  3. [SOLVED]Two nodes with relays interfering
26 Posts 6 Posters 7.7k Views 5 Watching
  • MasMatM
    MasMatM
    MasMat
    Im having the same problem. But I'm not finding the solution from this thread really. Did you find it?
    I'm going to manually asign node_ids next.
    I get interference inside one node with two relays (mqtt gw + 2relay) and also across two nodes (dht+relay and 6relay node).
    I checked the mqtt traffic and it sends the same mqtt topic twice (both on and off commands).
    Controller is Domoticz.
      Have you tried with just leds instead of the relays, just to exclude some parts of the circuit.
      MasMatM 1 Reply Last reply
        MasMatM
        MasMatM
        MasMat
        @gohan I have the boards soldered with the relays attached (regreting that now) so that would be difficult.
          ok, so do you get issues either with or without load on relays? Are they optoisolated from the rest of the circuit?
          • MasMatM
            MasMatM
            MasMat
            I've tested with load only. The circuits are very basic so no opto. The relays are powered from the 5v transformer directly and not vcc off Promini.
            The problem is not global (affecting all relays in node) but only a few lights/relays seem to be "tandem".
              Try without load. I have seen to be a recurring problem that load causes interference on the board. I you see things getting better, you know that opto will be the way :D
              • MasMatM
                MasMatM
                MasMat
                I will. But just out of curiosity, are relays always touchy or is it just something about certain loads? The loads are not heavy (10-15w fluorescent lamp per relay or 2-6w led bulb).
                  You know when there are coils involved and circuits opening and closing (especially if there are inductive loads) there can be interference generated during switching. There are also solid state relays that should solve this issue, there are some projects already in the openhardware section
                  • MasMatM
                    MasMatM
                    MasMat
                    Back at this after a while... I changed code for all nodes and manually assigned node_ids to make sure nothing interferes.
                    Currently the problem: when a remote nodes (number 4) relay is activated, it also causes the relay attached to gw-node to activate. The gw attached relay works well by itself (optocoupled).
                    I checked MQTT traffic and there's nothing fishy (activation message "1"). I also checked the debug on the gw and that looks OK to me as well.
                    The gw relays are optocoupled, the outside (it's a dht22+single relay node) light relay is not. GW receives power from car battery thru usb, so no interference should be possible.
                    Any ideas?
                    Conflicting relays code:
                    // Enable debug prints
                    #define MY_REPEATER_FEATURE
                    //#define MY_RS485
                    #define MY_NODE_ID 4
                    #define DHT_DATA_PIN 4
                    #define SENSOR_TEMP_OFFSET 0
                    //static const uint64_t UPDATE_INTERVAL = 60000;
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    float lastTemp;
                    float lastHum;
                    uint8_t nNoUpdatesTemp;
                    uint8_t nNoUpdatesHum;
                    bool metric = true;
                    DHT dht;
                    #define CHILD_ID_RELAY 2
                    void before()
                        pinMode(pin, OUTPUT);
                      sendSketchInfo("TempHumRelUlko", "vMasi");
                      present(CHILD_ID_HUM, S_HUM);
                      present(CHILD_ID_RELAY, S_BINARY);
                      //for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                        //present(sensor, S_BINARY);
                    //  if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) {
                      //  Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
                      sleep(2000);
                      dht.readSensor(true);
                      if (isnan(temperature)) {
                        lastTemp = temperature;
                        if (!metric) {
                        // Reset no updates counter
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                        Serial.print("T: ");
                        nNoUpdatesTemp++;
                      if (isnan(humidity)) {
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                        Serial.print("H: ");
                        Serial.println(humidity);
                        nNoUpdatesHum++;
                      //sleep(UPDATE_INTERVAL);
                    wait(120000);
                      if (message.type==V_STATUS) {
                        // Change relay state
                        // Store state in eeprom
                    And the debug from GW:
                    0;255;3;0;9;MCO:BGN:BFR
                    0;255;3;0;9;TSM:INIT
                    0;255;3;0;9;TSF:WUR:MS=0
                    0;255;3;0;9;TSM:INIT:TSP OK
                    0;255;3;0;9;TSM:INIT:GW MODE
                    IP: 192.168.0.201
                    0;255;3;0;9;MCO:BGN:STP
                    IP: 192.168.0.201
                    0;255;3;0;9;MQTT connected
                    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/0/0/18
                    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/11
                    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/12
                    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/1/0/0/3
                    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/2/0/0/3
                    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/4/1/1/1/2
                    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                    0;255;3;0;9;TSF:MSG:ACK
                    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/1/2
                    Incoming change for sensor:1, New status: 0
                    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
                    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                    Incoming change for sensor:1, New status: 1
                    • MasMatM MasMat
                      Any ideas?
                      //#define MY_RS485
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                      DHT dht;
                      void before()
                        sleep(2000);
                          if (!metric) {
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesTemp++;
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesHum++;
                      wait(120000);
                      IP: 192.168.0.201
                      IP: 192.168.0.201
                      @MasMat could you post the sketch for your gateway node as well?
                      • MasMatM
                        MasMatM
                        MasMat
                        Sure. Here it is. Slight mod from MQTT sketch with Relay sketch parts.
                        #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
                        #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
                        // Set MQTT client id
                        //#define MY_W5100_SPI_EN 4
                        // radio on the same spi bus.
                        #define MY_SOFTSPI
                        #ifndef MY_RF24_CE_PIN
                        #define MY_RF24_CE_PIN 5
                        #ifndef MY_RF24_CS_PIN
                        #define MY_RF24_CS_PIN 6
                        #define MY_IP_ADDRESS 192,168,0,201
                        #define MY_IP_GATEWAY_ADDRESS 192,168,0,254
                        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 200
                        #define MY_PORT 1883
                        // Enable inclusion mode
                        // Set blinking period
                        // Flash leds on rx/tx/err
                        #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                        // #define CHILD_ID_RELAY1 1
                        // #define CHILD_ID_RELAY2 2
                        #include <Ethernet.h>
                        void before()
                          sendSketchInfo("MQTT_GWAndRelay", "vMasi");
                        • MasMatM MasMat
                          #define MY_SOFTSPI
                          void before()
                          @MasMat Looks like the gateway's receive function is called even when the gateway is the destination of the message. That results in the gateway updating its relay even though it shouldn't.
                          I think you could do something like this:
                              if (message.sensor == 0) { // Only switch the relay if the message is for myself
                                  Serial.print("Updating relay state");
                          MasMatM 2 Replies Last reply
                            MasMatM
                            MasMatM
                            MasMat
                            wrote on last edited by MasMat
                            @mfalkvidd All this under "void loop"? Do I remove the "void receive"?
                            I added (and commented out previous) under "void receive": the relay became unresponsive.
                            debug:
                            0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/2/1/0/2
                            Incoming change for sensor:2, New status: 1
                            Incoming change for sensor:2, New status: 0
                              You need the receive, just replace the code
                                MasMatM
                                MasMatM
                                MasMat
                                @gohan I did. Relay unresponsive but clearly the messages are coming thru. Went back, relay works so not mechanical/electrical.
                                Current code:
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  @mfalkvidd I've been reviewing this: I have two relays actually attached, so this code will ignore the other completely, right? I think that's why it's not working. Or the numbering for the sensors is different?
                                  Am I wrong or does the "message.sensor" actually refer to child_id rather than node_id? Or am I following this wrong?
                                  • MasMatM MasMat
                                    @MasMat I have trouble finding documentation explaining the details, but I think you are right. See if message.destination works better.
                                      MasMatM
                                      MasMatM
                                      MasMat
                                      #23
                                      @mfalkvidd That fixed it right up and makes complete sense. I couldn't find docs either on message.sensor or message.destination...
                                      The problem now appears more complex...
                                      The GW (node 0) relay STILL follows the other nodes (node 4) commands (completely different circuits, so no electrical connection at all).
                                      GW debug (first a on & off test for gw-relay, then clicked the node4-relay, on comes OK (gwrelay follows) but off reboots gw)
                                      0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/1/1/0/2
                                      Updating relay stateIncoming change for sensor:1, New status: 1
                                      Updating relay stateIncoming change for sensor:1, New status: 0
                                      0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=0,pt=7,l=5,sg=0:16.6
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/0/0
                                      0;255;3;0;9;TSF:MSG:READ,4-4-0,s=0,c=1,t=1,pt=7,l=5,sg=0:69.8
                                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/0/1/0/1
                                      0;255;3;0;9;!TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                      0;255;3;0;9;MCO:BGN:BFR```
                                      • MasMatM
                                        MasMatM
                                        MasMat
                                        Nevermind. Whined too soon.
                                        Completely worked over the node4 code, moved "include"s around and eventually changed the relay presentations and receive clauses. Hope this helps someone with their problems later:
                                        Thanks a millions!
                                        void before()
                                            // Set relay pin in output mode
                                            pinMode(RELAY_1, OUTPUT);
                                            digitalWrite(RELAY_1, loadState(CHILD_ID_RELAY)?RELAY_ON:RELAY_OFF);
                                        later this....
                                        ....and ending with this...
                                            if (message.destination == MY_NODE_ID) { // Only switch the relay if the message is for this node
                                                digitalWrite(RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                                                saveState(CHILD_ID_RELAY, message.getBool());
                                        • MasMatM MasMat
                                          Thanks a millions!
                                          void before()
                                          later this....
                                          #25
                                          @MasMat great work! Maybe change this to make the output more complete?
                                          to
                                              Serial.print("Incoming change for node: ");
                                              Serial.print(message.destination);
                                              Serial.print(", sensor:");
