  3. UPS
UPS
30 Posts 8 Posters 9.0k Views 8 Watching
    my rpi3 usually uses 0.3A @5v with peaks of 0.6, I think it will be within 6W without problems
    Nca78N 1 Reply Last reply
      @gohan said in UPS:
      Wow that's surprisingly low, I guess it's not loaded too much, not using peripherals and video/hdmi output ?
        actually it is just sitting there headless with a NRF24 connected to it. I checked consumption with relays and with 5 relays on the consumption goes from 0.3 to 0.6A. I have 8 relays but I guess there will not be many of them on at the same time for a prolonged time.
        • ben999B ben999
          Hi guys
          I am using MySensors together with OpenHAB to protect my home and also for access control
          To make more sense I decided that all security related sensors shall be powered via battery
          To make even more sense I run my gateway and the box from an UPS. But...
          That UPS uses 220V AC to keep its 12V DC battery in shape. That's fine.
          But when it goes off the grid it converts 12V DC to 220V AC back to 12V DC for box (which powers Raspberry via USB)
          Would it make sense to have a pack of LiIon batteries that supply directly the box via some DC-DC regulator? And have the LiIon cells charged/balanced via these boards found on eBay?
          I imagine there would be a cut-off voltage unit that would protect the cells.
          Your comments on this matter would be welcome.
          As i am not able to design any electronics, best would be to use board found on eBay or similar...
          Thanks a lot for reading and even more thanks for your input
          See ya
          alexsh1A
          alexsh1A
          alexsh1
          @ben999
          I'm using on of these
          http://www.pimodulescart.com/shop/
          I have LiFePO4 4000mAh battery pack - this is enough to weather the longest power outage
          • alexsh1A alexsh1
            @ben999
            @alexsh1 thank you for the link.
            I'll give a try to the AliExpress version first for financial reasons, but I'll check yours if the cheap one fails.
            gohanG alexsh1A 2 Replies Last reply
            • Nca78N Nca78
              @Nca78 keep in mind that the one I posted is missing battery protection, so you need to have put one (unless your batteries have internal protection)
              • Nca78N Nca78
                alexsh1A
                alexsh1A
                alexsh1
                @Nca78 you are not too rich to spend you money on cheap stuff, are you? :-)
                If you want a real UPS with many feathers programmable buttons and LEDs, it cannot be super cheap. Anyway, it's your call
                  @gohan said in UPS:
                  Yes on the circuit you linked I'll put a 18650 with protection, I will test it on a wifi gateway.
                  For RPI I'll use the "hat" with battery that I linked in message above, only 17€ with battery.
                  • ben999B
                    ben999B
                    ben999
                    wrote on last edited by ben999
                    Guys
                    I am planning to use a 4S li-ion 18650 battery.
                    Please have a look at my Fritzing sketch :)
                    Battery pack will be monitored by this item :
                    http://www.ebay.com/itm/4S-6A-Li-ion-Lithium-Batterie-3-7v-18650-Charger-Battery-Protection-Board/382109076738?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                    When off-grid ISDN box and RPi will be powered with that battery via this board :
                    http://www.ebay.com/itm/Automatic-Buck-Boost-Step-Up-Down-DC-DC-Power-Supply-Converter-Replace-XL6009/142371180585?ssPageName=STRK%3AMEBIDX%3AIT&var=441392018812&_trksid=p2057872.m2749.l2649
                    When on-grid, this charger will charge the battery pack and power ISDN box/Rpi :
                    http://www.ebay.com/itm/EU-Plug-4S-16-8V-2A-AC-DC-Charger-Adapter-for-18650-Lithium-Li-ion-Battery-Cell-/262728544983?epid=507598255&hash=item3d2bd772d7:g:m6oAAOSwcLxYJaSF
                    Is this the correct way of building my UPS ?
                    Can i draw current from the charger to power box and RPi while it is charging ?
                    Thanks again for your input/advice.
                    • rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      isn't it better to buy ready made solution ? e.g. http://www.powerwalker.com/index.php?page=select&lang=en&cat=dc
                      ben999B 1 Reply Last reply
                      • rozpruwaczR rozpruwacz
                        ben999B
                        ben999B
                        ben999
                        @rozpruwacz
                        No DIY, no fun ! :wink:
                        gohanG 1 Reply Last reply
                        • rozpruwaczR
                          rozpruwaczR
                          rozpruwacz
                          haha :) yeah, totally agree :P
                          • ben999B ben999
                            @rozpruwacz
                            @ben999 said in UPS:
                            @rozpruwacz
                            No DIY, no problems, no fun :smile:
                            • dbemowskD
                              dbemowskD
                              I didn't read all the comments, so forgive me if this was mentioned. What if you just used an SLA or AGM battery and connected a battery tender to it. The battery tender should keep the battery topped off without over charging it, and I would think have enough power to power the PI also. Then you are converting 220 down to 12, and if the power goes down, the battery tender will just shut off and the battery would take over. No extra loss in converting 12 to 220 and back to12 again.
                                I think nobody wants to convert 12 to 220v
                                  ben999B
                                  ben999B
                                  ben999
                                  @dbemowsk
                                  Thank you for your message
                                  @gohan said in UPS:
                                  I think @gohan got me right here. I have a spare "standard" ups at home... but i dont find that tech very sexy (on top of it it's huge)
                                  It's fun to scratch head !!!
                                  • ben999B
                                    ben999B
                                    ben999
                                    #27
                                    Guys,
                                    One last question :
                                    Can i draw current from the charger to power box and RPi while it is charging the home-made UPS ?
                                    I might be ordering this in case it is possible:
                                    link text
                                    dbemowskD 1 Reply Last reply
                                      if the charger is not drawing too much current I'd say yes, but you need a buck converter
                                      • ben999B ben999
                                        Guys,
                                        One last question :
                                        link text
                                        dbemowskD
                                        dbemowskD
                                        @ben999 The highest current draw from the list of Pi models is 2.5A on the model 3B (https://www.raspberrypi.org/help/faqs/#powerReqs). If you have a power supply slightly larger than whatever model you are running, you should be good. you just need to be able to supply enough so that the PI has enough to run whatever it is doing and some for charging.
                                        • dbemowskD
                                          dbemowskD
                                          As I mentioned in my previous post a few days ago, you will want a battery tender, and not just a charger. A battery tender will shut off if the battery is fully charged, whereas just using a battery charger could overcharge the battery.
                                          12.5k
