  3. relays do not work using button
5 Posts 2 Posters 1.5k Views 2 Watching
  • DickD
    DickD
    Dick
    I have a working temperature compare node and I want to add2 relays with button. I am searching already for of few hours e why the relays are not working after using the buttons.
    Can anyone give me a tip ?
    #include <OneWire.h>
    // Partie Température
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    // Partie Relay
    #define RELAY_PIN  A1  // Arduino Digital I/O pinnumber for relay
    #define BUTTON_PIN  A3   // Arduino Digital I/O pin number for button
    #define CHILD_ID 17   // Id of the sensor child
    #define RELAY_PIN_1  A2  // Arduino Digital I/O pinnumber for relay
    #define BUTTON_PIN_1  A4   // Arduino Digital I/O pin number for button
    #define CHILD_ID_1 18   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    unsigned long previousMillis = 0;
    MyMessage msg2(CHILD_ID,V_LIGHT);//relay_pin A1
    MyMessage msg3(CHILD_ID,V_LIGHT);//relay_pin A2
      sensors.begin();
      gw.sendSketchInfo("Relay & Button", "1.0");
      gw.sendSketchInfo("Temperature Sensor", "1.1");
      Serial.print(numSensors);
      Serial.println(" temperature sensors detected");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      pinMode(BUTTON_PIN_1,INPUT);
      digitalWrite(BUTTON_PIN_1,HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer.attach(BUTTON_PIN_1);
         gw.present(i, S_TEMP);
      gw.present(CHILD_ID, S_LIGHT);
      gw.present(CHILD_ID_1, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
          digitalWrite(RELAY_PIN_1, RELAY_OFF);
      pinMode(RELAY_PIN_1, OUTPUT);
      state = gw.loadState(CHILD_ID);
      digitalWrite(RELAY_PIN_1, state?RELAY_ON:RELAY_OFF);
    *  Example on how to asynchronously check for new messages from gw
      // Relay button
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg2.set(state?false:true), true); // Send new state and request ack back
          gw.send(msg3.set(state?false:true), true);
      oldValue = value;
      //int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
      // gw.wait(conversionTime);
      if (currentMillis - previousMillis >= SLEEP_TIME) {
        // save the last time you read temperature
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          #if COMPARE_TEMP == 1
            gw.send(msg.setSensor(i).set(temperature,1));
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
         gw.saveState(CHILD_ID_1, state);
    Insert Code Here
    • DickD Dick
      int numSensors=0;
      // Partie Relay
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
        sensors.begin();
       // Setup the button
        // Relay button
        debouncer.update();
        oldValue = value;
      Insert Code Here
      @Dick the same debouncer instance can't be used for two buttons. You need to create another instance.
      To stay with the naming convention in your sketch, create
      Bounce debouncer_1 = Bounce();
      and change all calls for the second button to use debouncer_1. You'll also need to use different child ids for the two messages.
      DickD 1 Reply Last reply
        DickD
        DickD
        Dick
        @mfalkvidd
        Thanks for the info. I adjusted what you mentioned but still no reaction. this is what I have changed.
        InBounce debouncer = Bounce();
        int oldValue=0;
        bool state;
        int oldValue_1=0;
        bool state_1;
        MyMessage msg3(CHILD_ID_1,V_LIGHT);//relay_pin A2`
        • DickD Dick
          @mfalkvidd
          int oldValue=0;
          bool state;
          int oldValue_1=0;
          bool state_1;
          @Dick there are lots of more places that need update. Maybe you should try first to get one relay with one button working? Doing everything at once might be a too steep learning curve.
            DickD
            DickD
            Dick
            @mfalkvidd
            you are right, i try to make one relay working.
