  3. TSM:FPAR:No Reply
TSM:FPAR:No Reply
42 Posts 7 Posters 16.1k Views 8 Watching
  • T
    Tommas
    wrote on last edited by Tommas
    Dear gonhan!
    First of all, thank you for your help.
    I have two power module (https://www.ebay.com/itm/262102860958 ) with an mb102 bread board and i use it for powering my nrf24. I use a 7.5v 1000mA adapter to power the modules.
    The capacitor is a 47uF one.
    I power the two microcontrollers through USB connected to my laptop at the same time, because at this way i can switch the console output between the two controllers when i would like to see the output.
    I try to follow the guides described here. All parts are from keyestudio except the two nrf24(with antenna) module.
    I use the mysensors latest library , gatewayW5100mqttclient and a dht11 example sketch (but i have tried already another official mysensors lightsensor sketch) on the node.
      Try to put the radios a couple of meters apart and see if you see any change
        Tommas
        @gohan
        Dear gohan!
        I have tried but nothing change. I bought two nrf24 from keyestudio without pa/lna , if it arrives i will try those.
        I will write the experiences with the new ones.
        Best regards
          Are you using the PA lna? If so try a bigger cap, set pa power to min and you could also wrap the radio module with plastic and aluminum foil for shielding
            Tommas
            @gohan
            Hi gohan!
            Oh, OK! Im trying today. How can i set the power to minimum?
            Have a Good day!
              Look at the examples of other sketches, it's a define to be added, or you can set the default value in myconfig.h inside the library folder (look for the nrf24 section in the file)
              • ben999B
                ben999B
                ben999
                Did you define the node_Id and parent_ID in the sketch ?
                T 2 Replies Last reply
                • ben999B ben999
                  Tommas
                  @ben999
                  Hi Ben!
                  I havent define the parent ID because i havent known that i should do. i will try these settings as soon as i can.
                  I have already defined the node id in the node sketch
                  Thank you!
                    Tommas
                    • ben999B ben999
                      Tommas
                      @ben999
                      Hi Ben!
                      How can i define the parent id on the gateway?
                        You don't have to define a parent ID in your case.
                        • J
                          J
                          Jan Hilbrandt
                          Hi Guys,
                          i have the same Problem
                          I've build a Serial-Gateway (Arduino Nano clone + nrf24) and a node (Arduino Nano clone + DHT22 + nrf24)
                          I do the connecition from this Site and added a 10µF capacitor to VCC and GND.
                          I try to set a fix Node-ID, but there is the same problem
                          This is the Log from the Gateway:
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSF:WUR:MS=0
                          0;255;3;0;9;TSM:INIT:TSP OK
                          0;255;3;0;9;TSM:INIT:GW MODE
                          0;255;0;0;18;2.1.1
                          0;255;3;0;9;MCO:BGN:STP
                          And the Node:
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          13 TSF:SID:OK,ID=10
                          14 TSM:FPAR
                          1613 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          3621 !TSM:FPAR:NO REPLY
                          3623 TSM:FPAR
                          5223 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          7230 !TSM:FPAR:NO REPLY
                          7232 TSM:FPAR
                          8832 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          10839 !TSM:FPAR:NO REPLY
                          10841 TSM:FPAR
                          12440 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          14448 !TSM:FPAR:FAIL
                          14449 TSM:FAIL:CNT=1
                          14451 TSM:FAIL:PDT
                          24454 TSM:FAIL:RE-INIT
                          24456 TSM:INIT
                          24463 TSM:INIT:TSP OK
                          24465 TSF:SID:OK,ID=10
                          24467 TSM:FPAR
                          26066 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          28075 !TSM:FPAR:NO REPLY
                          28077 TSM:FPAR
                          I think the node is send some data but the gateway not answer.
                          I increase the distance between the gateway and the node, but still the same problem.
                          Sorry for my bad english :blush:
                            do you see any message in the GW log when node is trying to connect? Because if not it may be a problem ot the radio module of the note not sending correctly, one of the radio modules could be a fake module and very poor quality. In the beginning I bought some modules that had a blob instead of an IC on the module and they were all not working. I can suggest to try some sample sketches to check if modules are communicating and also you could give a try to mysensors library from development branch
                            • J
                              J
                              Jan Hilbrandt
                              No that is the full log from the GW. Damn...all my radiomodules have this blob like this one on the left picture.
                              I have also tested other NRF receivers (with the blob)
                                Those are the kind that normally doesn't work. Return them if you can or you can just dump them and get the good ones (look at the threads about genuine NRF24)
                                  Tommas
                                  @gohan
                                  Oh ok. Thanks.
                                  I tried to attach 100uF capacitor but the results are same.(no reply) . The node ID is defined, the parent ID isnt.
                                  It seems that im out of ideas. I wait for the new nrf24 without pa lna.
                                  Im attaching some pictures about the project.
                                  Should i foil the nrf24 modul?
                                  https://cloud.freeforall.hu/owncloud/public.php?service=files&t=1f73fddc20c6d9a2560f88f78affd499
                                    I can't see the link but I trying to foil the radio module could be an idea, as I wrote a few posts earlier
                                      Tommas
                                      @gohan
                                      Dear gohan!
                                      Sorry, it is a private home server and it was in maintenance mode when you were trying to connect. Now it should be working.
                                      (The new nrf24 have just arrived so im going to try these as soon as i can)
                                      Best regards
                                        Tommas
                                        @gohan
                                        Dear Gohan!
                                        I have just tried the new nrf24 standard, and it works!
                                        It seems that the GND should be common (im newbie).
                                        I would like to test further with the pa+lna version, but....
                                        I have an other question.
                                        I would like to power the board with 5V from the power module 5V output, and i would like to program the board via USB at the same time. How should i connect the power module to the board?
                                          why do you want to do that? And yes, GND is normally common
