  3. Cant even get my first node working...
28 Posts 6 Posters 6.9k Views 4 Watching
  • AndyRooA
    AndyRooA
    AndyRoo
    wrote on last edited by AndyRoo
    Controller is OpenHABian on Rpi3
    Gateway is Arduino Mega w/ W5100 Shield & NRF24l01
    Node is Arduino Nano w/ NRF24l01
    As far as I am aware, the gateway is working fine, running the Gateway5100mqtt example I can send and receive messages through MQTT, tested inside Pi terminal.
    BUT, my node just wont work, I've tried two different NRF modules, both work on the gateway, I've tested all the pins on the nano with an led and they are working.
    Running the Temp/Humidity example on the nano this is the error I am getting:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 !TSM:INIT:TSP FAIL
    12 TSM:FAIL:CNT=1
    14 TSM:FAIL:PDT
    10016 TSM:FAIL:RE-INIT
    10018 TSM:INIT
    10024 !TSM:INIT:TSP FAIL
    I have also tried clearing EEPROM with that sketch.
    Please any help at all, this is driving me insane!
    update: have also tried in an arduino uno now with the same error
    • AndyRooA
      AndyRooA
      AndyRoo
      No one knows how to fix this? I'm using known working components, I've followed the getting started guide, beginning to feel like mysensors is alot more trouble than its worth...
      • AndyRooA AndyRoo
        sundberg84S
        sundberg84S
        @AndyRoo - Hi!
        It seems like the radio cant be initialised.
        You should re-check all your wirings and power to the radio.
        AndyRooA 1 Reply Last reply
        • sundberg84S sundberg84
          @AndyRoo - Hi!
          AndyRooA
          AndyRooA
          AndyRoo
          @sundberg84 Hi,
          Thanks for your reply, unless the wiring on the website is wrong, then everything is correct, I've tripled checked.
          Could you confirm the wiring for a nano and uno are the same and if what's on the website matches what you are using?
          • AndyRooA AndyRoo
            @sundberg84 Hi,
            @AndyRoo yes. The wiring has been used to build several hundreds of nodes.
              Try swapping radios between the gateway and node just to make sure radio is not fried. It could be a wiring problem like said before or a power problem.
                @gohan that has already been tested, see the initial post.
                • R
                  R
                  royson84
                  Any solution to this? I have the same problem atm. Tried 3 or 4 different nrf24l01+ but with the same failures. I'm suspecting it's related to my sketches or something. Can't wire that many radios wrong, and they are from different vendors. My gateway is an Uno running with an W5100 and latest MySensors dev. Seems to be connecting just fine to both my Vera and when I tried it in Domoticz. The GW debug shows no fails.
                    try with just some example sketches to see if the radios are correctly communicating. Did you put a capacitor on the radio module?
                    R 1 Reply Last reply
                      R
                      R
                      royson84
                      @gohan I made a serial gateway with an Nano+Nrf24L01+ and hooked it up to my computer. Just to bypass the possibility that my regular gateway have radio problems. But even with that simple setup I get "11 !TSM:INIT:TSP FAIL" from the Nano. I have tried with 4.7, 47 and 100uF on the radio.
                        I am kind of suspecting the radio modules have issues.
                          R
                          R
                          royson84
                          @gohan ok. Im gonna try with different nrfs tonight. I have 13 from 3 different vendors. Reckon at least a couple of them should work..
                          I have made 3 sensors with Sundberg84 amazing PCB and they have the same issues, which makes me a bit sceptical.
                          • R
                            R
                            royson84
                            Im banging my head against the wall here. Uninstalled IDE and reinstalled version 1.6.4 and added Mysensors lib from the menus. Uploaded the GatewaySerial to a new Uno with attached radio+cap. No luck.
                            Uninstalled IDE and installed latest version which has Mysensors preinstalled. Same sketch. No luck. Gonna try with yet another radio. But I cant see how the 3 i've already tried could be broken.
                              can you post a picture of those radios?
                                R
                                R
                                royson84
                                @gohan Sure. I have tried 9 or 10 out of 13 now i think. With different libs and sketches that google found for me.
                                • R
                                  R
                                  royson84
                                  2_1500328749598_IMG_20170717_235131.jpg 1_1500328749598_IMG_20170717_235309.jpg 0_1500328749598_IMG_20170717_235509.jpg
                                  The first and second picture is from a seller called axeprice on ebay. Two different orders with a couple of weeks apart.
                                  The third picture is from a swedish shop called m.nu, great shop I might add.
                                    How much were they? They look quite on the cheap
                                      R
                                      R
                                      royson84
                                      @gohan http://www.ebay.com/itm/400594940658?rmvSB=true
                                      Its the radios linked in mysensors store...
                                      https://www.m.nu/breakout-boards/nrf24l01
                                      "swedish" one.
                                      m26872M sundberg84S gohanG 3 Replies Last reply
                                      • R royson84
                                        "swedish" one.
                                        m26872M
                                        m26872M
                                        m26872
                                        @royson84 Where in Sweden are you? Maybe someone near can help you.
                                        • R royson84
                                          "swedish" one.
                                          sundberg84S
                                          sundberg84S
                                          @royson84 - do yo have a multimeter and can comfirm there are power to the radio? If you are using the PCB you need to have atleast one jumper connected (as we spoke about - so I suspect that is ok). Could you post a picture of the complete setup?
                                          I live pretty near you (1.5h) in worst case scenario ;)
