  3. Air Humidity Sensor can't reach Gateway
8 Posts 4 Posters 2.6k Views 3 Watching
  • E Offline
    E Offline
    egfku
    Hi folks,
    I'm just getting started and having a hard time getting my Arduino Pro Mini talking to my Raspberry pi running Domoticz. Both client and gateway are using the nRF24L01+ module.
    I have a DHT22 sensor connected to the Arduino and can confirm that it's reading values correctly (using a DHT example). I'm now running the following code, adapted from the Air Humidity examples page:
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    #define MY_NODE_ID 255
    #define MY_PARENT_NODE_ID 0
    //#define MY_RS485
    //#define MY_RF24_PA_LEVEL RF24_PA_MAX
    #define MY_RF24_DATARATE RF24_2MBPS
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5000;
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    On the Arduino side, I seem to get stuck in a loop where the originating message doesn't get through to my gateway:
    0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0-beta
    49 TSM:INIT
    51 TSF:WUR:MS=0
    57 TSM:INIT:TSP OK
    59 TSM:INIT:STATID=10
    61 TSF:SID:OK,ID=10
    63 TSM:FPAR
    65 TSM:FPAR:STATP=0
    67 TSM:ID
    67 TSM:ID:OK
    69 TSM:UPL
    98 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    2107 TSM:UPL
    2136 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    4145 TSM:UPL
    4173 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    6184 TSM:UPL
    6213 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    8222 !TSM:UPL:FAIL
    8224 TSM:FPAR
    8224 TSM:FPAR:STATP=0
    8226 TSM:ID
    8228 TSM:ID:OK
    8230 TSM:UPL
    8259 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    10268 TSM:UPL
    10297 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    12306 TSM:UPL
    12335 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    14344 TSM:UPL
    14372 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    16384 !TSM:UPL:FAIL
    Something seems to be getting through to my RPi gateway, though, because Domoticz shows the following:
    0_1496356930318_upload-e38cf963-c71e-44f1-838a-506ca9e1c9d4
    Any suggestions would be very welcome. I've tried adding a capacitor across the power supply as suggested, as well as changing the transmit power levels on the Arduino radio, to no avail.
    Thanks in advance!
    S MarikM 2 Replies Last reply
    • E egfku
      Hi folks,
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      49 TSM:INIT
      51 TSF:WUR:MS=0
      57 TSM:INIT:TSP OK
      61 TSF:SID:OK,ID=10
      63 TSM:FPAR
      65 TSM:FPAR:STATP=0
      67 TSM:ID
      67 TSM:ID:OK
      69 TSM:UPL
      2107 TSM:UPL
      4145 TSM:UPL
      6184 TSM:UPL
      8222 !TSM:UPL:FAIL
      8224 TSM:FPAR
      8226 TSM:ID
      8228 TSM:ID:OK
      8230 TSM:UPL
      10268 TSM:UPL
      12306 TSM:UPL
      14344 TSM:UPL
      16384 !TSM:UPL:FAIL
      Thanks in advance!
      @egfku - I would say its a range or power issue. I would start here: https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help and go through that. Also you can parse your code into this: https://www.mysensors.org/build/parser and get more info out of it.
      Do you have capacitors on your radios? This is crucial! What distance are we talking about between node and gw? You can try moving they closer (or if they are really close - move them apart). Did you check the radio before using them (since there are alof of fake radios out there which perform really bad).
      You can also try to change the settings on the since you have made that into your code. Might be that the radio is shouting to loud (and/or not getting enough power to do so). How do you power the radios? Its really important and more important if you use the pa/lna version of the radio.
      • E egfku
        Hi folks,
        //#define MY_RS485
        float lastTemp;
        float lastHum;
        bool metric = true;
        DHT dht;
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            nNoUpdatesHum++;
        49 TSM:INIT
        51 TSF:WUR:MS=0
        57 TSM:INIT:TSP OK
        61 TSF:SID:OK,ID=10
        63 TSM:FPAR
        65 TSM:FPAR:STATP=0
        67 TSM:ID
        67 TSM:ID:OK
        69 TSM:UPL
        2107 TSM:UPL
        4145 TSM:UPL
        6184 TSM:UPL
        8222 !TSM:UPL:FAIL
        8224 TSM:FPAR
        8226 TSM:ID
        8228 TSM:ID:OK
        8230 TSM:UPL
        10268 TSM:UPL
        12306 TSM:UPL
        14344 TSM:UPL
        16384 !TSM:UPL:FAIL
        Thanks in advance!
        MarikM Offline
        MarikM Offline
        Marik
        @egfku I'm a bit new at this stuff too so I could be off base, but isn't node ID 255 reserved for broadcast? Try setting the MY_NODE_ID to something between 1 and 254.
        MySensors 2.1.1 - UNO R3 & W5100 Shield
        Domoticz v3.7686 - Ubuntu 16.04.1 on Hyper-V
        N 1 Reply Last reply
        • MarikM Marik
          N Offline
          N Offline
          @Marik is right !
          S 1 Reply Last reply
          • N Nca78
            @Marik is right !
            @Nca78 - Jupp! Well spottet @Marik !
            • E Offline
              E Offline
              egfku
              Hi everyone,
              Thank you for your replies! I think @sundberg84 is probably right that there's something wrong with the radio attached to my Arduino. I did try adding a 10uF capacitor, changing the power source, as well as swapping out a different radio, but that didn't seem to help. I've ordered some MCP1702 voltage regulators that hopefully will improve things.
              I did also try to directly specify the node ID, which is seen by my gateway, but it looks like the Arduino can't hear the gateway's response:
              pi@rpi:~ $ sudo mysgw -d
              mysgw: Starting gateway...
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              mysgw: TSF:MSG:READ,128-128-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              mysgw: TSF:MSG:BC
              mysgw: TSF:MSG:FPAR REQ,ID=128
              mysgw: TSF:CKU:OK,FCTRL
              mysgw: TSF:MSG:GWL OK
              mysgw: !TSF:MSG:SEND,0-0-128-128,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              mysgw: TSF:MSG:BC
              The parser says the gateway isn't getting acknowledged:
              Sent Message
              Sender: 0
              Last Node: 0
              Next Node: 128
              Destination: 128
              Sensor Id: 255
              Command: INTERNAL
              Message Type:I_FIND_PARENT_RESPONSE
              Payload Type: P_BYTE
              Payload Length: 1
              Signing: 0
              Failed uplink counter: 0
              Status: NACK (OK=success, NACK=no radio ACK received)
              Payload: 0
              Will keep testing and update if I get any joy!
              • E egfku
                Hi everyone,
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                mysgw: TSF:MSG:BC
                mysgw: TSF:MSG:BC
                Sent Message
                Sender: 0
                Last Node: 0
                Next Node: 128
                Destination: 128
                Sensor Id: 255
                Command: INTERNAL
                Payload Length: 1
                Signing: 0
                Payload: 0
                N Offline
                N Offline
                @egfku said in Air Humidity Sensor can't reach Gateway:
                Sensor Id: 255
                It cannot work like that. Node ID 255 is for broadcast, and for broadcast ACK will never be sent back.
                You should first reset the eprom config that is now written in your arduino.for that, in Arduino menu open File/Examples/MySensors/ClearEpromConfig example sketch and run it.
                Then put a sketch with the lines below commented :
                Also it doesn't seem to be a good idea to set data rate of NRF24 to 2MPS when you believe you have a radio communication/range problem. Keep the default value of 250K so you will have better range, for that comment the line below.
                (Of course you must have the same config on your gateway)
                • E Offline
                  E Offline
                  egfku
                  Thanks for the note, @Nca78 . It seems like my systems defaults to an ID of 255, though. I swapped out another Pro Mini and another radio (debugged the Arduino side using the RF24 library), and now I'm seeing more traffic between the Arduino and the RPi, though it seems to fall over at receiving an ID.
                  Note that I ran the ClearEpromConfig example immediately before pushing the MotionSensor example (no changes, did not define MY_NODE_ID).
                  Arduino:
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  14 TSM:FPAR
                  16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2025 !TSM:FPAR:NO REPLY
                  2027 TSM:FPAR
                  2029 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2037 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  2043 TSF:MSG:FPAR OK,ID=0,D=1
                  4038 TSM:FPAR:OK
                  4038 TSM:ID
                  4040 TSM:ID:REQ
                  4044 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                  6051 TSM:ID
                  6051 TSM:ID:REQ
                  6055 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                  8065 TSM:ID
                  8065 TSM:ID:REQ
                  8069 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                  10076 TSM:ID
                  10076 TSM:ID:REQ
                  10080 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                  12089 !TSM:ID:FAIL
                  12091 TSM:FAIL:CNT=1
                  12093 TSM:FAIL:PDT
                  22097 TSM:FAIL:RE-INIT
                  22099 TSM:INIT
                  22106 TSM:INIT:TSP OK
                  22110 TSM:FPAR
                  22112 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  24121 !TSM:FPAR:NO REPLY
                  24123 TSM:FPAR
                  24125 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  26134 !TSM:FPAR:NO REPLY
                  26136 TSM:FPAR
                  26138 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  28147 !TSM:FPAR:NO REPLY
                  28149 TSM:FPAR
                  28151 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  30162 !TSM:FPAR:FAIL
                  30164 TSM:FAIL:CNT=2
                  30167 TSM:FAIL:PDT
                  40171 TSM:FAIL:RE-INIT
                  40173 TSM:INIT
                  40179 TSM:INIT:TSP OK
                  40183 TSM:FPAR
                  40185 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  42196 !TSM:FPAR:NO REPLY
                  42199 TSM:FPAR
                  42201 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  42209 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  42215 TSF:MSG:FPAR OK,ID=0,D=1
                  44210 TSM:FPAR:OK
                  44212 TSM:ID
                  44212 TSM:ID:REQ
                  44216 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                  RPi:
                  pi@rpi:~/projects/RF24/rf24libs/RF24/examples_linux $ sudo mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  mysgw: New connection from 192.168.11.31
                  mysgw: Client 0 connected
                  mysgw: Client 0: 0;0;3;0;2;
                  mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:FPAR REQ,ID=255
                  mysgw: TSF:PNG:SEND,TO=0
                  mysgw: TSF:CKU:OK
                  mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                  mysgw: Client 0: 255;255;3;0;4;1
                  mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:CKU:OK
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:CKU:OK
                  mysgw: TSF:MSG:BC
                  Am I missing a step? I am running "sudo mysgw -d" on the RPI, followed by "sudo service domocoticz.sh restart", then pushing the MotionSensor example to my Pro Mini.
                  Thanks again for everyone's help!
