  2. Announcements
  • L lassivv
    Hi all
    Hope someone can help MySensors noob :) I try to do Raspberry pi 3 gateway with nrf24 module.
    Hardware:
    Raspberry pi 3
    nrf24 module
    3.3v 0.5A regulator.
    status leds (3pcs)
    Domoticz Beta
    I start with this instructions:
    https://www.mysensors.org/build/raspberry#improving-throughput-for-nrf24
    commands what i use:
    cd MySensors
    ./configure --my-transport=nrf24
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway (try ttyUSBMySensorsGateway too, but now help)
    ./configure --my-transport=nrf24 --my-rf24-irq-pin=15
    ./configure --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    make
    sudo ./bin/mysgw -d
    After that i get error what is same to that instruction site:
    http://i.imgur.com/jpiaMdC.png
    I douple check wiring that seems to be all right. I think Linux console tell wrong wiring, if wiring is problem? But anyway i douple checked that wiring.
    Hope someone can help me with this problem.
    I try many times different settings, dont know do i need delete some old files or can i try again and again do configure and give "make" command.
    @lassivv please don't post the same question in multiple places. Posting in multiple places will result in people trying to help you in one place, even after the problem has been solved in the other place. That is a waste of people's time.
    Anyone trying to help @lassivv please post in https://forum.mysensors.org/topic/7050/multi-node-project-mysensors-noob-raspberry-gateway-problem
    • L
      L
      lassivv
      Sorry see this topic after i post my own topic, thinks this is better topic to my problems. But i continue my own topic.
        sineverba
        I have a couple of nodes + PI working without issues from a couple of days.
        Now, I would add encryption / signing / security etc to protect traffic between Arduinos and PI.
        Could you please help me posting right configuration to add to the
        ./configure
        command?
        Thank you very much!
        S 1 Reply Last reply
        • OliverDogO
          OliverDogO
          OliverDog
          Why do Tx and Rx Leds blink every 5 to 6 seconds?
          Is it about communication between RPi and Gateway?
          Is there a way to disable it and keep blinks only with nodes communication?
          OliverDogO 1 Reply Last reply
          • S sineverba
            ./configure
            command?
            sineverba
            @sineverba said in 💬 Building a Raspberry Pi Gateway:
            ./configure
            command?
            Sorry..... I would UP! this :)
            AnticimexA 1 Reply Last reply
            • S sineverba
              ./configure
              command?
              AnticimexA
              AnticimexA
              Anticimex
              @sineverba is there not a --help argument to get a list of settings?
              • AnticimexA Anticimex
                sineverba
                @Anticimex sure... Bit I did read also the guide and .... I did noto understand very well whats I need to activate (if need) on gateway and on Arduinos to block, for example, the persone that live on third floor to play with my heater ..... :-) thank you in advance
                PS security only software, no other hardware implied / want use
                Thank you!
                • S sineverba
                  Thank you!
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @sineverba I am not sure I understand what you want. You want to enable signing? There is extensive documentation on how to enable that. As for what to pass to the configure command on a rPi I am unsure of the exact naming but I am pretty sure the names are very similar to the #define:s the signing documentation describes.
                    sineverba
                    @Anticimex Yes, the doc is ... maybe ... too extensive :)
                    By the way, I would signing. So I need to do on both? Gateway/Raspberry and Arduino?
                    Thank you
                    • S sineverba
                      Thank you
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @sineverba I am not sure I understand how it can be too excessive? It sounds like it is inadequate since you still have questions. :)
                      Of course you have to enable signing on both node and gateway. You also need to personalize the services with a hmac key. This is described. Please read the docs carefully. And if they are unclear, please provide a link to the documentation you have read, so I can verify you read the correct one.
                        sineverba
                        @Anticimex
                        I'm talking about this: https://www.mysensors.org/about/signing
                        Seems to me that probably need to be more clear your hint: you have to enable signing on both node and gateway.
                        I hope that soon I will can test on my network :)
                        Thank you for the moment :)
                        • S sineverba
                          @Anticimex
                          AnticimexA
                          AnticimexA
                          Anticimex
                          #520
                          @sineverba yes, well that is for the official release so so far so good. I assume you also run the official version of the library and not the beta version, right?
                          For details on rPi configuration, perhaps @marceloaqno can provide some assistance but you will find all information needed on that page for configuring signing on your nodes.
                            sineverba
                            @Anticimex On Raspberry PI V1 I can work only with branch development. With master the radio / serial doesn't work
                            • S sineverba
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @sineverba then please use this documentation instead.
                                sineverba
                                @Anticimex thank you but... it is not the same?
                                • S sineverba
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @sineverba no, it isn't. There are newer features on beta branch. A third simplified option for signing exist (and if you have a hard time figuring out signing I highly recommend you use it).
                                    sineverba
                                    wrote on last edited by sineverba
                                    #525
                                    Raspberry PI V1 Model B (2 USB ports, no wifi, 26 GPIO).
                                    RASPBIAN JESSIE LITE v 2017-04-10-raspbian-jessie-lite.
                                    Some day ago I did compile the gateway only with development branch, using this:
                                    ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                    And all works fantastic.
                                    Today I did try a new fresh installation for a friend, same PI, and same commands and routine from zero:
                                    1. Logged with PI
                                    2. Changed Password
                                    3. Activate SSH
                                    4. Activate SPI
                                    5. Expand Filesystem
                                    6. Changed timezone
                                    launched
                                    No error on output, rebooted many times, gateways locked. See the screen:
                                    With current setup (that works perfect), if I reconfigure to use Led TX/RX/Err, I get same lock.
                                    I have SD and a copy of it, but I would setup another one from zero.... and I cannot.
                                    Thank you
                                    • S sineverba
                                      1. Logged with PI
                                      2. Changed Password
                                      3. Activate SSH
                                      4. Activate SPI
                                      6. Changed timezone
                                      launched
                                      Thank you
                                      sineverba
                                      I don't want give up!
                                      I did download last RASPBIAN version (2017-06-21).
                                      Gitted from development branch...
                                      My question is.... is it a problem of my PI? Too old? Need to buy the V3?
                                      I don't understand why some time ./configure works (and entire system with domoticz works without problem!!!) and other time no!
                                      1. Logged with PI
                                      2. Changed Password
                                      3. Activate SSH
                                      4. Activate SPI
                                      6. Changed timezone
                                      launched
                                      Thank you
                                      • S sineverba
                                        1. Logged with PI
                                        2. Changed Password
                                        3. Activate SSH
                                        4. Activate SPI
                                        6. Changed timezone
                                        launched
                                        Thank you
                                        sineverba
                                        Hi to all!
                                        I did another test, on a new SD with Raspbian Lite 2017-06-21.
                                        It doesn't work. Hangs on protocol version.
                                        But... I did note this, after ./configure
                                        Master branch
                                          [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv6l.
                                        [OK] Finished.
                                        Development branch
                                          [OK] machine detected: SoC=BCM2835, Type=rpi1, CPU=armv6l.
                                          [OK] SPI driver detected:BCM.
                                        [OK] Finished.
                                        I'm going crazy :(
                                        1. Logged with PI
                                        2. Changed Password
                                        3. Activate SSH
                                        4. Activate SPI
                                        6. Changed timezone
                                        launched
                                        Thank you
                                          Try DIETPI instead of raspian and see if it changes
