  3. Domoticz
  4. Battery status does not show in Domoticz
16 Posts 6 Posters 6.0k Views 5 Watching
  • E Offline
    E Offline
    edsteve
    i was on the way building a relay node with battery status report. The Node sends the data as you can see from the serial monitor:
    Incoming change for sensor:1, New status: 1
    TSP:MSG:READ 0-0-5 s=1,c=1,t=2,pt=0,l=1,sg=0:0
    Incoming change for sensor:1, New status: 0
    Battery voltage: 4137 mV
    Battery percent: 104 %
    TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:104
    TSP:SANCHK:OK
    But it does not show in Domoticz:
    This is my sensor sketch:
    #define MY_REPEATER_FEATURE
    #define BATTERY_REPORT_CYCLE 2
    #define VMIN 3200           // Min Battery level
    #define VMAX 4100           // Max Battery level
    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;
    void before()
            pinMode(pin, OUTPUT);
        sendSketchInfo("Relay", "1.0");
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
        batteryReportCounter ++;
        bool forceTransmit = true;
       // Check battery
       if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
        long batteryVolt = readVcc();
        Serial.print("Battery voltage: "); Serial.print(batteryVolt); Serial.println(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        batteryReportCounter = 0;
    long readVcc() {
    Can't figure it out :(
    Hope someone can point me in the right direction.
    Y 1 Reply Last reply
    • E edsteve
      TSP:SANCHK:OK
      void before()
         // Check battery
      long readVcc() {
      Y Offline
      Y Offline
      @edsteve maybe because you're reporting an out of range percentage value?
        you could try setting VMAX to 4150 or 4200
        • mfalkviddM Offline
          Domoticz (v3.6179) shows 133% for one of my sensors so it can handle out of range.
          • E Offline
            E Offline
            edsteve
            Thanks for replies.
            Yes it can handle out of range. My weather sensor works just fine with 120% :-)
            Where would you start digging for the reason? A log file I can check?
              look in domoticz log and see if value is actually received
              • E Offline
                E Offline
                edsteve
                That's another question i have since a while now:
                How can i change the domoticz log to more debugging details? Hard to find that information. I can't find any values in the standard-log.
                S gohanG 2 Replies Last reply
                • E edsteve
                  @edsteve - I dont know if there is an easy way but the hard one is to compile the code youself for Domoticz and insert any output/debug you want...
                  • E edsteve
                    @edsteve
                    From Domoticz forum > if you edit /etc/init.d/domoticz.sh you can do this:
                    DAEMON_ARGS="-daemon -www 8080 -log /home/pi/log/domoticz.log -loglevel 0"
                    Just don't forget to put back the original config as the log file would grow quite a lot
                    • E Offline
                      E Offline
                      edsteve
                      wrote on last edited by edsteve
                      @gohan
                      I also have that info from the domoticz forum and i tried it. Tailing the new log file... still no more details. I give up...
                      Maaaybe... when i have motivation again i will try to read about @sunberg84 solution. But i am just not a linux expert.
                      Grml... never like it to live with an unsolved problem. But thx for the effort everyone.
                      Here is the link to the domoticz forum about the logging problem
                        try changing the node ID to a number you never used.
                        • markjgabbM Offline
                          markjgabbM Offline
                          markjgabb
                          @edsteve according to domoticz api data battery is measured in a rang of 0-225? wouldnt percentage send cause issueS?
                          S 1 Reply Last reply
                          • markjgabbM markjgabb
                            @markjgabb - I always recalculate the battery into % which is shown great in DOmoticz. I guess you can go up to 225 but if you like but thats not a problem if you convert it to %
                              markjgabbM Offline
                              markjgabb
                              fair enough...i havent done battery sensors before...i was just looking at the API earlier where it pointed out sending in that range so thought it might be in that sort of area obviously domoticz is smart enough to realize its been passed the percentage anyway
                                @markjgabb - could be Domticz can recalculate... dont know to be honest. I have always sent 0-100. Let me know if you find anything more clever :)
                                • E Offline
                                  E Offline
                                  edsteve
                                  Sorry guys. Not at home lately. I will report if and what solved my problem when i am back.
                                  12.1k
