  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
    So, is the speed of the Cortex on an nRF5 already good enough that one can simply emulate an atsha signing component, and thus that part now completely disappears from the BOM?
    AnticimexA
    AnticimexA
    Anticimex
    @NeverDie but remember that if you use soft signing it is your own responsibility to protect the hmac key from readout by an attacker with physical access to the device.
    • AnticimexA Anticimex
      #185
      @Anticimex said in Minimalist SAMD21 TQFP32 Pro Mini:
      Thanks! Good to know. Speaking only for myself, I don't think I'll be losing any sleep over the prospect of an attacker gaining physical access to one of my home devices with the intent of extracting the hmac key. I'm more likely to win a lottery than have that happen--and I don't even play lotteries.
      AnticimexA 1 Reply Last reply
        AnticimexA
        AnticimexA
        Anticimex
        @NeverDie that is probably correct, I just feel a responsibility to inform everyone of any known weaknesses in the security infrastructure ;)
          @Anticimex
          I don't mean to trivialize it. For commercial applications, the atsha204a would of course make sense.
          But, at least for now, it sounds likely that $2.73 will buy you the hardware for a nice little home wireless node, minus sensors and power supply. That's today's price for a NRF51822-04 MINI that NCA78 linked to above. And, of course, that price will continue to drop. Pretty cool!
            Which library is most recommended for exploiting the RTC that's on an nRF52832? Likewise, what's the best library for sleeping the nRF52832? Since I have the DK, I'd like to take some current measurements while running some demo code for that. That will establish a baseline for comparing future measurements.
            d00616D 1 Reply Last reply
              #189
              I just now ordered this:
              https://www.sparkfun.com/products/13746?_ga=2.39569123.1141912816.1499956888-1087552930.1495048698
              It's like a regular FTDI, but it can also power your project at 3.3v at up to 600ma! :) Previously I had to make my own hacked FTDI interface to do that. Ordinary 3.3v FTDI's will burn out under the load of, say, an ESP8266, or a 20db Tx power amplified nRF24L01.
                d00616D
                d00616D
                d00616
                @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                Sleeping is implemented by hwSleep(). This function uses one RTC. If you need advanced RTC access, you have to cooperate with this RTC, because the interrupt routine must reset the state registers. On nRF51 the other RTC is used for millis(). The nRF52 has one RTC free.
                  #191
                  In case anyone else either has, or is thinking of getting, the nRF52832 DK, it looks as though there is indeed a way to use its programmer to program an offboard nRF52832 without desoldering the nRF52832 that's on the DK. Here's the existence proof photo where an 832 DK is being used to program Sparkfun's nRF52832 breakout board over the two SW lines:
                  The caption reads "For faster programming, an nRF52832 Development Kit can be used to program the nRF52832 Breakout Board."
                  I haven't yet found the instructions on how to do it though.
                    @d00616
                    9mmx9mm would be great. However, are you certain? Product description says 15.4mmx15.4mm.
                    Pitty the lack of 32khz crystal, but for a lot of sensor nodes perhaps it won't matter much.
                    I did find this after making my prior post:
                    https://www.aliexpress.com/item/nRF51-M0-Ultra-small-Bluetooth-BLE-Module-4-0-Module-LIS3DH-Support-10-GPIOs/32697055436.html?spm=a2g0s.13010208.99999999.295.t9NHvJ
                    which is allegedly 8.5mmx10.5mm and allegedly does have a 32Khz crystal, but the trade-off is that it's an nRF51832, not an nRF52832.
                    @d00616
                    I'm convinced! I pulled this picture off the FCC website, and, indeed, it is 9x9mm:
                    (https://fccid.io/2AA72-PTR5628)
                    So, thanks for mentioning its size, or else I never would have known!
                      @d00616
                      So, what's the smallest nRF52 module that also includes a 32Khz crystal? I think I might want to standardize as much as possible on a single module rather than juggle a bunch of different ones.
                      d00616D 2 Replies Last reply
                        d00616D
                        d00616D
                        d00616
                        What do you think about creating an table with known modules including integrated hardware, available ports and size?
                        I think, most small modules comes without 32kHz crystal. This is mostly an option. Maybe for the 9x9mm module. But I think the antenna is no good choice for indoor usage.
                        I have a lot of RedBear BLE Nano 2 (18x21mm) modules. It's complete including 32Khz crystal and a 3-13V voltage converter. With 2.54mm pins it's easy to solder.
                        I have asked the manufacturer(cdebyte) of the nice nRF24 and nRF52 modules if it's possible to build an module including the nRF52, an RGB LED, an button and 5V protected inputs with the layout like the popular nRF24 modules plus two optional pins (6/8 IO Ports!). I think such type of nRF52 module makes it easy to migrate to 32 Bit using existing boards or build new boards.
                          #195
                          I just now noticed that Ebyte also has a storefront on aliexpress.
                          https://cdebyte.aliexpress.com/store/2077046?spm=2114.12010108.0.0.7Yid4a
                          For me, it's much better than ebay, because it includes free e-packet delivery to the US. So, unlike ebay, I will hopefully get their modules much sooner than September! The estimated delivery time from Ebyte if ordered through Aliexpress is 12-20 days. :)
                          https://www.aliexpress.com/store/product/CDEBYTE-E73-2G4M04S-BLE-4-2-5-0-long-distance-100m-2-4GHz-SMD-ARM-Core/2077046_32820692238.html?spm=2114.12010615.0.0.TZClHR
                          [Edit: Also, on Aliexpress, Ebyte gives a coupon for $5 off if you order >$45]
                          Nca78N 1 Reply Last reply
                            @NeverDie yes noticed their shop only 2 days ago and feeling frustrated now :D
                            For shipment delay I wouldn't be surprised if they shipped the same way with free option and it would just be a different way to state the delay on the 2 websites...
                            • Nca78N Nca78
                              @Nca78
                              We'll soon know. I ordered Ebyte products from both Ebay and Aliexpress, and I'll take note of when each order arrives.
                                d00616D
                                d00616D
                                d00616
                                wrote on last edited by d00616
                                #198
                                I have found the Raytec Modules. http://www.raytac.com/products.php?id=1
                                The smallest one is the MDBT42V 8,4x6,4x1,5mm with PCB antenna and 80m range in open space.
                                This module https://www.mtmtech.com.tw/M905.html is 6.5 ✕ 6.5 x 1.1 mm
                                • d00616D d00616
                                  @d00616 said in Minimalist SAMD21 TQFP32 Pro Mini:
                                  M905 is impressive, but with connectors at the bottom it's impossible to hand solder...
                                  Raytac module is what scalz used for the prototype of his "Aeos" board, pretty small but he didn't look so happy with the range.
                                  • TerrenceT
                                    TerrenceT
                                    Terrence
                                    Guys, when you start using these 832 chips are you going to be programming via Bluetooth or just using the radios in some other way?
                                    • TerrenceT Terrence
                                      #201
                                      I'd like to see the work extended to include Bluetooth. Nearly everything has bluetooth these days, so leveraging that would seem to make a lot of sense. I just don't know where to start.
                                      TerrenceT 1 Reply Last reply
                                        TerrenceT
                                        TerrenceT
                                        Terrence
                                        I agree.
                                        I have done a little bit of BT programming. It seems pretty complex, but I am sure that will change once we immerse our attention in it.
                                          I agree.
                                          I'd like to see an extremely basic script that simply has two bluetooth nodes talking back and forth to one another (maybe just increment a counter on each turn and send just that). If we could get that simple activity working, then I suspect the rest could follow more easily.
