  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
    @alexsh1 in case you don't already know, octopart is great for finding sources. https://octopart.com/search?q=MAX8887EZK27
    There seems to be only american sources for this component though :(
    alexsh1A
    alexsh1A
    alexsh1
    @mfalkvidd
    I did not know about this source
    Well, that's the problem. The postage is golden and then if the value is greater than 20 bucks (including postage), I have to pay 20% VAT.
    C NeverDieN 2 Replies Last reply
    • alexsh1A alexsh1
      @mfalkvidd
      C
      C
      ceech
      wrote on last edited by ceech
      #133
      @alexsh1 @NeverDie You can substitute the MAX8887 with MIC5365.
      This whole thing got me so intrigued that I'm going to make a board myself. With charger, super capacitors and DC-DC converter. I'll use MIC5365 and for DC-DC conversion TPS610986. It has loads of options. And the whole thing will cost less than 10 bucks. I've made a schematic
      alexsh1A NeverDieN 2 Replies Last reply
      • C ceech
        alexsh1A
        alexsh1A
        alexsh1
        @ceech said in How best to find the "best" small solar panel of a particular size?:
        TPS610986
        Excellent choice - TPS610986 - The TPS61098x
        suits for low power systems very well, especially for the system which
        spends the most of time in sleep mode and wakes up periodically to sense or transmit signals.
        • alexsh1A
          alexsh1A
          alexsh1
          @NeverDie I am sure you saw this brilliant write up by Nick Gammon:
          http://www.gammon.com.au/forum/?id=12821
          He experimented with 0.47F capacitor. It was enough to run a mote (<10uA in a sleep mode) overnight
          • alexsh1A alexsh1
            @alexsh1
            I hadn't seen it, but a mote in sleep mode draws practically nothing (<300na for combined draw from both atmega328p and RFM69). It's the self discharge rate of the capacitor more than anything which seems to govern.
            alexsh1A 1 Reply Last reply
              @alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              @NeverDie This is what he experienced! Have a look at the link. Within a few charges though, self discharge stabilised
              • alexsh1A alexsh1
                @mfalkvidd
                #138
                @alexsh1
                Regarding the choice of replacement LDO. If the LDO you pick turns out to have unacceptably large reverse current flow, just place the blocking diode after it instead of before it. That particular diode will leak only about 20na, and the entire issue doesn't even come up until the last ~0.3v of charging, where you'll then have a very long charge tail. However, if that were to be an issue, you could just use a larger Farad supercap, and then it wouldn't matter because you'd have enough charge already before encountering the long tail of the charge process.
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @NeverDie Thanks for heads-up. I'll keep it in mind
                  I found an interesting cap -
                  https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691204E3/4705PHBK-ND/5015889
                  Its voltage is very close to the solar panel so I think it may be connected directly via diode (0.7v drop = 6 - 0.7 = 5.3V vs 5.6V max rating)
                  • alexsh1A alexsh1
                    @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
                    I've tried that cap already, and I wouldn't recommend it. It has a fairly high ESR.
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @NeverDie Given that you have been tinkering with it for a while, what caps can you recommend? With what ESR?
                      This cap has got 2.4 Ohm @ 1kHz - I think it is low?!
                      • alexsh1A alexsh1
                        Perky explains it better than I can: https://lowpowerlab.com/forum/projects/a-solar-supercap-powered-moteino/msg18120/#msg18120
                        • C ceech
                          TPS610986
                          1.5 mm x 1.5 mm WSON Package
                          Not sure how easy that will be to solder?
                            TPS610986
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @NeverDie You need to get SMD rework station or oven.
                            This is extremely difficult to get done by even an iron with a fine tip.
                            C 1 Reply Last reply
                            • alexsh1A alexsh1
                              C
                              C
                              ceech
                              @alexsh1 @NeverDie Yes, they will be soldered in the oven.
                              • C ceech
                                @ceech
                                Well, I may end up buying it from ceech then. Even properly aligning it onto the solder pads becomes difficult. I really struggled with the BQ25504. Not saying it can't be done, but just that it requires a lot more skill.
                                  @ceech
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @NeverDie and a strong magnifying glass :-)
                                  • C
                                    C
                                    ceech
                                    Those are the boards BTW
                                    • C ceech
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @ceech it is very small. Excellent. Let us know when it is ready
                                      • C
                                        C
                                        ceech
                                        And if it is too tall, still, only two capacitors can be installed in horizontal position, or even just one.
                                        • C ceech
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #151
                                          @ceech How about a flat supercap like this:
                                          https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691252E3/4699PHBK-ND/5015883
                                          There is no need to have two in my view unless you want to raise voltage. One flat to make the board compact may be enough.
