ATC - which btw works more than perfect.
                                    I'm using Domoticz which includes a predefined device for moisture. This device uses the centibar scale, so I calibrated my sensors in % moisture and then convert to cb.
                                    #define MY_RFM69_NEW_DRIVER   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
                                    #define MY_RFM69_FREQUENCY RFM69_868MHZ
                                    #define MY_RFM69_ATC_TARGET_RSSI_DBM (-70)
                                    #define MY_RFM69_NETWORKID  100
                                    #define MY_PARENT_NODE_ID 0
                                    #define MY_TRANSPORT_MAX_TX_FAILURES 3
                                    #include <Vcc.h>
                                    #include <Streaming.h>
                                    #include <math.h>
                                    #define VERSION "1.1"
                                    /* Measurement probe connected to pins shown below
                                    I avoided using pins 2 and 3 because they are reserved for IRQ (potential future use) - 2 is also used by the RFM69 module.
                                    Although this may not actually have a noticeable effect, I also avoided 5 and 6 because they support PWM and hence are a bit slower.
                                    #define PIN_ALIM1 4                                   // Connect to input of resistor
                                    #define PIN_ALIM2 7                                   // Connect to input of measuring probe
                                    #define PIN_LECTURA A0
                                    #define AGUA_DIR 780.0
                                    #define AGUA_INV 160.0
                                    #define AIRE_DIR 0.0
                                    #define AIRE_INV 1023.0
                                    #define TIEMPO_LECTURA 5
                                    #define SLEEP_TIME_1h 3132000 // 1 h = 1*60*60000 = 3600000 ms -13% = 3132000 ms(my arduinos show a delay of 8s/min = 13%)
                                    #define SLEEP_TIME_2h 6264000 // 2 h = 2*60*60000 = 7200000 ms -13% = 6264000 ms
                                    #define SLEEP_TIME_3h 9396000 // 3 h = 3*60*60000 = 10800000 ms -13% = 9396000 ms
                                    // Battery calibration (Li-ion)
                                    const float VccMin   = 3.0;                         // Minimum expected Vcc level, in Volts.
                                    const float VccMax   = 4.2;                         // Maximum expected Vcc level, in Volts.
                                    const float VccCorrection = 3.82/3.74;              // Measured Vcc by multimeter divided by reported Vcc
                                    #define CHILD_MOIST_ID 1
                                    MyMessage msgmoist(CHILD_MOIST_ID, V_LEVEL);
                                    Vcc vcc(VccCorrection);
                                    float oldresultcb=0;
                                    int oldbat=0, count=0;
                                    void presentation(){
                                      sendSketchInfo("Sensor de humedad", VERSION);
                                      present(CHILD_MOIST_ID, S_MOISTURE, "Humedad suelo");
                                      analogReference(DEFAULT);
                                      pinMode(PIN_LECTURA, INPUT);
                                      pinMode(PIN_ALIM1, OUTPUT);
                                      pinMode(PIN_ALIM2, OUTPUT);
                                      unsigned int value1, value2;
                                      float result1, result2, resultp, resultcb;
                                    //Measurement of moisture
                                      wait(TIEMPO_LECTURA);
                                      digitalWrite(PIN_ALIM1, HIGH);
                                      digitalWrite(PIN_ALIM2, LOW);
                                      value1=analogRead(PIN_LECTURA);
                                      result1=constrain(value1/(AGUA_DIR-AIRE_DIR)*100.0, 1, 100);
                                      digitalWrite(PIN_ALIM1, LOW);
                                      digitalWrite(PIN_ALIM2, HIGH);
                                      value2=analogRead(PIN_LECTURA);
                                      result2=constrain(100-(value2-AGUA_INV)/(AIRE_INV-AGUA_INV)*100.0,1,100);
                                    /*Conversion from % moisture to cb taken from http://lieth.ucdavis.edu/Research/tens/98/SmtPub.htm
                                    Another option https://www.researchgate.net/figure/260321179_fig1_Fig-1-Relation-curve-between-water-tension-cb-and-soil-moisture-percentage
                                    The scale used in Domoticz is explained here http://www.irrometer.com/basics.html and can be checked in file domoticz/main/RFXNames.cpp
                                      0-10 Saturated Soil. Occurs for a day or two after irrigation
                                      10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
                                      20-60 Usual range to irrigate or water (most soils except heavy clay soils).
                                      60-100 Usual range to irrigate heavy clay soils
                                      100-200 Soil is becoming dangerously dry
                                      resultp=(result1+result2)/2.0;
                                      resultcb=constrain(square((-2.96699+351.395/resultp)),0,200);                           //Equation fit using stat software
                                      count++;
                                    //Send the data
                                      if ((oldresultcb!=resultcb) || (count==4)) send(msgmoist.set((unsigned int)resultcb));
                                    //Measure battery voltage here since it has been under change recently (more reliable)
                                      float v = vcc.Read_Volts();
                                      int p = vcc.Read_Perc(VccMin, VccMax);
                                      p=constrain(p,0,100);
                                      if ((p!=oldbat) || (count==4)) sendBatteryLevel(p);
                                    //Save the last values and reset the counter
                                      oldresultcb=resultcb;
                                      oldbat=p;
                                      if (count==4) count=0;
                                    #ifdef MY_DEBUG
                                      Serial << "Value1=" << value1 << " " << result1 << endl << "Value2=" << value2 << " " << result2 << endl << "Result = " << resultp << "% (" << resultcb << "cb)" << endl;
                                      Serial << "VCC = " << v << " Volts" << endl << "VCC% = " << p << " %" << endl;
                                      sleep(SLEEP_TIME_2h, true);
                                    And this is how it looks in Domoticz:
                                    I hope this helps.
                                    peternilsson75P 1 Reply Last reply
                                    • M manutremo
                                      #include <Vcc.h>
                                      #include <math.h>
                                        count++;
                                      //Send the data
                                        oldbat=p;
                                      #ifdef MY_DEBUG
                                      I hope this helps.
                                      peternilsson75P
                                      peternilsson75P
                                      peternilsson75
                                      @manutremo sensors ordered and I'm looking forward to try it! Just a quick question; where did you connect the resistor? Thanks,
                                      Peter
                                      • peternilsson75P peternilsson75
                                        Peter
                                        R
                                        R
                                        RobKuipers
                                        @peternilsson75 With the sketch I posted back in May, you just need two pieces of conductive wire. No resistor or amplifier needed. :-)
                                        • D
                                          dakipro
                                          Hey @RobKuipers I am trying to reuse your sketch as a water leakage sensor, but I got stopped at the Header.h file. Can you please share its content?
                                          I am also considering using two pieces of wire (on a ribbon strip though, just to peal isolation at strategic places).
                                          I will use it on battery and I was thinking on measuring every minute or so, and send a heartbeat every half hour/hour with battery status.
                                          Do you have any other tips about converting the sketch to water leak?
                                          Thanks for the sketch btw!
