  2. Announcements
  • S sineverba
    Going crazy here.
    I did get success with MySensors and first Arduino node on a fresh Raspbian (last image) and branch development. All ok!
    Now I want re-do on other SD (same Pi, same WIring, same Radio). I did put "old" sd on a secure location and re-start from scratch.
    I did compile with:
    ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
    and answer is:
      [OK] machine detected: SoC=BCM2835, Type=rpi1, CPU=armv6l.
      [OK] SPI driver detected:BCM.
    [OK] Finished.
    Make ends with no error.
    The debug
    sudo ./bin/mysgw –d
    locks here:
    mysgw: Starting gateway...
    And no other lines.
    I Repeat, same PI, same Radio, same wiring. If I try other SD, all goes ok and I can use it on domoticz.
    Thank you
    sineverba
    @sineverba
    @sineverba said in 💬 Building a Raspberry Pi Gateway:
    Going crazy here.
    I did compile with:
    and answer is:
    [OK] Finished.
    The debug
    sudo ./bin/mysgw –d
    locks here:
    And no other lines.
    Thank you
    OK, re-re-done on fresh install and all went ok.
    I think that problem was when I deleted the PI default user and created another one.
    I did follow the gordon guide: https://gordonlesti.com/change-default-users-on-raspberry-pi/
    Probably a permission issues changing or not changing root?
    Thank you
    • L
      L
      lassivv
      wrote on last edited by lassivv
      #508
      Hi all
      Hope someone can help MySensors noob :) I try to do Raspberry pi 3 gateway with nrf24 module.
      Hardware:
      Raspberry pi 3
      nrf24 module
      3.3v 0.5A regulator.
      status leds (3pcs)
      Domoticz Beta
      I start with this instructions:
      https://www.mysensors.org/build/raspberry#improving-throughput-for-nrf24
      commands what i use:
      cd MySensors
      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway (try ttyUSBMySensorsGateway too, but now help)
      ./configure --my-transport=nrf24 --my-rf24-irq-pin=15
      ./configure --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
      make
      sudo ./bin/mysgw -d
      After that i get error what is same to that instruction site:
      http://i.imgur.com/jpiaMdC.png
      I douple check wiring that seems to be all right. I think Linux console tell wrong wiring, if wiring is problem? But anyway i douple checked that wiring.
      Hope someone can help me with this problem.
      I try many times different settings, dont know do i need delete some old files or can i try again and again do configure and give "make" command.
      • L lassivv
        Hi all
        Hardware:
        Raspberry pi 3
        nrf24 module
        status leds (3pcs)
        Domoticz Beta
        cd MySensors
        make
        sudo ./bin/mysgw -d
        @lassivv please don't post the same question in multiple places. Posting in multiple places will result in people trying to help you in one place, even after the problem has been solved in the other place. That is a waste of people's time.
        Anyone trying to help @lassivv please post in https://forum.mysensors.org/topic/7050/multi-node-project-mysensors-noob-raspberry-gateway-problem
        • L
          L
          lassivv
          Sorry see this topic after i post my own topic, thinks this is better topic to my problems. But i continue my own topic.
            sineverba
            I have a couple of nodes + PI working without issues from a couple of days.
            Now, I would add encryption / signing / security etc to protect traffic between Arduinos and PI.
            Could you please help me posting right configuration to add to the
            ./configure
            command?
            Thank you very much!
            S 1 Reply Last reply
            • OliverDogO
              OliverDogO
              OliverDog
              Why do Tx and Rx Leds blink every 5 to 6 seconds?
              Is it about communication between RPi and Gateway?
              Is there a way to disable it and keep blinks only with nodes communication?
              OliverDogO 1 Reply Last reply
              • S sineverba
                ./configure
                command?
                sineverba
                ./configure
                command?
                Sorry..... I would UP! this :)
                AnticimexA 1 Reply Last reply
                • S sineverba
                  ./configure
                  command?
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @sineverba is there not a --help argument to get a list of settings?
                  • AnticimexA Anticimex
                    sineverba
                    @Anticimex sure... Bit I did read also the guide and .... I did noto understand very well whats I need to activate (if need) on gateway and on Arduinos to block, for example, the persone that live on third floor to play with my heater ..... :-) thank you in advance
                    PS security only software, no other hardware implied / want use
                    Thank you!
                    • S sineverba
                      Thank you!
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @sineverba I am not sure I understand what you want. You want to enable signing? There is extensive documentation on how to enable that. As for what to pass to the configure command on a rPi I am unsure of the exact naming but I am pretty sure the names are very similar to the #define:s the signing documentation describes.
                        sineverba
                        @Anticimex Yes, the doc is ... maybe ... too extensive :)
                        By the way, I would signing. So I need to do on both? Gateway/Raspberry and Arduino?
                        Thank you
                        • S sineverba
                          Thank you
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @sineverba I am not sure I understand how it can be too excessive? It sounds like it is inadequate since you still have questions. :)
                          Of course you have to enable signing on both node and gateway. You also need to personalize the services with a hmac key. This is described. Please read the docs carefully. And if they are unclear, please provide a link to the documentation you have read, so I can verify you read the correct one.
                            sineverba
                            @Anticimex
                            I'm talking about this: https://www.mysensors.org/about/signing
                            Seems to me that probably need to be more clear your hint: you have to enable signing on both node and gateway.
                            I hope that soon I will can test on my network :)
                            Thank you for the moment :)
                            • S sineverba
                              @Anticimex
                              AnticimexA
                              AnticimexA
                              Anticimex
                              #520
                              @sineverba yes, well that is for the official release so so far so good. I assume you also run the official version of the library and not the beta version, right?
                              For details on rPi configuration, perhaps @marceloaqno can provide some assistance but you will find all information needed on that page for configuring signing on your nodes.
                                sineverba
                                @Anticimex On Raspberry PI V1 I can work only with branch development. With master the radio / serial doesn't work
                                • S sineverba
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @sineverba then please use this documentation instead.
                                    sineverba
                                    @Anticimex thank you but... it is not the same?
                                    • S sineverba
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @sineverba no, it isn't. There are newer features on beta branch. A third simplified option for signing exist (and if you have a hard time figuring out signing I highly recommend you use it).
                                        sineverba
                                        wrote on last edited by sineverba
                                        #525
                                        Raspberry PI V1 Model B (2 USB ports, no wifi, 26 GPIO).
                                        RASPBIAN JESSIE LITE v 2017-04-10-raspbian-jessie-lite.
                                        Some day ago I did compile the gateway only with development branch, using this:
                                        ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                        And all works fantastic.
                                        Today I did try a new fresh installation for a friend, same PI, and same commands and routine from zero:
                                        1. Logged with PI
                                        2. Changed Password
                                        3. Activate SSH
                                        4. Activate SPI
                                        5. Expand Filesystem
                                        6. Changed timezone
                                        launched
                                        No error on output, rebooted many times, gateways locked. See the screen:
                                        With current setup (that works perfect), if I reconfigure to use Led TX/RX/Err, I get same lock.
                                        I have SD and a copy of it, but I would setup another one from zero.... and I cannot.
                                        Thank you
                                        • S sineverba
                                          1. Logged with PI
                                          2. Changed Password
                                          3. Activate SSH
                                          4. Activate SPI
                                          6. Changed timezone
                                          launched
                                          Thank you
                                          sineverba
                                          I don't want give up!
                                          I did download last RASPBIAN version (2017-06-21).
                                          Gitted from development branch...
                                          My question is.... is it a problem of my PI? Too old? Need to buy the V3?
                                          I don't understand why some time ./configure works (and entire system with domoticz works without problem!!!) and other time no!
                                          1. Logged with PI
                                          2. Changed Password
                                          3. Activate SSH
                                          4. Activate SPI
                                          6. Changed timezone
                                          launched
                                          Thank you
