  3. [solved] RPI Gateway with RFM95 does not receive any nodes
27 Posts 2 Posters 7.8k Views 3 Watching
    micropet
    My gateway will work, I think.
    Pity,
    I am using an Arduino Pro mini.
    I can make a node with esp8266.
    But I can not do that today, I think I have time for it tomorrow.
    • M micropet
      Pity,
      @micropet no rush, you've had to wait a long time to get any help :wink:
      Just post here when/if you have some news. If you are unable to find an esp I can probably find a Pro Mini and build a node.
        micropet
        Have a node with a NodeMCU built.
        Does not work either.
        At the gateway comes nothing.
        Since I must look further.
        22820 !TSM:FPAR:NO REPLY
        22822 TSM:FPAR
        24824 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        26831 !TSM:FPAR:NO REPLY
        26833 TSM:FPAR
        28835 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        30842 !TSM:FPAR:NO REPLY
        30844 TSM:FPAR
        32846 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        34853 !TSM:FPAR:FAIL
        34854 TSM:FAIL:CNT=1
        34856 TSM:FAIL:DIS
        34858 TSF:TDI:TSL
        44860 TSM:FAIL:RE-INIT
        44861 TSM:INIT
        44878 TSM:INIT:TSP OK
        44880 TSF:SID:OK,ID=33
        44882 TSM:FPAR
        46885 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        48892 !TSM:FPAR:NO REPLY
        48894 TSM:FPAR
        50896 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        52903 !TSM:FPAR:NO REPLY
        52905 TSM:FPAR
        54907 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        56914 !TSM:FPAR:NO REPLY
        56916 TSM:FPAR
        58918 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        60925 !TSM:FPAR:FAIL
        60926 TSM:FAIL:CNT=2
        60928 TSM:FAIL:DIS
        60930 TSF:TDI:TSL
          micropet
          A Node with a Pro mini or a Teensy would help me more.
          All my RFM69 Nodes have a Pro mini (50 pcs)
          The TTN Nodes a Pro mini or a Teensy. (Approx. 20 pieces)
            micropet
            Now I do not understand anything anymore.
            I have made an update on the RPI and compiled the gateway software again.
            I had already done more than 10 times.
            After the start of the RPI nothing worked.
            Multiple resets of the NodeMCU also brought nothing.
            I pulled the micro usb plug and plugged again - suddenly it works. WAU
            Then I must have a fault in the wiring between the RFM95 and the Arduino Pro.
              Just for info: I had set up 5 pieces. All do not work.
            ./bin/mysgw -d
            mysgw: Starting gateway...
            mysgw: MCO:BGN:INIT GW,CP=RLNG----,VER=2.2.0-beta
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            mysgw: MCO:BGN:STP
            mysgw: MCO:BGN:INIT OK,TSP=1
            mysgw: connected to 192.168.0.23
            mysgw: MQTT connected
            mysgw: Sending message on topic: mysensors2-out/0/255/0/0/18
            mysgw: TSF:MSG:READ,33-33-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
            mysgw: Sending message on topic: mysensors2-out/33/3/1/0/16
            mysgw: TSF:MSG:READ,33-33-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
              micropet
              I have connected my Arduino Pro Nodes. They do not work.
              The ESP Node has been running since last night without problems.
              Can you try an Arduino?
              • M micropet
                @micropet great work. I should be able to set up an Arduino node tomorrow. The forecast shows rain anyway :)
                  micropet
                  Fine.
                  I'm just trying a Teensy LC Node.
                  See you tomorrow.
                  Here in Essen, Germany, it should also rain. :)
                    micropet
                    The Teensy LC also works.
                    So the problem is the Arduino Pro mini.
                    • M micropet
                      @micropet I'm unfortunately not able to reproduce the problem. This is the output of my Pro Mini 3.3V node:
                      0 MCO:BGN:INIT NODE,CP=RLNNA---,VER=2.2.0-beta
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      16 TSM:INIT:TSP OK
                      18 TSF:SID:OK,ID=6
                      20 TSM:FPAR
                      71 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      1130 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      1134 TSF:MSG:FPAR OK,ID=0,D=1
                      2078 TSM:FPAR:OK
                      2078 TSM:ID
                      2080 TSM:ID:OK
                      2082 TSM:UPL
                      2183 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2232 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2238 TSF:MSG:PONG RECV,HP=1
                      2242 TSM:UPL:OK
                      2244 TSM:READY:ID=6,PAR=0,DIS=1
                      2375 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2426 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2578 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                      2689 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      4814 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor
                      4925 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                      5027 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
                      5036 MCO:REG:REQ
                      5132 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      5183 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      5189 MCO:PIM:NODE REG=1
                      5191 MCO:BGN:STP
                      5193 MCO:BGN:INIT OK,TSP=1
                      5326 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                      7438 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                      9549 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                      11661 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                      13774 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                      15886 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                      Gateway:
                      Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:BC
                      Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:FPAR REQ,ID=6
                      Jul  8 11:56:14 raspi1 mysgw: TSF:PNG:SEND,TO=0
                      Jul  8 11:56:14 raspi1 mysgw: TSF:CKU:OK
                      Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:GWL OK
                      Jul  8 11:56:15 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:PINGED,ID=6,HP=1
                      Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      Jul  8 11:56:17 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                      Jul  8 11:56:17 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/0/0/17
                      Jul  8 11:56:17 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      Jul  8 11:56:17 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/3/0/6
                      Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
                      Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/3/0/11
                      Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                      Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/3/0/12
                      Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
                      Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/0/0/0
                      Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                      Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:21 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                      Jul  8 11:56:21 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:24 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                      Jul  8 11:56:24 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:26 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                      Jul  8 11:56:26 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:28 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                      Jul  8 11:56:28 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:30 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                      Jul  8 11:56:30 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:32 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                      Jul  8 11:56:32 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:34 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                      Jul  8 11:56:34 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:36 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                      Jul  8 11:56:36 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Jul  8 11:56:38 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                      Jul  8 11:56:38 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                      Sketch for the node: (same as for the esp8266 except that I removed the pin defines)
                      //#define MY_RADIO_NRF24
                      #define MY_RADIO_RFM95
                      #define SKETCH_MAJOR_VER "1"
                      #define SKETCH_MINOR_VER "0"
                      #define PRIMARY_CHILD_ID 3
                      #define SECONDARY_CHILD_ID 4
                        static uint8_t sentValue = 2;
                        wait(5);
                        uint8_t  value = !sentValue;
                        if (value != sentValue) {
                          send(msg.set(value == HIGH));
                          sentValue = value;
                        wait(2000);
                      Wiring as per https://www.mysensors.org/build/connect_radio#rfm69-&-arduino
                        micropet
                        Thank you.
                        Now it works.
                        The trick is D100 must be on pin 2.
                        I try to make the pin assignments the same for all nodes (STM32, Arduino Pro, Teensy LC Tennsy 3.1 / 3.6, ESP8266).
                        D100 I had put on pin 6 and
                        #define MY_RFM95_IRQ_PIN 6
                        In the sketch.
                        That was the mistake with the Arduino.
                        On all other platforms it works.
                        Many Thanks. I had already given up.
                        • M micropet
                          Thank you.
                          Now it works.
                          In the sketch.
                          #25
                          @micropet great that you were able to isolate the problem. Thanks for the cooperation during troubleshooting.
                          In case you didn't already know, only pin 2 and 3 on Pro Mini can be used for hardware interrupts. See https://www.arduino.cc/en/Main/ArduinoBoardProMini for details.
                            micropet
                            wrote on last edited by micropet
                            #26
                            I thank you. Now I have come a whole lot further.
                            I know that only the pins 2 and 3 are IRQ capable.
                            I thought I would have read that the IRQ is not used, but the pin is only polled.
                            This is how it is done with the LMIC Lib at The Things Network.
                            I have still determined when I use the following at the Arduino:
                            #define MY_RFM95_RST_PIN 4
                            The Arduino does not send anything.
                            It works with Teensy or ESP.
                            The sleep mode with the teensy does also not always work.
                            Sometimes he freezes.
                            I will continue tomorrow....
                              micropet
                              #27
                              For information on electricity consumption:
                              Tensy 3.2 mit RFM96HW 130 µA
                              Tensy 3.2 mit RFM96HW BME280 130 µA
                              Tensy 3.2 mit RFM96HW BME280 BH1750 165 µA
                              Teensy LC mit RFM95 90 µA
                              Arduino Pro mit RFM95 DS18b20 6 µA
                              Arduino Pro mit RFM95 BME280 BH1750 11 µA
                              12.5k
