  3. Message is send twice
27 Posts 4 Posters 7.0k Views 4 Watching
  • E esawyja
    @core_c thanks so much, I will try it ASAP and provide feedback, thanks again!
    E
    E
    esawyja
    @core_c This works a treat, but I don't get the battery readings, if I look at the debug log, the MS seems to become quite large
    71362 MCO:SLP:MS=9681,SMS=0,I1=1,M1=1,I2=255,M2=255
    71366 MCO:SLP:TPD
    71370 MCO:SLP:WUP=-1
    71372 MCO:SLP:MS=9671,SMS=0,I1=1,M1=1,I2=255,M2=255
    71378 MCO:SLP:TPD
    71380 MCO:SLP:WUP=1
    71383 MCO:SLP:MS=9660,SMS=0,I1=1,M1=1,I2=255,M2=255
    71389 MCO:SLP:TPD
    71391 MCO:SLP:WUP=1
    Generator RUNNING - SENDING
    71401 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
    Generator message sent
    81424 MCO:SLP:MS=4294966915,SMS=0,I1=1,M1=1,I2=255,M2=255
    81430 MCO:SLP:TPD
    81432 MCO:SLP:WUP=1
    81434 MCO:SLP:MS=4294966905,SMS=0,I1=1,M1=1,I2=255,M2=255
    81440 MCO:SLP:TPD
    81444 MCO:SLP:WUP=1
    Generator NOT running - SENDING...
    81498 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
    91521 MCO:SLP:MS=4294956818,SMS=0,I1=1,M1=1,I2=255,M2=255
    91527 MCO:SLP:TPD
    Any suggestions please?
    E 1 Reply Last reply
    • E esawyja
      71366 MCO:SLP:TPD
      71378 MCO:SLP:TPD
      71380 MCO:SLP:WUP=1
      71389 MCO:SLP:TPD
      71391 MCO:SLP:WUP=1
      81430 MCO:SLP:TPD
      81432 MCO:SLP:WUP=1
      81440 MCO:SLP:TPD
      81444 MCO:SLP:WUP=1
      91527 MCO:SLP:TPD
      E
      E
      esawyja
      @core_c Sorry me again, here I made
      #define BATTERY_REPORT_INTERVAL 2000
      and printed the value
      battery_report_time = millis() + BATTERY_REPORT_INTERVAL;
      Serial.print("Battery report time is = ");
      Serial.println(battery_report_time);
      It looks like the sleep uses the time left over, as it prints faster and faster on the serial port and then the MS value just increases 10 fold
      21035 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
      Battery report time is = 23043
      21043 MCO:BGN:INIT OK,TSP=1
      21049 MCO:SLP:MS=1994,SMS=0,I1=1,M1=1,I2=255,M2=255
      21053 MCO:SLP:TPD
      21057 MCO:SLP:WUP=1
      21059 MCO:SLP:MS=1984,SMS=0,I1=1,M1=1,I2=255,M2=255
      21065 MCO:SLP:TPD
      21067 MCO:SLP:WUP=-1
      21069 MCO:SLP:MS=1974,SMS=0,I1=1,M1=1,I2=255,M2=255
      21075 MCO:SLP:TPD
      21078 MCO:SLP:WUP=-1
      21080 MCO:SLP:MS=1963,SMS=0,I1=1,M1=1,I2=255,M2=255
      21086 MCO:SLP:TPD
      21088 MCO:SLP:WUP=-1
      21092 MCO:SLP:MS=1951,SMS=0,I1=1,M1=1,I2=255,M2=255
      21096 MCO:SLP:TPD
      21100 MCO:SLP:WUP=-1
      22878 MCO:SLP:MS=165,SMS=0,I1=1,M1=1,I2=255,M2=255
      22882 MCO:SLP:TPD
      22884 MCO:SLP:WUP=-1
      22888 MCO:SLP:MS=155,SMS=0,I1=1,M1=1,I2=255,M2=255
      22892 MCO:SLP:TPD
      22896 MCO:SLP:WUP=-1
      22898 MCO:SLP:MS=145,SMS=0,I1=1,M1=1,I2=255,M2=255
      22904 MCO:SLP:TPD
      22906 MCO:SLP:WUP=-1
      22908 MCO:SLP:MS=135,SMS=0,I1=1,M1=1,I2=255,M2=255
      22915 MCO:SLP:TPD
      22917 MCO:SLP:WUP=-1
      22919 MCO:SLP:MS=124,SMS=0,I1=1,M1=1,I2=255,M2=255
      22925 MCO:SLP:TPD
      22927 MCO:SLP:WUP=-1
      22931 MCO:SLP:MS=112,SMS=0,I1=1,M1=1,I2=255,M2=255
      22935 MCO:SLP:TPD
      22937 MCO:SLP:WUP=-1
      22941 MCO:SLP:MS=102,SMS=0,I1=1,M1=1,I2=255,M2=255
      22945 MCO:SLP:TPD
      22947 MCO:SLP:WUP=-1
      22951 MCO:SLP:MS=92,SMS=0,I1=1,M1=1,I2=255,M2=255
      22958 MCO:SLP:TPD
      22960 MCO:SLP:WUP=-1
      22962 MCO:SLP:MS=81,SMS=0,I1=1,M1=1,I2=255,M2=255
      22968 MCO:SLP:TPD
      22970 MCO:SLP:WUP=-1
      22972 MCO:SLP:MS=71,SMS=0,I1=1,M1=1,I2=255,M2=255
      22978 MCO:SLP:TPD
      22980 MCO:SLP:WUP=-1
      22982 MCO:SLP:MS=61,SMS=0,I1=1,M1=1,I2=255,M2=255
      22988 MCO:SLP:TPD
      22990 MCO:SLP:WUP=-1
      22992 MCO:SLP:MS=51,SMS=0,I1=1,M1=1,I2=255,M2=255
      22999 MCO:SLP:TPD
      23001 MCO:SLP:WUP=-1
      23005 MCO:SLP:MS=38,SMS=0,I1=1,M1=1,I2=255,M2=255
      23009 MCO:SLP:TPD
      23011 MCO:SLP:WUP=-1
      23015 MCO:SLP:MS=28,SMS=0,I1=1,M1=1,I2=255,M2=255
      23019 MCO:SLP:TPD
      23021 MCO:SLP:WUP=-1
      23025 MCO:SLP:MS=18,SMS=0,I1=1,M1=1,I2=255,M2=255
      23029 MCO:SLP:TPD
      23031 MCO:SLP:WUP=-1
      23035 MCO:SLP:MS=8,SMS=0,I1=1,M1=1,I2=255,M2=255
      23040 MCO:SLP:TPD
      23044 MCO:SLP:WUP=-1
      23046 MCO:SLP:MS=4294967293,SMS=0,I1=1,M1=1,I2=255,M2=255
      23052 MCO:SLP:TPD
      After this, there is nothing more on the serial port
      core_cC 1 Reply Last reply
      • E esawyja
        21053 MCO:SLP:TPD
        21057 MCO:SLP:WUP=1
        21065 MCO:SLP:TPD
        21075 MCO:SLP:TPD
        21086 MCO:SLP:TPD
        21096 MCO:SLP:TPD
        22882 MCO:SLP:TPD
        22892 MCO:SLP:TPD
        22904 MCO:SLP:TPD
        22915 MCO:SLP:TPD
        22925 MCO:SLP:TPD
        22935 MCO:SLP:TPD
        22945 MCO:SLP:TPD
        22958 MCO:SLP:TPD
        22968 MCO:SLP:TPD
        22978 MCO:SLP:TPD
        22988 MCO:SLP:TPD
        22999 MCO:SLP:TPD
        23009 MCO:SLP:TPD
        23019 MCO:SLP:TPD
        23029 MCO:SLP:TPD
        23040 MCO:SLP:TPD
        23052 MCO:SLP:TPD
        core_cC
        core_cC
        core_c
        wrote on last edited by core_c
        @esawyja You are right. I made a mistake. This should fix it:
        Change this line:
        uint32_t sleep_time_left = battery_report_time - millis();
        into this:
        long sleep_time_left = battery_report_time - millis();
        A variable of type long can hold a negative number, but an unsigned long (same as uint32_t) can never hold a negative number (because it is unsigned, no sign, no minus sign, no negative).
        So, if (sleep_time_left < 0) will never be true.. That was the mistake.
        I was also wondering if the generator would produce interrupts without using attachInterrupt().
        Without that, you can still poll the generator pin, and see if the value changed (what is happening now), but the sleep() cycle would not be interrupted when the pin changed.
        To be on the safe side, i would also add the following to your code:
          attachInterrupt(digitalPinToInterrupt(GENERATOR_PIN), generator_pin_interrupt_handler, CHANGE);
        Hopefully that'll make it work as intended.
        • core_cC core_c
          Change this line:
          into this:
          E
          E
          esawyja
          wrote on last edited by esawyja
          @core_c Thanks for that
          I had to change the battery reading routine to this below, else when it gets to the routine, it stays there and never get back to the loop, I hope it makes sense
          void read_batt() {
            wait(15000);
            float batteryV = sensorValue * volt_value;
            send(batt_msg.set(batteryV,2));
            sleep_time_left = BATTERY_REPORT_INTERVAL;
            return;
          If I add this to setup, I get the following error
          gen_run_sketch:54: error: 'generator_pin_interrupt_handler' was not declared in this scope
          exit status 1
          • E esawyja
            void read_batt() {
              wait(15000);
              return;
            exit status 1
            core_cC
            core_cC
            core_c
            @esawyja attachInterrupt() should only be done once, in the setup() function.
            • core_cC core_c
              E
              E
              esawyja
              @core_c I'm sorry I do not understand, must I replace this in loop
              sleep(digitalPinToInterrupt(GENERATOR_PIN), CHANGE, sleep_time_left);
              With this in setup?
              Sorry for all the questions!! This is sooo confusing to me, it also seems that the battery level is not sending, I left it running for 12 hours plus and never got a reading, the line
              #define BATTERY_REPORT_INTERVAL 60000
              Does this define that the battery level must be send ever 60000 milli seconds?
                If it is a battery powered node you need to use the sleep function to put the node into low power mode.
                • E esawyja
                  With this in setup?
                  core_cC
                  core_cC
                  core_c
                  @esawyja i made the changes for you in my post made earlier^^
                  • core_cC core_c
                    E
                    E
                    esawyja
                    @core_c Thanks so much, I will try these changes!
                    • core_cC
                      core_cC
                      core_c
                      About your battery level send question, here's some explanation:
                      The intention is to let your node sleep when nothing happens.
                      Only when the generator pin changes, it interrupts the sleep cycle, and wakes up the node. It then checks the current generator pin state and sends the appropriate message. Then it goes to sleep again.
                      However, it does not sleep forever. At regular intervals the battery level is send. So every BATTERY_REPORT_INTERVAL milliseconds the current sleep cycle ends (because the timer has counted down and reached its end), and the battery level is send.
                      The program keeps doing this: Sleep, and wake up if the pin changed, and/or wake up when the battery level should be send.
                      E 2 Replies Last reply
                      • core_cC core_c
                        E
                        E
                        esawyja
                        @core_c Thanks, I will try all the changes, thanks again for the code!!
                        • core_cC core_c
                          E
                          E
                          esawyja
                          @core_c I'm still having problems with this, the generator running or not works a treat, but if I just reboot the node and leave it, it goes through the sleep from what I can see, but then nothing happens after that, it does not send the battery level, it just hangs. Also the #define BATTERY_REPORT_INTERVAL 3000 does not work correctly, I've set it to 3000 as a test and it definitely took longer than 3000 MS, the complete serial log is pasted below, I did not trigger the generator during this period
                          4 TSM:INIT
                          4 TSF:WUR:MS=1000
                          8 TSM:INIT:TSP OK
                          10 TSM:INIT:STATID=11
                          12 TSF:SID:OK,ID=11
                          14 TSM:FPAR
                          145 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          395 TSF:MSG:READ,0-0-11,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          401 TSF:MSG:FPAR OK,ID=0,D=1
                          1007 MCO:BGN:STP
                          1007 !MCO:SND:NODE NOT REG
                          2152 TSM:FPAR:OK
                          2152 TSM:ID
                          2154 TSM:ID:OK
                          2156 TSM:UPL
                          2164 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2215 TSF:MSG:READ,0-0-11,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2222 TSF:MSG:PONG RECV,HP=1
                          2224 TSM:UPL:OK
                          2226 TSM:READY:ID=11,PAR=0,DIS=1
                          2238 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2289 TSF:MSG:READ,0-0-11,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2304 TSF:MSG:SEND,11-11-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                          2320 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          4327 MCO:REG:REQ
                          4335 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          4386 TSF:MSG:READ,0-0-11,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          4392 MCO:PIM:NODE REG=1
                          11018 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                          11026 MCO:BGN:INIT OK,TSP=1
                          11030 MCO:SLP:MS=2996,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11036 MCO:SLP:TPD
                          11038 MCO:SLP:WUP=-1
                          11042 MCO:SLP:MS=2984,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11046 MCO:SLP:TPD
                          11051 MCO:SLP:WUP=-1
                          11053 MCO:SLP:MS=2973,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11059 MCO:SLP:TPD
                          11061 MCO:SLP:WUP=-1
                          11063 MCO:SLP:MS=2963,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11069 MCO:SLP:TPD
                          11071 MCO:SLP:WUP=-1
                          11073 MCO:SLP:MS=2953,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11079 MCO:SLP:TPD
                          11081 MCO:SLP:WUP=-1
                          11085 MCO:SLP:MS=2941,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11089 MCO:SLP:TPD
                          11094 MCO:SLP:WUP=-1
                          11096 MCO:SLP:MS=2930,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11102 MCO:SLP:TPD
                          11104 MCO:SLP:WUP=-1
                          11106 MCO:SLP:MS=2920,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11112 MCO:SLP:TPD
                          11114 MCO:SLP:WUP=-1
                          11118 MCO:SLP:MS=2908,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11122 MCO:SLP:TPD
                          11124 MCO:SLP:WUP=-1
                          11128 MCO:SLP:MS=2898,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11134 MCO:SLP:TPD
                          11137 MCO:SLP:WUP=-1
                          11139 MCO:SLP:MS=2887,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11145 MCO:SLP:TPD
                          11147 MCO:SLP:WUP=-1
                          11149 MCO:SLP:MS=2877,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11155 MCO:SLP:TPD
                          11157 MCO:SLP:WUP=-1
                          11161 MCO:SLP:MS=2865,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11165 MCO:SLP:TPD
                          11167 MCO:SLP:WUP=-1
                          11171 MCO:SLP:MS=2855,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11177 MCO:SLP:TPD
                          11180 MCO:SLP:WUP=-1
                          11182 MCO:SLP:MS=2844,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11188 MCO:SLP:TPD
                          11190 MCO:SLP:WUP=-1
                          11192 MCO:SLP:MS=2834,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11198 MCO:SLP:TPD
                          11200 MCO:SLP:WUP=-1
                          11204 MCO:SLP:MS=2822,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11208 MCO:SLP:TPD
                          11212 MCO:SLP:WUP=-1
                          11214 MCO:SLP:MS=2812,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11220 MCO:SLP:TPD
                          11223 MCO:SLP:WUP=-1
                          11225 MCO:SLP:MS=2801,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11231 MCO:SLP:TPD
                          11233 MCO:SLP:WUP=-1
                          11235 MCO:SLP:MS=2791,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11241 MCO:SLP:TPD
                          11243 MCO:SLP:WUP=-1
                          11247 MCO:SLP:MS=2779,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11251 MCO:SLP:TPD
                          11255 MCO:SLP:WUP=-1
                          11257 MCO:SLP:MS=2769,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11264 MCO:SLP:TPD
                          11266 MCO:SLP:WUP=-1
                          11268 MCO:SLP:MS=2758,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11274 MCO:SLP:TPD
                          11276 MCO:SLP:WUP=-1
                          11278 MCO:SLP:MS=2748,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11284 MCO:SLP:TPD
                          11286 MCO:SLP:WUP=-1
                          11290 MCO:SLP:MS=2736,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11294 MCO:SLP:TPD
                          11298 MCO:SLP:WUP=-1
                          11300 MCO:SLP:MS=2726,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11307 MCO:SLP:TPD
                          11309 MCO:SLP:WUP=-1
                          11311 MCO:SLP:MS=2715,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11317 MCO:SLP:TPD
                          11319 MCO:SLP:WUP=-1
                          11323 MCO:SLP:MS=2703,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11327 MCO:SLP:TPD
                          11329 MCO:SLP:WUP=-1
                          11333 MCO:SLP:MS=2693,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11339 MCO:SLP:TPD
                          11341 MCO:SLP:WUP=-1
                          11343 MCO:SLP:MS=2683,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11350 MCO:SLP:TPD
                          11352 MCO:SLP:WUP=-1
                          11354 MCO:SLP:MS=2672,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11360 MCO:SLP:TPD
                          11362 MCO:SLP:WUP=-1
                          11366 MCO:SLP:MS=2660,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11370 MCO:SLP:TPD
                          11372 MCO:SLP:WUP=-1
                          11376 MCO:SLP:MS=2650,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11382 MCO:SLP:TPD
                          11384 MCO:SLP:WUP=-1
                          11386 MCO:SLP:MS=2640,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11393 MCO:SLP:TPD
                          11395 MCO:SLP:WUP=-1
                          11397 MCO:SLP:MS=2629,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11403 MCO:SLP:TPD
                          11405 MCO:SLP:WUP=-1
                          11409 MCO:SLP:MS=2617,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11413 MCO:SLP:TPD
                          11415 MCO:SLP:WUP=-1
                          11419 MCO:SLP:MS=2607,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11425 MCO:SLP:TPD
                          11427 MCO:SLP:WUP=-1
                          11429 MCO:SLP:MS=2597,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11436 MCO:SLP:TPD
                          11438 MCO:SLP:WUP=-1
                          11440 MCO:SLP:MS=2586,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11446 MCO:SLP:TPD
                          11448 MCO:SLP:WUP=-1
                          11452 MCO:SLP:MS=2574,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11456 MCO:SLP:TPD
                          11458 MCO:SLP:WUP=-1
                          11462 MCO:SLP:MS=2564,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11468 MCO:SLP:TPD
                          11470 MCO:SLP:WUP=-1
                          11472 MCO:SLP:MS=2554,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11479 MCO:SLP:TPD
                          11481 MCO:SLP:WUP=-1
                          11483 MCO:SLP:MS=2543,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11489 MCO:SLP:TPD
                          11491 MCO:SLP:WUP=-1
                          11495 MCO:SLP:MS=2531,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11499 MCO:SLP:TPD
                          11503 MCO:SLP:WUP=-1
                          11505 MCO:SLP:MS=2521,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11511 MCO:SLP:TPD
                          11513 MCO:SLP:WUP=-1
                          11515 MCO:SLP:MS=2511,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11522 MCO:SLP:TPD
                          11524 MCO:SLP:WUP=-1
                          11526 MCO:SLP:MS=2500,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11532 MCO:SLP:TPD
                          11534 MCO:SLP:WUP=-1
                          11538 MCO:SLP:MS=2488,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11542 MCO:SLP:TPD
                          11544 MCO:SLP:WUP=-1
                          11548 MCO:SLP:MS=2478,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11554 MCO:SLP:TPD
                          11556 MCO:SLP:WUP=-1
                          11558 MCO:SLP:MS=2468,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11565 MCO:SLP:TPD
                          11567 MCO:SLP:WUP=-1
                          11569 MCO:SLP:MS=2457,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11575 MCO:SLP:TPD
                          11577 MCO:SLP:WUP=-1
                          11581 MCO:SLP:MS=2445,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11585 MCO:SLP:TPD
                          11589 MCO:SLP:WUP=-1
                          11591 MCO:SLP:MS=2435,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11597 MCO:SLP:TPD
                          11599 MCO:SLP:WUP=-1
                          11601 MCO:SLP:MS=2425,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11608 MCO:SLP:TPD
                          11610 MCO:SLP:WUP=-1
                          11612 MCO:SLP:MS=2414,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11618 MCO:SLP:TPD
                          11620 MCO:SLP:WUP=-1
                          11624 MCO:SLP:MS=2402,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11628 MCO:SLP:TPD
                          11632 MCO:SLP:WUP=-1
                          11634 MCO:SLP:MS=2392,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11640 MCO:SLP:TPD
                          11642 MCO:SLP:WUP=-1
                          11644 MCO:SLP:MS=2382,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11651 MCO:SLP:TPD
                          11653 MCO:SLP:WUP=-1
                          11655 MCO:SLP:MS=2371,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11661 MCO:SLP:TPD
                          11663 MCO:SLP:WUP=-1
                          11667 MCO:SLP:MS=2359,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11671 MCO:SLP:TPD
                          11675 MCO:SLP:WUP=-1
                          11677 MCO:SLP:MS=2349,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11683 MCO:SLP:TPD
                          11685 MCO:SLP:WUP=-1
                          11687 MCO:SLP:MS=2339,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11694 MCO:SLP:TPD
                          11696 MCO:SLP:WUP=-1
                          11698 MCO:SLP:MS=2328,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11704 MCO:SLP:TPD
                          11706 MCO:SLP:WUP=-1
                          11710 MCO:SLP:MS=2316,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11714 MCO:SLP:TPD
                          11716 MCO:SLP:WUP=-1
                          11720 MCO:SLP:MS=2306,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11726 MCO:SLP:TPD
                          11728 MCO:SLP:WUP=-1
                          11730 MCO:SLP:MS=2296,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11737 MCO:SLP:TPD
                          11739 MCO:SLP:WUP=-1
                          11741 MCO:SLP:MS=2285,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11747 MCO:SLP:TPD
                          11749 MCO:SLP:WUP=-1
                          11753 MCO:SLP:MS=2273,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11757 MCO:SLP:TPD
                          11759 MCO:SLP:WUP=-1
                          11763 MCO:SLP:MS=2263,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11769 MCO:SLP:TPD
                          11771 MCO:SLP:WUP=-1
                          11773 MCO:SLP:MS=2253,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11780 MCO:SLP:TPD
                          11782 MCO:SLP:WUP=-1
                          11784 MCO:SLP:MS=2242,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11790 MCO:SLP:TPD
                          11792 MCO:SLP:WUP=-1
                          11796 MCO:SLP:MS=2230,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11800 MCO:SLP:TPD
                          11802 MCO:SLP:WUP=-1
                          11806 MCO:SLP:MS=2220,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11812 MCO:SLP:TPD
                          11814 MCO:SLP:WUP=-1
                          11816 MCO:SLP:MS=2210,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11823 MCO:SLP:TPD
                          11825 MCO:SLP:WUP=-1
                          11827 MCO:SLP:MS=2199,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11833 MCO:SLP:TPD
                          11835 MCO:SLP:WUP=-1
                          11839 MCO:SLP:MS=2187,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11843 MCO:SLP:TPD
                          11845 MCO:SLP:WUP=-1
                          11849 MCO:SLP:MS=2177,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11855 MCO:SLP:TPD
                          11857 MCO:SLP:WUP=-1
                          11859 MCO:SLP:MS=2167,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11866 MCO:SLP:TPD
                          11868 MCO:SLP:WUP=-1
                          11870 MCO:SLP:MS=2156,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11876 MCO:SLP:TPD
                          11878 MCO:SLP:WUP=-1
                          11882 MCO:SLP:MS=2146,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11886 MCO:SLP:TPD
                          11888 MCO:SLP:WUP=-1
                          11892 MCO:SLP:MS=2134,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11898 MCO:SLP:TPD
                          11900 MCO:SLP:WUP=-1
                          11902 MCO:SLP:MS=2124,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11909 MCO:SLP:TPD
                          11911 MCO:SLP:WUP=-1
                          11913 MCO:SLP:MS=2113,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11919 MCO:SLP:TPD
                          11921 MCO:SLP:WUP=-1
                          11923 MCO:SLP:MS=2103,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11929 MCO:SLP:TPD
                          11931 MCO:SLP:WUP=-1
                          11935 MCO:SLP:MS=2091,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11939 MCO:SLP:TPD
                          11943 MCO:SLP:WUP=-1
                          11945 MCO:SLP:MS=2081,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11952 MCO:SLP:TPD
                          11954 MCO:SLP:WUP=-1
                          11956 MCO:SLP:MS=2070,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11962 MCO:SLP:TPD
                          11964 MCO:SLP:WUP=-1
                          11966 MCO:SLP:MS=2060,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11972 MCO:SLP:TPD
                          11974 MCO:SLP:WUP=-1
                          11978 MCO:SLP:MS=2048,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11982 MCO:SLP:TPD
                          11984 MCO:SLP:WUP=-1
                          11988 MCO:SLP:MS=2038,SMS=0,I1=1,M1=1,I2=255,M2=255
                          11995 MCO:SLP:TPD
                          11997 MCO:SLP:WUP=-1
                          11999 MCO:SLP:MS=2027,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12005 MCO:SLP:TPD
                          12007 MCO:SLP:WUP=-1
                          12009 MCO:SLP:MS=2017,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12015 MCO:SLP:TPD
                          12017 MCO:SLP:WUP=-1
                          12019 MCO:SLP:MS=2007,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12025 MCO:SLP:TPD
                          12027 MCO:SLP:WUP=-1
                          12032 MCO:SLP:MS=1994,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12036 MCO:SLP:TPD
                          12040 MCO:SLP:WUP=-1
                          12042 MCO:SLP:MS=1984,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12048 MCO:SLP:TPD
                          12050 MCO:SLP:WUP=-1
                          12052 MCO:SLP:MS=1974,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12058 MCO:SLP:TPD
                          12060 MCO:SLP:WUP=-1
                          12062 MCO:SLP:MS=1964,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12068 MCO:SLP:TPD
                          12070 MCO:SLP:WUP=-1
                          12075 MCO:SLP:MS=1951,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12079 MCO:SLP:TPD
                          12083 MCO:SLP:WUP=-1
                          12085 MCO:SLP:MS=1941,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12091 MCO:SLP:TPD
                          12093 MCO:SLP:WUP=-1
                          12095 MCO:SLP:MS=1931,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12101 MCO:SLP:TPD
                          12103 MCO:SLP:WUP=-1
                          12105 MCO:SLP:MS=1921,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12111 MCO:SLP:TPD
                          12113 MCO:SLP:WUP=-1
                          12118 MCO:SLP:MS=1908,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12122 MCO:SLP:TPD
                          12126 MCO:SLP:WUP=-1
                          12128 MCO:SLP:MS=1898,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12134 MCO:SLP:TPD
                          12136 MCO:SLP:WUP=-1
                          12138 MCO:SLP:MS=1888,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12144 MCO:SLP:TPD
                          12146 MCO:SLP:WUP=-1
                          12148 MCO:SLP:MS=1878,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12154 MCO:SLP:TPD
                          12156 MCO:SLP:WUP=-1
                          12161 MCO:SLP:MS=1865,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12165 MCO:SLP:TPD
                          12169 MCO:SLP:WUP=-1
                          12171 MCO:SLP:MS=1855,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12177 MCO:SLP:TPD
                          12179 MCO:SLP:WUP=-1
                          12181 MCO:SLP:MS=1845,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12187 MCO:SLP:TPD
                          12189 MCO:SLP:WUP=-1
                          12191 MCO:SLP:MS=1835,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12197 MCO:SLP:TPD
                          12199 MCO:SLP:WUP=-1
                          12204 MCO:SLP:MS=1822,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12208 MCO:SLP:TPD
                          12210 MCO:SLP:WUP=-1
                          12214 MCO:SLP:MS=1812,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12220 MCO:SLP:TPD
                          12222 MCO:SLP:WUP=-1
                          12224 MCO:SLP:MS=1802,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12230 MCO:SLP:TPD
                          12232 MCO:SLP:WUP=-1
                          12234 MCO:SLP:MS=1792,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12240 MCO:SLP:TPD
                          12242 MCO:SLP:WUP=-1
                          12247 MCO:SLP:MS=1779,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12251 MCO:SLP:TPD
                          12253 MCO:SLP:WUP=-1
                          12257 MCO:SLP:MS=1769,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12263 MCO:SLP:TPD
                          12265 MCO:SLP:WUP=-1
                          12267 MCO:SLP:MS=1759,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12273 MCO:SLP:TPD
                          12275 MCO:SLP:WUP=-1
                          12277 MCO:SLP:MS=1749,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12283 MCO:SLP:TPD
                          12285 MCO:SLP:WUP=-1
                          12290 MCO:SLP:MS=1736,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12294 MCO:SLP:TPD
                          12296 MCO:SLP:WUP=-1
                          12300 MCO:SLP:MS=1726,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12306 MCO:SLP:TPD
                          12308 MCO:SLP:WUP=-1
                          12310 MCO:SLP:MS=1716,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12316 MCO:SLP:TPD
                          12318 MCO:SLP:WUP=-1
                          12320 MCO:SLP:MS=1706,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12326 MCO:SLP:TPD
                          12328 MCO:SLP:WUP=-1
                          12333 MCO:SLP:MS=1693,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12337 MCO:SLP:TPD
                          12339 MCO:SLP:WUP=-1
                          12343 MCO:SLP:MS=1683,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12349 MCO:SLP:TPD
                          12351 MCO:SLP:WUP=-1
                          12353 MCO:SLP:MS=1673,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12359 MCO:SLP:TPD
                          12361 MCO:SLP:WUP=-1
                          12363 MCO:SLP:MS=1663,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12369 MCO:SLP:TPD
                          12371 MCO:SLP:WUP=-1
                          12374 MCO:SLP:MS=1652,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12380 MCO:SLP:TPD
                          12382 MCO:SLP:WUP=-1
                          12386 MCO:SLP:MS=1640,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12390 MCO:SLP:TPD
                          12394 MCO:SLP:WUP=-1
                          12396 MCO:SLP:MS=1630,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12402 MCO:SLP:TPD
                          12404 MCO:SLP:WUP=-1
                          12406 MCO:SLP:MS=1620,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12412 MCO:SLP:TPD
                          12414 MCO:SLP:WUP=-1
                          12417 MCO:SLP:MS=1609,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12423 MCO:SLP:TPD
                          12425 MCO:SLP:WUP=-1
                          12429 MCO:SLP:MS=1597,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12433 MCO:SLP:TPD
                          12437 MCO:SLP:WUP=-1
                          12439 MCO:SLP:MS=1587,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12445 MCO:SLP:TPD
                          12447 MCO:SLP:WUP=-1
                          12449 MCO:SLP:MS=1577,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12455 MCO:SLP:TPD
                          12457 MCO:SLP:WUP=-1
                          12460 MCO:SLP:MS=1566,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12466 MCO:SLP:TPD
                          12468 MCO:SLP:WUP=-1
                          12472 MCO:SLP:MS=1554,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12476 MCO:SLP:TPD
                          12478 MCO:SLP:WUP=-1
                          12482 MCO:SLP:MS=1544,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12488 MCO:SLP:TPD
                          12490 MCO:SLP:WUP=-1
                          12492 MCO:SLP:MS=1534,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12498 MCO:SLP:TPD
                          12500 MCO:SLP:WUP=-1
                          12503 MCO:SLP:MS=1523,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12509 MCO:SLP:TPD
                          12511 MCO:SLP:WUP=-1
                          12515 MCO:SLP:MS=1511,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12519 MCO:SLP:TPD
                          12521 MCO:SLP:WUP=-1
                          12525 MCO:SLP:MS=1501,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12531 MCO:SLP:TPD
                          12533 MCO:SLP:WUP=-1
                          12535 MCO:SLP:MS=1491,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12541 MCO:SLP:TPD
                          12544 MCO:SLP:WUP=-1
                          12546 MCO:SLP:MS=1480,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12552 MCO:SLP:TPD
                          12554 MCO:SLP:WUP=-1
                          12558 MCO:SLP:MS=1468,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12562 MCO:SLP:TPD
                          12564 MCO:SLP:WUP=-1
                          12568 MCO:SLP:MS=1458,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12574 MCO:SLP:TPD
                          12576 MCO:SLP:WUP=-1
                          12578 MCO:SLP:MS=1448,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12584 MCO:SLP:TPD
                          12587 MCO:SLP:WUP=-1
                          12589 MCO:SLP:MS=1437,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12595 MCO:SLP:TPD
                          12597 MCO:SLP:WUP=-1
                          12601 MCO:SLP:MS=1425,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12605 MCO:SLP:TPD
                          12607 MCO:SLP:WUP=-1
                          12611 MCO:SLP:MS=1415,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12617 MCO:SLP:TPD
                          12619 MCO:SLP:WUP=-1
                          12621 MCO:SLP:MS=1405,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12627 MCO:SLP:TPD
                          12630 MCO:SLP:WUP=-1
                          12632 MCO:SLP:MS=1394,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12638 MCO:SLP:TPD
                          12640 MCO:SLP:WUP=-1
                          12644 MCO:SLP:MS=1382,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12648 MCO:SLP:TPD
                          12650 MCO:SLP:WUP=-1
                          12654 MCO:SLP:MS=1372,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12658 MCO:SLP:TPD
                          12662 MCO:SLP:WUP=-1
                          12664 MCO:SLP:MS=1362,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12670 MCO:SLP:TPD
                          12673 MCO:SLP:WUP=-1
                          12675 MCO:SLP:MS=1351,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12681 MCO:SLP:TPD
                          12683 MCO:SLP:WUP=-1
                          12685 MCO:SLP:MS=1341,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12691 MCO:SLP:TPD
                          12693 MCO:SLP:WUP=-1
                          12697 MCO:SLP:MS=1329,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12701 MCO:SLP:TPD
                          12705 MCO:SLP:WUP=-1
                          12707 MCO:SLP:MS=1319,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12713 MCO:SLP:TPD
                          12716 MCO:SLP:WUP=-1
                          12718 MCO:SLP:MS=1308,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12724 MCO:SLP:TPD
                          12726 MCO:SLP:WUP=-1
                          12728 MCO:SLP:MS=1298,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12734 MCO:SLP:TPD
                          12736 MCO:SLP:WUP=-1
                          12740 MCO:SLP:MS=1286,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12744 MCO:SLP:TPD
                          12748 MCO:SLP:WUP=-1
                          12750 MCO:SLP:MS=1276,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12756 MCO:SLP:TPD
                          12759 MCO:SLP:WUP=-1
                          12761 MCO:SLP:MS=1265,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12767 MCO:SLP:TPD
                          12769 MCO:SLP:WUP=-1
                          12771 MCO:SLP:MS=1255,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12777 MCO:SLP:TPD
                          12779 MCO:SLP:WUP=-1
                          12783 MCO:SLP:MS=1243,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12787 MCO:SLP:TPD
                          12791 MCO:SLP:WUP=-1
                          12793 MCO:SLP:MS=1233,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12800 MCO:SLP:TPD
                          12802 MCO:SLP:WUP=-1
                          12804 MCO:SLP:MS=1222,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12810 MCO:SLP:TPD
                          12812 MCO:SLP:WUP=-1
                          12814 MCO:SLP:MS=1212,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12820 MCO:SLP:TPD
                          12822 MCO:SLP:WUP=-1
                          12826 MCO:SLP:MS=1200,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12830 MCO:SLP:TPD
                          12832 MCO:SLP:WUP=-1
                          12836 MCO:SLP:MS=1190,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12843 MCO:SLP:TPD
                          12845 MCO:SLP:WUP=-1
                          12847 MCO:SLP:MS=1179,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12853 MCO:SLP:TPD
                          12855 MCO:SLP:WUP=-1
                          12857 MCO:SLP:MS=1169,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12863 MCO:SLP:TPD
                          12865 MCO:SLP:WUP=-1
                          12869 MCO:SLP:MS=1157,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12873 MCO:SLP:TPD
                          12875 MCO:SLP:WUP=-1
                          12879 MCO:SLP:MS=1147,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12886 MCO:SLP:TPD
                          12888 MCO:SLP:WUP=-1
                          12890 MCO:SLP:MS=1136,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12896 MCO:SLP:TPD
                          12898 MCO:SLP:WUP=-1
                          12900 MCO:SLP:MS=1126,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12906 MCO:SLP:TPD
                          12908 MCO:SLP:WUP=-1
                          12912 MCO:SLP:MS=1114,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12916 MCO:SLP:TPD
                          12918 MCO:SLP:WUP=-1
                          12922 MCO:SLP:MS=1104,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12929 MCO:SLP:TPD
                          12931 MCO:SLP:WUP=-1
                          12933 MCO:SLP:MS=1093,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12939 MCO:SLP:TPD
                          12941 MCO:SLP:WUP=-1
                          12943 MCO:SLP:MS=1083,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12949 MCO:SLP:TPD
                          12951 MCO:SLP:WUP=-1
                          12955 MCO:SLP:MS=1071,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12959 MCO:SLP:TPD
                          12961 MCO:SLP:WUP=-1
                          12965 MCO:SLP:MS=1061,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12972 MCO:SLP:TPD
                          12974 MCO:SLP:WUP=-1
                          12976 MCO:SLP:MS=1050,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12982 MCO:SLP:TPD
                          12984 MCO:SLP:WUP=-1
                          12986 MCO:SLP:MS=1040,SMS=0,I1=1,M1=1,I2=255,M2=255
                          12992 MCO:SLP:TPD
                          12994 MCO:SLP:WUP=-1
                          12998 MCO:SLP:MS=1028,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13002 MCO:SLP:TPD
                          13004 MCO:SLP:WUP=-1
                          13008 MCO:SLP:MS=1018,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13015 MCO:SLP:TPD
                          13017 MCO:SLP:WUP=-1
                          13019 MCO:SLP:MS=1007,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13025 MCO:SLP:TPD
                          13027 MCO:SLP:WUP=-1
                          13029 MCO:SLP:MS=997,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13035 MCO:SLP:TPD
                          13037 MCO:SLP:WUP=-1
                          13039 MCO:SLP:MS=987,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13045 MCO:SLP:TPD
                          13047 MCO:SLP:WUP=-1
                          13051 MCO:SLP:MS=975,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13056 MCO:SLP:TPD
                          13058 MCO:SLP:WUP=-1
                          13062 MCO:SLP:MS=964,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13068 MCO:SLP:TPD
                          13070 MCO:SLP:WUP=-1
                          13072 MCO:SLP:MS=954,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13078 MCO:SLP:TPD
                          13080 MCO:SLP:WUP=-1
                          13082 MCO:SLP:MS=944,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13088 MCO:SLP:TPD
                          13090 MCO:SLP:WUP=-1
                          13092 MCO:SLP:MS=934,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13099 MCO:SLP:TPD
                          13101 MCO:SLP:WUP=-1
                          13105 MCO:SLP:MS=921,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13109 MCO:SLP:TPD
                          13111 MCO:SLP:WUP=-1
                          13115 MCO:SLP:MS=911,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13121 MCO:SLP:TPD
                          13123 MCO:SLP:WUP=-1
                          13125 MCO:SLP:MS=901,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13131 MCO:SLP:TPD
                          13133 MCO:SLP:WUP=-1
                          13135 MCO:SLP:MS=891,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13142 MCO:SLP:TPD
                          13144 MCO:SLP:WUP=-1
                          13146 MCO:SLP:MS=880,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13152 MCO:SLP:TPD
                          13154 MCO:SLP:WUP=-1
                          13158 MCO:SLP:MS=868,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13162 MCO:SLP:TPD
                          13164 MCO:SLP:WUP=-1
                          13168 MCO:SLP:MS=858,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13174 MCO:SLP:TPD
                          13176 MCO:SLP:WUP=-1
                          13178 MCO:SLP:MS=848,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13185 MCO:SLP:TPD
                          13187 MCO:SLP:WUP=-1
                          13189 MCO:SLP:MS=837,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13195 MCO:SLP:TPD
                          13197 MCO:SLP:WUP=-1
                          13199 MCO:SLP:MS=827,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13205 MCO:SLP:TPD
                          13207 MCO:SLP:WUP=-1
                          13211 MCO:SLP:MS=815,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13215 MCO:SLP:TPD
                          13217 MCO:SLP:WUP=-1
                          13221 MCO:SLP:MS=805,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13228 MCO:SLP:TPD
                          13230 MCO:SLP:WUP=-1
                          13232 MCO:SLP:MS=794,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13238 MCO:SLP:TPD
                          13240 MCO:SLP:WUP=-1
                          13242 MCO:SLP:MS=784,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13248 MCO:SLP:TPD
                          13250 MCO:SLP:WUP=-1
                          13252 MCO:SLP:MS=774,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13258 MCO:SLP:TPD
                          13260 MCO:SLP:WUP=-1
                          13264 MCO:SLP:MS=762,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13268 MCO:SLP:TPD
                          13271 MCO:SLP:WUP=-1
                          13275 MCO:SLP:MS=751,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13279 MCO:SLP:TPD
                          13283 MCO:SLP:WUP=-1
                          13285 MCO:SLP:MS=741,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13291 MCO:SLP:TPD
                          13293 MCO:SLP:WUP=-1
                          13295 MCO:SLP:MS=731,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13301 MCO:SLP:TPD
                          13303 MCO:SLP:WUP=-1
                          13305 MCO:SLP:MS=721,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13312 MCO:SLP:TPD
                          13314 MCO:SLP:WUP=-1
                          13318 MCO:SLP:MS=708,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13322 MCO:SLP:TPD
                          13324 MCO:SLP:WUP=-1
                          13328 MCO:SLP:MS=698,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13332 MCO:SLP:TPD
                          13336 MCO:SLP:WUP=-1
                          13338 MCO:SLP:MS=688,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13344 MCO:SLP:TPD
                          13346 MCO:SLP:WUP=-1
                          13348 MCO:SLP:MS=678,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13355 MCO:SLP:TPD
                          13357 MCO:SLP:WUP=-1
                          13359 MCO:SLP:MS=667,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13365 MCO:SLP:TPD
                          13367 MCO:SLP:WUP=-1
                          13371 MCO:SLP:MS=655,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13375 MCO:SLP:TPD
                          13377 MCO:SLP:WUP=-1
                          13381 MCO:SLP:MS=645,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13385 MCO:SLP:TPD
                          13389 MCO:SLP:WUP=-1
                          13391 MCO:SLP:MS=635,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13398 MCO:SLP:TPD
                          13400 MCO:SLP:WUP=-1
                          13402 MCO:SLP:MS=624,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13408 MCO:SLP:TPD
                          13410 MCO:SLP:WUP=-1
                          13412 MCO:SLP:MS=614,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13418 MCO:SLP:TPD
                          13420 MCO:SLP:WUP=-1
                          13424 MCO:SLP:MS=602,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13428 MCO:SLP:TPD
                          13430 MCO:SLP:WUP=-1
                          13434 MCO:SLP:MS=592,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13438 MCO:SLP:TPD
                          13441 MCO:SLP:WUP=-1
                          13445 MCO:SLP:MS=581,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13451 MCO:SLP:TPD
                          13453 MCO:SLP:WUP=-1
                          13455 MCO:SLP:MS=571,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13461 MCO:SLP:TPD
                          13463 MCO:SLP:WUP=-1
                          13465 MCO:SLP:MS=561,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13471 MCO:SLP:TPD
                          13473 MCO:SLP:WUP=-1
                          13475 MCO:SLP:MS=551,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13481 MCO:SLP:TPD
                          13484 MCO:SLP:WUP=-1
                          13488 MCO:SLP:MS=538,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13492 MCO:SLP:TPD
                          13494 MCO:SLP:WUP=-1
                          13498 MCO:SLP:MS=528,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13504 MCO:SLP:TPD
                          13506 MCO:SLP:WUP=-1
                          13508 MCO:SLP:MS=518,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13514 MCO:SLP:TPD
                          13516 MCO:SLP:WUP=-1
                          13518 MCO:SLP:MS=508,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13524 MCO:SLP:TPD
                          13527 MCO:SLP:WUP=-1
                          13529 MCO:SLP:MS=497,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13535 MCO:SLP:TPD
                          13537 MCO:SLP:WUP=-1
                          13541 MCO:SLP:MS=485,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13545 MCO:SLP:TPD
                          13547 MCO:SLP:WUP=-1
                          13551 MCO:SLP:MS=475,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13555 MCO:SLP:TPD
                          13559 MCO:SLP:WUP=-1
                          13561 MCO:SLP:MS=465,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13568 MCO:SLP:TPD
                          13570 MCO:SLP:WUP=-1
                          13572 MCO:SLP:MS=454,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13578 MCO:SLP:TPD
                          13580 MCO:SLP:WUP=-1
                          13582 MCO:SLP:MS=444,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13588 MCO:SLP:TPD
                          13590 MCO:SLP:WUP=-1
                          13594 MCO:SLP:MS=432,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13598 MCO:SLP:TPD
                          13600 MCO:SLP:WUP=-1
                          13604 MCO:SLP:MS=422,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13608 MCO:SLP:TPD
                          13613 MCO:SLP:WUP=-1
                          13615 MCO:SLP:MS=411,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13621 MCO:SLP:TPD
                          13623 MCO:SLP:WUP=-1
                          13625 MCO:SLP:MS=401,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13631 MCO:SLP:TPD
                          13633 MCO:SLP:WUP=-1
                          13635 MCO:SLP:MS=391,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13641 MCO:SLP:TPD
                          13643 MCO:SLP:WUP=-1
                          13647 MCO:SLP:MS=379,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13651 MCO:SLP:TPD
                          13654 MCO:SLP:WUP=-1
                          13658 MCO:SLP:MS=368,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13662 MCO:SLP:TPD
                          13664 MCO:SLP:WUP=-1
                          13668 MCO:SLP:MS=358,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13674 MCO:SLP:TPD
                          13676 MCO:SLP:WUP=-1
                          13678 MCO:SLP:MS=348,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13684 MCO:SLP:TPD
                          13686 MCO:SLP:WUP=-1
                          13688 MCO:SLP:MS=338,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13694 MCO:SLP:TPD
                          13697 MCO:SLP:WUP=-1
                          13699 MCO:SLP:MS=327,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13705 MCO:SLP:TPD
                          13707 MCO:SLP:WUP=-1
                          13711 MCO:SLP:MS=315,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13715 MCO:SLP:TPD
                          13717 MCO:SLP:WUP=-1
                          13721 MCO:SLP:MS=305,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13727 MCO:SLP:TPD
                          13729 MCO:SLP:WUP=-1
                          13731 MCO:SLP:MS=295,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13737 MCO:SLP:TPD
                          13740 MCO:SLP:WUP=-1
                          13742 MCO:SLP:MS=284,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13748 MCO:SLP:TPD
                          13750 MCO:SLP:WUP=-1
                          13752 MCO:SLP:MS=274,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13758 MCO:SLP:TPD
                          13760 MCO:SLP:WUP=-1
                          13764 MCO:SLP:MS=262,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13768 MCO:SLP:TPD
                          13770 MCO:SLP:WUP=-1
                          13774 MCO:SLP:MS=252,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13778 MCO:SLP:TPD
                          13783 MCO:SLP:WUP=-1
                          13785 MCO:SLP:MS=241,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13791 MCO:SLP:TPD
                          13793 MCO:SLP:WUP=-1
                          13795 MCO:SLP:MS=231,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13801 MCO:SLP:TPD
                          13803 MCO:SLP:WUP=-1
                          13805 MCO:SLP:MS=221,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13811 MCO:SLP:TPD
                          13813 MCO:SLP:WUP=-1
                          13817 MCO:SLP:MS=209,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13821 MCO:SLP:TPD
                          13824 MCO:SLP:WUP=-1
                          13828 MCO:SLP:MS=198,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13832 MCO:SLP:TPD
                          13836 MCO:SLP:WUP=-1
                          13838 MCO:SLP:MS=188,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13844 MCO:SLP:TPD
                          13846 MCO:SLP:WUP=-1
                          13848 MCO:SLP:MS=178,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13854 MCO:SLP:TPD
                          13856 MCO:SLP:WUP=-1
                          13858 MCO:SLP:MS=168,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13864 MCO:SLP:TPD
                          13867 MCO:SLP:WUP=-1
                          13869 MCO:SLP:MS=157,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13875 MCO:SLP:TPD
                          13877 MCO:SLP:WUP=-1
                          13881 MCO:SLP:MS=145,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13885 MCO:SLP:TPD
                          13887 MCO:SLP:WUP=-1
                          13891 MCO:SLP:MS=135,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13895 MCO:SLP:TPD
                          13899 MCO:SLP:WUP=-1
                          13901 MCO:SLP:MS=125,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13907 MCO:SLP:TPD
                          13910 MCO:SLP:WUP=-1
                          13912 MCO:SLP:MS=114,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13918 MCO:SLP:TPD
                          13920 MCO:SLP:WUP=-1
                          13922 MCO:SLP:MS=104,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13928 MCO:SLP:TPD
                          13930 MCO:SLP:WUP=-1
                          13932 MCO:SLP:MS=94,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13938 MCO:SLP:TPD
                          13940 MCO:SLP:WUP=-1
                          13944 MCO:SLP:MS=82,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13948 MCO:SLP:TPD
                          13950 MCO:SLP:WUP=-1
                          13955 MCO:SLP:MS=71,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13959 MCO:SLP:TPD
                          13961 MCO:SLP:WUP=-1
                          13965 MCO:SLP:MS=61,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13969 MCO:SLP:TPD
                          13971 MCO:SLP:WUP=-1
                          13975 MCO:SLP:MS=51,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13979 MCO:SLP:TPD
                          13983 MCO:SLP:WUP=-1
                          13985 MCO:SLP:MS=41,SMS=0,I1=1,M1=1,I2=255,M2=255
                          13991 MCO:SLP:TPD
                          13993 MCO:SLP:WUP=-1
                          13996 MCO:SLP:MS=30,SMS=0,I1=1,M1=1,I2=255,M2=255
                          14002 MCO:SLP:TPD
                          14004 MCO:SLP:WUP=-1
                          14006 MCO:SLP:MS=20,SMS=0,I1=1,M1=1,I2=255,M2=255
                          14012 MCO:SLP:TPD
                          14014 MCO:SLP:WUP=-1
                          14016 MCO:SLP:MS=10,SMS=0,I1=1,M1=1,I2=255,M2=255
                          14022 MCO:SLP:TPD
                          14024 MCO:SLP:WUP=-1
                          14026 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                          14032 MCO:SLP:TPD
                          I'm sorry for asking for help again @core_c but I have no idea what I'm doing wrong....
                          • E esawyja
                            4 TSM:INIT
                            4 TSF:WUR:MS=1000
                            8 TSM:INIT:TSP OK
                            12 TSF:SID:OK,ID=11
                            14 TSM:FPAR
                            1007 MCO:BGN:STP
                            2152 TSM:FPAR:OK
                            2152 TSM:ID
                            2154 TSM:ID:OK
                            2156 TSM:UPL
                            2224 TSM:UPL:OK
                            4327 MCO:REG:REQ
                            11036 MCO:SLP:TPD
                            11046 MCO:SLP:TPD
                            11059 MCO:SLP:TPD
                            11069 MCO:SLP:TPD
                            11079 MCO:SLP:TPD
                            11089 MCO:SLP:TPD
                            11102 MCO:SLP:TPD
                            11112 MCO:SLP:TPD
                            11122 MCO:SLP:TPD
                            11134 MCO:SLP:TPD
                            11145 MCO:SLP:TPD
                            11155 MCO:SLP:TPD
                            11165 MCO:SLP:TPD
                            11177 MCO:SLP:TPD
                            11188 MCO:SLP:TPD
                            11198 MCO:SLP:TPD
                            11208 MCO:SLP:TPD
                            11220 MCO:SLP:TPD
                            11231 MCO:SLP:TPD
                            11241 MCO:SLP:TPD
                            11251 MCO:SLP:TPD
                            11264 MCO:SLP:TPD
                            11274 MCO:SLP:TPD
                            11284 MCO:SLP:TPD
                            11294 MCO:SLP:TPD
                            11307 MCO:SLP:TPD
                            11317 MCO:SLP:TPD
                            11327 MCO:SLP:TPD
                            11339 MCO:SLP:TPD
                            11350 MCO:SLP:TPD
                            11360 MCO:SLP:TPD
                            11370 MCO:SLP:TPD
                            11382 MCO:SLP:TPD
                            11393 MCO:SLP:TPD
                            11403 MCO:SLP:TPD
                            11413 MCO:SLP:TPD
                            11425 MCO:SLP:TPD
                            11436 MCO:SLP:TPD
                            11446 MCO:SLP:TPD
                            11456 MCO:SLP:TPD
                            11468 MCO:SLP:TPD
                            11479 MCO:SLP:TPD
                            11489 MCO:SLP:TPD
                            11499 MCO:SLP:TPD
                            11511 MCO:SLP:TPD
                            11522 MCO:SLP:TPD
                            11532 MCO:SLP:TPD
                            11542 MCO:SLP:TPD
                            11554 MCO:SLP:TPD
                            11565 MCO:SLP:TPD
                            11575 MCO:SLP:TPD
                            11585 MCO:SLP:TPD
                            11597 MCO:SLP:TPD
                            11608 MCO:SLP:TPD
                            11618 MCO:SLP:TPD
                            11628 MCO:SLP:TPD
                            11640 MCO:SLP:TPD
                            11651 MCO:SLP:TPD
                            11661 MCO:SLP:TPD
                            11671 MCO:SLP:TPD
                            11683 MCO:SLP:TPD
                            11694 MCO:SLP:TPD
                            11704 MCO:SLP:TPD
                            11714 MCO:SLP:TPD
                            11726 MCO:SLP:TPD
                            11737 MCO:SLP:TPD
                            11747 MCO:SLP:TPD
                            11757 MCO:SLP:TPD
                            11769 MCO:SLP:TPD
                            11780 MCO:SLP:TPD
                            11790 MCO:SLP:TPD
                            11800 MCO:SLP:TPD
                            11812 MCO:SLP:TPD
                            11823 MCO:SLP:TPD
                            11833 MCO:SLP:TPD
                            11843 MCO:SLP:TPD
                            11855 MCO:SLP:TPD
                            11866 MCO:SLP:TPD
                            11876 MCO:SLP:TPD
                            11886 MCO:SLP:TPD
                            11898 MCO:SLP:TPD
                            11909 MCO:SLP:TPD
                            11919 MCO:SLP:TPD
                            11929 MCO:SLP:TPD
                            11939 MCO:SLP:TPD
                            11952 MCO:SLP:TPD
                            11962 MCO:SLP:TPD
                            11972 MCO:SLP:TPD
                            11982 MCO:SLP:TPD
                            11995 MCO:SLP:TPD
                            12005 MCO:SLP:TPD
                            12015 MCO:SLP:TPD
                            12025 MCO:SLP:TPD
                            12036 MCO:SLP:TPD
                            12048 MCO:SLP:TPD
                            12058 MCO:SLP:TPD
                            12068 MCO:SLP:TPD
                            12079 MCO:SLP:TPD
                            12091 MCO:SLP:TPD
                            12101 MCO:SLP:TPD
                            12111 MCO:SLP:TPD
                            12122 MCO:SLP:TPD
                            12134 MCO:SLP:TPD
                            12144 MCO:SLP:TPD
                            12154 MCO:SLP:TPD
                            12165 MCO:SLP:TPD
                            12177 MCO:SLP:TPD
                            12187 MCO:SLP:TPD
                            12197 MCO:SLP:TPD
                            12208 MCO:SLP:TPD
                            12220 MCO:SLP:TPD
                            12230 MCO:SLP:TPD
                            12240 MCO:SLP:TPD
                            12251 MCO:SLP:TPD
                            12263 MCO:SLP:TPD
                            12273 MCO:SLP:TPD
                            12283 MCO:SLP:TPD
                            12294 MCO:SLP:TPD
                            12306 MCO:SLP:TPD
                            12316 MCO:SLP:TPD
                            12326 MCO:SLP:TPD
                            12337 MCO:SLP:TPD
                            12349 MCO:SLP:TPD
                            12359 MCO:SLP:TPD
                            12369 MCO:SLP:TPD
                            12380 MCO:SLP:TPD
                            12390 MCO:SLP:TPD
                            12402 MCO:SLP:TPD
                            12412 MCO:SLP:TPD
                            12423 MCO:SLP:TPD
                            12433 MCO:SLP:TPD
                            12445 MCO:SLP:TPD
                            12455 MCO:SLP:TPD
                            12466 MCO:SLP:TPD
                            12476 MCO:SLP:TPD
                            12488 MCO:SLP:TPD
                            12498 MCO:SLP:TPD
                            12509 MCO:SLP:TPD
                            12519 MCO:SLP:TPD
                            12531 MCO:SLP:TPD
                            12541 MCO:SLP:TPD
                            12552 MCO:SLP:TPD
                            12562 MCO:SLP:TPD
                            12574 MCO:SLP:TPD
                            12584 MCO:SLP:TPD
                            12595 MCO:SLP:TPD
                            12605 MCO:SLP:TPD
                            12617 MCO:SLP:TPD
                            12627 MCO:SLP:TPD
                            12638 MCO:SLP:TPD
                            12648 MCO:SLP:TPD
                            12658 MCO:SLP:TPD
                            12670 MCO:SLP:TPD
                            12681 MCO:SLP:TPD
                            12691 MCO:SLP:TPD
                            12701 MCO:SLP:TPD
                            12713 MCO:SLP:TPD
                            12724 MCO:SLP:TPD
                            12734 MCO:SLP:TPD
                            12744 MCO:SLP:TPD
                            12756 MCO:SLP:TPD
                            12767 MCO:SLP:TPD
                            12777 MCO:SLP:TPD
                            12787 MCO:SLP:TPD
                            12800 MCO:SLP:TPD
                            12810 MCO:SLP:TPD
                            12820 MCO:SLP:TPD
                            12830 MCO:SLP:TPD
                            12843 MCO:SLP:TPD
                            12853 MCO:SLP:TPD
                            12863 MCO:SLP:TPD
                            12873 MCO:SLP:TPD
                            12886 MCO:SLP:TPD
                            12896 MCO:SLP:TPD
                            12906 MCO:SLP:TPD
                            12916 MCO:SLP:TPD
                            12929 MCO:SLP:TPD
                            12939 MCO:SLP:TPD
                            12949 MCO:SLP:TPD
                            12959 MCO:SLP:TPD
                            12972 MCO:SLP:TPD
                            12982 MCO:SLP:TPD
                            12992 MCO:SLP:TPD
                            13002 MCO:SLP:TPD
                            13015 MCO:SLP:TPD
                            13025 MCO:SLP:TPD
                            13035 MCO:SLP:TPD
                            13045 MCO:SLP:TPD
                            13056 MCO:SLP:TPD
                            13068 MCO:SLP:TPD
                            13078 MCO:SLP:TPD
                            13088 MCO:SLP:TPD
                            13099 MCO:SLP:TPD
                            13109 MCO:SLP:TPD
                            13121 MCO:SLP:TPD
                            13131 MCO:SLP:TPD
                            13142 MCO:SLP:TPD
                            13152 MCO:SLP:TPD
                            13162 MCO:SLP:TPD
                            13174 MCO:SLP:TPD
                            13185 MCO:SLP:TPD
                            13195 MCO:SLP:TPD
                            13205 MCO:SLP:TPD
                            13215 MCO:SLP:TPD
                            13228 MCO:SLP:TPD
                            13238 MCO:SLP:TPD
                            13248 MCO:SLP:TPD
                            13258 MCO:SLP:TPD
                            13268 MCO:SLP:TPD
                            13279 MCO:SLP:TPD
                            13291 MCO:SLP:TPD
                            13301 MCO:SLP:TPD
                            13312 MCO:SLP:TPD
                            13322 MCO:SLP:TPD
                            13332 MCO:SLP:TPD
                            13344 MCO:SLP:TPD
                            13355 MCO:SLP:TPD
                            13365 MCO:SLP:TPD
                            13375 MCO:SLP:TPD
                            13385 MCO:SLP:TPD
                            13398 MCO:SLP:TPD
                            13408 MCO:SLP:TPD
                            13418 MCO:SLP:TPD
                            13428 MCO:SLP:TPD
                            13438 MCO:SLP:TPD
                            13451 MCO:SLP:TPD
                            13461 MCO:SLP:TPD
                            13471 MCO:SLP:TPD
                            13481 MCO:SLP:TPD
                            13492 MCO:SLP:TPD
                            13504 MCO:SLP:TPD
                            13514 MCO:SLP:TPD
                            13524 MCO:SLP:TPD
                            13535 MCO:SLP:TPD
                            13545 MCO:SLP:TPD
                            13555 MCO:SLP:TPD
                            13568 MCO:SLP:TPD
                            13578 MCO:SLP:TPD
                            13588 MCO:SLP:TPD
                            13598 MCO:SLP:TPD
                            13608 MCO:SLP:TPD
                            13621 MCO:SLP:TPD
                            13631 MCO:SLP:TPD
                            13641 MCO:SLP:TPD
                            13651 MCO:SLP:TPD
                            13662 MCO:SLP:TPD
                            13674 MCO:SLP:TPD
                            13684 MCO:SLP:TPD
                            13694 MCO:SLP:TPD
                            13705 MCO:SLP:TPD
                            13715 MCO:SLP:TPD
                            13727 MCO:SLP:TPD
                            13737 MCO:SLP:TPD
                            13748 MCO:SLP:TPD
                            13758 MCO:SLP:TPD
                            13768 MCO:SLP:TPD
                            13778 MCO:SLP:TPD
                            13791 MCO:SLP:TPD
                            13801 MCO:SLP:TPD
                            13811 MCO:SLP:TPD
                            13821 MCO:SLP:TPD
                            13832 MCO:SLP:TPD
                            13844 MCO:SLP:TPD
                            13854 MCO:SLP:TPD
                            13864 MCO:SLP:TPD
                            13875 MCO:SLP:TPD
                            13885 MCO:SLP:TPD
                            13895 MCO:SLP:TPD
                            13907 MCO:SLP:TPD
                            13918 MCO:SLP:TPD
                            13928 MCO:SLP:TPD
                            13938 MCO:SLP:TPD
                            13948 MCO:SLP:TPD
                            13959 MCO:SLP:TPD
                            13969 MCO:SLP:TPD
                            13979 MCO:SLP:TPD
                            13991 MCO:SLP:TPD
                            14002 MCO:SLP:TPD
                            14012 MCO:SLP:TPD
                            14022 MCO:SLP:TPD
                            14032 MCO:SLP:TPD
                            E
                            E
                            esawyja
                            @core_c correction, after I typed and posted this, the serial log started again and it did send the message, this is weird
                            14032 MCO:SLP:TPD
                            14034 MCO:SLP:WUP=1
                            14047 TSF:MSG:SEND,11-11-0-0,s=7,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:0.85
                            14055 MCO:SLP:MS=3000,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14059 MCO:SLP:TPD
                            14061 MCO:SLP:WUP=-1
                            14065 MCO:SLP:MS=2990,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14071 MCO:SLP:TPD
                            14073 MCO:SLP:WUP=-1
                            14075 MCO:SLP:MS=2980,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14082 MCO:SLP:TPD
                            14084 MCO:SLP:WUP=-1
                            14086 MCO:SLP:MS=2969,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14092 MCO:SLP:TPD
                            14094 MCO:SLP:WUP=-1
                            14098 MCO:SLP:MS=2957,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14102 MCO:SLP:TPD
                            14104 MCO:SLP:WUP=-1
                            14108 MCO:SLP:MS=2947,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14114 MCO:SLP:TPD
                            14116 MCO:SLP:WUP=-1
                            14118 MCO:SLP:MS=2937,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14125 MCO:SLP:TPD
                            14127 MCO:SLP:WUP=-1
                            14129 MCO:SLP:MS=2926,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14135 MCO:SLP:TPD
                            14137 MCO:SLP:WUP=-1
                            14141 MCO:SLP:MS=2914,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14145 MCO:SLP:TPD
                            14147 MCO:SLP:WUP=-1
                            14151 MCO:SLP:MS=2904,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14157 MCO:SLP:TPD
                            14159 MCO:SLP:WUP=-1
                            14161 MCO:SLP:MS=2894,SMS=0,I1=1,M1=1,I2=255,M2=255
                            14168 MCO:SLP:TPD
