  3. TSM:FPAR:No Reply
TSM:FPAR:No Reply
42 Posts 7 Posters 16.1k Views 8 Watching
  • ben999B
    ben999B
    ben999
    Did you define the node_Id and parent_ID in the sketch ?
    T 2 Replies Last reply
    • ben999B ben999
      Tommas
      wrote on last edited by Tommas
      @ben999
      Hi Ben!
      I havent define the parent ID because i havent known that i should do. i will try these settings as soon as i can.
      I have already defined the node id in the node sketch
      Thank you!
        Look at the examples of other sketches, it's a define to be added, or you can set the default value in myconfig.h inside the library folder (look for the nrf24 section in the file)
        Tommas
        • ben999B ben999
          Tommas
          @ben999
          Hi Ben!
          How can i define the parent id on the gateway?
            You don't have to define a parent ID in your case.
            • J
              J
              Jan Hilbrandt
              Hi Guys,
              i have the same Problem
              I've build a Serial-Gateway (Arduino Nano clone + nrf24) and a node (Arduino Nano clone + DHT22 + nrf24)
              I do the connecition from this Site and added a 10µF capacitor to VCC and GND.
              I try to set a fix Node-ID, but there is the same problem
              This is the Log from the Gateway:
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSF:WUR:MS=0
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              0;255;0;0;18;2.1.1
              0;255;3;0;9;MCO:BGN:STP
              And the Node:
              3 TSM:INIT
              4 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSF:SID:OK,ID=10
              14 TSM:FPAR
              1613 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              3621 !TSM:FPAR:NO REPLY
              3623 TSM:FPAR
              5223 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              7230 !TSM:FPAR:NO REPLY
              7232 TSM:FPAR
              8832 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              10839 !TSM:FPAR:NO REPLY
              10841 TSM:FPAR
              12440 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              14448 !TSM:FPAR:FAIL
              14449 TSM:FAIL:CNT=1
              14451 TSM:FAIL:PDT
              24454 TSM:FAIL:RE-INIT
              24456 TSM:INIT
              24463 TSM:INIT:TSP OK
              24465 TSF:SID:OK,ID=10
              24467 TSM:FPAR
              26066 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              28075 !TSM:FPAR:NO REPLY
              28077 TSM:FPAR
              I think the node is send some data but the gateway not answer.
              I increase the distance between the gateway and the node, but still the same problem.
              Sorry for my bad english :blush:
                do you see any message in the GW log when node is trying to connect? Because if not it may be a problem ot the radio module of the note not sending correctly, one of the radio modules could be a fake module and very poor quality. In the beginning I bought some modules that had a blob instead of an IC on the module and they were all not working. I can suggest to try some sample sketches to check if modules are communicating and also you could give a try to mysensors library from development branch
                • J
                  J
                  Jan Hilbrandt
                  No that is the full log from the GW. Damn...all my radiomodules have this blob like this one on the left picture.
                  I have also tested other NRF receivers (with the blob)
                    Those are the kind that normally doesn't work. Return them if you can or you can just dump them and get the good ones (look at the threads about genuine NRF24)
                      Tommas
                      @gohan
                      Oh ok. Thanks.
                      I tried to attach 100uF capacitor but the results are same.(no reply) . The node ID is defined, the parent ID isnt.
                      It seems that im out of ideas. I wait for the new nrf24 without pa lna.
                      Im attaching some pictures about the project.
                      Should i foil the nrf24 modul?
                      https://cloud.freeforall.hu/owncloud/public.php?service=files&t=1f73fddc20c6d9a2560f88f78affd499
                        I can't see the link but I trying to foil the radio module could be an idea, as I wrote a few posts earlier
                          Tommas
                          @gohan
                          Dear gohan!
                          Sorry, it is a private home server and it was in maintenance mode when you were trying to connect. Now it should be working.
                          (The new nrf24 have just arrived so im going to try these as soon as i can)
                          Best regards
                            Tommas
                            @gohan
                            Dear Gohan!
                            I have just tried the new nrf24 standard, and it works!
                            It seems that the GND should be common (im newbie).
                            I would like to test further with the pa+lna version, but....
                            I have an other question.
                            I would like to power the board with 5V from the power module 5V output, and i would like to program the board via USB at the same time. How should i connect the power module to the board?
                              why do you want to do that? And yes, GND is normally common
                                Tommas
                                @gohan
                                Dear Gohan!
                                Everyone suggests that if you use pa+lna version you should power it from external regulated 3.3 V because the arduino clones 3.3V isnt strong enough. So i bought externaI power source.... i have figured out today that i can common the power source's gnd with the arduino gnd. It is working....
                                What is last that i would like to power the arduino uno from power module 5V and connect it to my computer same time... i dont know how to do it.
                                I have tested the two nrf24 pa+lna and these arent working together only. Separately is OK.
                                I will go with the standard nrf24 , make it working than i will try to buy branded nrf24 pa+lna.
                                Have you got favourite brand for cheaper electronic parts?
                                  Not really an external power source, you can just use the 5V output from the arduino and use a voltage regulator to 3.3v.
                                  I bought some of these http://www.gearbest.com/transmitters-receivers-module/pp_453011.html and I am very happy as they allow for quick swap of the radio and already have caps
                                    Tommas
                                    @gohan
                                    Dear gohan!
                                    Thank you for your help. I will buy from ebay this one: https://www.ebay.com/itm/200960749614
                                    And im planning that i will buy a shielded nrf24 pa+lna .
                                    Today im installing an openhab and try to transfer the datas from gateway to the openhab...
                                    What projects have you done already?
                                    Best regards
                                      The one on ebay it's missing the capacitor so remember to add one on the radio
                                      T rejoe2R 2 Replies Last reply
                                        Tommas
                                        @gohan
                                        Oh! I missed that. I will look for another one with cap.
                                          rejoe2R
                                          rejoe2R
                                          rejoe2
                                          @gohan
                                          According to this site, the ebay-modules have also caps included. There are also some sellers providing according schematics.
                                          I myselfe use a couple of them (also with +pa+nla-modules) and never ran into bigger trouble.
                                          Anyone with different experiences?
