  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
  • alexsh1A alexsh1
    I am using latest beta (2.2.0b). Does anyone know what this means in the log:
    !SGN:NCE:GEN
    I think this is related to signing
    AnticimexA
    AnticimexA
    Anticimex
    @alexsh1 to be more specific; the backend failed to generate a nonce. If you use the soft backed, it did not initialize properly (and you should have a log entry for that failure as well).
    If using atsha204a, it either failed init like described above, or it failed to communicate properly (which should also be visible in other failures in the log)
    alexsh1A 1 Reply Last reply
    • AnticimexA Anticimex
      alexsh1A
      alexsh1A
      alexsh1
      #403
      @Anticimex Spot on -> there was a mistake :
      #define MY_SIGNING_ATSHA204_PIN 3
      and should have been
      I was wondering why nonce was all zeros...
      AnticimexA 1 Reply Last reply
      • alexsh1A alexsh1
        AnticimexA
        AnticimexA
        Anticimex
        @alexsh1 excellent. Signing won't work well without proper communication with the chip :)
        I considered just hanging if that happened but decided it was a bit too harsh and might disguise the problem in case UART debug isn't enabled.
        • magpernM
          magpernM
          magpern
          wrote on last edited by magpern
          #405
          I cannot get my china USB to Serial device to work with the arduino boards, so I cannot program the board to run the personalization. As a work around a use a Arduino Uno board as the "USB to Serial" and now I can upload the sketch and the personalizer writes to serial output fine at 115200 baud.
          But, when it wants me to press SPACE, it responds with "Unexpected answer. Skipping lock."
          I tried an other sketch that does Serial.read() and echos back the result. It does not work at 115200 but works at 9600 baud. At 9600 I get char 32 back as SPACE, but 160 or 130 or 254 at 115200. Maybe the Uno board cannot handle 115200?
          So, question: Can the personalizer sketch be changed to use 9600 (or something slower than 115200)? I tried to change the Serial.begin(115200) to 9600, but it is still 115200.
          (of course, I can alter the code to bypass the press SPACE to press any key, but I want to get to the bottom with the problem)
          AnticimexA mfalkviddM 3 Replies Last reply
          • magpernM magpern
            AnticimexA
            AnticimexA
            Anticimex
            @Magnus-Pernemark
            Question 1: so you run stable release or beta?
            Answer 1: yes you can change baud rate but it is handled differently between stable and beta.
            • magpernM magpern
              AnticimexA
              AnticimexA
              Anticimex
              @Magnus-Pernemark there is a configuration switch to disable UART verification you can use
              • magpernM magpern
                @Magnus-Pernemark which version are you using?
                The development version from github supports
                #define MY_BAUD_RATE 9600
                at the start of the sketch.
                The 2.1.1 version has
                in the sketch. Just change that.
                magpernM 1 Reply Last reply
                  magpernM
                  magpernM
                  magpern
                  @Anticimex I am so not familiar with the arduino/mysensors development yet, but I guess I use 2.1.1, since i used "Sketch / Include Library / Manage Library" and it had 2.1.1
                  @mfalkvidd Since I have the line Serial.begin(115200) I assume it is 2.1.1, but changing it to 9600 and uploading the sketch does nothing. I still need to open serial window with 115200, else I just see garbage as output from the mini pro.
                  I will try the development version and see if that helps.
                  • magpernM magpern
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Magnus-Pernemark or you can just disable the confirmation altogether. Just define SKIP_UART_CONFIRMATION
                      magpernM
                      magpernM
                      magpern
                      @Anticimex hehe, true... but I am a developer by trade, and bypassing something just because it would be easier, feels so wrong. I might end up doing so, but I'll give it some more tries first. Problems are a very good way to learn, and in arduino development I am a total noobie, more used to C# and the .NET world.
                      • magpernM magpern
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Magnus-Pernemark as a developer by trade, you should be bold enough to use the beta releases and live on the bleeding edge then ;)
                          magpernM
                          magpernM
                          magpern
                          @Anticimex I'll start living on the edge immediately. It's the way to go!
                          I switched to develop and could change the band rate, however develop version skips UART confirmation by default so I never had the problem there. Never needed to send any keys. Got the chip configured atleast.
                          I kind of started in the wrong end - designed my own pcbs, then start to know the development environment.
                          But I'll figure it out... just takes time.. thanks for the help!!
                          • magpernM magpern
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Magnus-Pernemark that's correct. Or, it is correct if you follow the "guided mode". If you wanna be hardcore, you drop the guided defines and set the individual flags according to your specific needs, and then you get to enable (or more precisely, not disable) UART confirmation (in case you want to test it).
                            • gusG
                              gusG
                              gus
                              Hi!
                              Starting to learn signing. I use a parallell system (with another channel) where I could test signing before I went on my live system. For now I just use soft signing, it works perfect!
                              Now, I just want to test a node (motionsensor) that include:
                              The gateway has no signing feature (it has not gone thru personalition process) In my head, the node shall reject to connect to this gateway, but after the signing fails, it start to send data to the gateway. Did I miss something here?
                              Debug text on node:
                              0 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0-beta
                              49 SGN:PER:OK
                              83 SGN:INI:BND OK
                              83 TSM:INIT
                              86 TSF:WUR:MS=0
                              94 TSM:INIT:TSP OK
                              96 TSM:INIT:STATID=101
                              98 TSF:SID:OK,ID=101
                              100 TSM:FPAR
                              102 SGN:SGN:NREQ=255
                              139 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              684 TSF:MSG:READ,0-0-101,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              690 SGN:SKP:MSG CMD=3,TYPE=8
                              692 TSF:MSG:FPAR OK,ID=0,D=1
                              2148 TSM:FPAR:OK
                              2148 TSM:ID
                              2150 TSM:ID:OK
                              2152 TSM:UPL
                              2154 SGN:SGN:NREQ=0
                              2158 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              2168 TSF:MSG:READ,0-0-101,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              2174 SGN:SKP:MSG CMD=3,TYPE=25
                              2177 TSF:MSG:PONG RECV,HP=1
                              2181 TSM:UPL:OK
                              2183 TSM:READY:ID=101,PAR=0,DIS=1
                              2187 SGN:PRE:SGN REQ
                              2189 SGN:PRE:WHI NREQ
                              2191 SGN:SGN:NREQ=0
                              2195 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                              2203 SGN:PRE:XMT,TO=0
                              2205 SGN:PRE:WAIT GW
                              2207 TSF:MSG:READ,0-0-101,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              2213 SGN:SKP:MSG CMD=3,TYPE=15
                              2217 SGN:SGN:NREQ=0
                              2222 TSF:MSG:SEND,101-101-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                              2232 SGN:SGN:NREQ=0
                              2234 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                              2248 TSF:MSG:READ,0-0-101,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                              2254 !SGN:VER:NSG
                              2256 !TSF:MSG:SIGN VERIFY FAIL
                              2258 SGN:SGN:NREQ=0
                              2263 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                              2273 SGN:SGN:NREQ=0
                              2277 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                              2285 SGN:SGN:NREQ=0
                              2289 TSF:MSG:SEND,101-101-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                              2295 MCO:REG:REQ
                              2297 SGN:SGN:NREQ=0
                              2301 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                              2310 TSF:MSG:READ,0-0-101,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                              2316 !SGN:VER:NSG
                              2318 !TSF:MSG:SIGN VERIFY FAIL
                              2322 MCO:BGN:STP
                              2324 MCO:BGN:INIT OK,TSP=1
                              2326 SGN:SGN:NREQ=0
                              2330 TSF:MSG:SEND,101-101-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                              2338 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
                              2344 TSF:TDI:TSL
                              2347 MCO:SLP:WUP=1
                              2349 TSF:TRI:TSB
                              2351 SGN:SGN:NREQ=0
                              2355 TSF:MSG:SEND,101-101-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                              2363 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
                              2367 TSF:TDI:TSL
                              • gusG gus
                                Hi!
                                Debug text on node:
                                49 SGN:PER:OK
                                83 SGN:INI:BND OK
                                83 TSM:INIT
                                86 TSF:WUR:MS=0
                                94 TSM:INIT:TSP OK
                                100 TSM:FPAR
                                2148 TSM:FPAR:OK
                                2148 TSM:ID
                                2150 TSM:ID:OK
                                2152 TSM:UPL
                                2154 SGN:SGN:NREQ=0
                                2181 TSM:UPL:OK
                                2191 SGN:SGN:NREQ=0
                                2217 SGN:SGN:NREQ=0
                                2232 SGN:SGN:NREQ=0
                                2254 !SGN:VER:NSG
                                2258 SGN:SGN:NREQ=0
                                2273 SGN:SGN:NREQ=0
                                2285 SGN:SGN:NREQ=0
                                2295 MCO:REG:REQ
                                2297 SGN:SGN:NREQ=0
                                2316 !SGN:VER:NSG
                                2322 MCO:BGN:STP
                                2326 SGN:SGN:NREQ=0
                                2344 TSF:TDI:TSL
                                2347 MCO:SLP:WUP=1
                                2349 TSF:TRI:TSB
                                2351 SGN:SGN:NREQ=0
                                2367 TSF:TDI:TSL
                                AnticimexA
                                AnticimexA
                                Anticimex
                                #416
                                @gus what is it that you think is not working? Just because your node require signatures does not prevent the node from sending data to your gateway which does not require signatures.
                                And as you can see in the log you get errors about missing signatures (and hence failed verifications) so it looks as expected to me.
                                You could try to paste your log into the log parser to get a easier to read output.
                                gusG 1 Reply Last reply
                                  gusG
                                  gusG
                                  gus
                                  @Anticimex Ok, just thought when signing failed, the node was halted :confused:
                                  So that control mechanism need to be implemented in my sketch then?
                                  Great, I will use the log parser!
                                  • gusG gus
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @gus no, when signing verification fail, the message is just discarded
                                      gusG
                                      gusG
                                      gus
                                      @Anticimex Ahh, now I get it!! Thanks for helping me out here!
                                      • gusG gus
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @gus always :) nice to hear that you have a fully functional signing rig. Happy signing!
                                        • ahmedadelhosniA
                                          ahmedadelhosniA
                                          ahmedadelhosni
                                          Hello @Anticimex
                                          Sometimes it happens that the Serial printing is not correct and it is okay when the baud rate is lower to 57600. I guess the default is 115200 when this error happens.
                                          ⸮ M⸮Se⸮so⸮s security p⸮r⸮o⸮alizer ⸮
                                          ⸮ C⸮n⸮igur⸮t⸮on set⸮i⸮g⸮ ⸮
                                          | * G⸮i⸮e⸮ ⸮e⸮s⸮nali⸮ation/⸮t⸮ra⸮e of key⸮ ⸮n AT⸮H⸮204A |
                                          | * ⸮T⸮HA204A based ⸮e⸮s⸮n⸮l⸮z⸮t⸮o⸮ ⸮
                                          ⸮ * Will l⸮ck ATSH⸮204⸮ c⸮n⸮i⸮u⸮atio⸮ |
                                          ⸮ * W⸮ll no⸮ req⸮i⸮e any UA⸮T co⸮fi⸮m⸮ti⸮ns ⸮
                                          | * ⸮i⸮l ⸮to⸮e ⸮MA⸮ key to A⸮SH⸮204A |
                                          | * Will store ⸮ES ke⸮ to ⸮E⸮R⸮M ⸮
                                          AnticimexA magpernM 2 Replies Last reply
