  2. Enclosures / 3D Printing
  3. MySensors weather station
138 Posts 16 Posters 113.3k Views 15 Watching
  • dbemowskD
    dbemowskD
    So I am trying to figure out the SPI for the wind direction sensor. Where is the SPI code for MySensors. Do I need to call SPI.begin()? Does MySensors code use transactions? If so, where can I find that to look at.
      Doesn't it have a library?
      dbemowskD 1 Reply Last reply
        dbemowskD
        dbemowskD
        @gohan It does, but it is an untested library. This is the test code that I ran using that library:
        #include "AS5047.h"
        #include <EEPROM.h>
        #define SWITCH_PIN 7 //The north calibration switch
        AS5047 myAS5047(5); // SS pin
        int address = 0;      //EEPROM address counter
        int north_offset = 0;
        long value;
        int dir;
        bool button;
          SPI.begin;
          Serial.begin(9600);
          pinMode(SWITCH_PIN, INPUT_PULLUP);
          north_offset = EEPROM.read(address);
          value=(360*myAS5047.sensor_read())/16383;
          dir = ((value - north_offset) < 0) ? 360 - abs(value - north_offset) : value - north_offset;
          Serial.print("measured direction: ");
          Serial.println(dir);
          Serial.print("north_offset: ");
          Serial.println(north_offset);
          button = digitalRead(SWITCH_PIN);
          if (!button && north_offset != value) {
            EEPROM.write(address, value);
            north_offset = value;
            Serial.println("Button pressed");
          delay(1000);
        This test worked fine, now I am trying to merge this with my weather station sketch. I am not very familiar with working with SPI. In the setup() method, they call SPI.begin(). I am just trying to figure out what I need to do for merging the code.
        • dbemowskD
          dbemowskD
          Should all of the SPI stuff be included in the library?
          • dbemowskD
            dbemowskD
            So now I have the direction sensor on the SPI bus with the CS pin connected to D5 on my easy newbie board. If I run my sample program for the direction sensor to test it on the bus with the nRF24 radio, I get readings and it seems to work fine. The problem is, if I run my modified rain sensor sketch seen below, I cannot get the radio to work.
             Arduino Tipping Bucket Rain Gauge
             April 26, 2015
             Version 2.0
             Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
             gateway you can measure and sense local rain.  This sketch will create two devices on your
             Vera controller.  One will display your total precipitation for the last 5 days.  The other,
             a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
             Both these settings are user definable.
             There is a build overview video here: https://youtu.be/1eMfKQaLROo
             * Allows you to set the rain threshold in mm
             * Allows you to determine the tripped indicator window up to 120 hours.
             * Displays the last 5 days of rain in Variable1 through Variable5
               of the Rain Sensor device
             * Configuration changes to Sensor device updated every hour
             * Should run on any Arduino
             * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
               of data to EEPROM (Circular Buffer to maximize life of EEPROM)
             * LED status indicator
             * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
               #define DHT_ON  and/or #define LUX_ON
             * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
               Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
               a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
             by @BulldogLowell and @PeteWill for free public use
            #define MY_DEBUG // Enable MySensors debug prints to serial monitor
            //#define MY_NODE_ID 7 //uncomment this line to assign a static ID
            #include <math.h>
            #include <TimeLib.h>
            #include "AS5047.h"
            #define SKETCH_NAME "Weather Station"
            #define SKETCH_VERSION "2.0"
            #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
            //#define DEBUG_ON  // Rain gauge specific debug messages.
            #define DHT_ON // uncomment out this line to enable DHT sensor
            //#define LUX_ON // uncomment out this line to enable BH1750 sensor
            //#define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
            #define NORTH_SWITCH_PIN 7 //The north calibration switch
            #define AS5047_CHIP_SELECT_PIN 5 //The north calibration switch
            #define TIP_SENSOR_PIN 2 //The tipping bucket rain sensor
            #define CALIBRATE_FACTOR 60 // amount of rain per rain bucket tip e.g. 5 is .05mm
            #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
            #define WIND_DIR_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
            #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
            #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
            #define CHILD_ID_WIND 5  // Indicates Tripped when rain detected
            #define EEPROM_NORTH_OFFSET_LOCATION 0  // location of the EEPROM circular buffer
            #define EEPROM_BUFFER_LOCATION 1  // location of the EEPROM circular buffer
            #define E_BUFFER_LENGTH 240
            #define RAIN_BUCKET_SIZE 120
            #ifdef  DEBUG_ON
            MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
            MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
            MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
            MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
            MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
            MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
            MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
            MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
            MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
            MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
            MyMessage msgWindSpeed(CHILD_ID_WIND, V_WIND);
            MyMessage msgWindGust(CHILD_ID_WIND, V_GUST);
            MyMessage msgWindDirection(CHILD_ID_WIND, V_DIRECTION);
            #ifdef DHT_ON
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              DHT dht;
              float lastTemp;
              float lastHum;
              bool metric = false;
            #ifdef LUX_ON
              //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
              #include <BH1750.h>
              #define CHILD_ID_LIGHT 2
              BH1750 lightSensor;
              unsigned int lastlux;
              uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
            AS5047 myAS5047(5); //AS5047_CHIP_SELECT_PIN); //Wind direction magnetic position sensor
            uint8_t north_offset;
            bool button;
            int wind_direction;
            int last_direction;
            unsigned long sensorPreviousMillis;
            unsigned long windDirPreviousMillis;
            int eepromIndex;
            int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
            int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
            #ifdef DEBUG_ON
            unsigned long dataMillis;
            unsigned long serialInterval = 600000UL;
            const unsigned long oneHour = 3600000UL;
            unsigned long lastTipTime;
            unsigned long lastRainTime; //Used for rainRate calculation
            unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
            unsigned int rainRate = 0;
            uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
            volatile int wasTippedBuffer = 0;
            int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
            uint8_t state = 0;
            uint8_t oldState = 2; //Setting the default to something other than 1 or 0
            unsigned int lastRainRate = 0;
            int lastMeasure = 0;
            bool gotTime = false;
            uint8_t lastHour;
            uint8_t currentHour;
            void presentation()  {
              wait(DWELL_TIME);
              present(CHILD_ID_RAIN_LOG, S_RAIN);
              wait(DWELL_TIME);
              present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
              wait(DWELL_TIME);
              present(CHILD_ID_WIND, S_WIND);
              wait(DWELL_TIME);
            #ifdef DHT_ON
              present(CHILD_ID_HUM, S_HUM);
              wait(DWELL_TIME);
              wait(DWELL_TIME);
            #ifdef LUX_ON
              #ifndef MY_DEBUG
              SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
              pinMode(NORTH_SWITCH_PIN, INPUT_PULLUP);
              // Set up the IO
              pinMode(TIP_SENSOR_PIN, INPUT_PULLUP);
              attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
              pinMode(ledPin, OUTPUT);
              digitalWrite(ledPin, HIGH);
              //Sync time with the server
              unsigned long functionTimeout = millis();
              while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
                requestTime();
                DEBUG_PRINTLN(F("Getting Time"));
                wait(1000); // call once per second
                DEBUG_PRINTLN(F("."));
              currentHour = hour();
              lastHour = hour();
              //retrieve from EEPROM stored values on a power cycle.
              //Get the north offset direction
              north_offset = loadState(EEPROM_NORTH_OFFSET_LOCATION)*2;
              bool isDataOnEeprom = false;
              for (int i = 0; i < E_BUFFER_LENGTH; i++)
                uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
                if (locator == 0xFE)  // found the EEPROM circular buffer index
                  eepromIndex = EEPROM_BUFFER_LOCATION + i;
                  DEBUG_PRINT(F("EEPROM Index "));
                  DEBUG_PRINTLN(eepromIndex);
                  //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                  loadRainArray(eepromIndex);
                  isDataOnEeprom = true;
              if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
                DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
                eepromIndex = EEPROM_BUFFER_LOCATION;
                saveState(eepromIndex, 0xFE);
                saveState(eepromIndex + 1, 0xFE);
                //then I will clear out any bad data
                for (int i = 2; i <= E_BUFFER_LENGTH; i++)
                  saveState(i, 0x00);
              #ifdef DEBUG_ON
              dataMillis = millis();
              lastTipTime = millis();
              request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
              wait(DWELL_TIME);
              request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
              wait(DWELL_TIME);
            #ifdef DHT_ON
              //metric = false;
              wait(DWELL_TIME);
            #ifdef LUX_ON
              lightSensor.begin();
              transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
              if (state)
                prettyFade();  // breathe if tripped
                slowFlash();   // blink if not tripped
            #ifdef DEBUG_ON  // Serial Debug Block
              if ( (millis() - dataMillis) >= serialInterval)
                for (int i = 24; i <= 120; i = i + 24)
                  updateSerialData(i);
              //NORTH_SWITCH_PIN
              button = digitalRead(NORTH_SWITCH_PIN);
              if (!button) {
                setNorthOffset();
              // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
              int measure = 0; // Check to see if we need to show sensor tripped in this block
              for (int i = 0; i < rainWindow; i++)
                measure += rainBucket [i];
                if (measure != lastMeasure)
                  //      DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                  //      DEBUG_PRINTLN(measure);
                  lastMeasure = measure;
              state = (measure >= (rainSensorThreshold * 100));
              if (state != oldState)
                send(msgTripped.set(state));
                wait(DWELL_TIME);
                DEBUG_PRINT(F("New Sensor State... Sensor: "));
                DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                oldState = state;
              //WIND_DIR_DELAY
              if (millis() - windDirPreviousMillis > WIND_DIR_DELAY)
                wind_direction = getWindDirection();
                if (wind_direction != last_direction)
                  send(msgWindDirection.set(wind_direction));
                last_direction = wind_direction;
                windDirPreviousMillis = millis();
              unsigned long tipDelay = millis() - lastRainTime;
              if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
                DEBUG_PRINTLN(F("Sensor Tipped"));
                DEBUG_PRINT(F("rainBucket [0] value: "));
                DEBUG_PRINTLN(rainBucket [0]);
                send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
                wait(DWELL_TIME);
                wasTippedBuffer--;
                rainRate = ((oneHour) / tipDelay);
                if (rainRate != lastRainRate)
                  send(msgRainRate.set(rainRate, 1));
                  wait(DWELL_TIME);
                  DEBUG_PRINT(F("RainRate= "));
                  DEBUG_PRINTLN(rainRate);
                  lastRainRate = rainRate;
                lastRainTime = lastTipTime;
              if (currentHour != lastHour)
                DEBUG_PRINTLN(F("One hour elapsed."));
                send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
                wait(DWELL_TIME);
                saveState(eepromIndex, highByte(rainBucket[0]));
                saveState(eepromIndex + 1, lowByte(rainBucket[0]));
                DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
                DEBUG_PRINTLN(rainBucket[0]);
                for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
                  rainBucket [i + 1] = rainBucket [i];
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                rainBucket[0] = 0;
                eepromIndex = eepromIndex + 2;
                if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
                DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                requestTime(); // sync the time every hour
                wait(DWELL_TIME);
                transmitRainData();
                rainRate = 0;
                wait(DWELL_TIME);
                DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
                lastHour = hour();
              if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
                #ifdef DHT_ON  //DHT Code
                  doDHT();
                #ifdef LUX_ON
                  doLUX();
                sensorPreviousMillis = millis();
            int getWindDirection()
              north_offset = loadState(EEPROM_NORTH_OFFSET_LOCATION);
              int value = readDir();
              int dir = ((value - north_offset) < 0) ? 360 - abs(value - north_offset) : value - north_offset;
                DEBUG_PRINT("Wind direction: ");
                DEBUG_PRINTLN(dir);
              return dir;
            void setNorthOffset()
              if (north_offset != value)
                saveState(EEPROM_NORTH_OFFSET_LOCATION, value/2);
                DEBUG_PRINT("North offset set to: ");
                DEBUG_PRINTLN(value/2);
            int readDir()
              int value = (359*myAS5047.sensor_read())/16383;
              return value;
            #ifdef DHT_ON
            void doDHT(void)
                if (isnan(temperature))
                  DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                } else if (temperature != lastTemp)
                  lastTemp = temperature;
                  if (!metric)
                  wait(DWELL_TIME);
                  DEBUG_PRINT(F("Temperature is: "));
                  DEBUG_PRINTLN(temperature);
                float humidity = dht.getHumidity();;
                if (isnan(humidity))
                  DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                } else if (humidity != lastHum)
                  lastHum = humidity;
                  wait(DWELL_TIME);
                  DEBUG_PRINT(F("Humidity is: "));
                  DEBUG_PRINTLN(humidity);
            #ifdef LUX_ON
            void doLUX(void)
              unsigned int lux = lightSensor.readLightLevel();// Get Lux value
              DEBUG_PRINT(F("Current LUX Level: "));
              DEBUG_PRINTLN(lux);
              heartbeat++;
              if (lux != lastlux || heartbeat > 10)
                send(msg.set(lux));
                lastlux = lux;
              if (heartbeat > 10)
                heartbeat = 0;
            void sensorTipped()
              unsigned long thisTipTime = millis();
              if (thisTipTime - lastTipTime > 100UL)
                rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                wasTippedBuffer++;
              lastTipTime = thisTipTime;
            int rainTotal(int hours)
              int total = 0;
              for ( int i = 0; i <= hours; i++)
                total += rainBucket [i];
              return total;
            #ifdef DEBUG_ON
            void updateSerialData(int x)
              DEBUG_PRINT(F("Rain last "));
              DEBUG_PRINT(x);
              DEBUG_PRINTLN(F(" hours: "));
              float tipCount = 0;
              for (int i = 0; i < x; i++)
                tipCount = tipCount + rainBucket [i];
              tipCount = tipCount / 100;
              DEBUG_PRINTLN(tipCount);
            void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
              for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
                eValue = eValue - 2;
                if (eValue < EEPROM_BUFFER_LOCATION)
                  eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
                DEBUG_PRINT(F("EEPROM location: "));
                DEBUG_PRINTLN(eValue);
                uint8_t rainValueHigh = loadState(eValue);
                uint8_t rainValueLow = loadState(eValue + 1);
                unsigned int rainValue = rainValueHigh << 8;
                rainValue |= rainValueLow;
                rainBucket[i] = rainValue;
                DEBUG_PRINT(F("rainBucket[ value: "));
                DEBUG_PRINT(i);
                DEBUG_PRINT(F("] value: "));
                DEBUG_PRINTLN(rainBucket[i]);
            void transmitRainData(void)
              DEBUG_PRINT(F("In transmitRainData. currentHour = "));
              DEBUG_PRINTLN(currentHour);
              int rainUpdateTotal = 0;
              for (int i = currentHour; i >= 0; i--)
                rainUpdateTotal += rainBucket[i];
                DEBUG_PRINT(F("Adding rainBucket["));
                DEBUG_PRINT(i);
                DEBUG_PRINTLN(F("] to rainUpdateTotal."));
              DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
              DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
              send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 24; i > currentHour; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
              send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 48; i > currentHour + 24; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
              send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 72; i > currentHour + 48; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
              send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 96; i > currentHour + 72; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
              send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
              if (message.sensor == CHILD_ID_RAIN_LOG)
                // nothing to do here
              else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
                if (message.type == V_VAR1)
                  rainWindow = atoi(message.data);
                  if (rainWindow > 120)
                    rainWindow = 120;
                  else if (rainWindow < 1)
                    rainWindow = 1;
                  if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                    send(msgTrippedVar1.set(rainWindow));
                  rainSensorThreshold = atoi(message.data);
                  if (rainSensorThreshold > 10000)
                    rainSensorThreshold = 10000;
                  else if (rainSensorThreshold < 1)
                    rainSensorThreshold = 1;
                  if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                    send(msgTrippedVar2.set(rainSensorThreshold));
            void prettyFade(void)
              float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
              analogWrite(ledPin, val);
            void slowFlash(void)
              static bool ledState = true;
              static unsigned long pulseStart = millis();
              if (millis() - pulseStart < 100UL)
                digitalWrite(ledPin, !ledState);
            void receiveTime(unsigned long newTime)
              DEBUG_PRINTLN(F("Time received..."));
              setTime(newTime);
              char theTime[6];
              sprintf(theTime, "%d:%2d", hour(), minute());
              DEBUG_PRINTLN(theTime);
            These are the errors that I get when I try to run the code:
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            If I disconnect the direction sensor and start it, the radio works fine. The odd thing is that when I run the test code for the direction sensor with the radio connected to the bus, that works fine.
            Any ideas?
            Nca78N 1 Reply Last reply
            • dbemowskD dbemowsk
               April 26, 2015
               Version 2.0
              #include <math.h>
              #include "AS5047.h"
              #ifdef  DEBUG_ON
              #ifdef DHT_ON
                DHT dht;
                float lastTemp;
                float lastHum;
              #ifdef LUX_ON
                #include <BH1750.h>
                BH1750 lightSensor;
              bool button;
              int wind_direction;
              int last_direction;
              int eepromIndex;
              #ifdef DEBUG_ON
              uint8_t state = 0;
              uint8_t lastHour;
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                wait(DWELL_TIME);
              #ifdef DHT_ON
                wait(DWELL_TIME);
                wait(DWELL_TIME);
              #ifdef LUX_ON
                #ifndef MY_DEBUG
                // Set up the IO
                  requestTime();
                lastHour = hour();
                    saveState(i, 0x00);
                #ifdef DEBUG_ON
                wait(DWELL_TIME);
                wait(DWELL_TIME);
              #ifdef DHT_ON
                //metric = false;
                wait(DWELL_TIME);
              #ifdef LUX_ON
                if (state)
                //NORTH_SWITCH_PIN
                if (!button) {
                  setNorthOffset();
                  wait(DWELL_TIME);
                  oldState = state;
                //WIND_DIR_DELAY
                  wait(DWELL_TIME);
                  wasTippedBuffer--;
                    wait(DWELL_TIME);
                  wait(DWELL_TIME);
                  wait(DWELL_TIME);
                  wait(DWELL_TIME);
                  rainBucket[0] = 0;
                  wait(DWELL_TIME);
                  transmitRainData();
                  rainRate = 0;
                  wait(DWELL_TIME);
                  lastHour = hour();
                    doDHT();
                  #ifdef LUX_ON
                    doLUX();
                  DEBUG_PRINTLN(dir);
                return dir;
              int readDir()
                return value;
              #ifdef DHT_ON
              void doDHT(void)
                    if (!metric)
                    wait(DWELL_TIME);
                    lastHum = humidity;
                    wait(DWELL_TIME);
              #ifdef LUX_ON
              void doLUX(void)
                DEBUG_PRINTLN(lux);
                heartbeat++;
                  send(msg.set(lux));
                  lastlux = lux;
                if (heartbeat > 10)
                  heartbeat = 0;
              void sensorTipped()
                  wasTippedBuffer++;
                int total = 0;
                return total;
              #ifdef DEBUG_ON
                DEBUG_PRINT(x);
                float tipCount = 0;
                  DEBUG_PRINT(i);
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
                      rainWindow = 120;
                      rainWindow = 1;
                setTime(newTime);
                char theTime[6];
              TSM:INIT
              !TSM:RADIO:FAIL
              !TSM:FAILURE
              TSM:PDT
              Any ideas?
              @dbemowsk my guess is your sensor tries to communicate on the SPI bus and prevents communication with NRF24.
              I don't know what is in you AS5047 files so I'm not sure but I suppose it's taking over the SPI bus at creation, you should try to force the CSN pin used for the as5047 to HIGH in before() method to disable it before MySensors library starts using the radio.
              • Nca78N Nca78
                dbemowskD
                dbemowskD
                #103
                @Nca78 ok, so I tried adding this:
                void before()
                  digitalWrite(AS5047_CHIP_SELECT_PIN, HIGH);
                This seems to now allow the radio to connect, but I am still having some trouble. I then tried removing setting the CSN pin high in the before(), and adding it to the constructor of the library class here:
                AS5047::AS5047(uint16_t SelectPin)
                         : _ss(SelectPin)
                         pinMode(_ss, OUTPUT);
                         SPCR = (1<<SPE) | (1<<MSTR) | (1<<CPHA) | (1<<SPR1) | (1<<SPR0); // slow down clock speed, set up spi
                         digitalWrite(_ss, HIGH); //<<-------------
                         SPI.begin();
                This seemed to do the same as putting it in the begin() method, but still having some trouble. I am going to see if I can work through the problems on my own, but I may post if I have questions. Let me know if you see problems with what I did to the class.
                  void before()
                           : _ss(SelectPin)
                           SPI.begin();
                  #104
                  @dbemowsk it's good practice to have a pull up resistor on each SPI CS line (approx. 10k).
                  It can save you a lot of hassle when multiple devices share the same SPI bus.
                  • YveauxY Yveaux
                    dbemowskD
                    dbemowskD
                    @Yveaux Thanks, this is easy enough. I have some small 1/8w 10k resistors with a small bit of room in the proto area of the easy newbie board yet, I will add one in.
                      @dbemowsk said in MySensors weather station:
                      I will add one in.
                      Two, one for each SPI device ;-)
                      • YveauxY Yveaux
                        I will add one in.
                        dbemowskD
                        dbemowskD
                        @Yveaux I thought the nRF24 radios would have had it built in to the module, but I never checked. It is just that and the magnetic direction sensor on the SPI bus. After thinking about it too, I may just add the resistor on to the small board I have inside the wind speed and direction sensor case that the wire harness connects to, or do you think it would be better if it was closer to the arduino? If that is the case, then I would stick with my original plan to put it in the little bit of leftover space in the proto area of the easy newbie board. Jumper wires are getting a bit cramped in that space though, so if I can avoid it I will.
                          #108
                          @dbemowsk the nrf module doesn't have a pullup on CS.
                          Where you put them doesn't really matter. It's just to have a defined, unselected state when the lines are not actively driven by the microcontroller.
                          If it is too much trouble in your current hardware, then skip the pull-ups and save them for your next piece of hardware. The same can be achieved in software, but you just must make sure all CS lines are made inactive (high) before doing anything with the SPI bus. Before() is a good place to achieve this, but bad designed drivers that use eg the constructor to do spi initialization could still beat you to it...
                          Therefore pull-ups are preferred.
                          dbemowskD 2 Replies Last reply
                          • YveauxY Yveaux
                            dbemowskD
                            dbemowskD
                            @Yveaux If I am going to do one for the radio too, I can put one in the case of the wind sensor and one in the proto area for the radio. I think I'll be alright. It will eliminate confusion on the programming end.
                            • YveauxY Yveaux
                              dbemowskD
                              dbemowskD
                              @Yveaux So if this is done in software, is it better to be done in the before() method rather than the constructor of the library class? If the nRF24 radios do not have a built in pull up on the CS line, does the MySensors library somehow take care of this in one of it's class files? I haven't seen a push to have designers of MySensors hardware include pull-ups on the nRF24's CS line...
                                #111
                                It all depends on initialization order of the classes, which isn't trivial. For global static instances (declared outside a function like loop()) the constructor will be called before the before() call, but if one places an instance inside a function or dynamically creates it things will be different. So, when designing a library you simply can't be sure when your constructie is called...
                                I'm not sure right now if the drivers actively pull the CS line high at startup, but IMHO they should.
                                The fact that some mySensors hardware designs lack pull-ups on CS is probably because the SPI bus isn't shared in many cases, and maybe because people aren't aware.
                                This would be a good item to add to a design checklist, if only we had one :-)
                                • YveauxY Yveaux
                                  dbemowskD
                                  dbemowskD
                                  @Yveaux Great explanation, thanks.
                                  I am close to having things all working. I will post more as I progress.
                                  • dbemowskD
                                    dbemowskD
                                    OK, so here is my easy newbie board layout showing pin connections and header plug identifications. I am still working on the code a bit. I still need to work in the wind speed and wind gust code and figure out the calculations for that. I am nearing the point of full sensor testing. I will then need to figure out my power situation.
                                    0_1500169191817_upload-6df2b074-decd-4232-958c-973fb97d1173
                                    • dbemowskD
                                      dbemowskD
                                      Here are some of the final pics of the wind sensor assembly. The first one shows the circuit board mounting assembly. I have a small channel on the top and bottom sides of the mounting plate to hold rubber O-ring seals to keep water out. The seals can be seen to the left of the image.
                                      0_1500170436823_upload-15dd3888-b1c6-4e4b-8b03-32a0533eec63
                                      Next is just a wide angle shot of all the parts. The connector for the anemometer reed switch feeds through the hole next to the wire harness board and plugs into a header on that board.
                                      0_1500170696031_upload-bca62065-4537-4f33-a19e-cb472587f0ef
                                      The last pic is the fully assembled unit with the wire harness attached. I added a shot of the O-rings sandwiched between the layers to keep water out.
                                      0_1500171521761_upload-fd7d3c7c-9ac7-4a13-8a91-d6423d083117
                                        @dbemowsk great work, thanks for sharing!
                                        My 3D printer does not create watertight prints. Water seems to be able to slowly pass through the walls. Hopefully your printer is better, but it might be something to look out for.
                                          dbemowskD
                                          dbemowskD
                                          @mfalkvidd The walls of the upper and lower case are pretty thick. I used 100% infill which was probably a bit overboard, but I didn't want any water in it. That is why I also put the rubber O-rings in the middle. With the sides compressing that rubber it gives it a pretty good seal. I was originally going to make gaskets. but I found the O-rings to be a better fit.
                                          12.5k
