  3. Cheap dirty way to send a raw-mysensors message?
13 Posts 7 Posters 5.1k Views 10 Watching
  • cimba007C Offline
    cimba007C Offline
    cimba007
    wrote on last edited by cimba007
    is it possible to "inject" a sensor-value into the gateway by hand-crafting a data packet?
    I recently got some of these little guys (https://wemakethings.net/chirp/)
    Now my idea was to slap a NRF24 on the ISP header (+2 extra pins for CE and CSN).
    So far so good .. now I want to craft a simple packet to get data to my gateways ..
    This is what I got so far but my gateway is not picking up anything.
        radio.begin(); // Start up the radio
        radio.setDataRate(RF24_250KBPS);
        radio.setAutoAck(1); // Ensure autoACK is enabled
        radio.setRetries(15,15); // Max delay between retries & number of retries
        byte station_address[] = { 0x00, 0xFC, 0xE1, 0xA8, 0xA8 };
        //byte station_address[] = { 0xA8, 0xA8, 0xE1, 0xFC, 0x00 };
        radio.openWritingPipe(station_address); // Write to device address 0x00,0xFC,0xE1,0xA8,0xA8
        radio.stopListening();
        byte test[] = { 250, 250, 0, 0b10000001 /* version_length */, 0b00100001,  7 /* S_HUM */ , 1 /* V_HUM */, 123};
        radio.write(test,8);
    And no .. I can't cram the mysensors library on the ATTINY44.
    I am currently happe that I got the basic chirp functunality for measuring the humidity of the soil, attiny debug serial and nrf24 all running on 4k of flash.
    Der Sketch verwendet **4046 Bytes (98%)** des Programmspeicherplatzes. Das Maximum sind 4096 Bytes.
    Globale Variablen verwenden 150 Bytes (58%) des dynamischen Speichers, 106 Bytes für lokale Variablen verbleiben. Das Maximum sind 256 Bytes.
    If anybody know if this is even possible I would like to hear from you.
    Best regards Marc
      The problem I think is that the gateway needs the node to register on the network so it knows what it should expect receiving, it is a 2 way communication not like those devices using RF link that only transmit and other only receives.
      Have you evaluated the button size node on openhardware? I think it could be an alternative for your needs
      • cimba007C Offline
        cimba007C Offline
        cimba007
        @gohan Thanks for your response. The problem is that I already have 5 "chirps" and just later came up with the idea of adding nrf24 to them. I might try to add a "relay" node which will listen for "normal" rf24 packets and then send them to my gateway using the mysensors library.
        • cimba007C Offline
          cimba007C Offline
          cimba007
          After many hours trial and error I present you .. the raw-mysensors-client!!
          MyGateway: ESP8266 + mysensorsMQTT
          MyNode: https://github.com/Miceuz/PlantWateringAlarm
          MyNode-MCU: Attiny44 (MemoryFootprint: 87% of 4KB)
          ArduinoCore: https://github.com/SpenceKonde/ATTinyCore
          ArduinoCore-PinLayout: Counterclockwise (like AttinyCore)
          Note: The default "counterclockwise"pinout is the alternate pinout shown here: https://github.com/SpenceKonde/ATTinyCore/blob/master/avr/extras/ATtiny_x4.md
          The important hint is here (http://tmrh20.github.io/RF24/ATTiny.html)
          Connect MOSI of the RF24 to PA5 of the attiny and MISO of the RF24 to PA6 of the attiny.
          CE = 8
          CSN = 7
          To get the connection done right DONT .. i mean DO NOT BECAUSE IT DOESNT FUCKING WORK connect MOSI of the RF24 to MOSI of the attiny. RF24 uses a embedded implementation of the USI-engine found on some AtTiny's.
          radio-initilisation
              //radio.setPayloadSize(8);
              radio.enableDynamicPayloads();
              radio.setPALevel(RF24_PA_MAX);
              byte tx_address[] = { 0x00, 0xFC, 0xE1, 0xA8, 0xA8 };
              //byte tx_address[] = { 0xA8, 0xA8, 0xE1, 0xFC, 0x00 };
              radio.openWritingPipe(tx_address);
          Send-Function:
          void sendHumidity(uint16_t humidity)
              // snprintf_P(_fmtBuffer, MY_GATEWAY_MAX_SEND_LENGTH, PSTR("%s/%d/%d/%d/%d/%d"), prefix, message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type);
              // X8X22<\0><\n>!<7>7AY0;255;3;0;9;TSF:MSG:READ,50-50-0,s=55,c=1,t=7,pt=1,l=1,sg=0:65<\n>
              // 0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/50/55/1/0/7<\n>
              #define LAST_NODE_ID  50  // last
              #define NODE_ID       50  // sender
              #define GATEWAY_ID    0   // destination
                                        // version_length     // 5 bit - Length of payload // 1 bit - Signed flag // 2 bit - Protocol version
                                        // command_ack_payload // 3 bit - Payload data type // 1 bit - Is ack messsage - Indicator that this is the actual ack message. // 1 bit - Request an ack - Indicator that receiver should send an ack back. // 3 bit - Command type
              #define SENSOR_TYPE   7   // type S_HUM = 7
              #define SENSOR_ID     55  // sensor-id
              byte test[] = { LAST_NODE_ID, NODE_ID, GATEWAY_ID, 0b00010010, 0b01100001,  SENSOR_TYPE, SENSOR_ID, (uint8_t)(humidity & 0x00FF), (uint8_t)((humidity >> 8) & 0x00FF),  0x00 };
              radio.write(test,9);
          I am not quite sure yet if the message-types etc. are right but I am trying to find this out. 'A' (dec 65) is the "value" of my humidity .. next step is to make this a real value ofc.
          Proof at domoticz:
          0_1499525234377_upload-22170821-6116-4d1a-a08b-c0631b3fac15
          @gohan: In the file MyConfig.h I commented this out:
          // #define MY_REGISTRATION_FEATURE
          This will skip the whole hasse of registering the client properly (which I can't .. remember 87% of flash is full)
          mfalkviddM M 2 Replies Last reply
          • cimba007C cimba007
            CE = 8
            CSN = 7
            radio-initilisation
            Send-Function:
            Proof at domoticz:
            @cimba007 very nice work! Great way to be compatible with the MySensors protocol/ecosystem on a limited device when the full MySensors feature set is not needed.
            • cimba007C Offline
              cimba007C Offline
              cimba007
              I might have run into a bug in the calculation of message length.
              In my handcrafted packet I use this as the 4thy byte send:
              0b10000001
              So to craft this I looked at MyMessage.h which showed me this:
              uint8_t version_length;		 // 2 bit - Protocol version
              So from my understanding:
              Protocol Version = 2 => 0b10
              Signed Flag = 0 => 0b0
              Length of Payload = 1 = 0b00001
              Which results in 0b10 0 00001 = 0b10000001
              But I get this error:
              LEN,8!=23
              So .. where might this come from?
              Mycontroller received a packet with the length of 8 but expected a packet with the length of .. 23 ?!
              #define mGetLength(_message) ((uint8_t)BF_GET(_message.version_length, 3, 5)) //!< Get length field
              Which in essential is BF_GET ..
              #define BF_GET(y, start, len)   ( ((y)>>(start)) & BIT_MASK(len) ) //!< Extract a bitfield of length 'len' starting at bit 'start' from 'y'
              So what is happening?
              BF_GET(0b10000001, 3, 5)   ( ((0b10000001)>>(3)) & BIT_MASK(5) ) //!< Extract a bitfield of length 'len' starting at bit 'start'
              Whoops? This will throw away all the length-information!!!
              (0b10000001)>>(3)
              This should result in:
              0b11110000 & BIT_MASK5 = 0b1111000 & 0b00011111 = 0b00010000 = 16 decimal
              const uint8_t expectedMessageLength = HEADER_SIZE + (mGetSigned(_msg) ? MAX_PAYLOAD : msgLength);
              const uint8_t expectedMessageLength = 7+ 16); // = 23
              Yeah .. the lib is right .. 8 != 23 .. but the handcrafted length = 1 + header_length (7) = 8
              Am I wrong or is this a bug?
              Edit: I might have read the comments in the source code the wrong way
              • cimba007C Offline
                cimba007C Offline
                cimba007
                From time to time I run into this bug .. not sure if this is related:
                0;255;3;0;9;TSM:READY:NWD REQ<\n>
                0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:<\n>
                Fatal exception 28(LoadProhibitedCause):<\n>
                epc1=0x40202704, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x00000000<\n>
                <\r><\n>
                • N Offline
                  N Offline
                  I wish the chirp had been designed with an atmega328p. Cost and footprint for the smd is similar I believe
                  • cimba007C Offline
                    cimba007C Offline
                    cimba007
                    Its not "that" bad .. the Attiny44A is compatible with Arduino thanks to https://github.com/SpenceKonde/ATTinyCore
                    For now I got Humidity and Voltage(VCC) running up fine.
                    • K Offline
                      K Offline
                      kasparsd
                      @cimba007 Could you please share your latest working code for generating the packet?
                      I've created an ATTiny841 node with the RFM69CW radio (with a modified RFM69 library to match the radio config registers of MySensors) but the Raspberry Pi gateway is seeing the packets different.
                      Here is the sending part:
                      byte test[] = {
                        1, // last
                        1, // sender
                        255, // destination
                        0b00001010, // version_length: 2 bit - Protocol version (2), 1 bit - Signed flag (no), 5 bit - Length of payload (1 byte)
                        0b00100001, // command_ack_payload: 3 bit - Command type (C_SET), 1 bit - Request an ack (no), 1 bit - Is ack message (no), 3 bit - Payload data type (P_BYTE)
                        16, // type: V_TRIPPED
                        3, // sensor ID
                        1 // Value: 1
                      radio.send(255, packet, strlen(packet));
                      which is received as:
                      DEBUG TSF:MSG:READ,10-255-33,s=0,c=3,t=1,pt=0,l=2,sg=0:
                      DEBUG !TSF:MSG:LEN,6!=9
                      where none of the fields match the packet :(
                      Here is the packet definition in core/MyMessage.h:
                      uint8_t last;            	 ///< 8 bit - Id of last node this message passed
                      uint8_t sender;          	 ///< 8 bit - Id of sender node (origin)
                      uint8_t destination;     	 ///< 8 bit - Id of destination node
                       * 2 bit - Protocol version<br>
                       * 1 bit - Signed flag<br>
                       * 5 bit - Length of payload
                       * 3 bit - Command type<br>
                       * 1 bit - Request an ack - Indicator that receiver should send an ack back<br>
                       * 1 bit - Is ack message - Indicator that this is the actual ack message<br>
                       * 3 bit - Payload data type
                      uint8_t command_ack_payload;
                      uint8_t type; ///< 8 bit - Type varies depending on command
                      uint8_t sensor; ///< 8 bit - Id of sensor that this message concerns.
                       * Each message can transfer a payload. We add one extra byte for string
                       * terminator \0 to be "printable" this is not transferred OTA
                       * This union is used to simplify the construction of the binary data types transferred.
                      union {
                          uint8_t bValue; ///< unsigned byte value (8-bit)
                          uint16_t uiValue; ///< unsigned integer value (16-bit)
                          int16_t iValue; ///< signed integer value (16-bit)
                          uint32_t ulValue; ///< unsigned long value (32-bit)
                          int32_t lValue; ///< signed long value (32-bit)
                          struct { //< Float messages
                              float fValue;
                              uint8_t fPrecision; ///< Number of decimals when serializing
                          struct {  //< Presentation messages
                              uint8_t version; ///< Library version
                              uint8_t sensorType; ///< Sensor type hint for controller, see table above
                          char data[MAX_PAYLOAD + 1]; ///< Buffer for raw payload data
                      } __attribute__((packed)); ///< Doxygen will complain without this comment
                      I'll try and log the raw incoming packet on the Pi side just to confirm that the radio config is actually matching.
                      K 1 Reply Last reply
                      • K kasparsd
                        byte test[] = {
                          1, // last
                          1, // sender
                          255, // destination
                          3, // sensor ID
                          1 // Value: 1
                        union {
                                float fValue;
                        K Offline
                        K Offline
                        kasparsd
                        Turns out that the RFM69 arduino library was missing two additional bytes from the packet header -- rfm69_header_t.version and rfm69_header_t.sequenceNumber in RFM69::sendFrame() (see the diff).
                          select();
                          SPI.transfer(REG_FIFO | 0x80); // Select the FIFO write register.
                          SPI.transfer(bufferSize + 5); // rfm69_header_t.packetLen
                          SPI.transfer(toAddress); // rfm69_header_t.recipient
                          SPI.transfer(1); // RFM69_PACKET_HEADER_VERSION = (1u) rfm69_header_t.version header version (20180128tk: >=3.0.0 fused with controlFlags)
                          SPI.transfer(_address); // rfm69_header_t.sender
                          SPI.transfer(CTLbyte); // rfm69_header_t.controlFlags
                          SPI.transfer(0); // rfm69_header_t.sequenceNumber
                          for (uint8_t i = 0; i < bufferSize; i++)
                            SPI.transfer(((uint8_t*) buffer)[i]);
                          unselect();
                        So after adding SPI.transfer(1); as rfm69_header_t.version and SPI.transfer(0); as rfm69_header_t.sequenceNumber the packets are now being parsed correctly:
                        DEBUG TSF:MSG:READ,1-1-255,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                        DEBUG TSF:MSG:BC
                        • B Offline
                          B Offline
                          blachner
                          @kasparsd I'm also interested in using ATTiny with a RFM69CW module as a MySensor node. How have you initialized the radio with your modified library? Can you show a complete example?
                            CE = 8
                            CSN = 7
                            radio-initilisation
                            Send-Function:
                            Proof at domoticz:
                            M Offline
                            M Offline
                            Mickey
                            @cimba007
                            Can you post the complete code of the chirp including the headers?
                            Did you only include these libraries:
                            #include "nRF24L01.h"
                            #include "RF24.h"
