  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.8k Views 53 Watching
    why don't you connect the radio directly to battery?
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      this is very wierd ... maybe try another nrf module ? also try what gohan suggested. But it should work as it is. I have similar configuration, but the boost converter has pass trough mode, so i can switch it on and off from the atmega and have no problems with that setup, no matter if the boost converter is os or off, the communication is ok. Can you upload a picture of your setup ? maybe we see something you didn't realize is important to say.
      • F FatBeard
        I made progress. So the capacitor idea doesn't seem to work. However rozpruwacz suggested measuring the current which I did. I disconnected the negative wire and put my multimeter in between the negative from the battery and the ground pin on the step up module. I measured 72ma when the device powers up, then it runs at .16ma when in sleep mode. But here is the thing, in this configuration, mysensors worked as a thermometer. I got humidity and temperature readings from the sensor to my mqtt server through the gateway over the nrfs. When I removed the multimeter again from the equation it stopped working. Surely this would hint at what the problem is for someone more familiar with electronics than myself?
        sundberg84S
        sundberg84S
        @FatBeard - Could it be that the step up booster are making alot of noice. When you connect your multimeter it works in some way like a filter and reduces the noice?
        I have made alot of these sensors and i strongly suggest you connect i like @gohan suggest - radio directly to the bat.
        This is how i have created my EasyPCB and with alot of trial and error - radio + booster isnt a good idea.
        https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
        F 1 Reply Last reply
        • sundberg84S sundberg84
          F
          F
          FatBeard
          @sundberg84 Ok, thanks guys. I'll try your suggestions out tonight. I would have preferred to do it through the step up to get the most out of the batteries but maybe this is not practical.
            maybe you could use the booster, but you would need to analyze the kind of noise and build a specific filter for that.
            • F FatBeard
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @FatBeard boost converter has limited efficiency, this means that it eat the battery power. Nrf can work down to 1.9 V so it is not so obvious that the booster actually will make your sensor live longer.
                wrote on last edited by gohan
                #119
                It can help drainig the battery to even lower voltages, but the tradeoff is lower efficiency and noise
                • sundberg84S
                  sundberg84S
                  Search the forum. Booster VS not booster - its always a tradeoff.
                  Some people go further and skip booster and lower BOD on the arduino instead.
                  I would say 1.9V is pretty good... I have had my longest temp sensor now since the beginning (Almost 3 years) and changed 2xAA once. If you are using sleep and measure once you will get away with a long lasting sensor.
                  • mfalkviddM
                    #121
                    At 0.95V per cell, an alkaline battery has delivered about 99% of its total capacity. Look at a discharge curve like this:
                    So if the booster has more than 1% overhead, using a booster to power nrf24 and atmega328 will give worse battery performance than running directly off 2 alkaline batteries.
                    • F
                      F
                      FatBeard
                      Thats for the response guys. So tried connecting directly to the battery. I cut the trace on the pcb, then soldered a wire directly from the vIn to the positive leg of the 4.7u cap that leads to the radio. No joy though. Still same problem.
                      To the point about disabling bod, i have done that already, my issue with that setup though is that my dht22 seems to give inconsistent measurements when operating. It would give readings a degree apart every 5 minutes when the temperature would have remained a lot more stable. I assumed this to be due to the 2x batteries running at just a tad below 3v, while the dht22 is rated at 3.3v. Hence i thought the stepup would fix this problem.
                        Get a more serious sensor like sht31 or si7021 😉
                        • F FatBeard
                          sundberg84S
                          sundberg84S
                          #124
                          @FatBeard - I use this setup, run the radio from the battery and arduino and dht22 from booster without problems. It should work. About the readings... as gohan said... the dht22 is known for... not that good quality
                          F 2 Replies Last reply
                            F
                            F
                            FatBeard
                            I've actually ordered some bme280s which I'm waiting on, I think they will work down to low voltages too. So hopefully that will sort this issue by not needing the step up.
                            I would like to still to be able to figure out this problem though. I tried removing the dht22 completely to see if it was contributing to the problem, no luck. I've tried various capacitors over the ground and vout to no avail.
                            How would I go about analysing noise on the circuit?
                              F
                              F
                              FatBeard
                              @sundberg84 I'll also take a look at your pcb. I was trying to achieve a pcb like that. A generic one to use with various sensors. I Was hoping to do it myself for the sake of learning. But I may have change tact.
                              • F FatBeard
                                sundberg84S
                                sundberg84S
                                #127
                                @FatBeard - I would start by changing the Nrf24l01+ - there are some really bad ones out there.
                                Second I would rewire everyhing from/to the radio. After that I would rewire everything else and maybe change the arduino. As you said, removing all sensors and try debug in "bare minimun" (Power, Arudino and Radio) is a good idea. You can create a fake motion sensor sketch for example sending 1/0 with a 10 sec delay in between just to test the setup (without sensor attached).
                                  sineverba
                                  wrote on last edited by sineverba
                                  #128
                                  I'm using an approach read some thread bottom. Direct 2XAA to the Atmega barebone @8Mhz with BOD disabled and step up (not very efficient) to port the voltage of the batteries to a 3.3v for the DHT22. I'm reading the voltage with "secret voltmeter" example posted (https://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/ )
                                  The Atmega sleep for 10 minutes, take reading and if different sends to the gateway (as your sketches). I want shutdown the booster, as it is not very efficient. I did have a debate on arduino forum: https://forum.arduino.cc/index.php?topic=488315.0
                                  Basically, a part that I don't absolutely "cut the ground" with a NPN, otherwise I could have issues with different potential grounds etc etc, I don't know anymore if my design is secure and can works.
                                  For all friday, saturday and sunday my node was power on without issues, but I don't want my house burning for a short circuit from batteries...
                                  This is base fritzing draw:
                                  And this is the real pictures of node:
                                  And final this is the not-so-efficient booster: https://www.amazon.it/gp/product/B06XHJCHX6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 and regulated exit to 3.3v.
                                  (Voltage goes down from friday to today from 2.74 to 2.63).
                                  Am I wrong with my connections? Thank you to all....
                                  • S sineverba
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @sineverba I gave up trying to cross connect power controls directly and went for bistable telecoms relays, 100mW fire 30ms max latched stay open until you reverse signals from + & - pins. Works a treat, powered only for duration of latch....pity the sensor it controlled was shit, but hey ho....small steps
                                    S 1 Reply Last reply
                                    • zboblamontZ zboblamont
                                      sineverba
                                      @zboblamont
                                      A bistable could cost more than entire node :D
                                      But it could be an idea... instead of NPN. But remain my doubt.... for the moment, with node powered in this mode..... Am I in danger of burn battery / node / house? :(
                                        If I were you I'd go for an I2C sensor that could also work at low voltage, this way you could also power the sensor via a digital pin and turn it off before entering the sleep function to save extra power.
                                          sineverba
                                          @gohan
                                          What sensor do you use? Seems interesting the Bosch BM280 that has also the pressure but seems it wants the 3.3v...
