  3. Message is send twice
27 Posts 4 Posters 7.0k Views 4 Watching
  • core_cC core_c
    @esawyja You are right. I made a mistake. This should fix it:
    Change this line:
    uint32_t sleep_time_left = battery_report_time - millis();
    into this:
    long sleep_time_left = battery_report_time - millis();
    A variable of type long can hold a negative number, but an unsigned long (same as uint32_t) can never hold a negative number (because it is unsigned, no sign, no minus sign, no negative).
    So, if (sleep_time_left < 0) will never be true.. That was the mistake.
    I was also wondering if the generator would produce interrupts without using attachInterrupt().
    Without that, you can still poll the generator pin, and see if the value changed (what is happening now), but the sleep() cycle would not be interrupted when the pin changed.
    To be on the safe side, i would also add the following to your code:
      attachInterrupt(digitalPinToInterrupt(GENERATOR_PIN), generator_pin_interrupt_handler, CHANGE);
    Hopefully that'll make it work as intended.
    E
    E
    esawyja
    wrote on last edited by esawyja
    @core_c Thanks for that
    I had to change the battery reading routine to this below, else when it gets to the routine, it stays there and never get back to the loop, I hope it makes sense
    void read_batt() {
      wait(15000);
      float batteryV = sensorValue * volt_value;
      send(batt_msg.set(batteryV,2));
      battery_report_time = millis() + BATTERY_REPORT_INTERVAL;
      sleep_time_left = BATTERY_REPORT_INTERVAL;
      return;
    If I add this to setup, I get the following error
      Serial.print("Battery report time is = ");
      Serial.println(battery_report_time);
    gen_run_sketch:54: error: 'generator_pin_interrupt_handler' was not declared in this scope
    exit status 1
    core_cC 1 Reply Last reply
    • E esawyja
      void read_batt() {
        wait(15000);
        return;
      exit status 1
      core_cC
      core_cC
      core_c
      @esawyja attachInterrupt() should only be done once, in the setup() function.
      E 1 Reply Last reply
      • core_cC core_c
        E
        E
        esawyja
        @core_c I'm sorry I do not understand, must I replace this in loop
        sleep(digitalPinToInterrupt(GENERATOR_PIN), CHANGE, sleep_time_left);
        With this in setup?
        Sorry for all the questions!! This is sooo confusing to me, it also seems that the battery level is not sending, I left it running for 12 hours plus and never got a reading, the line
        #define BATTERY_REPORT_INTERVAL 60000
        Does this define that the battery level must be send ever 60000 milli seconds?
          If it is a battery powered node you need to use the sleep function to put the node into low power mode.
          • E esawyja
            With this in setup?
            core_cC
            core_cC
            core_c
            @esawyja i made the changes for you in my post made earlier^^
            • core_cC core_c
              E
              E
              esawyja
              @core_c Thanks so much, I will try these changes!
              • core_cC
                core_cC
                core_c
                About your battery level send question, here's some explanation:
                The intention is to let your node sleep when nothing happens.
                Only when the generator pin changes, it interrupts the sleep cycle, and wakes up the node. It then checks the current generator pin state and sends the appropriate message. Then it goes to sleep again.
                However, it does not sleep forever. At regular intervals the battery level is send. So every BATTERY_REPORT_INTERVAL milliseconds the current sleep cycle ends (because the timer has counted down and reached its end), and the battery level is send.
                The program keeps doing this: Sleep, and wake up if the pin changed, and/or wake up when the battery level should be send.
                E 2 Replies Last reply
                • core_cC core_c
                  E
                  E
                  esawyja
                  @core_c Thanks, I will try all the changes, thanks again for the code!!
                  • core_cC core_c
                    E
                    E
                    esawyja
                    @core_c I'm still having problems with this, the generator running or not works a treat, but if I just reboot the node and leave it, it goes through the sleep from what I can see, but then nothing happens after that, it does not send the battery level, it just hangs. Also the #define BATTERY_REPORT_INTERVAL 3000 does not work correctly, I've set it to 3000 as a test and it definitely took longer than 3000 MS, the complete serial log is pasted below, I did not trigger the generator during this period
                    4 TSM:INIT
                    4 TSF:WUR:MS=1000
                    8 TSM:INIT:TSP OK
                    10 TSM:INIT:STATID=11
                    12 TSF:SID:OK,ID=11
                    14 TSM:FPAR
                    145 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    395 TSF:MSG:READ,0-0-11,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    401 TSF:MSG:FPAR OK,ID=0,D=1
                    1007 MCO:BGN:STP
                    1007 !MCO:SND:NODE NOT REG
                    2152 TSM:FPAR:OK
                    2152 TSM:ID
                    2154 TSM:ID:OK
                    2156 TSM:UPL
                    2164 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2215 TSF:MSG:READ,0-0-11,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2222 TSF:MSG:PONG RECV,HP=1
                    2224 TSM:UPL:OK
                    2226 TSM:READY:ID=11,PAR=0,DIS=1
                    2238 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2289 TSF:MSG:READ,0-0-11,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2304 TSF:MSG:SEND,11-11-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                    2320 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    4327 MCO:REG:REQ
                    4335 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    4386 TSF:MSG:READ,0-0-11,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    4392 MCO:PIM:NODE REG=1
                    11018 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                    Generator message sent
                    11026 MCO:BGN:INIT OK,TSP=1
                    11030 MCO:SLP:MS=2996,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11036 MCO:SLP:TPD
                    11038 MCO:SLP:WUP=-1
                    11042 MCO:SLP:MS=2984,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11046 MCO:SLP:TPD
                    11051 MCO:SLP:WUP=-1
                    11053 MCO:SLP:MS=2973,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11059 MCO:SLP:TPD
                    11061 MCO:SLP:WUP=-1
                    11063 MCO:SLP:MS=2963,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11069 MCO:SLP:TPD
                    11071 MCO:SLP:WUP=-1
                    11073 MCO:SLP:MS=2953,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11079 MCO:SLP:TPD
                    11081 MCO:SLP:WUP=-1
                    11085 MCO:SLP:MS=2941,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11089 MCO:SLP:TPD
                    11094 MCO:SLP:WUP=-1
                    11096 MCO:SLP:MS=2930,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11102 MCO:SLP:TPD
                    11104 MCO:SLP:WUP=-1
                    11106 MCO:SLP:MS=2920,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11112 MCO:SLP:TPD
                    11114 MCO:SLP:WUP=-1
                    11118 MCO:SLP:MS=2908,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11122 MCO:SLP:TPD
                    11124 MCO:SLP:WUP=-1
                    11128 MCO:SLP:MS=2898,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11134 MCO:SLP:TPD
                    11137 MCO:SLP:WUP=-1
                    11139 MCO:SLP:MS=2887,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11145 MCO:SLP:TPD
                    11147 MCO:SLP:WUP=-1
                    11149 MCO:SLP:MS=2877,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11155 MCO:SLP:TPD
                    11157 MCO:SLP:WUP=-1
                    11161 MCO:SLP:MS=2865,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11165 MCO:SLP:TPD
                    11167 MCO:SLP:WUP=-1
                    11171 MCO:SLP:MS=2855,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11177 MCO:SLP:TPD
                    11180 MCO:SLP:WUP=-1
                    11182 MCO:SLP:MS=2844,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11188 MCO:SLP:TPD
                    11190 MCO:SLP:WUP=-1
                    11192 MCO:SLP:MS=2834,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11198 MCO:SLP:TPD
                    11200 MCO:SLP:WUP=-1
                    11204 MCO:SLP:MS=2822,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11208 MCO:SLP:TPD
                    11212 MCO:SLP:WUP=-1
                    11214 MCO:SLP:MS=2812,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11220 MCO:SLP:TPD
                    11223 MCO:SLP:WUP=-1
                    11225 MCO:SLP:MS=2801,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11231 MCO:SLP:TPD
                    11233 MCO:SLP:WUP=-1
                    11235 MCO:SLP:MS=2791,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11241 MCO:SLP:TPD
                    11243 MCO:SLP:WUP=-1
                    11247 MCO:SLP:MS=2779,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11251 MCO:SLP:TPD
                    11255 MCO:SLP:WUP=-1
                    11257 MCO:SLP:MS=2769,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11264 MCO:SLP:TPD
                    11266 MCO:SLP:WUP=-1
                    11268 MCO:SLP:MS=2758,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11274 MCO:SLP:TPD
                    11276 MCO:SLP:WUP=-1
                    11278 MCO:SLP:MS=2748,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11284 MCO:SLP:TPD
                    11286 MCO:SLP:WUP=-1
                    11290 MCO:SLP:MS=2736,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11294 MCO:SLP:TPD
                    11298 MCO:SLP:WUP=-1
                    11300 MCO:SLP:MS=2726,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11307 MCO:SLP:TPD
                    11309 MCO:SLP:WUP=-1
                    11311 MCO:SLP:MS=2715,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11317 MCO:SLP:TPD
                    11319 MCO:SLP:WUP=-1
                    11323 MCO:SLP:MS=2703,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11327 MCO:SLP:TPD
                    11329 MCO:SLP:WUP=-1
                    11333 MCO:SLP:MS=2693,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11339 MCO:SLP:TPD
                    11341 MCO:SLP:WUP=-1
                    11343 MCO:SLP:MS=2683,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11350 MCO:SLP:TPD
                    11352 MCO:SLP:WUP=-1
                    11354 MCO:SLP:MS=2672,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11360 MCO:SLP:TPD
                    11362 MCO:SLP:WUP=-1
                    11366 MCO:SLP:MS=2660,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11370 MCO:SLP:TPD
                    11372 MCO:SLP:WUP=-1
                    11376 MCO:SLP:MS=2650,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11382 MCO:SLP:TPD
                    11384 MCO:SLP:WUP=-1
                    11386 MCO:SLP:MS=2640,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11393 MCO:SLP:TPD
                    11395 MCO:SLP:WUP=-1
                    11397 MCO:SLP:MS=2629,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11403 MCO:SLP:TPD
                    11405 MCO:SLP:WUP=-1
                    11409 MCO:SLP:MS=2617,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11413 MCO:SLP:TPD
                    11415 MCO:SLP:WUP=-1
                    11419 MCO:SLP:MS=2607,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11425 MCO:SLP:TPD
                    11427 MCO:SLP:WUP=-1
                    11429 MCO:SLP:MS=2597,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11436 MCO:SLP:TPD
                    11438 MCO:SLP:WUP=-1
                    11440 MCO:SLP:MS=2586,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11446 MCO:SLP:TPD
                    11448 MCO:SLP:WUP=-1
                    11452 MCO:SLP:MS=2574,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11456 MCO:SLP:TPD
                    11458 MCO:SLP:WUP=-1
                    11462 MCO:SLP:MS=2564,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11468 MCO:SLP:TPD
                    11470 MCO:SLP:WUP=-1
                    11472 MCO:SLP:MS=2554,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11479 MCO:SLP:TPD
                    11481 MCO:SLP:WUP=-1
                    11483 MCO:SLP:MS=2543,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11489 MCO:SLP:TPD
                    11491 MCO:SLP:WUP=-1
                    11495 MCO:SLP:MS=2531,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11499 MCO:SLP:TPD
                    11503 MCO:SLP:WUP=-1
                    11505 MCO:SLP:MS=2521,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11511 MCO:SLP:TPD
                    11513 MCO:SLP:WUP=-1
                    11515 MCO:SLP:MS=2511,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11522 MCO:SLP:TPD
                    11524 MCO:SLP:WUP=-1
                    11526 MCO:SLP:MS=2500,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11532 MCO:SLP:TPD
                    11534 MCO:SLP:WUP=-1
                    11538 MCO:SLP:MS=2488,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11542 MCO:SLP:TPD
                    11544 MCO:SLP:WUP=-1
                    11548 MCO:SLP:MS=2478,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11554 MCO:SLP:TPD
                    11556 MCO:SLP:WUP=-1
                    11558 MCO:SLP:MS=2468,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11565 MCO:SLP:TPD
                    11567 MCO:SLP:WUP=-1
                    11569 MCO:SLP:MS=2457,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11575 MCO:SLP:TPD
                    11577 MCO:SLP:WUP=-1
                    11581 MCO:SLP:MS=2445,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11585 MCO:SLP:TPD
                    11589 MCO:SLP:WUP=-1
                    11591 MCO:SLP:MS=2435,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11597 MCO:SLP:TPD
                    11599 MCO:SLP:WUP=-1
                    11601 MCO:SLP:MS=2425,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11608 MCO:SLP:TPD
                    11610 MCO:SLP:WUP=-1
                    11612 MCO:SLP:MS=2414,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11618 MCO:SLP:TPD
                    11620 MCO:SLP:WUP=-1
                    11624 MCO:SLP:MS=2402,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11628 MCO:SLP:TPD
                    11632 MCO:SLP:WUP=-1
                    11634 MCO:SLP:MS=2392,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11640 MCO:SLP:TPD
                    11642 MCO:SLP:WUP=-1
                    11644 MCO:SLP:MS=2382,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11651 MCO:SLP:TPD
                    11653 MCO:SLP:WUP=-1
                    11655 MCO:SLP:MS=2371,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11661 MCO:SLP:TPD
                    11663 MCO:SLP:WUP=-1
                    11667 MCO:SLP:MS=2359,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11671 MCO:SLP:TPD
                    11675 MCO:SLP:WUP=-1
                    11677 MCO:SLP:MS=2349,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11683 MCO:SLP:TPD
                    11685 MCO:SLP:WUP=-1
                    11687 MCO:SLP:MS=2339,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11694 MCO:SLP:TPD
                    11696 MCO:SLP:WUP=-1
                    11698 MCO:SLP:MS=2328,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11704 MCO:SLP:TPD
                    11706 MCO:SLP:WUP=-1
                    11710 MCO:SLP:MS=2316,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11714 MCO:SLP:TPD
                    11716 MCO:SLP:WUP=-1
                    11720 MCO:SLP:MS=2306,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11726 MCO:SLP:TPD
                    11728 MCO:SLP:WUP=-1
                    11730 MCO:SLP:MS=2296,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11737 MCO:SLP:TPD
                    11739 MCO:SLP:WUP=-1
                    11741 MCO:SLP:MS=2285,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11747 MCO:SLP:TPD
                    11749 MCO:SLP:WUP=-1
                    11753 MCO:SLP:MS=2273,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11757 MCO:SLP:TPD
                    11759 MCO:SLP:WUP=-1
                    11763 MCO:SLP:MS=2263,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11769 MCO:SLP:TPD
                    11771 MCO:SLP:WUP=-1
                    11773 MCO:SLP:MS=2253,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11780 MCO:SLP:TPD
                    11782 MCO:SLP:WUP=-1
                    11784 MCO:SLP:MS=2242,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11790 MCO:SLP:TPD
                    11792 MCO:SLP:WUP=-1
                    11796 MCO:SLP:MS=2230,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11800 MCO:SLP:TPD
                    11802 MCO:SLP:WUP=-1
                    11806 MCO:SLP:MS=2220,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11812 MCO:SLP:TPD
                    11814 MCO:SLP:WUP=-1
                    11816 MCO:SLP:MS=2210,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11823 MCO:SLP:TPD
                    11825 MCO:SLP:WUP=-1
                    11827 MCO:SLP:MS=2199,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11833 MCO:SLP:TPD
                    11835 MCO:SLP:WUP=-1
                    11839 MCO:SLP:MS=2187,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11843 MCO:SLP:TPD
                    11845 MCO:SLP:WUP=-1
                    11849 MCO:SLP:MS=2177,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11855 MCO:SLP:TPD
                    11857 MCO:SLP:WUP=-1
                    11859 MCO:SLP:MS=2167,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11866 MCO:SLP:TPD
                    11868 MCO:SLP:WUP=-1
                    11870 MCO:SLP:MS=2156,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11876 MCO:SLP:TPD
                    11878 MCO:SLP:WUP=-1
                    11882 MCO:SLP:MS=2146,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11886 MCO:SLP:TPD
                    11888 MCO:SLP:WUP=-1
                    11892 MCO:SLP:MS=2134,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11898 MCO:SLP:TPD
                    11900 MCO:SLP:WUP=-1
                    11902 MCO:SLP:MS=2124,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11909 MCO:SLP:TPD
                    11911 MCO:SLP:WUP=-1
                    11913 MCO:SLP:MS=2113,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11919 MCO:SLP:TPD
                    11921 MCO:SLP:WUP=-1
                    11923 MCO:SLP:MS=2103,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11929 MCO:SLP:TPD
                    11931 MCO:SLP:WUP=-1
                    11935 MCO:SLP:MS=2091,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11939 MCO:SLP:TPD
                    11943 MCO:SLP:WUP=-1
                    11945 MCO:SLP:MS=2081,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11952 MCO:SLP:TPD
                    11954 MCO:SLP:WUP=-1
                    11956 MCO:SLP:MS=2070,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11962 MCO:SLP:TPD
                    11964 MCO:SLP:WUP=-1
                    11966 MCO:SLP:MS=2060,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11972 MCO:SLP:TPD
                    11974 MCO:SLP:WUP=-1
                    11978 MCO:SLP:MS=2048,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11982 MCO:SLP:TPD
                    11984 MCO:SLP:WUP=-1
                    11988 MCO:SLP:MS=2038,SMS=0,I1=1,M1=1,I2=255,M2=255
                    11995 MCO:SLP:TPD
                    11997 MCO:SLP:WUP=-1
                    11999 MCO:SLP:MS=2027,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12005 MCO:SLP:TPD
                    12007 MCO:SLP:WUP=-1
                    12009 MCO:SLP:MS=2017,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12015 MCO:SLP:TPD
                    12017 MCO:SLP:WUP=-1
                    12019 MCO:SLP:MS=2007,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12025 MCO:SLP:TPD
                    12027 MCO:SLP:WUP=-1
                    12032 MCO:SLP:MS=1994,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12036 MCO:SLP:TPD
                    12040 MCO:SLP:WUP=-1
                    12042 MCO:SLP:MS=1984,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12048 MCO:SLP:TPD
                    12050 MCO:SLP:WUP=-1
                    12052 MCO:SLP:MS=1974,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12058 MCO:SLP:TPD
                    12060 MCO:SLP:WUP=-1
                    12062 MCO:SLP:MS=1964,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12068 MCO:SLP:TPD
                    12070 MCO:SLP:WUP=-1
                    12075 MCO:SLP:MS=1951,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12079 MCO:SLP:TPD
                    12083 MCO:SLP:WUP=-1
                    12085 MCO:SLP:MS=1941,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12091 MCO:SLP:TPD
                    12093 MCO:SLP:WUP=-1
                    12095 MCO:SLP:MS=1931,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12101 MCO:SLP:TPD
                    12103 MCO:SLP:WUP=-1
                    12105 MCO:SLP:MS=1921,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12111 MCO:SLP:TPD
                    12113 MCO:SLP:WUP=-1
                    12118 MCO:SLP:MS=1908,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12122 MCO:SLP:TPD
                    12126 MCO:SLP:WUP=-1
                    12128 MCO:SLP:MS=1898,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12134 MCO:SLP:TPD
                    12136 MCO:SLP:WUP=-1
                    12138 MCO:SLP:MS=1888,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12144 MCO:SLP:TPD
                    12146 MCO:SLP:WUP=-1
                    12148 MCO:SLP:MS=1878,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12154 MCO:SLP:TPD
                    12156 MCO:SLP:WUP=-1
                    12161 MCO:SLP:MS=1865,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12165 MCO:SLP:TPD
                    12169 MCO:SLP:WUP=-1
                    12171 MCO:SLP:MS=1855,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12177 MCO:SLP:TPD
                    12179 MCO:SLP:WUP=-1
                    12181 MCO:SLP:MS=1845,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12187 MCO:SLP:TPD
                    12189 MCO:SLP:WUP=-1
                    12191 MCO:SLP:MS=1835,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12197 MCO:SLP:TPD
                    12199 MCO:SLP:WUP=-1
                    12204 MCO:SLP:MS=1822,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12208 MCO:SLP:TPD
                    12210 MCO:SLP:WUP=-1
                    12214 MCO:SLP:MS=1812,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12220 MCO:SLP:TPD
                    12222 MCO:SLP:WUP=-1
                    12224 MCO:SLP:MS=1802,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12230 MCO:SLP:TPD
                    12232 MCO:SLP:WUP=-1
                    12234 MCO:SLP:MS=1792,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12240 MCO:SLP:TPD
                    12242 MCO:SLP:WUP=-1
                    12247 MCO:SLP:MS=1779,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12251 MCO:SLP:TPD
                    12253 MCO:SLP:WUP=-1
                    12257 MCO:SLP:MS=1769,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12263 MCO:SLP:TPD
                    12265 MCO:SLP:WUP=-1
                    12267 MCO:SLP:MS=1759,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12273 MCO:SLP:TPD
                    12275 MCO:SLP:WUP=-1
                    12277 MCO:SLP:MS=1749,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12283 MCO:SLP:TPD
                    12285 MCO:SLP:WUP=-1
                    12290 MCO:SLP:MS=1736,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12294 MCO:SLP:TPD
                    12296 MCO:SLP:WUP=-1
                    12300 MCO:SLP:MS=1726,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12306 MCO:SLP:TPD
                    12308 MCO:SLP:WUP=-1
                    12310 MCO:SLP:MS=1716,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12316 MCO:SLP:TPD
                    12318 MCO:SLP:WUP=-1
                    12320 MCO:SLP:MS=1706,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12326 MCO:SLP:TPD
                    12328 MCO:SLP:WUP=-1
                    12333 MCO:SLP:MS=1693,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12337 MCO:SLP:TPD
                    12339 MCO:SLP:WUP=-1
                    12343 MCO:SLP:MS=1683,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12349 MCO:SLP:TPD
                    12351 MCO:SLP:WUP=-1
                    12353 MCO:SLP:MS=1673,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12359 MCO:SLP:TPD
                    12361 MCO:SLP:WUP=-1
                    12363 MCO:SLP:MS=1663,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12369 MCO:SLP:TPD
                    12371 MCO:SLP:WUP=-1
                    12374 MCO:SLP:MS=1652,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12380 MCO:SLP:TPD
                    12382 MCO:SLP:WUP=-1
                    12386 MCO:SLP:MS=1640,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12390 MCO:SLP:TPD
                    12394 MCO:SLP:WUP=-1
                    12396 MCO:SLP:MS=1630,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12402 MCO:SLP:TPD
                    12404 MCO:SLP:WUP=-1
                    12406 MCO:SLP:MS=1620,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12412 MCO:SLP:TPD
                    12414 MCO:SLP:WUP=-1
                    12417 MCO:SLP:MS=1609,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12423 MCO:SLP:TPD
                    12425 MCO:SLP:WUP=-1
                    12429 MCO:SLP:MS=1597,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12433 MCO:SLP:TPD
                    12437 MCO:SLP:WUP=-1
                    12439 MCO:SLP:MS=1587,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12445 MCO:SLP:TPD
                    12447 MCO:SLP:WUP=-1
                    12449 MCO:SLP:MS=1577,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12455 MCO:SLP:TPD
                    12457 MCO:SLP:WUP=-1
                    12460 MCO:SLP:MS=1566,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12466 MCO:SLP:TPD
                    12468 MCO:SLP:WUP=-1
                    12472 MCO:SLP:MS=1554,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12476 MCO:SLP:TPD
                    12478 MCO:SLP:WUP=-1
                    12482 MCO:SLP:MS=1544,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12488 MCO:SLP:TPD
                    12490 MCO:SLP:WUP=-1
                    12492 MCO:SLP:MS=1534,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12498 MCO:SLP:TPD
                    12500 MCO:SLP:WUP=-1
                    12503 MCO:SLP:MS=1523,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12509 MCO:SLP:TPD
                    12511 MCO:SLP:WUP=-1
                    12515 MCO:SLP:MS=1511,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12519 MCO:SLP:TPD
                    12521 MCO:SLP:WUP=-1
                    12525 MCO:SLP:MS=1501,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12531 MCO:SLP:TPD
                    12533 MCO:SLP:WUP=-1
                    12535 MCO:SLP:MS=1491,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12541 MCO:SLP:TPD
                    12544 MCO:SLP:WUP=-1
                    12546 MCO:SLP:MS=1480,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12552 MCO:SLP:TPD
                    12554 MCO:SLP:WUP=-1
                    12558 MCO:SLP:MS=1468,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12562 MCO:SLP:TPD
                    12564 MCO:SLP:WUP=-1
                    12568 MCO:SLP:MS=1458,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12574 MCO:SLP:TPD
                    12576 MCO:SLP:WUP=-1
                    12578 MCO:SLP:MS=1448,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12584 MCO:SLP:TPD
                    12587 MCO:SLP:WUP=-1
                    12589 MCO:SLP:MS=1437,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12595 MCO:SLP:TPD
                    12597 MCO:SLP:WUP=-1
                    12601 MCO:SLP:MS=1425,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12605 MCO:SLP:TPD
                    12607 MCO:SLP:WUP=-1
                    12611 MCO:SLP:MS=1415,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12617 MCO:SLP:TPD
                    12619 MCO:SLP:WUP=-1
                    12621 MCO:SLP:MS=1405,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12627 MCO:SLP:TPD
                    12630 MCO:SLP:WUP=-1
                    12632 MCO:SLP:MS=1394,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12638 MCO:SLP:TPD
                    12640 MCO:SLP:WUP=-1
                    12644 MCO:SLP:MS=1382,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12648 MCO:SLP:TPD
                    12650 MCO:SLP:WUP=-1
                    12654 MCO:SLP:MS=1372,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12658 MCO:SLP:TPD
                    12662 MCO:SLP:WUP=-1
                    12664 MCO:SLP:MS=1362,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12670 MCO:SLP:TPD
                    12673 MCO:SLP:WUP=-1
                    12675 MCO:SLP:MS=1351,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12681 MCO:SLP:TPD
                    12683 MCO:SLP:WUP=-1
                    12685 MCO:SLP:MS=1341,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12691 MCO:SLP:TPD
                    12693 MCO:SLP:WUP=-1
                    12697 MCO:SLP:MS=1329,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12701 MCO:SLP:TPD
                    12705 MCO:SLP:WUP=-1
                    12707 MCO:SLP:MS=1319,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12713 MCO:SLP:TPD
                    12716 MCO:SLP:WUP=-1
                    12718 MCO:SLP:MS=1308,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12724 MCO:SLP:TPD
                    12726 MCO:SLP:WUP=-1
                    12728 MCO:SLP:MS=1298,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12734 MCO:SLP:TPD
                    12736 MCO:SLP:WUP=-1
                    12740 MCO:SLP:MS=1286,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12744 MCO:SLP:TPD
                    12748 MCO:SLP:WUP=-1
                    12750 MCO:SLP:MS=1276,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12756 MCO:SLP:TPD
                    12759 MCO:SLP:WUP=-1
                    12761 MCO:SLP:MS=1265,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12767 MCO:SLP:TPD
                    12769 MCO:SLP:WUP=-1
                    12771 MCO:SLP:MS=1255,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12777 MCO:SLP:TPD
                    12779 MCO:SLP:WUP=-1
                    12783 MCO:SLP:MS=1243,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12787 MCO:SLP:TPD
                    12791 MCO:SLP:WUP=-1
                    12793 MCO:SLP:MS=1233,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12800 MCO:SLP:TPD
                    12802 MCO:SLP:WUP=-1
                    12804 MCO:SLP:MS=1222,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12810 MCO:SLP:TPD
                    12812 MCO:SLP:WUP=-1
                    12814 MCO:SLP:MS=1212,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12820 MCO:SLP:TPD
                    12822 MCO:SLP:WUP=-1
                    12826 MCO:SLP:MS=1200,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12830 MCO:SLP:TPD
                    12832 MCO:SLP:WUP=-1
                    12836 MCO:SLP:MS=1190,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12843 MCO:SLP:TPD
                    12845 MCO:SLP:WUP=-1
                    12847 MCO:SLP:MS=1179,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12853 MCO:SLP:TPD
                    12855 MCO:SLP:WUP=-1
                    12857 MCO:SLP:MS=1169,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12863 MCO:SLP:TPD
                    12865 MCO:SLP:WUP=-1
                    12869 MCO:SLP:MS=1157,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12873 MCO:SLP:TPD
                    12875 MCO:SLP:WUP=-1
                    12879 MCO:SLP:MS=1147,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12886 MCO:SLP:TPD
                    12888 MCO:SLP:WUP=-1
                    12890 MCO:SLP:MS=1136,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12896 MCO:SLP:TPD
                    12898 MCO:SLP:WUP=-1
                    12900 MCO:SLP:MS=1126,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12906 MCO:SLP:TPD
                    12908 MCO:SLP:WUP=-1
                    12912 MCO:SLP:MS=1114,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12916 MCO:SLP:TPD
                    12918 MCO:SLP:WUP=-1
                    12922 MCO:SLP:MS=1104,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12929 MCO:SLP:TPD
                    12931 MCO:SLP:WUP=-1
                    12933 MCO:SLP:MS=1093,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12939 MCO:SLP:TPD
                    12941 MCO:SLP:WUP=-1
                    12943 MCO:SLP:MS=1083,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12949 MCO:SLP:TPD
                    12951 MCO:SLP:WUP=-1
                    12955 MCO:SLP:MS=1071,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12959 MCO:SLP:TPD
                    12961 MCO:SLP:WUP=-1
                    12965 MCO:SLP:MS=1061,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12972 MCO:SLP:TPD
                    12974 MCO:SLP:WUP=-1
                    12976 MCO:SLP:MS=1050,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12982 MCO:SLP:TPD
                    12984 MCO:SLP:WUP=-1
                    12986 MCO:SLP:MS=1040,SMS=0,I1=1,M1=1,I2=255,M2=255
                    12992 MCO:SLP:TPD
                    12994 MCO:SLP:WUP=-1
                    12998 MCO:SLP:MS=1028,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13002 MCO:SLP:TPD
                    13004 MCO:SLP:WUP=-1
                    13008 MCO:SLP:MS=1018,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13015 MCO:SLP:TPD
                    13017 MCO:SLP:WUP=-1
                    13019 MCO:SLP:MS=1007,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13025 MCO:SLP:TPD
                    13027 MCO:SLP:WUP=-1
                    13029 MCO:SLP:MS=997,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13035 MCO:SLP:TPD
                    13037 MCO:SLP:WUP=-1
                    13039 MCO:SLP:MS=987,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13045 MCO:SLP:TPD
                    13047 MCO:SLP:WUP=-1
                    13051 MCO:SLP:MS=975,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13056 MCO:SLP:TPD
                    13058 MCO:SLP:WUP=-1
                    13062 MCO:SLP:MS=964,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13068 MCO:SLP:TPD
                    13070 MCO:SLP:WUP=-1
                    13072 MCO:SLP:MS=954,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13078 MCO:SLP:TPD
                    13080 MCO:SLP:WUP=-1
                    13082 MCO:SLP:MS=944,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13088 MCO:SLP:TPD
                    13090 MCO:SLP:WUP=-1
                    13092 MCO:SLP:MS=934,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13099 MCO:SLP:TPD
                    13101 MCO:SLP:WUP=-1
                    13105 MCO:SLP:MS=921,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13109 MCO:SLP:TPD
                    13111 MCO:SLP:WUP=-1
                    13115 MCO:SLP:MS=911,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13121 MCO:SLP:TPD
                    13123 MCO:SLP:WUP=-1
                    13125 MCO:SLP:MS=901,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13131 MCO:SLP:TPD
                    13133 MCO:SLP:WUP=-1
                    13135 MCO:SLP:MS=891,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13142 MCO:SLP:TPD
                    13144 MCO:SLP:WUP=-1
                    13146 MCO:SLP:MS=880,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13152 MCO:SLP:TPD
                    13154 MCO:SLP:WUP=-1
                    13158 MCO:SLP:MS=868,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13162 MCO:SLP:TPD
                    13164 MCO:SLP:WUP=-1
                    13168 MCO:SLP:MS=858,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13174 MCO:SLP:TPD
                    13176 MCO:SLP:WUP=-1
                    13178 MCO:SLP:MS=848,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13185 MCO:SLP:TPD
                    13187 MCO:SLP:WUP=-1
                    13189 MCO:SLP:MS=837,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13195 MCO:SLP:TPD
                    13197 MCO:SLP:WUP=-1
                    13199 MCO:SLP:MS=827,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13205 MCO:SLP:TPD
                    13207 MCO:SLP:WUP=-1
                    13211 MCO:SLP:MS=815,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13215 MCO:SLP:TPD
                    13217 MCO:SLP:WUP=-1
                    13221 MCO:SLP:MS=805,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13228 MCO:SLP:TPD
                    13230 MCO:SLP:WUP=-1
                    13232 MCO:SLP:MS=794,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13238 MCO:SLP:TPD
                    13240 MCO:SLP:WUP=-1
                    13242 MCO:SLP:MS=784,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13248 MCO:SLP:TPD
                    13250 MCO:SLP:WUP=-1
                    13252 MCO:SLP:MS=774,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13258 MCO:SLP:TPD
                    13260 MCO:SLP:WUP=-1
                    13264 MCO:SLP:MS=762,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13268 MCO:SLP:TPD
                    13271 MCO:SLP:WUP=-1
                    13275 MCO:SLP:MS=751,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13279 MCO:SLP:TPD
                    13283 MCO:SLP:WUP=-1
                    13285 MCO:SLP:MS=741,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13291 MCO:SLP:TPD
                    13293 MCO:SLP:WUP=-1
                    13295 MCO:SLP:MS=731,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13301 MCO:SLP:TPD
                    13303 MCO:SLP:WUP=-1
                    13305 MCO:SLP:MS=721,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13312 MCO:SLP:TPD
                    13314 MCO:SLP:WUP=-1
                    13318 MCO:SLP:MS=708,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13322 MCO:SLP:TPD
                    13324 MCO:SLP:WUP=-1
                    13328 MCO:SLP:MS=698,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13332 MCO:SLP:TPD
                    13336 MCO:SLP:WUP=-1
                    13338 MCO:SLP:MS=688,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13344 MCO:SLP:TPD
                    13346 MCO:SLP:WUP=-1
                    13348 MCO:SLP:MS=678,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13355 MCO:SLP:TPD
                    13357 MCO:SLP:WUP=-1
                    13359 MCO:SLP:MS=667,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13365 MCO:SLP:TPD
                    13367 MCO:SLP:WUP=-1
                    13371 MCO:SLP:MS=655,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13375 MCO:SLP:TPD
                    13377 MCO:SLP:WUP=-1
                    13381 MCO:SLP:MS=645,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13385 MCO:SLP:TPD
                    13389 MCO:SLP:WUP=-1
                    13391 MCO:SLP:MS=635,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13398 MCO:SLP:TPD
                    13400 MCO:SLP:WUP=-1
                    13402 MCO:SLP:MS=624,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13408 MCO:SLP:TPD
                    13410 MCO:SLP:WUP=-1
                    13412 MCO:SLP:MS=614,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13418 MCO:SLP:TPD
                    13420 MCO:SLP:WUP=-1
                    13424 MCO:SLP:MS=602,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13428 MCO:SLP:TPD
                    13430 MCO:SLP:WUP=-1
                    13434 MCO:SLP:MS=592,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13438 MCO:SLP:TPD
                    13441 MCO:SLP:WUP=-1
                    13445 MCO:SLP:MS=581,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13451 MCO:SLP:TPD
                    13453 MCO:SLP:WUP=-1
                    13455 MCO:SLP:MS=571,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13461 MCO:SLP:TPD
                    13463 MCO:SLP:WUP=-1
                    13465 MCO:SLP:MS=561,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13471 MCO:SLP:TPD
                    13473 MCO:SLP:WUP=-1
                    13475 MCO:SLP:MS=551,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13481 MCO:SLP:TPD
                    13484 MCO:SLP:WUP=-1
                    13488 MCO:SLP:MS=538,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13492 MCO:SLP:TPD
                    13494 MCO:SLP:WUP=-1
                    13498 MCO:SLP:MS=528,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13504 MCO:SLP:TPD
                    13506 MCO:SLP:WUP=-1
                    13508 MCO:SLP:MS=518,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13514 MCO:SLP:TPD
                    13516 MCO:SLP:WUP=-1
                    13518 MCO:SLP:MS=508,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13524 MCO:SLP:TPD
                    13527 MCO:SLP:WUP=-1
                    13529 MCO:SLP:MS=497,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13535 MCO:SLP:TPD
                    13537 MCO:SLP:WUP=-1
                    13541 MCO:SLP:MS=485,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13545 MCO:SLP:TPD
                    13547 MCO:SLP:WUP=-1
                    13551 MCO:SLP:MS=475,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13555 MCO:SLP:TPD
                    13559 MCO:SLP:WUP=-1
                    13561 MCO:SLP:MS=465,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13568 MCO:SLP:TPD
                    13570 MCO:SLP:WUP=-1
                    13572 MCO:SLP:MS=454,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13578 MCO:SLP:TPD
                    13580 MCO:SLP:WUP=-1
                    13582 MCO:SLP:MS=444,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13588 MCO:SLP:TPD
                    13590 MCO:SLP:WUP=-1
                    13594 MCO:SLP:MS=432,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13598 MCO:SLP:TPD
                    13600 MCO:SLP:WUP=-1
                    13604 MCO:SLP:MS=422,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13608 MCO:SLP:TPD
                    13613 MCO:SLP:WUP=-1
                    13615 MCO:SLP:MS=411,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13621 MCO:SLP:TPD
                    13623 MCO:SLP:WUP=-1
                    13625 MCO:SLP:MS=401,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13631 MCO:SLP:TPD
                    13633 MCO:SLP:WUP=-1
                    13635 MCO:SLP:MS=391,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13641 MCO:SLP:TPD
                    13643 MCO:SLP:WUP=-1
                    13647 MCO:SLP:MS=379,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13651 MCO:SLP:TPD
                    13654 MCO:SLP:WUP=-1
                    13658 MCO:SLP:MS=368,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13662 MCO:SLP:TPD
                    13664 MCO:SLP:WUP=-1
                    13668 MCO:SLP:MS=358,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13674 MCO:SLP:TPD
                    13676 MCO:SLP:WUP=-1
                    13678 MCO:SLP:MS=348,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13684 MCO:SLP:TPD
                    13686 MCO:SLP:WUP=-1
                    13688 MCO:SLP:MS=338,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13694 MCO:SLP:TPD
                    13697 MCO:SLP:WUP=-1
                    13699 MCO:SLP:MS=327,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13705 MCO:SLP:TPD
                    13707 MCO:SLP:WUP=-1
                    13711 MCO:SLP:MS=315,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13715 MCO:SLP:TPD
                    13717 MCO:SLP:WUP=-1
                    13721 MCO:SLP:MS=305,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13727 MCO:SLP:TPD
                    13729 MCO:SLP:WUP=-1
                    13731 MCO:SLP:MS=295,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13737 MCO:SLP:TPD
                    13740 MCO:SLP:WUP=-1
                    13742 MCO:SLP:MS=284,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13748 MCO:SLP:TPD
                    13750 MCO:SLP:WUP=-1
                    13752 MCO:SLP:MS=274,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13758 MCO:SLP:TPD
                    13760 MCO:SLP:WUP=-1
                    13764 MCO:SLP:MS=262,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13768 MCO:SLP:TPD
                    13770 MCO:SLP:WUP=-1
                    13774 MCO:SLP:MS=252,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13778 MCO:SLP:TPD
                    13783 MCO:SLP:WUP=-1
                    13785 MCO:SLP:MS=241,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13791 MCO:SLP:TPD
                    13793 MCO:SLP:WUP=-1
                    13795 MCO:SLP:MS=231,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13801 MCO:SLP:TPD
                    13803 MCO:SLP:WUP=-1
                    13805 MCO:SLP:MS=221,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13811 MCO:SLP:TPD
                    13813 MCO:SLP:WUP=-1
                    13817 MCO:SLP:MS=209,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13821 MCO:SLP:TPD
                    13824 MCO:SLP:WUP=-1
                    13828 MCO:SLP:MS=198,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13832 MCO:SLP:TPD
                    13836 MCO:SLP:WUP=-1
                    13838 MCO:SLP:MS=188,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13844 MCO:SLP:TPD
                    13846 MCO:SLP:WUP=-1
                    13848 MCO:SLP:MS=178,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13854 MCO:SLP:TPD
                    13856 MCO:SLP:WUP=-1
                    13858 MCO:SLP:MS=168,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13864 MCO:SLP:TPD
                    13867 MCO:SLP:WUP=-1
                    13869 MCO:SLP:MS=157,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13875 MCO:SLP:TPD
                    13877 MCO:SLP:WUP=-1
                    13881 MCO:SLP:MS=145,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13885 MCO:SLP:TPD
                    13887 MCO:SLP:WUP=-1
                    13891 MCO:SLP:MS=135,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13895 MCO:SLP:TPD
                    13899 MCO:SLP:WUP=-1
                    13901 MCO:SLP:MS=125,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13907 MCO:SLP:TPD
                    13910 MCO:SLP:WUP=-1
                    13912 MCO:SLP:MS=114,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13918 MCO:SLP:TPD
                    13920 MCO:SLP:WUP=-1
                    13922 MCO:SLP:MS=104,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13928 MCO:SLP:TPD
                    13930 MCO:SLP:WUP=-1
                    13932 MCO:SLP:MS=94,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13938 MCO:SLP:TPD
                    13940 MCO:SLP:WUP=-1
                    13944 MCO:SLP:MS=82,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13948 MCO:SLP:TPD
                    13950 MCO:SLP:WUP=-1
                    13955 MCO:SLP:MS=71,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13959 MCO:SLP:TPD
                    13961 MCO:SLP:WUP=-1
                    13965 MCO:SLP:MS=61,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13969 MCO:SLP:TPD
                    13971 MCO:SLP:WUP=-1
                    13975 MCO:SLP:MS=51,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13979 MCO:SLP:TPD
                    13983 MCO:SLP:WUP=-1
                    13985 MCO:SLP:MS=41,SMS=0,I1=1,M1=1,I2=255,M2=255
                    13991 MCO:SLP:TPD
                    13993 MCO:SLP:WUP=-1
                    13996 MCO:SLP:MS=30,SMS=0,I1=1,M1=1,I2=255,M2=255
                    14002 MCO:SLP:TPD
                    14004 MCO:SLP:WUP=-1
                    14006 MCO:SLP:MS=20,SMS=0,I1=1,M1=1,I2=255,M2=255
                    14012 MCO:SLP:TPD
                    14014 MCO:SLP:WUP=-1
                    14016 MCO:SLP:MS=10,SMS=0,I1=1,M1=1,I2=255,M2=255
                    14022 MCO:SLP:TPD
                    14024 MCO:SLP:WUP=-1
                    14026 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                    14032 MCO:SLP:TPD
                    I'm sorry for asking for help again @core_c but I have no idea what I'm doing wrong....
                    • E esawyja
                      4 TSM:INIT
                      4 TSF:WUR:MS=1000
                      8 TSM:INIT:TSP OK
                      12 TSF:SID:OK,ID=11
                      14 TSM:FPAR
                      1007 MCO:BGN:STP
                      2152 TSM:FPAR:OK
                      2152 TSM:ID
                      2154 TSM:ID:OK
                      2156 TSM:UPL
                      2224 TSM:UPL:OK
                      4327 MCO:REG:REQ
                      11036 MCO:SLP:TPD
                      11046 MCO:SLP:TPD
                      11059 MCO:SLP:TPD
                      11069 MCO:SLP:TPD
                      11079 MCO:SLP:TPD
                      11089 MCO:SLP:TPD
                      11102 MCO:SLP:TPD
                      11112 MCO:SLP:TPD
                      11122 MCO:SLP:TPD
                      11134 MCO:SLP:TPD
                      11145 MCO:SLP:TPD
                      11155 MCO:SLP:TPD
                      11165 MCO:SLP:TPD
                      11177 MCO:SLP:TPD
                      11188 MCO:SLP:TPD
                      11198 MCO:SLP:TPD
                      11208 MCO:SLP:TPD
                      11220 MCO:SLP:TPD
                      11231 MCO:SLP:TPD
                      11241 MCO:SLP:TPD
                      11251 MCO:SLP:TPD
                      11264 MCO:SLP:TPD
                      11274 MCO:SLP:TPD
                      11284 MCO:SLP:TPD
                      11294 MCO:SLP:TPD
                      11307 MCO:SLP:TPD
                      11317 MCO:SLP:TPD
                      11327 MCO:SLP:TPD
                      11339 MCO:SLP:TPD
                      11350 MCO:SLP:TPD
                      11360 MCO:SLP:TPD
                      11370 MCO:SLP:TPD
                      11382 MCO:SLP:TPD
                      11393 MCO:SLP:TPD
                      11403 MCO:SLP:TPD
                      11413 MCO:SLP:TPD
                      11425 MCO:SLP:TPD
                      11436 MCO:SLP:TPD
                      11446 MCO:SLP:TPD
                      11456 MCO:SLP:TPD
                      11468 MCO:SLP:TPD
                      11479 MCO:SLP:TPD
                      11489 MCO:SLP:TPD
                      11499 MCO:SLP:TPD
                      11511 MCO:SLP:TPD
                      11522 MCO:SLP:TPD
                      11532 MCO:SLP:TPD
                      11542 MCO:SLP:TPD
                      11554 MCO:SLP:TPD
                      11565 MCO:SLP:TPD
                      11575 MCO:SLP:TPD
                      11585 MCO:SLP:TPD
                      11597 MCO:SLP:TPD
                      11608 MCO:SLP:TPD
                      11618 MCO:SLP:TPD
                      11628 MCO:SLP:TPD
                      11640 MCO:SLP:TPD
                      11651 MCO:SLP:TPD
                      11661 MCO:SLP:TPD
                      11671 MCO:SLP:TPD
                      11683 MCO:SLP:TPD
                      11694 MCO:SLP:TPD
                      11704 MCO:SLP:TPD
                      11714 MCO:SLP:TPD
                      11726 MCO:SLP:TPD
                      11737 MCO:SLP:TPD
                      11747 MCO:SLP:TPD
                      11757 MCO:SLP:TPD
                      11769 MCO:SLP:TPD
                      11780 MCO:SLP:TPD
                      11790 MCO:SLP:TPD
                      11800 MCO:SLP:TPD
                      11812 MCO:SLP:TPD
                      11823 MCO:SLP:TPD
                      11833 MCO:SLP:TPD
                      11843 MCO:SLP:TPD
                      11855 MCO:SLP:TPD
                      11866 MCO:SLP:TPD
                      11876 MCO:SLP:TPD
                      11886 MCO:SLP:TPD
                      11898 MCO:SLP:TPD
                      11909 MCO:SLP:TPD
                      11919 MCO:SLP:TPD
                      11929 MCO:SLP:TPD
                      11939 MCO:SLP:TPD
                      11952 MCO:SLP:TPD
                      11962 MCO:SLP:TPD
                      11972 MCO:SLP:TPD
                      11982 MCO:SLP:TPD
                      11995 MCO:SLP:TPD
                      12005 MCO:SLP:TPD
                      12015 MCO:SLP:TPD
                      12025 MCO:SLP:TPD
                      12036 MCO:SLP:TPD
                      12048 MCO:SLP:TPD
                      12058 MCO:SLP:TPD
                      12068 MCO:SLP:TPD
                      12079 MCO:SLP:TPD
                      12091 MCO:SLP:TPD
                      12101 MCO:SLP:TPD
                      12111 MCO:SLP:TPD
                      12122 MCO:SLP:TPD
                      12134 MCO:SLP:TPD
                      12144 MCO:SLP:TPD
                      12154 MCO:SLP:TPD
                      12165 MCO:SLP:TPD
                      12177 MCO:SLP:TPD
                      12187 MCO:SLP:TPD
                      12197 MCO:SLP:TPD
                      12208 MCO:SLP:TPD
                      12220 MCO:SLP:TPD
                      12230 MCO:SLP:TPD
                      12240 MCO:SLP:TPD
                      12251 MCO:SLP:TPD
                      12263 MCO:SLP:TPD
                      12273 MCO:SLP:TPD
                      12283 MCO:SLP:TPD
                      12294 MCO:SLP:TPD
                      12306 MCO:SLP:TPD
                      12316 MCO:SLP:TPD
                      12326 MCO:SLP:TPD
                      12337 MCO:SLP:TPD
                      12349 MCO:SLP:TPD
                      12359 MCO:SLP:TPD
                      12369 MCO:SLP:TPD
                      12380 MCO:SLP:TPD
                      12390 MCO:SLP:TPD
                      12402 MCO:SLP:TPD
                      12412 MCO:SLP:TPD
                      12423 MCO:SLP:TPD
                      12433 MCO:SLP:TPD
                      12445 MCO:SLP:TPD
                      12455 MCO:SLP:TPD
                      12466 MCO:SLP:TPD
                      12476 MCO:SLP:TPD
                      12488 MCO:SLP:TPD
                      12498 MCO:SLP:TPD
                      12509 MCO:SLP:TPD
                      12519 MCO:SLP:TPD
                      12531 MCO:SLP:TPD
                      12541 MCO:SLP:TPD
                      12552 MCO:SLP:TPD
                      12562 MCO:SLP:TPD
                      12574 MCO:SLP:TPD
                      12584 MCO:SLP:TPD
                      12595 MCO:SLP:TPD
                      12605 MCO:SLP:TPD
                      12617 MCO:SLP:TPD
                      12627 MCO:SLP:TPD
                      12638 MCO:SLP:TPD
                      12648 MCO:SLP:TPD
                      12658 MCO:SLP:TPD
                      12670 MCO:SLP:TPD
                      12681 MCO:SLP:TPD
                      12691 MCO:SLP:TPD
                      12701 MCO:SLP:TPD
                      12713 MCO:SLP:TPD
                      12724 MCO:SLP:TPD
                      12734 MCO:SLP:TPD
                      12744 MCO:SLP:TPD
                      12756 MCO:SLP:TPD
                      12767 MCO:SLP:TPD
                      12777 MCO:SLP:TPD
                      12787 MCO:SLP:TPD
                      12800 MCO:SLP:TPD
                      12810 MCO:SLP:TPD
                      12820 MCO:SLP:TPD
                      12830 MCO:SLP:TPD
                      12843 MCO:SLP:TPD
                      12853 MCO:SLP:TPD
                      12863 MCO:SLP:TPD
                      12873 MCO:SLP:TPD
                      12886 MCO:SLP:TPD
                      12896 MCO:SLP:TPD
                      12906 MCO:SLP:TPD
                      12916 MCO:SLP:TPD
                      12929 MCO:SLP:TPD
                      12939 MCO:SLP:TPD
                      12949 MCO:SLP:TPD
                      12959 MCO:SLP:TPD
                      12972 MCO:SLP:TPD
                      12982 MCO:SLP:TPD
                      12992 MCO:SLP:TPD
                      13002 MCO:SLP:TPD
                      13015 MCO:SLP:TPD
                      13025 MCO:SLP:TPD
                      13035 MCO:SLP:TPD
                      13045 MCO:SLP:TPD
                      13056 MCO:SLP:TPD
                      13068 MCO:SLP:TPD
                      13078 MCO:SLP:TPD
                      13088 MCO:SLP:TPD
                      13099 MCO:SLP:TPD
                      13109 MCO:SLP:TPD
                      13121 MCO:SLP:TPD
                      13131 MCO:SLP:TPD
                      13142 MCO:SLP:TPD
                      13152 MCO:SLP:TPD
                      13162 MCO:SLP:TPD
                      13174 MCO:SLP:TPD
                      13185 MCO:SLP:TPD
                      13195 MCO:SLP:TPD
                      13205 MCO:SLP:TPD
                      13215 MCO:SLP:TPD
                      13228 MCO:SLP:TPD
                      13238 MCO:SLP:TPD
                      13248 MCO:SLP:TPD
                      13258 MCO:SLP:TPD
                      13268 MCO:SLP:TPD
                      13279 MCO:SLP:TPD
                      13291 MCO:SLP:TPD
                      13301 MCO:SLP:TPD
                      13312 MCO:SLP:TPD
                      13322 MCO:SLP:TPD
                      13332 MCO:SLP:TPD
                      13344 MCO:SLP:TPD
                      13355 MCO:SLP:TPD
                      13365 MCO:SLP:TPD
                      13375 MCO:SLP:TPD
                      13385 MCO:SLP:TPD
                      13398 MCO:SLP:TPD
                      13408 MCO:SLP:TPD
                      13418 MCO:SLP:TPD
                      13428 MCO:SLP:TPD
                      13438 MCO:SLP:TPD
                      13451 MCO:SLP:TPD
                      13461 MCO:SLP:TPD
                      13471 MCO:SLP:TPD
                      13481 MCO:SLP:TPD
                      13492 MCO:SLP:TPD
                      13504 MCO:SLP:TPD
                      13514 MCO:SLP:TPD
                      13524 MCO:SLP:TPD
                      13535 MCO:SLP:TPD
                      13545 MCO:SLP:TPD
                      13555 MCO:SLP:TPD
                      13568 MCO:SLP:TPD
                      13578 MCO:SLP:TPD
                      13588 MCO:SLP:TPD
                      13598 MCO:SLP:TPD
                      13608 MCO:SLP:TPD
                      13621 MCO:SLP:TPD
                      13631 MCO:SLP:TPD
                      13641 MCO:SLP:TPD
                      13651 MCO:SLP:TPD
                      13662 MCO:SLP:TPD
                      13674 MCO:SLP:TPD
                      13684 MCO:SLP:TPD
                      13694 MCO:SLP:TPD
                      13705 MCO:SLP:TPD
                      13715 MCO:SLP:TPD
                      13727 MCO:SLP:TPD
                      13737 MCO:SLP:TPD
                      13748 MCO:SLP:TPD
                      13758 MCO:SLP:TPD
                      13768 MCO:SLP:TPD
                      13778 MCO:SLP:TPD
                      13791 MCO:SLP:TPD
                      13801 MCO:SLP:TPD
                      13811 MCO:SLP:TPD
                      13821 MCO:SLP:TPD
                      13832 MCO:SLP:TPD
                      13844 MCO:SLP:TPD
                      13854 MCO:SLP:TPD
                      13864 MCO:SLP:TPD
                      13875 MCO:SLP:TPD
                      13885 MCO:SLP:TPD
                      13895 MCO:SLP:TPD
                      13907 MCO:SLP:TPD
                      13918 MCO:SLP:TPD
                      13928 MCO:SLP:TPD
                      13938 MCO:SLP:TPD
                      13948 MCO:SLP:TPD
                      13959 MCO:SLP:TPD
                      13969 MCO:SLP:TPD
                      13979 MCO:SLP:TPD
                      13991 MCO:SLP:TPD
                      14002 MCO:SLP:TPD
                      14012 MCO:SLP:TPD
                      14022 MCO:SLP:TPD
                      14032 MCO:SLP:TPD
                      E
                      E
                      esawyja
                      @core_c correction, after I typed and posted this, the serial log started again and it did send the message, this is weird
                      14032 MCO:SLP:TPD
                      14034 MCO:SLP:WUP=1
                      14047 TSF:MSG:SEND,11-11-0-0,s=7,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:0.85
                      14055 MCO:SLP:MS=3000,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14059 MCO:SLP:TPD
                      14061 MCO:SLP:WUP=-1
                      14065 MCO:SLP:MS=2990,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14071 MCO:SLP:TPD
                      14073 MCO:SLP:WUP=-1
                      14075 MCO:SLP:MS=2980,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14082 MCO:SLP:TPD
                      14084 MCO:SLP:WUP=-1
                      14086 MCO:SLP:MS=2969,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14092 MCO:SLP:TPD
                      14094 MCO:SLP:WUP=-1
                      14098 MCO:SLP:MS=2957,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14102 MCO:SLP:TPD
                      14104 MCO:SLP:WUP=-1
                      14108 MCO:SLP:MS=2947,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14114 MCO:SLP:TPD
                      14116 MCO:SLP:WUP=-1
                      14118 MCO:SLP:MS=2937,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14125 MCO:SLP:TPD
                      14127 MCO:SLP:WUP=-1
                      14129 MCO:SLP:MS=2926,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14135 MCO:SLP:TPD
                      14137 MCO:SLP:WUP=-1
                      14141 MCO:SLP:MS=2914,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14145 MCO:SLP:TPD
                      14147 MCO:SLP:WUP=-1
                      14151 MCO:SLP:MS=2904,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14157 MCO:SLP:TPD
                      14159 MCO:SLP:WUP=-1
                      14161 MCO:SLP:MS=2894,SMS=0,I1=1,M1=1,I2=255,M2=255
                      14168 MCO:SLP:TPD
