  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • F Floca
    I have declared, that i want to use RFM69CW instead of NRF24 and have nothing else changed.
    That what i have declared was ok for the 2.0.0 build...
    I dont know, if there is an difference between the C an non C Versions of the Module.
    sundberg84S
    sundberg84S
    @Floca
    From https://www.mysensors.org/build/connect_radio:
    And if you need an advanced configuration, you may need to also add these defines :
    #define MY_RFM69_FREQUENCY RF69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    //#define MY_RFM69_NETWORKID 100  // Default is 100 in lib. Uncomment it and set your preferred network id if needed
    //#define RF69_IRQ_PIN 4  // Default in lib is using D2 for common Atmel 328p (mini pro, nano, uno etc.). Uncomment it and set the pin you're using. Note for Atmel 328p, Mysensors, and regarding Arduino core implementation D2 or D3 are only available. But for advanced mcus like Atmel SAMD (Arduino Zero etc.), Esp8266 you will need to set this define for the corresponding pin used for IRQ
    // #define MY_RF69_IRQ_NUM 4 // Temporary define (will be removed in next radio driver revision). Needed if you want to change the IRQ pin your radio is connected. So, if your radio is connected to D3/INT1, value is 1 (INT1). For others mcu like Atmel SAMD, Esp8266, value is simply the same as your RF69_IRQ_PIN
    // #define MY_RF69_SPI_CS 15 // If using a different CS pin for the SPI bus. Use MY_RFM69_CS_PIN for the development branch.
    But i guess you are fine, since you are not using H version unless your wiring is ok.
    • F
      F
      Floca
      Ok, i have seen this defines and used them (without the define for the HW Module, because it is only for that), the Result was 1:1 the same as without the definitions.
      • F
        F
        Floca
        Here are the Codes from the Gateway and Node (works in 2.0.0, in all versions above 2.0.0 it works not):
         * Version 1.0 - Henrik EKblad
         * Contribution by tekka,
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * LED purposes:
         * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #include <ArduinoOTA.h>
        #define MY_BAUD_RATE 9600
        #define MY_RADIO_RFM69
        #define MY_RF69_IRQ_PIN 4
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "MySSID"
        #define MY_ESP8266_PASSWORD "MyPass"
        #define MY_ESP8266_HOSTNAME "RFM69-Gateway"
        // Enable UDP communication
        //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
        #include <WiFiUDP.h>
        #include <ESP8266WiFi.h>
        	ArduinoOTA.onStart([]() {
        		debug("ArduinoOTA start\n");
        	ArduinoOTA.onEnd([]() {
        		debug("\nArduinoOTA end\n");
          ArduinoOTA.setPassword((const char *)"123");
        	ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
        		debug("OTA Progress: %u%%\r", (progress / (total / 100)));
        	ArduinoOTA.onError([](ota_error_t error) {
        		debug("Error[%u]: ", error);
        		if (error == OTA_AUTH_ERROR) {
        			debug("Auth Failed\n");
        		} else if (error == OTA_BEGIN_ERROR) {
        			debug("Begin Failed\n");
        		} else if (error == OTA_CONNECT_ERROR) {
        			debug("Connect Failed\n");
        		} else if (error == OTA_RECEIVE_ERROR) {
        			debug("Receive Failed\n");
        		} else if (error == OTA_END_ERROR) {
        			debug("End Failed\n");
        	ArduinoOTA.begin();
        	ArduinoOTA.handle();
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        // Enable debug prints
        #define MY_RF69_IRQ_PIN 2
        #define MY_RF69_SPI_CS 10
        #define DHT_DATA_PIN 3
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 60000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
        • D
          DavidZH
          Can you post a picture of het back of your RFM module? That way we can eliminate the definitions you won't need.
          I run on 2.1.1 with 868MHz versions of both HW and low power. No problems whatsoever. I'm getting very curious as to why I keep reading about users facing issues with the RFM based nodes.
          F 1 Reply Last reply
          • archiijsA
            archiijsA
            archiijs
            Hi, I will look closely this, because I would really like to get RFM network going for my outide, not with NRF reachable sensors.
            In my definition, I added
            and
            cause my radio was like 4th from left in the picture below. I was using antenna bundled with radios (173mm) stranded but changed to solid but with the same length.
            • D DavidZH
              F
              F
              Floca
              wrote on last edited by Floca
              @DavidZH said in RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0:
              RFM69CW
              • D
                DavidZH
                Well there's your problem! You have a 868MHz CW version. So NOT the HCW That means both of the above mentioned defines ar not valid. The only define you'd have to make is #define MY_RADIO_RFM69. That should work.
                You can tell that it is not the H version because of the missing components that make up the extra RF amplifier on the module.
                Hope this helps! Good luck!
                • F
                  F
                  Floca
                  As i told above, i have no definitions for the H Module...
                  Take a look in the posted Scripts, all definitions are excluded, that are belong to the H Version.
                  • mfalkviddM
                    I think @DavidZH was confused by @archiijs post about the H version.
                    I double-checked your sketches and none has the definition for H so now that's out of the way at least.
                    @Floca could you post debug output from the gateway and the node (preferably from the same time) ?
                    Also, just to double-check, have you made any modifications to MyConfig.h or are you using the untouched original version?
                    • archiijsA
                      archiijsA
                      archiijs
                      Yes, sorry for this, I will stand back til @Floca gets his problem (and maybe mine) figured out and then jump in to avoid confusion, sorry again.
                      • F
                        F
                        Floca
                        GW 2.0.0
                        Ê$OH˜KlKùið¤0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:RADIO:OK
                        0;255;3;0;9;TSM:GW MODE
                        0;255;3;0;9;TSM:READY
                        scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 4
                        cnt
                        f r0, scandone
                        connected with N3tw0rk.NET, channel 1
                        dhcp client start...
                        ..ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
                        .IP: 192.168.178.118
                        pm open,type:2 0
                        0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:BC
                        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
                        0;255;3;0;9;TSP:CHKUPL:OK
                        0;255;3;0;9;TSP:MSG:GWL OK
                        0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                        0;255;3;0;9;TSP:MSG:PINGED (ID=100, hops=1)
                        0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        0;255;3;0;9;!TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                        0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
                        0;255;3;0;9;TSP:MSG:READ 100-100-0 s=0,c=1,t=1,pt=7,l=5,sg=0:80.7
                        0;255;3;0;9;TSP:SANCHK:OK
                        SENSOR 2.0.0
                        Starting sensor (RRNNA-, 2.0.0)
                        TSM:INIT
                        TSM:RADIO:OK
                        TSP:ASSIGNID:OK (ID=100)
                        TSM:FPAR
                        TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        TSP:MSG:PAR OK (ID=0, dist=1)
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=100)
                        TSM:UPL
                        TSP:PING:SEND (dest=0)
                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                        TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        TSP:MSG:PONG RECV (hops=1)
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                        !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                        TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=2,st=ok:TemperatureAndHumidity
                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=fail:1.1
                        TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=ok:
                        TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                        Request registration...
                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                        TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        Node registration=1
                        Init complete, id=100, parent=0, distance=1, registration=1
                        TSP:MSG:SEND 100-100-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.8
                        T: 22.80
                        TSP:MSG:SEND 100-100-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:80.8
                        H: 80.80
                        Gateway 2.2.0
                        ÈDpÈtAhÀD´ðCXXüü0;255;3;0;9;238 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0-beta
                        0;255;3;0;9;299 TSF:LRT:OK
                        0;255;3;0;9;327 TSM:INIT
                        0;255;3;0;9;353 TSF:WUR:MS=0
                        scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 4
                        cnt
                        0;255;3;0;9;470 TSM:INIT:TSP OK
                        0;255;3;0;9;502 TSM:INIT:GW MODE
                        0;255;3;0;9;537 TSM:READY:ID=0,PAR=0,DIS=0
                        0;255;3;0;9;582 MCO:REG:NOT NEEDED
                        f r0, scandone
                        .....ip:192.168.178.118,mask:255.255.255.0,gw:192.168.178.1
                        0;255;3;0;9;3682 MCO:BGN:STP
                        0;255;3;0;9;3735 MCO:BGN:INIT OK,TSP=1
                        pm open,type:2 0
                        Sensor 2.2.0
                        0 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0-beta
                        4 TSM:INIT
                        4 TSF:WUR:MS=0
                        8 TSM:INIT:TSP OK
                        10 TSM:FPAR
                        1228 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        3237 !TSM:FPAR:NO REPLY
                        3239 TSM:FPAR
                        4468 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        6477 !TSM:FPAR:NO REPLY
                        6479 TSM:FPAR
                        7698 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        9707 !TSM:FPAR:NO REPLY
                        9709 TSM:FPAR
                        10928 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        12937 !TSM:FPAR:FAIL
                        12939 TSM:FAIL:CNT=1
                        12941 TSM:FAIL:DIS
                        12943 TSF:TDI:TSL
                        22947 TSM:FAIL:RE-INIT
                        22949 TSM:INIT
                        22951 TSM:INIT:TSP OK
                        22956 TSM:FPAR
                        24174 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        26183 !TSM:FPAR:NO REPLY
                        26185 TSM:FPAR
                        27404 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        29413 !TSM:FPAR:NO REPLY
                        29415 TSM:FPAR
                        30633 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        32643 !TSM:FPAR:NO REPLY
                        32645 TSM:FPAR
                        33867 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        35876 !TSM:FPAR:FAIL
                        35878 TSM:FAIL:CNT=2
                        35880 TSM:FAIL:DIS
                        35883 TSF:TDI:TSL
                        45887 TSM:FAIL:RE-INIT
                        45889 TSM:INIT
                        45891 TSM:INIT:TSP OK
                        45895 TSM:FPAR
                        47114 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        49123 !TSM:FPAR:NO REPLY
                        49125 TSM:FPAR
                        50370 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        52379 !TSM:FPAR:NO REPLY
                        52381 TSM:FPAR
                        53600 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        55609 !TSM:FPAR:NO REPLY
                        55611 TSM:FPAR
                        56829 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        58839 !TSM:FPAR:FAIL
                        58841 TSM:FAIL:CNT=3
                        58843 TSM:FAIL:DIS
                        58845 TSF:TDI:TSL
                        68849 TSM:FAIL:RE-INIT
                        68851 TSM:INIT
                        68853 TSM:INIT:TSP OK
                        68857 TSM:FPAR
                        70076 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        72085 !TSM:FPAR:NO REPLY
                        72087 TSM:FPAR
                        73306 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        75315 !TSM:FPAR:NO REPLY
                        75317 TSM:FPAR
                        76535 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        78546 !TSM:FPAR:NO REPLY
                        78548 TSM:FPAR
                        79767 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        81776 !TSM:FPAR:FAIL
                        81778 TSM:FAIL:CNT=4
                        81780 TSM:FAIL:DIS
                        81782 TSF:TDI:TSL
                        91785 TSM:FAIL:RE-INIT
                        91787 TSM:INIT
                        91789 TSM:INIT:TSP OK
                        91793 TSM:FPAR
                        93011 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        95021 !TSM:FPAR:NO REPLY
                        95023 TSM:FPAR
                        96241 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        98250 !TSM:FPAR:NO REPLY
                        98252 TSM:FPAR
                        99471 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        101480 !TSM:FPAR:NO REPLY
                        101482 TSM:FPAR
                        102703 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        104712 !TSM:FPAR:FAIL
                        104714 TSM:FAIL:CNT=5
                        104716 TSM:FAIL:DIS
                        104718 TSF:TDI:TSL
                        114722 TSM:FAIL:RE-INIT
                        114724 TSM:INIT
                        114728 TSM:INIT:TSP OK
                        114731 TSM:FPAR
                        115951 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        117960 !TSM:FPAR:NO REPLY
                        117962 TSM:FPAR
                        119183 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        121192 !TSM:FPAR:NO REPLY
                        121194 TSM:FPAR
                        122443 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        124452 !TSM:FPAR:NO REPLY
                        124454 TSM:FPAR
                        125673 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        127682 !TSM:FPAR:FAIL
                        127684 TSM:FAIL:CNT=6
                        127686 TSM:FAIL:DIS
                        127688 TSF:TDI:TSL
                        137691 TSM:FAIL:RE-INIT
                        137693 TSM:INIT
                        137697 TSM:INIT:TSP OK
                        137699 TSM:FPAR
                        138919 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        140929 !TSM:FPAR:NO REPLY
                        140931 TSM:FPAR
                        142151 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        144160 !TSM:FPAR:NO REPLY
                        144162 TSM:FPAR
                        145381 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        • The Config is the Standard Config which comes with the Package on Github.
                        • The Scripts from above are used to flash the devices.
                        • The Gateway on 2.2.0-beta gives only these lines as in Codebox, then, nothing else happens.
                        • I have cleaned the EEPROM from the devices with the eeprom clean example in mysensors examples
                          @Floca
                          thx for logs. Logs are always useful ;)
                          I tried a few weeks ago rfm69 with atsam, esp32 etc and was working well here.
                          So I'll take a look asap. Need to find a wemos to have same setup.
                          Note:
                          • in your first post, you say that you tried with a nano. But nano is 5v whereas rfm69 is not 5v tolerant. So this can't work.
                          • all rfm69 modules works the same. C, W the same. HW and HCW the same too. These are just different package and mapping, that's all. But sure, if using HW, HCW, needs the high power dfine in MySensors (not your case here)
                          • F
                            F
                            Floca
                            Oh, of course, i wrote Nano, my mistake :(
                            I use Arduino PRO MINI's 3.3v for my Nodes.
                            • mfalkviddM
                              I'll dig out some modules and see if I can reproduce the problem.
                              • mfalkviddM
                                @Floca which pins (GPIOxx or Dx) do these correspond to?
                                MySensors is not able to initialize the radio, probably due to my wiring not being the same as yours.
                                • F
                                  F
                                  Floca
                                  I use this Module...
                                  https://www.openhardware.io/view/386/Minimalist-RFM69CW-WeMos-D1-Mini-Shield
                                  IRQ=DIO0= GPIO4=D2
                                  CS=NSS=GPIO15=D8
                                  • mfalkviddM
                                    I've spent 2 hours and I can't even get gw+node working on 2.0.0.
                                    I'll take a break and try to clear my head so I can figure out what is wrong.
                                    • F
                                      F
                                      Floca
                                      ...on 2.0.0 or on 2.2.0?
                                      • F Floca
                                        @Floca on 2.0.0.
                                        I can't do any troubleshooting unless I know I have a working configuration.
                                        Troubleshooting 2.2.0-beta with a configuration that I know is broken on 2.0.0 it totally useless.
                                        • F
                                          F
                                          Floca
                                          Ok, i know what you mean, that is true.
