  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • F
    F
    Floca
    Hello Everybody,
    i'm working some timeon the project, to switch my network to rfm69(cw), because i read many good things about them (e.g. better range)
    I have tested around for a couple of days, with an Wemos Esp8266, and an Arduino Nano as Gateway and a ProMini with dht22 as Node.
    I had no Chance to get them to work (gateway not responding), now i read, that i must switch back to 2.0.0 and everything is really fine (first try, success).
    Is that a known Bug? Why is it not getting fixed?
    I would like to use the newer Firmwares instead of 2.0.0...
    Thanks for the Mysensors Projekt :)
    Floca
      without much infos (debugs logs etc..) it's hard to help.
      As far as i know, rfm69 is working well with the latest Mysensors development branch at github..
      • F
        F
        Floca
        the log is in this case not very usefull, because they start up normal, with or without rfm69 attached.
        The node try's to find the gateway "No Reply" but is it not answering.
        I have tried some different szenario's... if they are paired with 2.0.0 i can update the node to any newer version, but not the gateway.
        The Gateway is not answering when it gets a newer version.
        When its not paired, no chance to add new nodes with newer versions.
        • archiijsA
          archiijsA
          archiijs
          Well, that would explain why some time back I could not get RFM network to work. After a week of reading and changing sketches, and trying to figure it out I give up (got the same "No Replay").
          Not tried with an older version, but got one instance when gateway found the node and then immediately hanged, after that nothing.
          I guess that I should check again with an older version then.
          • F
            F
            Floca
            Yes,
            that should be the Same Problem, as i tried to explain above.
            2.0.0 works fine, if you have no Problem, that you don't get any updates :(
            • F Floca
              Yes,
              sundberg84S
              sundberg84S
              @Floca I have just tested RFM69w with the development branch and that works great. Don't know if the code is different from c versions though. It was very important to have the right declarations as described in the radio section.
              • F
                F
                Floca
                I have declared, that i want to use RFM69CW instead of NRF24 and have nothing else changed.
                That what i have declared was ok for the 2.0.0 build...
                I dont know, if there is an difference between the C an non C Versions of the Module.
                • F Floca
                  sundberg84S
                  sundberg84S
                  @Floca
                  From https://www.mysensors.org/build/connect_radio:
                  And if you need an advanced configuration, you may need to also add these defines :
                  #define MY_RFM69_FREQUENCY RF69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
                  #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
                  //#define MY_RFM69_NETWORKID 100  // Default is 100 in lib. Uncomment it and set your preferred network id if needed
                  //#define RF69_IRQ_PIN 4  // Default in lib is using D2 for common Atmel 328p (mini pro, nano, uno etc.). Uncomment it and set the pin you're using. Note for Atmel 328p, Mysensors, and regarding Arduino core implementation D2 or D3 are only available. But for advanced mcus like Atmel SAMD (Arduino Zero etc.), Esp8266 you will need to set this define for the corresponding pin used for IRQ
                  // #define MY_RF69_IRQ_NUM 4 // Temporary define (will be removed in next radio driver revision). Needed if you want to change the IRQ pin your radio is connected. So, if your radio is connected to D3/INT1, value is 1 (INT1). For others mcu like Atmel SAMD, Esp8266, value is simply the same as your RF69_IRQ_PIN
                  // #define MY_RF69_SPI_CS 15 // If using a different CS pin for the SPI bus. Use MY_RFM69_CS_PIN for the development branch.
                  But i guess you are fine, since you are not using H version unless your wiring is ok.
                  • F
                    F
                    Floca
                    Ok, i have seen this defines and used them (without the define for the HW Module, because it is only for that), the Result was 1:1 the same as without the definitions.
                    • F
                      F
                      Floca
                      Here are the Codes from the Gateway and Node (works in 2.0.0, in all versions above 2.0.0 it works not):
                       * Version 1.0 - Henrik EKblad
                       * Contribution by tekka,
                       * Contribution by Ivo Pullens (ESP8266 support)
                       * The EthernetGateway sends data received from sensors to the WiFi link.
                       * VERA CONFIGURATION:
                       * LED purposes:
                       * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                       * nRF24L01+  ESP8266
                       * VCC        VCC
                       * CE         GPIO4
                       * CSN/CS     GPIO15
                       * SCK        GPIO14
                       * MISO       GPIO12
                       * MOSI       GPIO13
                       * GND        GND
                        * Inclusion mode button:
                      #include <ArduinoOTA.h>
                      #define MY_BAUD_RATE 9600
                      #define MY_RADIO_RFM69
                      #define MY_RF69_IRQ_PIN 4
                      #define MY_GATEWAY_ESP8266
                      #define MY_ESP8266_SSID "MySSID"
                      #define MY_ESP8266_PASSWORD "MyPass"
                      #define MY_ESP8266_HOSTNAME "RFM69-Gateway"
                      // Enable UDP communication
                      //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                      #define MY_PORT 5003
                      // Enable inclusion mode
                      // #define MY_INCLUSION_BUTTON_FEATURE
                      // Set blinking period
                      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                      // Flash leds on rx/tx/err
                      #if defined(MY_USE_UDP)
                      #include <WiFiUDP.h>
                      #include <ESP8266WiFi.h>
                      	ArduinoOTA.onStart([]() {
                      		debug("ArduinoOTA start\n");
                      	ArduinoOTA.onEnd([]() {
                      		debug("\nArduinoOTA end\n");
                        ArduinoOTA.setPassword((const char *)"123");
                      	ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                      		debug("OTA Progress: %u%%\r", (progress / (total / 100)));
                      	ArduinoOTA.onError([](ota_error_t error) {
                      		debug("Error[%u]: ", error);
                      		if (error == OTA_AUTH_ERROR) {
                      			debug("Auth Failed\n");
                      		} else if (error == OTA_BEGIN_ERROR) {
                      			debug("Begin Failed\n");
                      		} else if (error == OTA_CONNECT_ERROR) {
                      			debug("Connect Failed\n");
                      		} else if (error == OTA_RECEIVE_ERROR) {
                      			debug("Receive Failed\n");
                      		} else if (error == OTA_END_ERROR) {
                      			debug("End Failed\n");
                      	ArduinoOTA.begin();
                      	ArduinoOTA.handle();
                       * Version 1.0: Henrik EKblad
                       * sensor using a DHT11/DHT-22.
                      // Enable debug prints
                      #define MY_RF69_IRQ_PIN 2
                      #define MY_RF69_SPI_CS 10
                      #define DHT_DATA_PIN 3
                      #define SENSOR_TEMP_OFFSET 0
                      static const uint64_t UPDATE_INTERVAL = 60000;
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      float lastTemp;
                      float lastHum;
                      uint8_t nNoUpdatesTemp;
                      uint8_t nNoUpdatesHum;
                      bool metric = true;
                      DHT dht;
                        sendSketchInfo("TemperatureAndHumidity", "1.1");
                        present(CHILD_ID_HUM, S_HUM);
                        dht.readSensor(true);
                        if (isnan(temperature)) {
                          lastTemp = temperature;
                          if (!metric) {
                          // Reset no updates counter
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          Serial.print("T: ");
                          nNoUpdatesTemp++;
                        if (isnan(humidity)) {
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          Serial.print("H: ");
                          Serial.println(humidity);
                          nNoUpdatesHum++;
                        sleep(UPDATE_INTERVAL);
                      • D
                        DavidZH
                        Can you post a picture of het back of your RFM module? That way we can eliminate the definitions you won't need.
                        I run on 2.1.1 with 868MHz versions of both HW and low power. No problems whatsoever. I'm getting very curious as to why I keep reading about users facing issues with the RFM based nodes.
                        F 1 Reply Last reply
                        • archiijsA
                          archiijsA
                          archiijs
                          Hi, I will look closely this, because I would really like to get RFM network going for my outide, not with NRF reachable sensors.
                          In my definition, I added
                          and
                          cause my radio was like 4th from left in the picture below. I was using antenna bundled with radios (173mm) stranded but changed to solid but with the same length.
                          • D DavidZH
                            F
                            F
                            Floca
                            wrote on last edited by Floca
                            @DavidZH said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
                            RFM69CW
                            • D
                              DavidZH
                              Well there's your problem! You have a 868MHz CW version. So NOT the HCW That means both of the above mentioned defines ar not valid. The only define you'd have to make is #define MY_RADIO_RFM69. That should work.
                              You can tell that it is not the H version because of the missing components that make up the extra RF amplifier on the module.
                              Hope this helps! Good luck!
                              • F
                                F
                                Floca
                                As i told above, i have no definitions for the H Module...
                                Take a look in the posted Scripts, all definitions are excluded, that are belong to the H Version.
                                • mfalkviddM
                                  I think @DavidZH was confused by @archiijs post about the H version.
                                  I double-checked your sketches and none has the definition for H so now that's out of the way at least.
                                  @Floca could you post debug output from the gateway and the node (preferably from the same time) ?
                                  Also, just to double-check, have you made any modifications to MyConfig.h or are you using the untouched original version?
                                  • archiijsA
                                    archiijsA
                                    archiijs
                                    Yes, sorry for this, I will stand back til @Floca gets his problem (and maybe mine) figured out and then jump in to avoid confusion, sorry again.
                                    • F
                                      F
                                      Floca
                                      GW 2.0.0
                                      Ê$OH˜KlKùið¤0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                                      0;255;3;0;9;TSM:INIT
                                      0;255;3;0;9;TSM:RADIO:OK
                                      0;255;3;0;9;TSM:GW MODE
                                      0;255;3;0;9;TSM:READY
                                      scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 4
                                      cnt
                                      f r0, scandone
                                      connected with N3tw0rk.NET, channel 1
                                      dhcp client start...
                                      ..ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
                                      .IP: 192.168.178.118
                                      pm open,type:2 0
                                      0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:BC
                                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
                                      0;255;3;0;9;TSP:CHKUPL:OK
                                      0;255;3;0;9;TSP:MSG:GWL OK
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                      0;255;3;0;9;TSP:MSG:PINGED (ID=100, hops=1)
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      0;255;3;0;9;!TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
                                      0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=1,t=1,pt=7,l=5,sg=0:80.7
                                      0;255;3;0;9;TSP:SANCHK:OK
                                      SENSOR 2.0.0
                                      Starting sensor (RRNNA-, 2.0.0)
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=100)
                                      TSM:FPAR
                                      TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=100)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                      !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                                      TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=2,st=ok:TemperatureAndHumidity
                                      !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=fail:1.1
                                      TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=ok:
                                      TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                      Request registration...
                                      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=100, parent=0, distance=1, registration=1
                                      TSP:MSG:SEND 100-100-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.8
                                      T: 22.80
                                      TSP:MSG:SEND 100-100-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:80.8
                                      H: 80.80
                                      Gateway 2.2.0
                                      ÈDpÈtAhÀD´ðCXXüü0;255;3;0;9;238 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0-beta
                                      0;255;3;0;9;299 TSF:LRT:OK
                                      0;255;3;0;9;327 TSM:INIT
                                      0;255;3;0;9;353 TSF:WUR:MS=0
                                      scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 4
                                      cnt
                                      0;255;3;0;9;470 TSM:INIT:TSP OK
                                      0;255;3;0;9;502 TSM:INIT:GW MODE
                                      0;255;3;0;9;537 TSM:READY:ID=0,PAR=0,DIS=0
                                      0;255;3;0;9;582 MCO:REG:NOT NEEDED
                                      f r0, scandone
                                      .....ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
                                      0;255;3;0;9;3682 MCO:BGN:STP
                                      0;255;3;0;9;3735 MCO:BGN:INIT OK,TSP=1
                                      pm open,type:2 0
                                      Sensor 2.2.0
                                      0 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0-beta
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      8 TSM:INIT:TSP OK
                                      10 TSM:FPAR
                                      1228 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3237 !TSM:FPAR:NO REPLY
                                      3239 TSM:FPAR
                                      4468 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6477 !TSM:FPAR:NO REPLY
                                      6479 TSM:FPAR
                                      7698 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      9707 !TSM:FPAR:NO REPLY
                                      9709 TSM:FPAR
                                      10928 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      12937 !TSM:FPAR:FAIL
                                      12939 TSM:FAIL:CNT=1
                                      12941 TSM:FAIL:DIS
                                      12943 TSF:TDI:TSL
                                      22947 TSM:FAIL:RE-INIT
                                      22949 TSM:INIT
                                      22951 TSM:INIT:TSP OK
                                      22956 TSM:FPAR
                                      24174 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      26183 !TSM:FPAR:NO REPLY
                                      26185 TSM:FPAR
                                      27404 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      29413 !TSM:FPAR:NO REPLY
                                      29415 TSM:FPAR
                                      30633 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      32643 !TSM:FPAR:NO REPLY
                                      32645 TSM:FPAR
                                      33867 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      35876 !TSM:FPAR:FAIL
                                      35878 TSM:FAIL:CNT=2
                                      35880 TSM:FAIL:DIS
                                      35883 TSF:TDI:TSL
                                      45887 TSM:FAIL:RE-INIT
                                      45889 TSM:INIT
                                      45891 TSM:INIT:TSP OK
                                      45895 TSM:FPAR
                                      47114 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      49123 !TSM:FPAR:NO REPLY
                                      49125 TSM:FPAR
                                      50370 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      52379 !TSM:FPAR:NO REPLY
                                      52381 TSM:FPAR
                                      53600 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      55609 !TSM:FPAR:NO REPLY
                                      55611 TSM:FPAR
                                      56829 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      58839 !TSM:FPAR:FAIL
                                      58841 TSM:FAIL:CNT=3
                                      58843 TSM:FAIL:DIS
                                      58845 TSF:TDI:TSL
                                      68849 TSM:FAIL:RE-INIT
                                      68851 TSM:INIT
                                      68853 TSM:INIT:TSP OK
                                      68857 TSM:FPAR
                                      70076 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      72085 !TSM:FPAR:NO REPLY
                                      72087 TSM:FPAR
                                      73306 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      75315 !TSM:FPAR:NO REPLY
                                      75317 TSM:FPAR
                                      76535 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      78546 !TSM:FPAR:NO REPLY
                                      78548 TSM:FPAR
                                      79767 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      81776 !TSM:FPAR:FAIL
                                      81778 TSM:FAIL:CNT=4
                                      81780 TSM:FAIL:DIS
                                      81782 TSF:TDI:TSL
                                      91785 TSM:FAIL:RE-INIT
                                      91787 TSM:INIT
                                      91789 TSM:INIT:TSP OK
                                      91793 TSM:FPAR
                                      93011 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      95021 !TSM:FPAR:NO REPLY
                                      95023 TSM:FPAR
                                      96241 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      98250 !TSM:FPAR:NO REPLY
                                      98252 TSM:FPAR
                                      99471 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      101480 !TSM:FPAR:NO REPLY
                                      101482 TSM:FPAR
                                      102703 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      104712 !TSM:FPAR:FAIL
                                      104714 TSM:FAIL:CNT=5
                                      104716 TSM:FAIL:DIS
                                      104718 TSF:TDI:TSL
                                      114722 TSM:FAIL:RE-INIT
                                      114724 TSM:INIT
                                      114728 TSM:INIT:TSP OK
                                      114731 TSM:FPAR
                                      115951 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      117960 !TSM:FPAR:NO REPLY
                                      117962 TSM:FPAR
                                      119183 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      121192 !TSM:FPAR:NO REPLY
                                      121194 TSM:FPAR
                                      122443 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      124452 !TSM:FPAR:NO REPLY
                                      124454 TSM:FPAR
                                      125673 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      127682 !TSM:FPAR:FAIL
                                      127684 TSM:FAIL:CNT=6
                                      127686 TSM:FAIL:DIS
                                      127688 TSF:TDI:TSL
                                      137691 TSM:FAIL:RE-INIT
                                      137693 TSM:INIT
                                      137697 TSM:INIT:TSP OK
                                      137699 TSM:FPAR
                                      138919 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      140929 !TSM:FPAR:NO REPLY
                                      140931 TSM:FPAR
                                      142151 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      144160 !TSM:FPAR:NO REPLY
                                      144162 TSM:FPAR
                                      145381 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      • The Config is the Standard Config which comes with the Package on Github.
                                      • The Scripts from above are used to flash the devices.
                                      • The Gateway on 2.2.0-beta gives only these lines as in Codebox, then, nothing else happens.
                                      • I have cleaned the EEPROM from the devices with the eeprom clean example in mysensors examples
                                        @Floca
                                        thx for logs. Logs are always useful ;)
                                        I tried a few weeks ago rfm69 with atsam, esp32 etc and was working well here.
                                        So I'll take a look asap. Need to find a wemos to have same setup.
                                        Note:
                                        • in your first post, you say that you tried with a nano. But nano is 5v whereas rfm69 is not 5v tolerant. So this can't work.
                                        • all rfm69 modules works the same. C, W the same. HW and HCW the same too. These are just different package and mapping, that's all. But sure, if using HW, HCW, needs the high power dfine in MySensors (not your case here)
                                        • F
                                          F
                                          Floca
                                          Oh, of course, i wrote Nano, my mistake :(
                                          I use Arduino PRO MINI's 3.3v for my Nodes.
