  3. nRF5 action!
nRF5 action!
    #237
    Looks as though the nRF52832 sparkfun board has more of a conventional trace antenna:
    though isn't it somewhat odd that it appears to also be directly connected to the ground plane(?), or at least a copper pour. Is that normal? This was one of the images produced by sending their .BRD file to oshpark, so that I could get a look at the antenna.
    NeverDieN JokgiJ 2 Replies Last reply
    • J
      J
      jpb
      http://news.silabs.com/2016-11-08-Bluetooth-SiP-Module-from-Silicon-Labs-Offers-Worlds-Smallest-Footprint-for-IoT-End-Nodes
      Please, take a look at the Soc version, only 3,33,10,5 ... Ok it is a Soc version ...
      but unbelievable ....
      BR
      JP
      Same question for WIFI bgn and bng/ac ... including a low power CortexM4F also ?
      • J jpb
        BR
        JP
        #239
        @jpb said in nRF5 Bluetooth action!:
        BR
        JP
        @jpb
        Nice, but for present purposes the problem is that it doesn't use a Nordic nRF5. The existing mysensors development release doesn't support bluetooth per se, but rather the nRF24-type modes of the nRF5 chip. A chip from a non-Nordic chip manufacturer wouldn't support those modes.
        What will be interesting is if/when mysensors does in some way support bluetooth proper, at which point maybe some kinds (?) of bluetooth interactions with non-nordic bluetooth devices may be possible. Nordic has a bluetooth stack available for use on its nRF5 chips, and so it's ripe for integration.
          For people who like coincell motes, this type of PCB design should be easy to put together:
          https://www.aliexpress.com/item/iBeacon-Module-Bluetooth-4-0-BLE-Support-Near-field-Positioning-Sensor-Wireless-Acquisition/2049663760.html?spm=2114.search0104.3.32.DOxJ8e&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-normal#cfs,searchweb201603_1,ppcSwitch_4&btsid=4fa0fbcf-4595-46be-bd67-15faeeec2be5&algo_expid=f9915ec2-6be8-4ffb-aa7c-5da25d04f4a1-4&algo_pvid=f9915ec2-6be8-4ffb-aa7c-5da25d04f4a1
            #241
            I have some of these 1.27mm 10 pin box connectors on order from Aliexpress (above), but I'm ordering a few more from Digikey so I can get them faster:
            https://www.digikey.com/product-detail/en/3220-10-0100-00/1175-1627-ND/3883661
            It should make wire-ups for chip programming/debugging a lot easier.
            Of course, I'd most prefer to do it all wirelessly.... Has anyone reading this had any success with that, or know of anyone who has without resorting to espruino?
              #242
              If we upload to an nRF52840 the current mysensors demo code examples for an nRF52832, will it work? Anyone tried it?
              d00616D 1 Reply Last reply
                d00616D
                d00616D
                d00616
                The 52840 is currently unsupported:
                https://github.com/sandeepmistry/arduino-nRF5/issues/70
                You can try the source code from: https://github.com/lpercifield/arduino-nRF5/tree/nrf52840
                  #244
                  In that case I think I may order another nRF52832 DK, because I want to establish very soon some kind of reasonable baseline for the kind of range I should expect. The adafruit nRF52832 Feather seems to have awful range, and I'm not sure if that's what I should expect generally, or whether it's just that particular design/device. If it turns out to be true for nRF52832 generally, then I may just shelve things and wait for the nRF52840 to become supported and then try again with that.
                  TerrenceT 1 Reply Last reply
                    TerrenceT
                    TerrenceT
                    Terrence
                      #246
                      I found I could improve reception from the Adafruit nRF52832 Feather by using an PA+LNA boosted nRF24L01. So, although this feels a bit like a step backward, it's at least workable and fairly cheap. Also, it need only go onto a gateway, thereby allowing other motes to potentially use smaller nRF5 modules. :)
                        I have this on order to serve the purpose:
                        https://www.aliexpress.com/item/E01-ML01DP5-Ebyte-2-4GHz-20dBm-2100m-nRF24L01-SPI-Wireless-transceiver-module/32638720689.html
                        though yesterday I tested the idea using one of these:
                        https://www.aliexpress.com/item/Smart-Electronics-1Set-2-4G-1100-Meters-Long-Distance-NRF24L01-PA-LNA-Wireless-Transceiver-Communication-Modules/32707423150.html?spm=2114.search0204.3.105.TGUiz5&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-10111,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=a7086a85-885c-430a-a6db-e8f80171efc1&algo_expid=959e3532-756a-47c5-8de7-461b096da1d9-10&algo_pvid=959e3532-756a-47c5-8de7-461b096da1d9
                          Here's a demo of the high speed feature of nRF52 on a Samsung S8 phone:
                          https://devzone.nordicsemi.com/blogs/1106/bluetooth-5-2mbps-demo-with-nrf52-series-and-samsu/
                          It occurs to me now how much more interesting this will get when phones later have the nRF52840 in them and can do long range bluetooth communication.
                            TerrenceT
                            TerrenceT
                            Terrence
                            @NeverDie >>1100-Meters Long-Distance
                            That would be impressive.
                              https://www.openhardware.io/view/436
                                Maybe @sundberg84 could take inspiration for his easy pcb 😀
                                  Mike_Lemo
                                  how'd you program this blank nrf52832 chip with an SWD programmer like the ST link v2 what programming environment to use and so on?
                                  NeverDieN mtiutiuM 2 Replies Last reply
                                  • M Mike_Lemo
                                    #253
                                    @Mike_Lemo
                                    I had no luck using the ST link v2 from Windows. You might be luckier, or you might try using it from Linux. However, as discussed above, I have had success using the nRF52832 DK and the Arduino IDE from Windows. That's how I intend to program the nRF52832 module using the breakout board I posted above.
                                    • M Mike_Lemo
                                      mtiutiuM
                                      mtiutiuM
                                      mtiutiu
                                      #254
                                      @Mike_Lemo
                                      I used the Arduino IDE with sandeepmistry arduino core installed and I managed to program a nrf51822 module with success. I used a cheap st-link programmer from AliExpress. I don't know about nrf52832 as I don't have one. But I don't see why it wouldn't work. You need 4 wires: Vdd(3.3V), GND, SWD and SWCLK.
                                      From Arduino IDE you need to select st-link as programmer.
                                      It uses openocd under the hood to do the work and it worked both on Windows and Linux. On Linux you might need to set udev rules for allowing regular user to use the st-link.
                                      NeverDieN M 2 Replies Last reply
                                      • mtiutiuM mtiutiu
                                        @Mike_Lemo
                                        Did you power the nrf51822 through the st-link programmer, or did you power it independently?
                                        mtiutiuM 1 Reply Last reply
                                        • mtiutiuM mtiutiu
                                          @Mike_Lemo
                                          Mike_Lemo
                                          @mtiutiu And when you want to program an independent chip with the ST link V2 do you just chose "generic nrf52"?
                                          Also how is it possible to connect between through two NRF52s in slave master config?
                                          Is it possible to take advantage of the NFC functionality with that programming environment?
