  3. No Sleep is driving me crazy!
11 Posts 4 Posters 2.4k Views 4 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    I folloed the api and have done what I believe to be correct, but obviously isn't as I get a compile warning.
    So why does this fail to work at the end of the loop?
     int8_t sleep(int 1, int FALLING, unsigned long SLEEP_TIME);
    See here for api instructions I followed.... https://www.mysensors.org/download/sensor_api_20#sleeping
    Thanks for any pointers here.....
    mfalkviddM YveauxY rozpruwaczR 3 Replies Last reply
    • skywatchS skywatch
      @skywatch what is the return value of the sleep function?
      Are you perhaps using an esp8266?
        YveauxY Offline
        YveauxY Offline
        @skywatch and, as always, which mySensors version are you using...
        • skywatchS Offline
          skywatchS Offline
          skywatch
          I am using mysensors 2.1.1 which I believe is the latest one.
          But I get a compiler error with arduino IDE 1.8.3 when I add the line exactly as shown above. I have treid various combinations to try and solve the issue, but that's as far as I can get.
          It might be a library issue as I had that earlier this week! Here is the error output as it appears after compilation check
          C:\Users\captain\Documents\Arduino\MYS-Cinema-0.1\MYS-Cinema-0.1.ino: In function 'void loop()':
          MYS-Cinema-0.1:130: error: expected ',' or '...' before numeric constant
             int8_t smartSleep(int 1, int FALLING, unsigned long ms=27000);
          Multiple libraries were found for "SPI.h"
           Used: C:\Program Files (x86)\Arduino1.8.3\hardware\arduino\avr\libraries\SPI
           Not used: C:\Users\captain\Documents\Arduino\libraries\SPI
          Multiple libraries were found for "Wire.h"
           Used: C:\Program Files (x86)\Arduino1.8.3\hardware\arduino\avr\libraries\Wire
           Not used: C:\Users\captain\Documents\Arduino\libraries\Wire
          exit status 1
          The set up is pro-mini with htu21DF, NRF24L01+, Door sensor.
          You might see what the problem is from that!
          Thanks for your time.
          YveauxY mfalkviddM 2 Replies Last reply
            exit status 1
            YveauxY Offline
            YveauxY Offline
            @skywatch start by upgrading to development branch (2.2.0 beta) as sleep and interrupts is broken in 2.1.x
              rozpruwaczR Offline
              rozpruwaczR Offline
              rozpruwacz
              @skywatch are you trying to compile this piece of code:
              because this is not a valid c code ...
                exit status 1
                @skywatch try changing to
                int8_t sleepReturn = smartSleep(1, FALLING, 27000);
                Serial.println(sleepReturn);
                • skywatchS Offline
                  skywatchS Offline
                  skywatch
                  Do I replace 2.1.1 with dev or add it over the top? The contents are different comparing the two.
                  And can someone please add this 'broken' bit to the API so others don't waste hours of their time too.
                  • skywatchS Offline
                    skywatchS Offline
                    skywatch
                    @mfalkvidd
                    Thanks this does compile OK (the value of examples) - But wiil it work as expected if sleep is broken in 2.1.1?
                    int8_t smartSleep(1, FALLING, 27000);
                    Also, is this all that is needed for the interrupt to work or do I need to declare it as I would in an arduino sketch?
                    thanks
                    • skywatchS Offline
                      skywatchS Offline
                      skywatch
                      Secret then is it?
                        Secret then is it?
                        @skywatch I think you are confusing "secret" with "unknown".
