  2. Announcements
  • L
    L
    lassivv
    Sorry see this topic after i post my own topic, thinks this is better topic to my problems. But i continue my own topic.
      sineverba
      I have a couple of nodes + PI working without issues from a couple of days.
      Now, I would add encryption / signing / security etc to protect traffic between Arduinos and PI.
      Could you please help me posting right configuration to add to the
      ./configure
      command?
      Thank you very much!
      S 1 Reply Last reply
      • OliverDogO
        OliverDogO
        OliverDog
        Why do Tx and Rx Leds blink every 5 to 6 seconds?
        Is it about communication between RPi and Gateway?
        Is there a way to disable it and keep blinks only with nodes communication?
        OliverDogO 1 Reply Last reply
        • S sineverba
          ./configure
          command?
          sineverba
          @sineverba said in 💬 Building a Raspberry Pi Gateway:
          ./configure
          command?
          Sorry..... I would UP! this :)
          AnticimexA 1 Reply Last reply
          • S sineverba
            ./configure
            command?
            AnticimexA
            AnticimexA
            Anticimex
            @sineverba is there not a --help argument to get a list of settings?
            • AnticimexA Anticimex
              sineverba
              @Anticimex sure... Bit I did read also the guide and .... I did noto understand very well whats I need to activate (if need) on gateway and on Arduinos to block, for example, the persone that live on third floor to play with my heater ..... :-) thank you in advance
              PS security only software, no other hardware implied / want use
              Thank you!
              • S sineverba
                Thank you!
                AnticimexA
                AnticimexA
                Anticimex
                @sineverba I am not sure I understand what you want. You want to enable signing? There is extensive documentation on how to enable that. As for what to pass to the configure command on a rPi I am unsure of the exact naming but I am pretty sure the names are very similar to the #define:s the signing documentation describes.
                  sineverba
                  @Anticimex Yes, the doc is ... maybe ... too extensive :)
                  By the way, I would signing. So I need to do on both? Gateway/Raspberry and Arduino?
                  Thank you
                  • S sineverba
                    Thank you
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @sineverba I am not sure I understand how it can be too excessive? It sounds like it is inadequate since you still have questions. :)
                    Of course you have to enable signing on both node and gateway. You also need to personalize the services with a hmac key. This is described. Please read the docs carefully. And if they are unclear, please provide a link to the documentation you have read, so I can verify you read the correct one.
                      sineverba
                      @Anticimex
                      I'm talking about this: https://www.mysensors.org/about/signing
                      Seems to me that probably need to be more clear your hint: you have to enable signing on both node and gateway.
                      I hope that soon I will can test on my network :)
                      Thank you for the moment :)
                      • S sineverba
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        #520
                        @sineverba yes, well that is for the official release so so far so good. I assume you also run the official version of the library and not the beta version, right?
                        For details on rPi configuration, perhaps @marceloaqno can provide some assistance but you will find all information needed on that page for configuring signing on your nodes.
                          sineverba
                          @Anticimex On Raspberry PI V1 I can work only with branch development. With master the radio / serial doesn't work
                          • S sineverba
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @sineverba then please use this documentation instead.
                              sineverba
                              @Anticimex thank you but... it is not the same?
                              • S sineverba
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @sineverba no, it isn't. There are newer features on beta branch. A third simplified option for signing exist (and if you have a hard time figuring out signing I highly recommend you use it).
                                  sineverba
                                  wrote on last edited by sineverba
                                  #525
                                  Raspberry PI V1 Model B (2 USB ports, no wifi, 26 GPIO).
                                  RASPBIAN JESSIE LITE v 2017-04-10-raspbian-jessie-lite.
                                  Some day ago I did compile the gateway only with development branch, using this:
                                  ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                  And all works fantastic.
                                  Today I did try a new fresh installation for a friend, same PI, and same commands and routine from zero:
                                  1. Logged with PI
                                  2. Changed Password
                                  3. Activate SSH
                                  4. Activate SPI
                                  5. Expand Filesystem
                                  6. Changed timezone
                                  launched
                                  No error on output, rebooted many times, gateways locked. See the screen:
                                  With current setup (that works perfect), if I reconfigure to use Led TX/RX/Err, I get same lock.
                                  I have SD and a copy of it, but I would setup another one from zero.... and I cannot.
                                  Thank you
                                  • S sineverba
                                    1. Logged with PI
                                    2. Changed Password
                                    3. Activate SSH
                                    4. Activate SPI
                                    6. Changed timezone
                                    launched
                                    Thank you
                                    sineverba
                                    I don't want give up!
                                    I did download last RASPBIAN version (2017-06-21).
                                    Gitted from development branch...
                                    My question is.... is it a problem of my PI? Too old? Need to buy the V3?
                                    I don't understand why some time ./configure works (and entire system with domoticz works without problem!!!) and other time no!
                                    1. Logged with PI
                                    2. Changed Password
                                    3. Activate SSH
                                    4. Activate SPI
                                    6. Changed timezone
                                    launched
                                    Thank you
                                    • S sineverba
                                      1. Logged with PI
                                      2. Changed Password
                                      3. Activate SSH
                                      4. Activate SPI
                                      6. Changed timezone
                                      launched
                                      Thank you
                                      sineverba
                                      Hi to all!
                                      I did another test, on a new SD with Raspbian Lite 2017-06-21.
                                      It doesn't work. Hangs on protocol version.
                                      But... I did note this, after ./configure
                                      Master branch
                                        [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv6l.
                                      [OK] Finished.
                                      Development branch
                                        [OK] machine detected: SoC=BCM2835, Type=rpi1, CPU=armv6l.
                                        [OK] SPI driver detected:BCM.
                                      [OK] Finished.
                                      I'm going crazy :(
                                      1. Logged with PI
                                      2. Changed Password
                                      3. Activate SSH
                                      4. Activate SPI
                                      6. Changed timezone
                                      launched
                                      Thank you
                                        Try DIETPI instead of raspian and see if it changes
                                          sineverba
                                          @gohan
                                          I can and I will try, of sure. But, why do you think that something will change? My hardware is too old?
