  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.3k Views 33 Watching
  • Kodiak80K Kodiak80
    I'm trying to get a single Dallas Temp sensor displayed in OpenHAB using the Serial Gateway. I'm running the MySensors v2 Dallas Temp sketch, and I'm seeing my sensor in the logs. However, I'm getting the following:
    2016-09-28 07:34:21.805 [ERROR] [i.internal.GenericItemProvider] - Binding configuration of type 'mysensors' of item ?Temperature? could not be parsed correctly.
    java.lang.NullPointerException: null
    	at java.util.regex.Matcher.getTextLength(Matcher.java:1234) ~[na:1.7.0_101]
    	at java.util.regex.Matcher.reset(Matcher.java:308) ~[na:1.7.0_101]
    	at java.util.regex.Matcher.<init>(Matcher.java:228) ~[na:1.7.0_101]
    	at java.util.regex.Pattern.matcher(Pattern.java:1088) ~[na:1.7.0_101]
    	at org.openhab.binding.mysensors.internal.MySensorsGenericBindingProvider.validateItemType(MySensorsGenericBindingProvider.java:57) ~[na:na]
    	at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:347) [org.openhab.model.item_1.8.3.jar:na]
    	at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:324) [org.openhab.model.item_1.8.3.jar:na]
    	at org.openhab.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:171) [org.openhab.model.item_1.8.3.jar:na]
    	at org.openhab.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:390) [org.openhab.model.item_1.8.3.jar:na]
    	at org.openhab.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:159) [org.openhab.model.core_1.8.3.jar:na]
    	at org.openhab.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:100) [org.openhab.model.core_1.8.3.jar:na]
    	at org.openhab.model.core.internal.folder.FolderObserver.checkFolder(FolderObserver.java:142) [org.openhab.model.core_1.8.3.jar:na]
    	at org.openhab.model.core.internal.folder.FolderObserver.run(FolderObserver.java:99) [org.openhab.model.core_1.8.3.jar:na]
    My item definition looks like the following:
    Number  Temperature           "Temp [%s °C]"     <temperature>   (gBio,gTemperature)     {mysensors=105;1;V_TEMP}
    As a follow-on, I've been trying to understand the {mysensors=105;1;V_TEMP} binding and what the semicolon separated values represent. So far I've been following example code, and haven't found the right documentation. Can someone point me to the right place? I appreciate any help.
    bklB
    bklB
    bkl
    Hi @Kodiak80
    Your are missing the " item definition should be.
    Number  Temperature           "Temp [%s °C]"     <temperature>   (gBio,gTemperature)     {mysensors="105;1;V_TEMP"}
    The values is just
    node-id;child-sensor-id;sub-type
    • bklB bkl
      @NickBuilder
      From what i know sendCommand should be the way to go.
      myElecVar.sendCommand(0);
      That should send the value to your sensor, and then update its value of pulseCount
      NickBuilderN
      NickBuilderN
      NickBuilder
      @bkl
      Ok. But for some reason the new value is not accepted in my case. I will try and see if the serial terminal, when connected to the sensor, will give a hint on what’s going on. It would be nice if the debug of the binding could show what is actually being sent to (and possibly through) the gateway. Is this possible already by ”activating” a certain debug.xml module?
      The serial binding is quite clear in this regard as the message with payload according to the mysensor protocol is displayed in the debug log.
      • Velo17V
        Velo17V
        Velo17
        ...trying to download the jar from the link in the first post, but server is not reachable. Is there any other URL to this .jar?
        • jerseyguy1996J
          jerseyguy1996J
          jerseyguy1996
          @bkl First off I want to thank you for the MySensors openhab binding. It works wonderfully!
          In the MySensors 2.0 there is an internal message that doesn't seem to be handled by the binding. I believe it needs to be handled in MySensorsBinding.java. I would do it myself but my knowledge of Java sucks....to put it lightly. The internal message is:
          I_DISCOVER_RESPONSE
          so my openhab log keeps getting spammed with:
          2016-10-21 22:16:21.653 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
          2016-10-21 22:26:21.374 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
          2016-10-21 22:36:22.127 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
          2016-10-21 22:46:21.847 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
          2016-10-21 22:56:21.569 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "4;255;I_DISCOVER_RESPONSE"
          I'm assuming that we just need to add a line to:
          public void incommingMessage(Message message)
          to handle it but I would rather let you do it since like I said....I suck with Java. Is that something that would be an easy fix?
          • A
            andreground
            Ethernet gw binding source seems to be missing in github repo.
            Any clue?
            : Compilation failure:
            [ERROR] /root/openhab/bundles/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/internal/MySensorsBinding.java:[17]
            [ERROR] import org.openhab.binding.mysensors.internal.gateway.Ethernet;
            [ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
            [ERROR] The import org.openhab.binding.mysensors.internal.gateway.Ethernet cannot be resolved
            [ERROR] /root/openhab/bundles/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/internal/MySensorsBinding.java:[117]
            [ERROR] gateway = new Ethernet(prop.getProperty("host"), Integer.parseInt(prop.getProperty("port", "5003")));
            [ERROR] ^^^^^^^^
            [ERROR] Ethernet cannot be resolved to a type
            [ERROR] 2 problems (2 errors)
            [ERROR] -> [Help 1]
            [ERROR]
            [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
            [ERROR] Re-run Maven using the -X switch to enable full debug logging.
            [ERROR]
            [ERROR] For more information about the errors and possible solutions, please read the following articles:
            [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
            [ERROR]
            [ERROR] After correcting the problems, you can resume the build with the command
            [ERROR] mvn <goals> -rf :org.openhab.binding.mysensors
            • F
              F
              Fritzin
              How do I add the "my-sensors" add on to openhab2.0. I openhab2 up and running based on their rasp-image. I have downloaded a couple other adds and install just fine. I don't know how to place the .jar file into the adds. Is there a clear guide on how to get this done ? PLS HELP!
              • andredtsA
                andredtsA
                andredts
                @bkl Hi,
                Use this biding from it`s beginning, many thanks again. Just want to know if there is any function like the "ack" as there is on OH2 binding, where gateway re-sends the msg 5 times if it does not hear from the sensor after a command. It´s a killer function to make it more reliable, but I´m not ready for OH2 yet.
                • parachutesjP
                  parachutesjP
                  parachutesj
                  wrote on last edited by parachutesj
                  #81
                  after my openHAB system completely failed I had to re-install everying. I had MySensors configured the old way with a lot of rules with the serial binding I thought I give the binding a try.
                  In general it works but I have issues with S_COVER, not sure how to configure this.
                  But of course in openhab it is a single Rollershutter item... I think I could do a workaround in creating in total 4 items and only show my rollershutter and then have a rule and based on up/down/stop update the 3 items.
                  Anyhow, seems to complex.
                  What is best practice here?
                  The sensor presents itself with this:
                   * Example item: 188;2;V_UP                 - Window covering. Up.
                   * Example item: 188;2;V_DOWN               - Window covering. Down.
                   * Example item: 188;2;V_STOP               - Window covering. Stop.
                   * Example item: 188;2;V_PERCENTAGE         - Percentage value. 0-100 (%) ```
                  parachutesjP 1 Reply Last reply
                  • parachutesjP parachutesj
                    parachutesjP
                    parachutesjP
                    parachutesj
                    #82
                    I saw STOP in S_cover is not supported in OH2 - what about OH1? Anyone?
                      TimO
                      @parachutesj According OH2: That was fixed a looooooong time ago. :D
                      Refer to: https://github.com/tobof/openhab2-addons/wiki/Examples for an example (cover).
                      • T TimO
                        parachutesjP
                        parachutesjP
                        parachutesj
                        @TimO thank you.
                        and what is with OH1? Not getting it to work.
                        Does not seem that STOP works, UP & DOWN and PERCENTAGE work
                          @TimO thank you.
                          TimO
                          @parachutesj I can't help you with this version of the binding, I've never used it.
                          • T TimO
                            parachutesjP
                            parachutesjP
                            parachutesj
                            @TimO Thanks anyway. I am slowly moving into the OH2 direction - still a lot of things to be clarified and configured
                            • G
                              G
                              Guillermo Schimmel
                              Hello guys, who can unpin this post?
                              It is terribly outdated.
                              The effort for an openhab-mysensors binding is still valid but several things changed on OpenHAB, making this a lot easier.
                              • G Guillermo Schimmel
                                @guillermo-schimmel done. Is there some other post that should be pinned instead?
                                G 1 Reply Last reply
                                  G
                                  G
                                  Guillermo Schimmel
                                  @mfalkvidd Thanks! Just give me a couple of days and I will try to make a new tutorial for mysensors+openhab.
