  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
    @alexsh1
    Regarding the choice of replacement LDO. If the LDO you pick turns out to have unacceptably large reverse current flow, just place the blocking diode after it instead of before it. That particular diode will leak only about 20na, and the entire issue doesn't even come up until the last ~0.3v of charging, where you'll then have a very long charge tail. However, if that were to be an issue, you could just use a larger Farad supercap, and then it wouldn't matter because you'd have enough charge already before encountering the long tail of the charge process.
    alexsh1A
    alexsh1A
    alexsh1
    @NeverDie Thanks for heads-up. I'll keep it in mind
    I found an interesting cap -
    https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691204E3/4705PHBK-ND/5015889
    Its voltage is very close to the solar panel so I think it may be connected directly via diode (0.7v drop = 6 - 0.7 = 5.3V vs 5.6V max rating)
    • alexsh1A alexsh1
      @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
      I've tried that cap already, and I wouldn't recommend it. It has a fairly high ESR.
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @NeverDie Given that you have been tinkering with it for a while, what caps can you recommend? With what ESR?
        This cap has got 2.4 Ohm @ 1kHz - I think it is low?!
        • alexsh1A alexsh1
          Perky explains it better than I can: https://lowpowerlab.com/forum/projects/a-solar-supercap-powered-moteino/msg18120/#msg18120
          • C ceech
            @alexsh1 @NeverDie You can substitute the MAX8887 with MIC5365.
            This whole thing got me so intrigued that I'm going to make a board myself. With charger, super capacitors and DC-DC converter. I'll use MIC5365 and for DC-DC conversion TPS610986. It has loads of options. And the whole thing will cost less than 10 bucks. I've made a schematic
            @ceech said in How best to find the "best" small solar panel of a particular size?:
            TPS610986
            1.5 mm x 1.5 mm WSON Package
            Not sure how easy that will be to solder?
              TPS610986
              alexsh1A
              alexsh1A
              alexsh1
              @NeverDie You need to get SMD rework station or oven.
              This is extremely difficult to get done by even an iron with a fine tip.
              C 1 Reply Last reply
              • alexsh1A alexsh1
                C
                C
                ceech
                @alexsh1 @NeverDie Yes, they will be soldered in the oven.
                • C ceech
                  @ceech
                  Well, I may end up buying it from ceech then. Even properly aligning it onto the solder pads becomes difficult. I really struggled with the BQ25504. Not saying it can't be done, but just that it requires a lot more skill.
                    @ceech
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @NeverDie and a strong magnifying glass :-)
                    • C
                      C
                      ceech
                      Those are the boards BTW
                      • C ceech
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @ceech it is very small. Excellent. Let us know when it is ready
                        • C
                          C
                          ceech
                          And if it is too tall, still, only two capacitors can be installed in horizontal position, or even just one.
                          • C ceech
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #151
                            @ceech How about a flat supercap like this:
                            https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691252E3/4699PHBK-ND/5015883
                            There is no need to have two in my view unless you want to raise voltage. One flat to make the board compact may be enough.
                            • C
                              C
                              ceech
                              Flat ones are nice. Nice package. High internal resistance, therefore low current. The double cell 15F flat capacitor can only supply 70mA.
                                This is great. :+1: Maybe more people will start playing with this stuff if they can buy inexpensive pre-made boards from ceech. The more, the merrier. :)
                                • C ceech
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @ceech said iThe double cell 15F flat capacitor can only supply 70mA.
                                  It should be enough if not using nrf24l01+ pa lna or rfm69HW. In this case perhaps, it would be better to have 150mA at least to cover those transmitters?
                                  I like the size - It is really flat.
                                  • alexsh1A alexsh1
                                    If you start to get choosy, that's when it's time to start making your own boards. It's easier than you might think. Otherwise, you just have to accept that the off-the-shelf stuff will never be exactly what you want.
                                    It's really too bad there isn't more of a universal PCB format that's easily edited, so you can simply start with a board that's close to what you want and just customize it a bit (the way one might with, say, software). For instance, even just changing LDO's--unless the new LDO has exactly the same land pattern--can necessitate redoing the board. No problem if you're the original designer, but it's a PITA if you aren't.
                                      #156
                                      I received the Chinese supercaps today. My "el cheapo" component tester is, I guess, too cheap, because it can't identify them:
                                      So, if anyone has suggestions for a good capacitor tester, let me know.
                                      However, I did plug the first one into my solar node after charging it ,and, so far it's not holding it's charge very well at all. I'll try the green one next.
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @NeverDie I just watched this video:
                                        https://youtu.be/EKRZEc-4SBo
                                        Is this what you have been looking?
                                        • alexsh1A alexsh1
                                          #158
                                          @alexsh1
                                          I like Julien's videos, butI'd find something that's faster and more automated to be preferable, as well as something that can measure ESR too.
