  3. [solved] RPI Gateway with RFM95 does not receive any nodes
27 Posts 2 Posters 7.8k Views 3 Watching
    micropet
    Thus, the node is in operation. The gateway does not show anything new.
    I need mqtt. My RFM69 Nodes (433 MHz and 868 MHz) also run with mqtt.
    The Node output is:
    0 MCO:BGN:INIT NODE,CP=RLNNA---,VER=2.2.0-beta
    4 TSM:INIT
    4 TSF:WUR:MS=0
    6 RFM95:INIT
    8 RFM95:INIT:PIN,CS=10,IQP=4,IQN=0
    22 RFM95:PTX:LEVEL=5
    24 TSM:INIT:TSP OK
    26 TSM:INIT:STATID=150
    28 TSF:SID:OK,ID=150
    30 TSM:FPAR
    32 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    2037 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4046 !TSM:FPAR:NO REPLY
    4048 TSM:FPAR
    4050 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    6057 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8067 !TSM:FPAR:NO REPLY
    8069 TSM:FPAR
    8071 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    10076 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    12085 !TSM:FPAR:NO REPLY
    12087 TSM:FPAR
    12089 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    14094 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    16103 !TSM:FPAR:FAIL
    16105 TSM:FAIL:CNT=1
    16107 TSM:FAIL:DIS
    16109 TSF:TDI:TSL
    16111 RFM95:RSL
    26114 TSM:FAIL:RE-INIT
    26116 TSM:INIT
    26118 RFM95:INIT
    26120 RFM95:INIT:PIN,CS=10,IQP=4,IQN=0
    26134 RFM95:PTX:LEVEL=5
    26136 TSM:INIT:TSP OK
    26138 TSM:INIT:STATID=150
    26140 TSF:SID:OK,ID=150
    26144 TSM:FPAR
    26146 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    28151 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    30162 !TSM:FPAR:NO REPLY
    30164 TSM:FPAR
    30167 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    32172 TSF:MSG:SEND,150-150-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    • M micropet
      The Node output is:
      4 TSM:INIT
      4 TSF:WUR:MS=0
      6 RFM95:INIT
      24 TSM:INIT:TSP OK
      30 TSM:FPAR
      4048 TSM:FPAR
      8069 TSM:FPAR
      12087 TSM:FPAR
      16107 TSM:FAIL:DIS
      16109 TSF:TDI:TSL
      16111 RFM95:RSL
      26116 TSM:INIT
      26118 RFM95:INIT
      26144 TSM:FPAR
      30164 TSM:FPAR
      @micropet I understand you prefer mqtt. But if you are able to verify that the gateway works with ethernet, we would know that the problem is mqtt related. Now the problem might be related to anything.
        micropet
        Yes I understand.
        I'm just checking the pin assignment of the node.
        How did you connect the Node to the RFM95?
          micropet
          I use the same connections as for a TTN node.
          Board is Arduino Pro mini.
          10 NSS CS
          13 SCK
          11 MOSI
          12 MISO
          4 DI00
          5 DIO1
          And have in the sketch:
          #define MY_RFM95_CS_PIN 10 // NSS
          #define MY_RFM95_IRQ_PIN 4 // IRQ D100
          • M micropet
            Yes I understand.
            @micropet mqtt works:
            pi@raspi1:~/MySensors $ sudo ./bin/mysgw -d
            mysgw: Starting gateway...
            mysgw: MCO:BGN:INIT GW,CP=RLNG----,VER=2.2.0-beta
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            mysgw: MCO:BGN:STP
            mysgw: MCO:BGN:INIT OK,TSP=1
            mysgw: connected to 192.168.1.101
            mysgw: MQTT connected
            mysgw: Sending message on topic: mysensors-rfm95-out/0/255/0/0/18
            mysgw: TSF:MSG:READ,102-102-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            mysgw: TSF:MSG:BC
            mysgw: TSF:MSG:FPAR REQ,ID=102
            mysgw: TSF:PNG:SEND,TO=0
            mysgw: TSF:CKU:OK
            mysgw: TSF:MSG:GWL OK
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            mysgw: TSF:MSG:PINGED,ID=102,HP=1
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
            mysgw: Sending message on topic: mysensors-rfm95-out/102/255/0/0/17
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            mysgw: Sending message on topic: mysensors-rfm95-out/102/255/3/0/6
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
            mysgw: Sending message on topic: mysensors-rfm95-out/102/255/3/0/11
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            mysgw: Sending message on topic: mysensors-rfm95-out/102/255/3/0/12
            mysgw: TSF:MSG:READ,102-102-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
            mysgw: Sending message on topic: mysensors-rfm95-out/102/3/0/0/0
            mysgw: TSF:MSG:READ,102-102-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            mysgw: TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
            mysgw: TSF:MSG:READ,102-102-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
            mysgw: Sending message on topic: mysensors-rfm95-out/102/3/1/0/16
            mysgw: TSF:MSG:READ,102-102-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
            I used this configure command:
            ./configure --my-gateway=mqtt --my-controller-ip-address=192.168.1.101 --my-mqtt-publish-topic-prefix=mysensors-rfm95-out --my-mqtt-subscribe-topic-prefix=mysensors-rfm95-in --my-mqtt-client-id=mygateway-rfm95 --my-transport=rfm95 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
            For the wiring, I used the instructions for rfm69 on the raspberry pi gateway page.
            • mfalkviddM
              For the node, I used this sketch (esp8266 nodemcu):
              //#define MY_RADIO_NRF24
              #define MY_RADIO_RFM95
              #define MY_RFM95_CS_PIN D8 // NSS
              #define MY_RFM95_IRQ_PIN D1 // IRQ DIO0
              #define MY_RFM95_RST_PIN D3 // Reset, not connected
              #define SKETCH_MAJOR_VER "1"
              #define SKETCH_MINOR_VER "0"
              #define PRIMARY_CHILD_ID 3
              #define SECONDARY_CHILD_ID 4
                static uint8_t sentValue = 2;
                wait(5);
                uint8_t  value = !sentValue;
                if (value != sentValue) {
                  send(msg.set(value == HIGH));
                  sentValue = value;
                wait(2000);
                micropet
                My gateway will work, I think.
                Pity,
                I am using an Arduino Pro mini.
                I can make a node with esp8266.
                But I can not do that today, I think I have time for it tomorrow.
                • M micropet
                  Pity,
                  @micropet no rush, you've had to wait a long time to get any help :wink:
                  Just post here when/if you have some news. If you are unable to find an esp I can probably find a Pro Mini and build a node.
                    micropet
                    Have a node with a NodeMCU built.
                    Does not work either.
                    At the gateway comes nothing.
                    Since I must look further.
                    22820 !TSM:FPAR:NO REPLY
                    22822 TSM:FPAR
                    24824 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    26831 !TSM:FPAR:NO REPLY
                    26833 TSM:FPAR
                    28835 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    30842 !TSM:FPAR:NO REPLY
                    30844 TSM:FPAR
                    32846 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    34853 !TSM:FPAR:FAIL
                    34854 TSM:FAIL:CNT=1
                    34856 TSM:FAIL:DIS
                    34858 TSF:TDI:TSL
                    44860 TSM:FAIL:RE-INIT
                    44861 TSM:INIT
                    44878 TSM:INIT:TSP OK
                    44880 TSF:SID:OK,ID=33
                    44882 TSM:FPAR
                    46885 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    48892 !TSM:FPAR:NO REPLY
                    48894 TSM:FPAR
                    50896 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    52903 !TSM:FPAR:NO REPLY
                    52905 TSM:FPAR
                    54907 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    56914 !TSM:FPAR:NO REPLY
                    56916 TSM:FPAR
                    58918 TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    60925 !TSM:FPAR:FAIL
                    60926 TSM:FAIL:CNT=2
                    60928 TSM:FAIL:DIS
                    60930 TSF:TDI:TSL
                      micropet
                      A Node with a Pro mini or a Teensy would help me more.
                      All my RFM69 Nodes have a Pro mini (50 pcs)
                      The TTN Nodes a Pro mini or a Teensy. (Approx. 20 pieces)
                        micropet
                        Now I do not understand anything anymore.
                        I have made an update on the RPI and compiled the gateway software again.
                        I had already done more than 10 times.
                        After the start of the RPI nothing worked.
                        Multiple resets of the NodeMCU also brought nothing.
                        I pulled the micro usb plug and plugged again - suddenly it works. WAU
                        Then I must have a fault in the wiring between the RFM95 and the Arduino Pro.
                          Just for info: I had set up 5 pieces. All do not work.
                        ./bin/mysgw -d
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        mysgw: connected to 192.168.0.23
                        mysgw: Sending message on topic: mysensors2-out/0/255/0/0/18
                        mysgw: TSF:MSG:READ,33-33-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                        mysgw: Sending message on topic: mysensors2-out/33/3/1/0/16
                        mysgw: TSF:MSG:READ,33-33-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                          micropet
                          I have connected my Arduino Pro Nodes. They do not work.
                          The ESP Node has been running since last night without problems.
                          Can you try an Arduino?
                          • M micropet
                            @micropet great work. I should be able to set up an Arduino node tomorrow. The forecast shows rain anyway :)
                              micropet
                              Fine.
                              I'm just trying a Teensy LC Node.
                              See you tomorrow.
                              Here in Essen, Germany, it should also rain. :)
                                micropet
                                The Teensy LC also works.
                                So the problem is the Arduino Pro mini.
                                • M micropet
                                  @micropet I'm unfortunately not able to reproduce the problem. This is the output of my Pro Mini 3.3V node:
                                  4 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  16 TSM:INIT:TSP OK
                                  18 TSF:SID:OK,ID=6
                                  20 TSM:FPAR
                                  71 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  1130 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  1134 TSF:MSG:FPAR OK,ID=0,D=1
                                  2078 TSM:FPAR:OK
                                  2078 TSM:ID
                                  2080 TSM:ID:OK
                                  2082 TSM:UPL
                                  2183 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2232 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2238 TSF:MSG:PONG RECV,HP=1
                                  2242 TSM:UPL:OK
                                  2244 TSM:READY:ID=6,PAR=0,DIS=1
                                  2375 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  2426 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  2578 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                                  2689 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  4814 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor
                                  4925 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                  5027 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
                                  5036 MCO:REG:REQ
                                  5132 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                  5183 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  5189 MCO:PIM:NODE REG=1
                                  5191 MCO:BGN:STP
                                  5193 MCO:BGN:INIT OK,TSP=1
                                  5326 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  7438 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  9549 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  11661 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  13774 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  15886 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  Gateway:
                                  Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:BC
                                  Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:FPAR REQ,ID=6
                                  Jul  8 11:56:14 raspi1 mysgw: TSF:PNG:SEND,TO=0
                                  Jul  8 11:56:14 raspi1 mysgw: TSF:CKU:OK
                                  Jul  8 11:56:14 raspi1 mysgw: TSF:MSG:GWL OK
                                  Jul  8 11:56:15 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                  Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:PINGED,ID=6,HP=1
                                  Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  Jul  8 11:56:16 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  Jul  8 11:56:17 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                                  Jul  8 11:56:17 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/0/0/17
                                  Jul  8 11:56:17 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  Jul  8 11:56:17 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/3/0/6
                                  Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
                                  Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/3/0/11
                                  Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                  Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/255/3/0/12
                                  Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
                                  Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/0/0/0
                                  Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                  Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  Jul  8 11:56:19 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                                  Jul  8 11:56:19 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:21 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                                  Jul  8 11:56:21 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:24 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                                  Jul  8 11:56:24 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:26 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                                  Jul  8 11:56:26 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:28 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                                  Jul  8 11:56:28 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:30 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                                  Jul  8 11:56:30 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:32 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                                  Jul  8 11:56:32 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:34 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                                  Jul  8 11:56:34 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:36 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:0
                                  Jul  8 11:56:36 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Jul  8 11:56:38 raspi1 mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=1,l=1,sg=0:1
                                  Jul  8 11:56:38 raspi1 mysgw: Sending message on topic: mysensors-rfm95-out/6/3/1/0/16
                                  Sketch for the node: (same as for the esp8266 except that I removed the pin defines)
                                    wait(5);
                                      sentValue = value;
                                    wait(2000);
                                  Wiring as per https://www.mysensors.org/build/connect_radio#rfm69-&-arduino
                                    micropet
                                    Thank you.
                                    Now it works.
                                    The trick is D100 must be on pin 2.
                                    I try to make the pin assignments the same for all nodes (STM32, Arduino Pro, Teensy LC Tennsy 3.1 / 3.6, ESP8266).
                                    D100 I had put on pin 6 and
                                    #define MY_RFM95_IRQ_PIN 6
                                    In the sketch.
                                    That was the mistake with the Arduino.
                                    On all other platforms it works.
                                    Many Thanks. I had already given up.
                                    • M micropet
                                      Thank you.
                                      Now it works.
                                      In the sketch.
                                      #25
                                      @micropet great that you were able to isolate the problem. Thanks for the cooperation during troubleshooting.
                                      In case you didn't already know, only pin 2 and 3 on Pro Mini can be used for hardware interrupts. See https://www.arduino.cc/en/Main/ArduinoBoardProMini for details.
                                        micropet
                                        wrote on last edited by micropet
                                        #26
                                        I thank you. Now I have come a whole lot further.
                                        I know that only the pins 2 and 3 are IRQ capable.
                                        I thought I would have read that the IRQ is not used, but the pin is only polled.
                                        This is how it is done with the LMIC Lib at The Things Network.
                                        I have still determined when I use the following at the Arduino:
                                        #define MY_RFM95_RST_PIN 4
                                        The Arduino does not send anything.
                                        It works with Teensy or ESP.
                                        The sleep mode with the teensy does also not always work.
                                        Sometimes he freezes.
                                        I will continue tomorrow....
                                          micropet
                                          #27
                                          For information on electricity consumption:
                                          Tensy 3.2 mit RFM96HW 130 µA
                                          Tensy 3.2 mit RFM96HW BME280 130 µA
                                          Tensy 3.2 mit RFM96HW BME280 BH1750 165 µA
                                          Teensy LC mit RFM95 90 µA
                                          Arduino Pro mit RFM95 DS18b20 6 µA
                                          Arduino Pro mit RFM95 BME280 BH1750 11 µA
                                          12.5k
