  3. TSM:FPAR:No Reply
TSM:FPAR:No Reply
42 Posts 7 Posters 16.1k Views 8 Watching
    Try to put the radios a couple of meters apart and see if you see any change
    Tommas
    @gohan
    Dear gohan!
    I have tried but nothing change. I bought two nrf24 from keyestudio without pa/lna , if it arrives i will try those.
    I will write the experiences with the new ones.
    Best regards
      Are you using the PA lna? If so try a bigger cap, set pa power to min and you could also wrap the radio module with plastic and aluminum foil for shielding
        Tommas
        @gohan
        Hi gohan!
        Oh, OK! Im trying today. How can i set the power to minimum?
        Have a Good day!
          Look at the examples of other sketches, it's a define to be added, or you can set the default value in myconfig.h inside the library folder (look for the nrf24 section in the file)
          • ben999B
            ben999B
            ben999
            Did you define the node_Id and parent_ID in the sketch ?
            T 2 Replies Last reply
            • ben999B ben999
              Tommas
              wrote on last edited by Tommas
              @ben999
              Hi Ben!
              I havent define the parent ID because i havent known that i should do. i will try these settings as soon as i can.
              I have already defined the node id in the node sketch
              Thank you!
                Tommas
                • ben999B ben999
                  Tommas
                  @ben999
                  Hi Ben!
                  How can i define the parent id on the gateway?
                    You don't have to define a parent ID in your case.
                    • J
                      J
                      Jan Hilbrandt
                      Hi Guys,
                      i have the same Problem
                      I've build a Serial-Gateway (Arduino Nano clone + nrf24) and a node (Arduino Nano clone + DHT22 + nrf24)
                      I do the connecition from this Site and added a 10µF capacitor to VCC and GND.
                      I try to set a fix Node-ID, but there is the same problem
                      This is the Log from the Gateway:
                      0;255;3;0;9;TSM:INIT
                      0;255;3;0;9;TSF:WUR:MS=0
                      0;255;3;0;9;TSM:INIT:TSP OK
                      0;255;3;0;9;TSM:INIT:GW MODE
                      0;255;0;0;18;2.1.1
                      0;255;3;0;9;MCO:BGN:STP
                      And the Node:
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSF:SID:OK,ID=10
                      14 TSM:FPAR
                      1613 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      3621 !TSM:FPAR:NO REPLY
                      3623 TSM:FPAR
                      5223 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      7230 !TSM:FPAR:NO REPLY
                      7232 TSM:FPAR
                      8832 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      10839 !TSM:FPAR:NO REPLY
                      10841 TSM:FPAR
                      12440 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      14448 !TSM:FPAR:FAIL
                      14449 TSM:FAIL:CNT=1
                      14451 TSM:FAIL:PDT
                      24454 TSM:FAIL:RE-INIT
                      24456 TSM:INIT
                      24463 TSM:INIT:TSP OK
                      24465 TSF:SID:OK,ID=10
                      24467 TSM:FPAR
                      26066 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      28075 !TSM:FPAR:NO REPLY
                      28077 TSM:FPAR
                      I think the node is send some data but the gateway not answer.
                      I increase the distance between the gateway and the node, but still the same problem.
                      Sorry for my bad english :blush:
                        do you see any message in the GW log when node is trying to connect? Because if not it may be a problem ot the radio module of the note not sending correctly, one of the radio modules could be a fake module and very poor quality. In the beginning I bought some modules that had a blob instead of an IC on the module and they were all not working. I can suggest to try some sample sketches to check if modules are communicating and also you could give a try to mysensors library from development branch
                        • J
                          J
                          Jan Hilbrandt
                          No that is the full log from the GW. Damn...all my radiomodules have this blob like this one on the left picture.
                          I have also tested other NRF receivers (with the blob)
                            Those are the kind that normally doesn't work. Return them if you can or you can just dump them and get the good ones (look at the threads about genuine NRF24)
                              Tommas
                              @gohan
                              Oh ok. Thanks.
                              I tried to attach 100uF capacitor but the results are same.(no reply) . The node ID is defined, the parent ID isnt.
                              It seems that im out of ideas. I wait for the new nrf24 without pa lna.
                              Im attaching some pictures about the project.
                              Should i foil the nrf24 modul?
                              https://cloud.freeforall.hu/owncloud/public.php?service=files&t=1f73fddc20c6d9a2560f88f78affd499
                                I can't see the link but I trying to foil the radio module could be an idea, as I wrote a few posts earlier
                                  Tommas
                                  @gohan
                                  Dear gohan!
                                  Sorry, it is a private home server and it was in maintenance mode when you were trying to connect. Now it should be working.
                                  (The new nrf24 have just arrived so im going to try these as soon as i can)
                                  Best regards
                                    Tommas
                                    @gohan
                                    Dear Gohan!
                                    I have just tried the new nrf24 standard, and it works!
                                    It seems that the GND should be common (im newbie).
                                    I would like to test further with the pa+lna version, but....
                                    I have an other question.
                                    I would like to power the board with 5V from the power module 5V output, and i would like to program the board via USB at the same time. How should i connect the power module to the board?
                                      why do you want to do that? And yes, GND is normally common
                                        Tommas
                                        @gohan
                                        Dear Gohan!
                                        Everyone suggests that if you use pa+lna version you should power it from external regulated 3.3 V because the arduino clones 3.3V isnt strong enough. So i bought externaI power source.... i have figured out today that i can common the power source's gnd with the arduino gnd. It is working....
                                        What is last that i would like to power the arduino uno from power module 5V and connect it to my computer same time... i dont know how to do it.
                                        I have tested the two nrf24 pa+lna and these arent working together only. Separately is OK.
                                        I will go with the standard nrf24 , make it working than i will try to buy branded nrf24 pa+lna.
                                        Have you got favourite brand for cheaper electronic parts?
                                          Not really an external power source, you can just use the 5V output from the arduino and use a voltage regulator to 3.3v.
                                          I bought some of these http://www.gearbest.com/transmitters-receivers-module/pp_453011.html and I am very happy as they allow for quick swap of the radio and already have caps
