  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
    Sorry but I am still missing the point. If you have to make a mysensors node anyway, why not make a classic relay node?
    wrote on last edited by Nca78
    #58
    @gohan because when using the sonoff I do not have to care about the power supply/safety, to find a case that is safe for electrical device and I only have a few things to solder.
    And sonoff is cheaper than buying separately the power supply, case, relay etc
    So just solder a few low voltage components on a PCB, plug in the sonoff and get a safe main powered actuator.
    Not 100% sure it's worth it yet, still thinking a out it ;)
    But main advantage is to reuse it in more complex sonoff devices with multiple relays, power measurement, in wall plugs etc etc
      Once you come up with something I'll take a look to better understand what you want to do 😀
      I have seen how to hack some of them to add a couple of wires directly on the esp8266 chip to get an i2c bus.
      • Jonathan CaesJ
        Jonathan CaesJ
        Jonathan Caes
        How can I create a new device in Vera for a gateway? Can't seem to get that working :/
        • Jonathan CaesJ
          Jonathan CaesJ
          Jonathan Caes
          @efflon Do you know how I can setup the sonoff gateway on the Vera Edge? I used the MySensors plugin to add the sonoff to the network but can't get the relay to toggle.. :/ Help is much appreciated!! Thanks!!
          dbemowskD 1 Reply Last reply
          • T
            tkald
            wrote on last edited by tkald
            #62
            If someone wants, I create a modification to cooperate with DHT22. Data pin of DHT22 is connected to pin 5 of sonoff.
             * Version 1.0 - Henrik EKblad
             * Contribution by Ivo Pullens (ESP8266 support)
             * The EthernetGateway sends data received from sensors to the WiFi link.
             * VERA CONFIGURATION:
             * LED purposes:
             * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
             * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
             * nRF24L01+  ESP8266
             * VCC        VCC
             * CE         GPIO4
             * CSN/CS     GPIO15
             * SCK        GPIO14
             * MISO       GPIO12
             * MOSI       GPIO13
             * GND        GND
              * Inclusion mode button:
             * Sonoff specific details (IM15116002)
             * The sonoff header left to right, relay above, LED below.
             *  [1]  vcc 3v3
             *   2   rx
             *   3   tx
             *   4   gnd
             *   5
             * In arduinoIDE 1.6.* choose Generic ESP8226 module.
             * Hold Sonoff button when attaching FTDI to flash.
            #define MY_BAUD_RATE 9600
            // No radio in Sonoff
            // #define MY_RADIO_NRF24
            // #define MY_RADIO_RFM69
            #define MY_GATEWAY_ESP8266
            #define MY_ESP8266_SSID "wifissid"
            #define MY_ESP8266_PASSWORD "wifipassword"
            // Enable UDP communication
            //#define MY_USE_UDP
            // #define MY_ESP8266_HOSTNAME "sensor-gateway"
            #define MY_IP_ADDRESS 192,168,2,200
            #define MY_IP_GATEWAY_ADDRESS 192,168,2,1
            #define MY_PORT 5003
            // #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
            // Enable inclusion mode
            // #define MY_INCLUSION_BUTTON_FEATURE
            // Set blinking period
            // #define MY_DEFAULT_LED_BLINK_PERIOD 300
            // Flash leds on rx/tx/err
            #if defined(MY_USE_UDP)
            #include <WiFiUdp.h>
            #include <ESP8266WiFi.h>
            #define BUTTON_PIN 0  // Sonoff pin number for button
            #define RELAY_PIN 12  // Sonoff pin number for relay
            #define LED_PIN 13    // Sonoff pin number for LED
            #define RELAY_ON 1
            #define RELAY_OFF 0
            #define LED_ON 0
            #define LED_OFF 1
            #define DHT_DATA_PIN 14
            #define SENSOR_TEMP_OFFSET 0
            static const uint64_t UPDATE_INTERVAL = 5000;
            unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
            unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
            // Id of the sensor child
            // Set unique id for each sonoff if sub/pub on same mqtt topic
            #define CHILD_ID 0
            #define CHILD_ID_HUM 1
            #define CHILD_ID_TEMP 2
            float lastTemp;
            float lastHum;
            uint8_t nNoUpdatesTemp;
            uint8_t nNoUpdatesHum;
            bool metric = true;
            MyMessage msg(CHILD_ID,V_STATUS);
            DHT dht;
            Bounce debouncer = Bounce();
            int oldValue = 0;
            bool state = false;
              // Setup the button
              pinMode(BUTTON_PIN, INPUT_PULLUP);
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              // Make sure relays and LED are off when starting up
              digitalWrite(LED_PIN, LED_OFF);
              pinMode(RELAY_PIN, OUTPUT);
              pinMode(LED_PIN, OUTPUT);
            void presentation()  {
              // Send the sketch version information
              sendSketchInfo("Sonoff ethernet DHT22", "1.0");
              // Register sensor
              present(CHILD_ID, S_BINARY);
              present(CHILD_ID_HUM, S_HUM);
              // Send the current state
              send(msg.set(state?true:false));
              // Blink when ready
              blink();
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue && value==0) {
                // Toggle the state
                state = state?false:true;
                // Change relay state
                // Change LED state
                digitalWrite(LED_PIN, state?LED_ON:LED_OFF);
                // Send new state
                send(msg.set(state));
              oldValue = value;
              boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
              if (needRefresh)
                  lastRefreshTime = millis();
              dht.readSensor(true);
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                // Reset no updates counter
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                Serial.print("T: ");
                nNoUpdatesTemp++;
              if (isnan(humidity)) {
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                Serial.print("H: ");
                Serial.println(humidity);
                nNoUpdatesHum++;
              //sleep(UPDATE_INTERVAL);
              // We only react on status messages from the controller
              // to this CHILD_ID.
              if (message.type==V_STATUS  && message.sensor==CHILD_ID) {
                // Only switch if the state is new
                if (message.getBool() != state) {
                  state = message.getBool();
                  // Change LED state
            void blink()
              digitalWrite(LED_PIN, digitalRead(LED_PIN)?LED_ON:LED_OFF);
              wait(200);
              wait(200);
              wait(200);
            • Morten MathiasenM
              Morten MathiasenM
              Morten Mathiasen
              I think it is an easier and more general solution to use https://github.com/arendst/Sonoff-Tasmota
              gohanG 1 Reply Last reply
              • Morten MathiasenM Morten Mathiasen
                @Morten-Mathiasen that is the one I'm using on my sonoff pow
                • Jonathan CaesJ Jonathan Caes
                  dbemowskD
                  dbemowskD
                  @Jonathan-Caes said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                  I am using a Vera Plus. I did not go the route of MySensors for my Sonoffs. I use the ESP Easy firmware with a slightly modified Vera plugin. Here is my BLOG post on how to do it.
                  https://dan.bemowski.info/2017/07/04/using-a-sonoff-with-espeasy-and-vera/
                  You could still go the MySensors route. I just figured I'd show another alternative to this.
                  sam9sS 1 Reply Last reply
                  • J
                    J
                    Jan Gatzke
                    It's a shame that we cannot have both, mysensors and the ESP Easy stuff. There has been a project for this: https://github.com/letscontrolit/ESPEasyMySensors :disappointed_relieved:
                    dbemowskD gohanG 2 Replies Last reply
                    • J Jan Gatzke
                      dbemowskD
                      dbemowskD
                      @Jan-Gatzke It is my understanding that ESP Easy can send and receive MQTT messages, couldn't you just use a MySensors MQTT gateway if you wanted to keep it on the MySensors path?
                      J 1 Reply Last reply
                      • dbemowskD dbemowsk
                        J
                        J
                        Jan Gatzke
                        @dbemowsk You cannot because MQTT is just a transport and not a strict data format. You can however use MySenSors MQTT + ESP Easy MQTT + a broker + node red + a controller. Node Red can do data conversions and integrate everything.
                        • J Jan Gatzke
                          dbemowskD
                          dbemowskD
                          @Jan-Gatzke I was just speculating. I do not use MQTT, so I am by no means an authority on the subject.
                          • J Jan Gatzke
                            @Jan-Gatzke said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                            There is no real benefit to have the sonoff running mysensors instead of other firmwares, if your controller is able to communicate over mqtt to switch on/off the relay, you are fine
                            J Nca78N 2 Replies Last reply
                              J
                              J
                              Jan Gatzke
                              @gohan I know some controller are aware of ESP Easy via MQTT. If you controller does not support this directly, you have to integrate it manually (with node red). In my opinion scenarios, where MySensors with ESP Easy frontend would be of use, do still exist.
                                @gohan said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
                                IMHO there is one, when your controller is down, gateway is down or whatever, you could still have direct control or the light switch from a MySensors button with node to node communication.
                                  How do you do that if the sonoff is only having wifi?
                                  Nca78N 1 Reply Last reply
                                    Ah yes in that case you can't and yes there's no benefit :)
                                      A wired button would be a much fail safe option for sonoffs 😀
                                        J
                                        J
                                        Jan Gatzke
                                        @gohan won't this option miss some features? :D
                                        • J Jan Gatzke
                                          @Jan-Gatzke for a sonoff there aren't many options and also a wired button you are pretty sure it would always work. 😀
