  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.3k Views 33 Watching
  • andredtsA
    andredtsA
    andredts
    @bkl Hi,
    Use this biding from it`s beginning, many thanks again. Just want to know if there is any function like the "ack" as there is on OH2 binding, where gateway re-sends the msg 5 times if it does not hear from the sensor after a command. It´s a killer function to make it more reliable, but I´m not ready for OH2 yet.
    • parachutesjP
      parachutesjP
      parachutesj
      wrote on last edited by parachutesj
      #81
      after my openHAB system completely failed I had to re-install everying. I had MySensors configured the old way with a lot of rules with the serial binding I thought I give the binding a try.
      In general it works but I have issues with S_COVER, not sure how to configure this.
      But of course in openhab it is a single Rollershutter item... I think I could do a workaround in creating in total 4 items and only show my rollershutter and then have a rule and based on up/down/stop update the 3 items.
      Anyhow, seems to complex.
      What is best practice here?
      The sensor presents itself with this:
       * Example item: 188;2;V_UP                 - Window covering. Up.
       * Example item: 188;2;V_DOWN               - Window covering. Down.
       * Example item: 188;2;V_STOP               - Window covering. Stop.
       * Example item: 188;2;V_PERCENTAGE         - Percentage value. 0-100 (%) ```
      parachutesjP 1 Reply Last reply
      • parachutesjP parachutesj
        parachutesjP
        parachutesjP
        parachutesj
        #82
        I saw STOP in S_cover is not supported in OH2 - what about OH1? Anyone?
          TimO
          @parachutesj According OH2: That was fixed a looooooong time ago. :D
          Refer to: https://github.com/tobof/openhab2-addons/wiki/Examples for an example (cover).
          • T TimO
            parachutesjP
            parachutesjP
            parachutesj
            @TimO thank you.
            and what is with OH1? Not getting it to work.
            Does not seem that STOP works, UP & DOWN and PERCENTAGE work
              @TimO thank you.
              TimO
              @parachutesj I can't help you with this version of the binding, I've never used it.
              • T TimO
                parachutesjP
                parachutesjP
                parachutesj
                @TimO Thanks anyway. I am slowly moving into the OH2 direction - still a lot of things to be clarified and configured
                • G
                  G
                  Guillermo Schimmel
                  Hello guys, who can unpin this post?
                  It is terribly outdated.
                  The effort for an openhab-mysensors binding is still valid but several things changed on OpenHAB, making this a lot easier.
                  • G Guillermo Schimmel
                    @guillermo-schimmel done. Is there some other post that should be pinned instead?
                    G 1 Reply Last reply
                      G
                      G
                      Guillermo Schimmel
                      @mfalkvidd Thanks! Just give me a couple of days and I will try to make a new tutorial for mysensors+openhab.
