  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
    I remember reading non to connect any other serial device while the Sonoff is connected to mains or it would get damaged.
    @gohan said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
    I supposed that's when you connect your computer to sonoff using serial adapter ?
    I see no reason for damage if both es8266 and atmega are connected to the same VCC/GND.
      I think it's because the gnd on the sonoff is shared with neutral from the mains. I have seen pictures of burned stuff but I actually never wanted to try to see if the computer gets fried or not 😁
      Nca78N 1 Reply Last reply
        @gohan yes with it could happen, but if you just connect a standalone Arduino powered with VCC GND from esp8266 there's no reason to have a problem.
          But why would you want to connect another arduino to the sonoff?
          • E Ed1500
            @betonishard ESPeasy I am not sure, but supposedly Tasmota does
            B
            B
            betonishard
            @Ed1500 Thanks for your answer. Went for espurna.. Tested tasmota, but compared to espurna it was kind of slow. Works stable for quite some time now.
            E 1 Reply Last reply
            • B betonishard
              E
              E
              Ed1500
              @betonishard Good to know. I was thinking about trying Tasmota for regular Sonoff, but I will keep slowness in mind
                To have a real MySensors node that can be directly controlled with another node and not relying on wifi and controller.
                  Sorry but I am still missing the point. If you have to make a mysensors node anyway, why not make a classic relay node?
                    wrote on last edited by Nca78
                    #58
                    @gohan because when using the sonoff I do not have to care about the power supply/safety, to find a case that is safe for electrical device and I only have a few things to solder.
                    And sonoff is cheaper than buying separately the power supply, case, relay etc
                    So just solder a few low voltage components on a PCB, plug in the sonoff and get a safe main powered actuator.
                    Not 100% sure it's worth it yet, still thinking a out it ;)
                    But main advantage is to reuse it in more complex sonoff devices with multiple relays, power measurement, in wall plugs etc etc
                      Once you come up with something I'll take a look to better understand what you want to do 😀
                      I have seen how to hack some of them to add a couple of wires directly on the esp8266 chip to get an i2c bus.
                      • Jonathan CaesJ
                        Jonathan CaesJ
                        Jonathan Caes
                        How can I create a new device in Vera for a gateway? Can't seem to get that working :/
                        • Jonathan CaesJ
                          Jonathan CaesJ
                          Jonathan Caes
                          @efflon Do you know how I can setup the sonoff gateway on the Vera Edge? I used the MySensors plugin to add the sonoff to the network but can't get the relay to toggle.. :/ Help is much appreciated!! Thanks!!
                          dbemowskD 1 Reply Last reply
                          • T
                            tkald
                            wrote on last edited by tkald
                            #62
                            If someone wants, I create a modification to cooperate with DHT22. Data pin of DHT22 is connected to pin 5 of sonoff.
                             * Version 1.0 - Henrik EKblad
                             * Contribution by Ivo Pullens (ESP8266 support)
                             * The EthernetGateway sends data received from sensors to the WiFi link.
                             * VERA CONFIGURATION:
                             * LED purposes:
                             * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
                             * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                             * nRF24L01+  ESP8266
                             * VCC        VCC
                             * CE         GPIO4
                             * CSN/CS     GPIO15
                             * SCK        GPIO14
                             * MISO       GPIO12
                             * MOSI       GPIO13
                             * GND        GND
                              * Inclusion mode button:
                             * Sonoff specific details (IM15116002)
                             * The sonoff header left to right, relay above, LED below.
                             *  [1]  vcc 3v3
                             *   2   rx
                             *   3   tx
                             *   4   gnd
                             *   5
                             * In arduinoIDE 1.6.* choose Generic ESP8226 module.
                             * Hold Sonoff button when attaching FTDI to flash.
                            #define MY_BAUD_RATE 9600
                            // No radio in Sonoff
                            // #define MY_RADIO_NRF24
                            // #define MY_RADIO_RFM69
                            #define MY_GATEWAY_ESP8266
                            #define MY_ESP8266_SSID "wifissid"
                            #define MY_ESP8266_PASSWORD "wifipassword"
                            // Enable UDP communication
                            //#define MY_USE_UDP
                            // #define MY_ESP8266_HOSTNAME "sensor-gateway"
                            #define MY_IP_ADDRESS 192,168,2,200
                            #define MY_IP_GATEWAY_ADDRESS 192,168,2,1
                            #define MY_PORT 5003
                            // #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
                            // Enable inclusion mode
                            // #define MY_INCLUSION_BUTTON_FEATURE
                            // Set blinking period
                            // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                            // Flash leds on rx/tx/err
                            #if defined(MY_USE_UDP)
                            #include <WiFiUdp.h>
                            #include <ESP8266WiFi.h>
                            #define BUTTON_PIN 0  // Sonoff pin number for button
                            #define RELAY_PIN 12  // Sonoff pin number for relay
                            #define LED_PIN 13    // Sonoff pin number for LED
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            #define LED_ON 0
                            #define LED_OFF 1
                            #define DHT_DATA_PIN 14
                            #define SENSOR_TEMP_OFFSET 0
                            static const uint64_t UPDATE_INTERVAL = 5000;
                            unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
                            unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
                            // Id of the sensor child
                            // Set unique id for each sonoff if sub/pub on same mqtt topic
                            #define CHILD_ID 0
                            #define CHILD_ID_HUM 1
                            #define CHILD_ID_TEMP 2
                            float lastTemp;
                            float lastHum;
                            uint8_t nNoUpdatesTemp;
                            uint8_t nNoUpdatesHum;
                            bool metric = true;
                            MyMessage msg(CHILD_ID,V_STATUS);
                            DHT dht;
                            Bounce debouncer = Bounce();
                            int oldValue = 0;
                            bool state = false;
                              // Setup the button
                              pinMode(BUTTON_PIN, INPUT_PULLUP);
                              debouncer.attach(BUTTON_PIN);
                              debouncer.interval(5);
                              // Make sure relays and LED are off when starting up
                              digitalWrite(LED_PIN, LED_OFF);
                              pinMode(RELAY_PIN, OUTPUT);
                              pinMode(LED_PIN, OUTPUT);
                            void presentation()  {
                              // Send the sketch version information
                              sendSketchInfo("Sonoff ethernet DHT22", "1.0");
                              // Register sensor
                              present(CHILD_ID, S_BINARY);
                              present(CHILD_ID_HUM, S_HUM);
                              // Send the current state
                              send(msg.set(state?true:false));
                              // Blink when ready
                              blink();
                              debouncer.update();
                              // Get the update value
                              int value = debouncer.read();
                              if (value != oldValue && value==0) {
                                // Toggle the state
                                state = state?false:true;
                                // Change relay state
                                // Change LED state
                                digitalWrite(LED_PIN, state?LED_ON:LED_OFF);
                                // Send new state
                                send(msg.set(state));
                              oldValue = value;
                              boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
                              if (needRefresh)
                                  lastRefreshTime = millis();
                              dht.readSensor(true);
                              if (isnan(temperature)) {
                                lastTemp = temperature;
                                if (!metric) {
                                // Reset no updates counter
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                Serial.print("T: ");
                                nNoUpdatesTemp++;
                              if (isnan(humidity)) {
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                Serial.print("H: ");
                                Serial.println(humidity);
                                nNoUpdatesHum++;
                              //sleep(UPDATE_INTERVAL);
                              // We only react on status messages from the controller
                              // to this CHILD_ID.
                              if (message.type==V_STATUS  && message.sensor==CHILD_ID) {
                                // Only switch if the state is new
                                if (message.getBool() != state) {
                                  state = message.getBool();
                                  // Change LED state
                            void blink()
                              digitalWrite(LED_PIN, digitalRead(LED_PIN)?LED_ON:LED_OFF);
                              wait(200);
                              wait(200);
                              wait(200);
                            • Morten MathiasenM
                              Morten MathiasenM
                              Morten Mathiasen
                              I think it is an easier and more general solution to use https://github.com/arendst/Sonoff-Tasmota
                              gohanG 1 Reply Last reply
                              • Morten MathiasenM Morten Mathiasen
                                @Morten-Mathiasen that is the one I'm using on my sonoff pow
                                • Jonathan CaesJ Jonathan Caes
                                  dbemowskD
                                  dbemowskD
                                  @Jonathan-Caes said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                                  I am using a Vera Plus. I did not go the route of MySensors for my Sonoffs. I use the ESP Easy firmware with a slightly modified Vera plugin. Here is my BLOG post on how to do it.
                                  https://dan.bemowski.info/2017/07/04/using-a-sonoff-with-espeasy-and-vera/
                                  You could still go the MySensors route. I just figured I'd show another alternative to this.
                                  sam9sS 1 Reply Last reply
                                  • J
                                    J
                                    Jan Gatzke
                                    It's a shame that we cannot have both, mysensors and the ESP Easy stuff. There has been a project for this: https://github.com/letscontrolit/ESPEasyMySensors :disappointed_relieved:
                                    dbemowskD gohanG 2 Replies Last reply
                                    • J Jan Gatzke
                                      dbemowskD
                                      dbemowskD
                                      @Jan-Gatzke It is my understanding that ESP Easy can send and receive MQTT messages, couldn't you just use a MySensors MQTT gateway if you wanted to keep it on the MySensors path?
                                      J 1 Reply Last reply
                                      • dbemowskD dbemowsk
                                        J
                                        J
                                        Jan Gatzke
                                        @dbemowsk You cannot because MQTT is just a transport and not a strict data format. You can however use MySenSors MQTT + ESP Easy MQTT + a broker + node red + a controller. Node Red can do data conversions and integrate everything.
                                        • J Jan Gatzke
                                          dbemowskD
                                          dbemowskD
                                          @Jan-Gatzke I was just speculating. I do not use MQTT, so I am by no means an authority on the subject.
