  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
    @ceech Is there a particular brand/source of supercaps that you recommend to fit your PCB? Or do they come pre-installed?
    alexsh1A
    alexsh1A
    alexsh1
    #124
    @NeverDie @Nca78
    I must admit, I got totally lost in the middle of this thread with so many links.
    Did you manage to find a holy grail? I'm keep to change a 400mA LiPO for supercapacitors on one of my nodes
    • alexsh1A alexsh1
      @NeverDie @Nca78
      #125
      @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
      @NeverDie @Nca78
      I haven't received the supercaps from China, so I can't comment on them as yet. I expect they should arrive by next weekend, or possibly before. However, there are lots of other supercaps that one might use.
      I still think that for most people a simple 6v solar panel for around $1 on Aliexpress, together with https://www.openhardware.io/view/382/Tiny-Solar-Charger-for-27v-Mote-Supercap
      and a sufficiently large supercap is all you're going to need for most things. If you have a sensor that needs 3.3v, then you will want to add a pass-through boost charger such as:
      https://www.openhardware.io/view/285/33v-Boost-Converter-with-Pass-Through
      or
      https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
      that you enable when your node wakes up and disable before going back to sleep.
      One can get more elaborate to handle more challenging low-light cases, but for 80%+ of the cases, I would expect the above to be enough.
      Fortunately, all this stuff is fairly inexpensive and easy to assemble.
      alexsh1A 1 Reply Last reply
      • TerrenceT
        TerrenceT
        Terrence
        I have this Solar Powered IoT Device Kit from Cypress....but have not started using it yet. though I would post it in case you might find the BOM useful.
        http://www.cypress.com/documentation/development-kitsboards/s6sae101a00sa1002-solar-powered-iot-device-kit
          @NeverDie @Nca78
          or
          alexsh1A
          alexsh1A
          alexsh1
          #127
          @NeverDie Thanks for your suggestion. Here is a thing - I cannot find MAX8887EZK27 anywhere.
          Meantime, I did manage to find this interesting article - https://www.ti5.tu-harburg.de/publications/2009/fgsn09_lifetime.pdf
          And these boost converters on the e-bay:
          1. http://www.ebay.co.uk/itm/ClosedCube-TPS61221-Low-Input-Voltage-from-0-7V-Boost-3-3V-Converter-Breakout-/182051630756
          2. http://www.ebay.co.uk/itm/ClosedCube-TPS61291-Low-Iq-Boost-Converter-with-Bypass-Operation-Breakout-/182304011227?var=&hash=item2a722a73db:m:mCSTFZtUluPLYwuCR7RYaeQ
          A bit expensive, but based on a very advanced chip which may be used with supercaps.
          • alexsh1A alexsh1
            https://www.digikey.com/product-detail/en/maxim-integrated/MAX8887EZK27-/MAX8887EZK27--ND/6227255
              alexsh1A
              alexsh1A
              alexsh1
              @NeverDie it is a no go for me at USD 18 delivery charge to the UK. Unfortunately, there are no other sources for this chip.
                You'll need to substitute a different LDO for it then.
                • alexsh1A alexsh1
                  #131
                  @alexsh1 in case you don't already know, octopart is great for finding sources. https://octopart.com/search?q=MAX8887EZK27
                  There seems to be only american sources for this component though :(
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @mfalkvidd
                    I did not know about this source
                    Well, that's the problem. The postage is golden and then if the value is greater than 20 bucks (including postage), I have to pay 20% VAT.
                    C NeverDieN 2 Replies Last reply
                    • alexsh1A alexsh1
                      @mfalkvidd
                      C
                      C
                      ceech
                      wrote on last edited by ceech
                      #133
                      @alexsh1 @NeverDie You can substitute the MAX8887 with MIC5365.
                      This whole thing got me so intrigued that I'm going to make a board myself. With charger, super capacitors and DC-DC converter. I'll use MIC5365 and for DC-DC conversion TPS610986. It has loads of options. And the whole thing will cost less than 10 bucks. I've made a schematic
                      alexsh1A NeverDieN 2 Replies Last reply
                      • C ceech
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @ceech said in How best to find the "best" small solar panel of a particular size?:
                        TPS610986
                        Excellent choice - TPS610986 - The TPS61098x
                        suits for low power systems very well, especially for the system which
                        spends the most of time in sleep mode and wakes up periodically to sense or transmit signals.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @NeverDie I am sure you saw this brilliant write up by Nick Gammon:
                          http://www.gammon.com.au/forum/?id=12821
                          He experimented with 0.47F capacitor. It was enough to run a mote (<10uA in a sleep mode) overnight
                          • alexsh1A alexsh1
                            @alexsh1
                            I hadn't seen it, but a mote in sleep mode draws practically nothing (<300na for combined draw from both atmega328p and RFM69). It's the self discharge rate of the capacitor more than anything which seems to govern.
                              @alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @NeverDie This is what he experienced! Have a look at the link. Within a few charges though, self discharge stabilised
                              • alexsh1A alexsh1
                                @mfalkvidd
                                #138
                                @alexsh1
                                Regarding the choice of replacement LDO. If the LDO you pick turns out to have unacceptably large reverse current flow, just place the blocking diode after it instead of before it. That particular diode will leak only about 20na, and the entire issue doesn't even come up until the last ~0.3v of charging, where you'll then have a very long charge tail. However, if that were to be an issue, you could just use a larger Farad supercap, and then it wouldn't matter because you'd have enough charge already before encountering the long tail of the charge process.
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @NeverDie Thanks for heads-up. I'll keep it in mind
                                  I found an interesting cap -
                                  https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691204E3/4705PHBK-ND/5015889
                                  Its voltage is very close to the solar panel so I think it may be connected directly via diode (0.7v drop = 6 - 0.7 = 5.3V vs 5.6V max rating)
                                  • alexsh1A alexsh1
                                    I've tried that cap already, and I wouldn't recommend it. It has a fairly high ESR.
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @NeverDie Given that you have been tinkering with it for a while, what caps can you recommend? With what ESR?
                                      This cap has got 2.4 Ohm @ 1kHz - I think it is low?!
                                      • alexsh1A alexsh1
                                        Perky explains it better than I can: https://lowpowerlab.com/forum/projects/a-solar-supercap-powered-moteino/msg18120/#msg18120
                                        • C ceech
                                          TPS610986
                                          1.5 mm x 1.5 mm WSON Package
                                          Not sure how easy that will be to solder?
