  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 57.0k Views 19 Watching
    Ok, so it was just a copy-paste leftover in the feature description from the nrf version.
    sundberg84S
    sundberg84S
    @martinhjelmare - It wasnt meant to make the project visible but I did unfortunately. I will correct as soon as possible
    I dont think its going to be that newbie friendly with a level converter for 5v so Im going to propose a 3.3v Pro mini only. Then I might add a voltage regulator with 5 and 3.3v in.
    • sundberg84S
      sundberg84S
      Well, since I posted the thread without it was finished (not usually my way of working) I can keep you updated on the work i guess... get input on the way.
      New schematics made... not final! Not implemented any booster yet.
      • sundberg84S
        sundberg84S
        @gohan - looking better on that SMA connector...
        Anyone knows if its possible to have a SMA and Hole for DIY antenna on the same PCB like this?
        Edit:
        Well, so far tonight... a couple of hours work and im happy :) some small stuff to fix before production.
        J 1 Reply Last reply
        • fisherF
          fisherF
          fisher
          Looking forward to buy this board. Thanks for including SMA connector. Now it's complete board for me :-)
          • sundberg84S
            sundberg84S
            OK - beta release.
            I have updated the description, bom, gerber files and kicad files on openhardware.io.
            I have placed an order for fast delivery on pcbway.com but it will take some time before my RFM69 radios reach me from china-land. So I won't be able to test it for some time.
            IF you are curoius (and willing to debug and cut / resolder if there are errors) feel free to download the gerbers and place an order. I cant promise its 100% (or work as intended) and because of that I wont add them for sale on openhardware.io yet.
            • sundberg84S sundberg84
              Edit:
              J
              J
              jlaraujo
              @sundberg84 I did this in my take of a SMA with a wire Antenna option:
              0_1494632694334_upload-ce399877-38ed-4251-924d-a293c9df13fb , you can see more details here https://www.openhardware.io/view/388/RFM69HW-Arduino-Mini-Pro-Shield.
              Haven't tried with the wire antenna trough.
              Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
                Actually it seems a good solution to have the hole on the sma pad
                • J jlaraujo
                  sundberg84S
                  sundberg84S
                  @jlaraujo , @gohan - I does look really good and effective!
                  Would be great if you could test it! At the moment I have placed my order so I cant change it for this run, but out of experience there will be other stuff I want to change.
                  Thank you for input! I greatly appreciate it!
                  • sundberg84S
                    sundberg84S
                    • sundberg84S
                      sundberg84S
                      So, this temporary GW is now connected to Domoticz and running at 34800 baud rate (had some problems to figure this out...) I have one (fake) node connected but still have some range issues to sort out. Most likley because of the DIY antenna...
                      • sundberg84S
                        sundberg84S
                        I now have a gw and node working together on 3.3v and 433mhz (not HW version). I would say its quite safe to order the PCB if someone wants to try it out.
                        Note to myself and others... the RFM69 is really sensitive to high power. I fried one because I tried it on a Nano which i think is using 5v on its gpio. I was just thinking... hmm 3.3v - nano got one of those!
                        gohanG 1 Reply Last reply
                        • sundberg84S
                          sundberg84S
                          And now I also have a batterynode working... Power consumtion will come later... it works atleast :)
                          Someone that can guess what kind of power consumtion this setup would be (removing LED / regulator)?
                            @sundberg84 said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                            It's in datasheet that it is not 5v tolerant and absolute max voltage it's like 3.6v
                              sundberg84S
                              sundberg84S
                              @gohan - I was fooled by that the Nano got a 3.3v output... stupid.
                                wrote on last edited by gohan
                                #21
                                Yeah, that's a noob's mistake 😁
                                Pro mini 3.3v is the only way 😎
                                • sundberg84S
                                  sundberg84S
                                  So I have made the adjustment for low power/battery mode (removed the LED, voltage regulator and sleeping most of the time).
                                  Im having a hard time to trust my Multimeter at this point... showing 5.1uA in sleep() mode while sending shows almost 2mA! This cant be right???
                                  At the moment im all out of boosters... I was sure I had more so I didnt order.
                                  What I have done now is uploaded a sketch sleeping 15min, running the vcc check (since I dont have a booster) and reporting it back to me. Lets see what happens...
                                  E 1 Reply Last reply
                                  • sundberg84S
                                    sundberg84S
                                    To answer my own question I found this thread where he gets the exact same sleep current as I do (5.2uA). Still wondering about the high send current though.
                                    Is 2.0mA a normal power consumption for RFM69W when its transmitting? Will investigate but all input appreciated...
                                      @sundberg84 no. It should consume 16-45 mA. See datasheet.
                                        sundberg84S
                                        sundberg84S
                                        #25
                                        @mfalkvidd - thanks. Have to recheck... maybe 2mA was during loop and there was a peak up which I didnt notice when transmitting. * feeling a bit more confident *
                                        • qqlapralineQ
                                          qqlapralineQ
                                          qqlapraline
                                          Very nice job (as usual).
                                          I think the first version was produced with Eagle. Can you post the Eagle version of the schematics and pcb ?
                                          Thank you.
                                          Qq.
