  3. nRF5 action!
nRF5 action!
  • TerrenceT Terrence
    @NeverDie Good work, I am glad you have successfully programmed a chip from the DK.
    Do you think we should open a new thread devoted to all of this Bluetooth action?
    #233
    @Terrence said in Bluetooth action!:
    Meh, I'll leave that up to the moderator. Meanwhile, I changed this thread's title to match your catch phrase.
    TerrenceT 1 Reply Last reply
    • MiKaM MiKa
      next nice board with NRF 52832
      http://www.espruino.com/Puck.js
      #234
      @MiKa said in nRF5 Bluetooth action!:
      Thanks for your post! Looks as though they have some very nice tutorials to go with it. That really sets it apart and makes it much more desirable.
      Perhaps most significant of all: it claims it can be "programmed and debugged wirelessly"! Well, that makes sense, given the nature of its language.
        Success! Got Blink compiled and uploaded to the Adafruit nRF52832 Feather using the nRF52832 DK.
        BTW, the adafruit LED works the opposite of the DK LED: on the Adafruit (as with most Arduino's), LOW means OFF, and HIGH means ON. For some reason the DK is the opposite of that.
        wrote on last edited by gohan
        #235
        Maybe it is like the esp32 that the led is connected to vcc and not to gnd
          TerrenceT
          TerrenceT
          Terrence
          Perfect.
            #237
            Looks as though the nRF52832 sparkfun board has more of a conventional trace antenna:
            though isn't it somewhat odd that it appears to also be directly connected to the ground plane(?), or at least a copper pour. Is that normal? This was one of the images produced by sending their .BRD file to oshpark, so that I could get a look at the antenna.
            NeverDieN JokgiJ 2 Replies Last reply
            • J
              J
              jpb
              http://news.silabs.com/2016-11-08-Bluetooth-SiP-Module-from-Silicon-Labs-Offers-Worlds-Smallest-Footprint-for-IoT-End-Nodes
              Please, take a look at the Soc version, only 3,33,10,5 ... Ok it is a Soc version ...
              but unbelievable ....
              BR
              JP
              Same question for WIFI bgn and bng/ac ... including a low power CortexM4F also ?
              • J jpb
                BR
                JP
                #239
                @jpb said in nRF5 Bluetooth action!:
                BR
                JP
                @jpb
                Nice, but for present purposes the problem is that it doesn't use a Nordic nRF5. The existing mysensors development release doesn't support bluetooth per se, but rather the nRF24-type modes of the nRF5 chip. A chip from a non-Nordic chip manufacturer wouldn't support those modes.
                What will be interesting is if/when mysensors does in some way support bluetooth proper, at which point maybe some kinds (?) of bluetooth interactions with non-nordic bluetooth devices may be possible. Nordic has a bluetooth stack available for use on its nRF5 chips, and so it's ripe for integration.
                  For people who like coincell motes, this type of PCB design should be easy to put together:
                  https://www.aliexpress.com/item/iBeacon-Module-Bluetooth-4-0-BLE-Support-Near-field-Positioning-Sensor-Wireless-Acquisition/2049663760.html?spm=2114.search0104.3.32.DOxJ8e&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-normal#cfs,searchweb201603_1,ppcSwitch_4&btsid=4fa0fbcf-4595-46be-bd67-15faeeec2be5&algo_expid=f9915ec2-6be8-4ffb-aa7c-5da25d04f4a1-4&algo_pvid=f9915ec2-6be8-4ffb-aa7c-5da25d04f4a1
                    #241
                    I have some of these 1.27mm 10 pin box connectors on order from Aliexpress (above), but I'm ordering a few more from Digikey so I can get them faster:
                    https://www.digikey.com/product-detail/en/3220-10-0100-00/1175-1627-ND/3883661
                    It should make wire-ups for chip programming/debugging a lot easier.
                    Of course, I'd most prefer to do it all wirelessly.... Has anyone reading this had any success with that, or know of anyone who has without resorting to espruino?
                      #242
                      If we upload to an nRF52840 the current mysensors demo code examples for an nRF52832, will it work? Anyone tried it?
                      d00616D 1 Reply Last reply
                        d00616D
                        d00616D
                        d00616
                        The 52840 is currently unsupported:
                        https://github.com/sandeepmistry/arduino-nRF5/issues/70
                        You can try the source code from: https://github.com/lpercifield/arduino-nRF5/tree/nrf52840
                          #244
                          In that case I think I may order another nRF52832 DK, because I want to establish very soon some kind of reasonable baseline for the kind of range I should expect. The adafruit nRF52832 Feather seems to have awful range, and I'm not sure if that's what I should expect generally, or whether it's just that particular design/device. If it turns out to be true for nRF52832 generally, then I may just shelve things and wait for the nRF52840 to become supported and then try again with that.
                            TerrenceT
                            TerrenceT
                            Terrence
                              #246
                              I found I could improve reception from the Adafruit nRF52832 Feather by using an PA+LNA boosted nRF24L01. So, although this feels a bit like a step backward, it's at least workable and fairly cheap. Also, it need only go onto a gateway, thereby allowing other motes to potentially use smaller nRF5 modules. :)
                                I have this on order to serve the purpose:
                                https://www.aliexpress.com/item/E01-ML01DP5-Ebyte-2-4GHz-20dBm-2100m-nRF24L01-SPI-Wireless-transceiver-module/32638720689.html
                                though yesterday I tested the idea using one of these:
                                https://www.aliexpress.com/item/Smart-Electronics-1Set-2-4G-1100-Meters-Long-Distance-NRF24L01-PA-LNA-Wireless-Transceiver-Communication-Modules/32707423150.html?spm=2114.search0204.3.105.TGUiz5&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10084_10083_10080_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_5360020_10189_10052_10053_10142_10107_10050_10051-10111,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=a7086a85-885c-430a-a6db-e8f80171efc1&algo_expid=959e3532-756a-47c5-8de7-461b096da1d9-10&algo_pvid=959e3532-756a-47c5-8de7-461b096da1d9
                                  Here's a demo of the high speed feature of nRF52 on a Samsung S8 phone:
                                  https://devzone.nordicsemi.com/blogs/1106/bluetooth-5-2mbps-demo-with-nrf52-series-and-samsu/
                                  It occurs to me now how much more interesting this will get when phones later have the nRF52840 in them and can do long range bluetooth communication.
                                    TerrenceT
                                    TerrenceT
                                    Terrence
                                    @NeverDie >>1100-Meters Long-Distance
                                    That would be impressive.
                                      https://www.openhardware.io/view/436
                                        Maybe @sundberg84 could take inspiration for his easy pcb 😀
                                          Mike_Lemo
                                          how'd you program this blank nrf52832 chip with an SWD programmer like the ST link v2 what programming environment to use and so on?
                                          NeverDieN mtiutiuM 2 Replies Last reply
