  3. Domoticz
  4. Battery status does not show in Domoticz
16 Posts 6 Posters 6.4k Views 5 Watching
  • edsteveE
    edsteveE
    edsteve
    Thanks for replies.
    Yes it can handle out of range. My weather sensor works just fine with 120% :-)
    Where would you start digging for the reason? A log file I can check?
      look in domoticz log and see if value is actually received
      • edsteveE
        edsteveE
        edsteve
        That's another question i have since a while now:
        How can i change the domoticz log to more debugging details? Hard to find that information. I can't find any values in the standard-log.
        sundberg84S gohanG 2 Replies Last reply
        • edsteveE edsteve
          sundberg84S
          sundberg84S
          @edsteve - I dont know if there is an easy way but the hard one is to compile the code youself for Domoticz and insert any output/debug you want...
          • edsteveE edsteve
            @edsteve
            From Domoticz forum > if you edit /etc/init.d/domoticz.sh you can do this:
            DAEMON_ARGS="-daemon -www 8080 -log /home/pi/log/domoticz.log -loglevel 0"
            Just don't forget to put back the original config as the log file would grow quite a lot
            • edsteveE
              edsteveE
              edsteve
              wrote on last edited by edsteve
              @gohan
              I also have that info from the domoticz forum and i tried it. Tailing the new log file... still no more details. I give up...
              Maaaybe... when i have motivation again i will try to read about @sunberg84 solution. But i am just not a linux expert.
              Grml... never like it to live with an unsolved problem. But thx for the effort everyone.
              Here is the link to the domoticz forum about the logging problem
                try changing the node ID to a number you never used.
                • markjgabbM
                  markjgabbM
                  markjgabb
                  @edsteve according to domoticz api data battery is measured in a rang of 0-225? wouldnt percentage send cause issueS?
                  • markjgabbM markjgabb
                    sundberg84S
                    sundberg84S
                    @markjgabb - I always recalculate the battery into % which is shown great in DOmoticz. I guess you can go up to 225 but if you like but thats not a problem if you convert it to %
                    • markjgabbM
                      markjgabbM
                      markjgabb
                      fair enough...i havent done battery sensors before...i was just looking at the API earlier where it pointed out sending in that range so thought it might be in that sort of area obviously domoticz is smart enough to realize its been passed the percentage anyway
                        sundberg84S
                        sundberg84S
                        @markjgabb - could be Domticz can recalculate... dont know to be honest. I have always sent 0-100. Let me know if you find anything more clever :)
                        • edsteveE
                          edsteveE
                          edsteve
                          Sorry guys. Not at home lately. I will report if and what solved my problem when i am back.
