  3. nRF5 action!
nRF5 action!
    #244
    In that case I think I may order another nRF52832 DK, because I want to establish very soon some kind of reasonable baseline for the kind of range I should expect. The adafruit nRF52832 Feather seems to have awful range, and I'm not sure if that's what I should expect generally, or whether it's just that particular design/device. If it turns out to be true for nRF52832 generally, then I may just shelve things and wait for the nRF52840 to become supported and then try again with that.
    TerrenceT 1 Reply Last reply
      TerrenceT
      TerrenceT
      Terrence
        #246
        I found I could improve reception from the Adafruit nRF52832 Feather by using an PA+LNA boosted nRF24L01. So, although this feels a bit like a step backward, it's at least workable and fairly cheap. Also, it need only go onto a gateway, thereby allowing other motes to potentially use smaller nRF5 modules. :)
          I have this on order to serve the purpose:
          https://www.aliexpress.com/item/E01-ML01DP5-Ebyte-2-4GHz-20dBm-2100m-nRF24L01-SPI-Wireless-transceiver-module/32638720689.html
          though yesterday I tested the idea using one of these:
          https://www.aliexpress.com/item/Smart-Electronics-1Set-2-4G-1100-Meters-Long-Distance-NRF24L01-PA-LNA-Wireless-Transceiver-Communication-Modules/32707423150.html?spm=2114.search0204.3.105.TGUiz5&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-10111,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=a7086a85-885c-430a-a6db-e8f80171efc1&algo_expid=959e3532-756a-47c5-8de7-461b096da1d9-10&algo_pvid=959e3532-756a-47c5-8de7-461b096da1d9
            Here's a demo of the high speed feature of nRF52 on a Samsung S8 phone:
            https://devzone.nordicsemi.com/blogs/1106/bluetooth-5-2mbps-demo-with-nrf52-series-and-samsu/
            It occurs to me now how much more interesting this will get when phones later have the nRF52840 in them and can do long range bluetooth communication.
              TerrenceT
              TerrenceT
              Terrence
              @NeverDie >>1100-Meters Long-Distance
              That would be impressive.
                https://www.openhardware.io/view/436
                  Maybe @sundberg84 could take inspiration for his easy pcb 😀
                    Mike_Lemo
                    how'd you program this blank nrf52832 chip with an SWD programmer like the ST link v2 what programming environment to use and so on?
                    NeverDieN mtiutiuM 2 Replies Last reply
                    • M Mike_Lemo
                      #253
                      @Mike_Lemo
                      I had no luck using the ST link v2 from Windows. You might be luckier, or you might try using it from Linux. However, as discussed above, I have had success using the nRF52832 DK and the Arduino IDE from Windows. That's how I intend to program the nRF52832 module using the breakout board I posted above.
                      • M Mike_Lemo
                        mtiutiuM
                        mtiutiuM
                        mtiutiu
                        #254
                        @Mike_Lemo
                        I used the Arduino IDE with sandeepmistry arduino core installed and I managed to program a nrf51822 module with success. I used a cheap st-link programmer from AliExpress. I don't know about nrf52832 as I don't have one. But I don't see why it wouldn't work. You need 4 wires: Vdd(3.3V), GND, SWD and SWCLK.
                        From Arduino IDE you need to select st-link as programmer.
                        It uses openocd under the hood to do the work and it worked both on Windows and Linux. On Linux you might need to set udev rules for allowing regular user to use the st-link.
                        NeverDieN M 2 Replies Last reply
                        • mtiutiuM mtiutiu
                          @Mike_Lemo
                          Did you power the nrf51822 through the st-link programmer, or did you power it independently?
                          mtiutiuM 1 Reply Last reply
                          • mtiutiuM mtiutiu
                            @Mike_Lemo
                            Mike_Lemo
                            @mtiutiu And when you want to program an independent chip with the ST link V2 do you just chose "generic nrf52"?
                            Also how is it possible to connect between through two NRF52s in slave master config?
                            Is it possible to take advantage of the NFC functionality with that programming environment?
                              Good news! I received my second nRF52832 DK today, so now I can have a DK on both ends of a link. Bottom line: I ran some quick tests, and it has much better range than the Adafruit nRF52832 Feather.
                              Whew! What a relief. The Adafruit had very disappointing range. In contrast, and as expected, the two DK's have better range than regular nRF24L01+ radios.
                                Mike_Lemo
                                @NeverDie How did you manage to send and receive data between these two units? may you share the code with us?
                                • M Mike_Lemo
                                  #259
                                  @Mike_Lemo
                                  I'm simply using the GatewaySerial and the LightSensor sketches from the mysensors developers release. Just make the following change in each sketch:
                                  //#define MY_RADIO_NRF24
                                  #define MY_RADIO_NRF5_ESB
                                    mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    Powered from st-link programmer.
                                    • M Mike_Lemo
                                      mtiutiuM
                                      mtiutiuM
                                      mtiutiu
                                      #261
                                      @Mike_Lemo
                                      I used generic and no soft device as Mysensors doesn't use soft devices. I don't know about master-slave, didn't used such a configuration.
                                      You need to create another variant for other pin definitions as this is the way arduino framework works as far as I know.
                                      Never used NFC so I can't give you hints on that, sorry.
                                        Looks as though these guys came up with a fairly easy way to develop using actual bluetooth low energy: http://mklec.com/project-kits/kd-circuits/bluetooth-low-energy-board-anaren-A20737-module
                                        Unfortunately, I don't believe it runs on the nRF5 though.
                                          Looks as though the nRF52832 sparkfun board has more of a conventional trace antenna:
                                          though isn't it somewhat odd that it appears to also be directly connected to the ground plane(?), or at least a copper pour. Is that normal? This was one of the images produced by sending their .BRD file to oshpark, so that I could get a look at the antenna.
                                          More good news! I was able to program a Sparkfun nrf52832 board using the DK, and its range is better than the Adafruit nRF52832 Feather and also better than an nRF24L01+.
                                          So, my provisional conclusion is to avoid chip antennas, such as Adafruit is using, if better range is desired.
                                          Also, this now gives me a "known good" platform, namely the Sparkfun nRF52832 board, to order PCB's for and try to see if I can successfully solder on any of the bonus nRF52832 chips I received with my two DK's.
