  3. UPS
UPS
30 Posts 8 Posters 9.0k Views 8 Watching
  • ben999B
    ben999B
    ben999
    wrote on last edited by ben999
    Guys
    I am planning to use a 4S li-ion 18650 battery.
    Please have a look at my Fritzing sketch :)
    Battery pack will be monitored by this item :
    http://www.ebay.com/itm/4S-6A-Li-ion-Lithium-Batterie-3-7v-18650-Charger-Battery-Protection-Board/382109076738?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
    When off-grid ISDN box and RPi will be powered with that battery via this board :
    http://www.ebay.com/itm/Automatic-Buck-Boost-Step-Up-Down-DC-DC-Power-Supply-Converter-Replace-XL6009/142371180585?ssPageName=STRK%3AMEBIDX%3AIT&var=441392018812&_trksid=p2057872.m2749.l2649
    When on-grid, this charger will charge the battery pack and power ISDN box/Rpi :
    http://www.ebay.com/itm/EU-Plug-4S-16-8V-2A-AC-DC-Charger-Adapter-for-18650-Lithium-Li-ion-Battery-Cell-/262728544983?epid=507598255&hash=item3d2bd772d7:g:m6oAAOSwcLxYJaSF
    Is this the correct way of building my UPS ?
    Can i draw current from the charger to power box and RPi while it is charging ?
    Thanks again for your input/advice.
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      isn't it better to buy ready made solution ? e.g. http://www.powerwalker.com/index.php?page=select&lang=en&cat=dc
      ben999B 1 Reply Last reply
      • rozpruwaczR rozpruwacz
        ben999B
        ben999B
        ben999
        @rozpruwacz
        No DIY, no fun ! :wink:
        gohanG 1 Reply Last reply
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          haha :) yeah, totally agree :P
          • ben999B ben999
            @rozpruwacz
            @ben999 said in UPS:
            @rozpruwacz
            No DIY, no problems, no fun :smile:
            • dbemowskD
              dbemowskD
              I didn't read all the comments, so forgive me if this was mentioned. What if you just used an SLA or AGM battery and connected a battery tender to it. The battery tender should keep the battery topped off without over charging it, and I would think have enough power to power the PI also. Then you are converting 220 down to 12, and if the power goes down, the battery tender will just shut off and the battery would take over. No extra loss in converting 12 to 220 and back to12 again.
                I think nobody wants to convert 12 to 220v
                  ben999B
                  ben999B
                  ben999
                  @dbemowsk
                  Thank you for your message
                  @gohan said in UPS:
                  I think @gohan got me right here. I have a spare "standard" ups at home... but i dont find that tech very sexy (on top of it it's huge)
                  It's fun to scratch head !!!
                  • ben999B
                    ben999B
                    ben999
                    #27
                    Guys,
                    One last question :
                    Can i draw current from the charger to power box and RPi while it is charging the home-made UPS ?
                    I might be ordering this in case it is possible:
                    link text
                    dbemowskD 1 Reply Last reply
                      if the charger is not drawing too much current I'd say yes, but you need a buck converter
                      • ben999B ben999
                        Guys,
                        One last question :
                        link text
                        dbemowskD
                        dbemowskD
                        @ben999 The highest current draw from the list of Pi models is 2.5A on the model 3B (https://www.raspberrypi.org/help/faqs/#powerReqs). If you have a power supply slightly larger than whatever model you are running, you should be good. you just need to be able to supply enough so that the PI has enough to run whatever it is doing and some for charging.
                        • dbemowskD
                          dbemowskD
                          As I mentioned in my previous post a few days ago, you will want a battery tender, and not just a charger. A battery tender will shut off if the battery is fully charged, whereas just using a battery charger could overcharge the battery.
                          12.5k
