  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
  • magpernM
    magpernM
    magpern
    wrote on last edited by magpern
    #405
    I cannot get my china USB to Serial device to work with the arduino boards, so I cannot program the board to run the personalization. As a work around a use a Arduino Uno board as the "USB to Serial" and now I can upload the sketch and the personalizer writes to serial output fine at 115200 baud.
    But, when it wants me to press SPACE, it responds with "Unexpected answer. Skipping lock."
    I tried an other sketch that does Serial.read() and echos back the result. It does not work at 115200 but works at 9600 baud. At 9600 I get char 32 back as SPACE, but 160 or 130 or 254 at 115200. Maybe the Uno board cannot handle 115200?
    So, question: Can the personalizer sketch be changed to use 9600 (or something slower than 115200)? I tried to change the Serial.begin(115200) to 9600, but it is still 115200.
    (of course, I can alter the code to bypass the press SPACE to press any key, but I want to get to the bottom with the problem)
    AnticimexA mfalkviddM 3 Replies Last reply
    • magpernM magpern
      AnticimexA
      AnticimexA
      Anticimex
      @Magnus-Pernemark
      Question 1: so you run stable release or beta?
      Answer 1: yes you can change baud rate but it is handled differently between stable and beta.
      • magpernM magpern
        AnticimexA
        AnticimexA
        Anticimex
        @Magnus-Pernemark there is a configuration switch to disable UART verification you can use
        • magpernM magpern
          @Magnus-Pernemark which version are you using?
          The development version from github supports
          #define MY_BAUD_RATE 9600
          at the start of the sketch.
          The 2.1.1 version has
          in the sketch. Just change that.
          magpernM 1 Reply Last reply
            magpernM
            magpernM
            magpern
            @Anticimex I am so not familiar with the arduino/mysensors development yet, but I guess I use 2.1.1, since i used "Sketch / Include Library / Manage Library" and it had 2.1.1
            @mfalkvidd Since I have the line Serial.begin(115200) I assume it is 2.1.1, but changing it to 9600 and uploading the sketch does nothing. I still need to open serial window with 115200, else I just see garbage as output from the mini pro.
            I will try the development version and see if that helps.
            AnticimexA 1 Reply Last reply
            • magpernM magpern
              AnticimexA
              AnticimexA
              Anticimex
              @Magnus-Pernemark or you can just disable the confirmation altogether. Just define SKIP_UART_CONFIRMATION
              • AnticimexA Anticimex
                magpernM
                magpernM
                magpern
                @Anticimex hehe, true... but I am a developer by trade, and bypassing something just because it would be easier, feels so wrong. I might end up doing so, but I'll give it some more tries first. Problems are a very good way to learn, and in arduino development I am a total noobie, more used to C# and the .NET world.
                • magpernM magpern
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @Magnus-Pernemark as a developer by trade, you should be bold enough to use the beta releases and live on the bleeding edge then ;)
                    magpernM
                    magpernM
                    magpern
                    @Anticimex I'll start living on the edge immediately. It's the way to go!
                    I switched to develop and could change the band rate, however develop version skips UART confirmation by default so I never had the problem there. Never needed to send any keys. Got the chip configured atleast.
                    I kind of started in the wrong end - designed my own pcbs, then start to know the development environment.
                    But I'll figure it out... just takes time.. thanks for the help!!
                    • magpernM magpern
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @Magnus-Pernemark that's correct. Or, it is correct if you follow the "guided mode". If you wanna be hardcore, you drop the guided defines and set the individual flags according to your specific needs, and then you get to enable (or more precisely, not disable) UART confirmation (in case you want to test it).
                      • gusG
                        gusG
                        gus
                        Hi!
                        Starting to learn signing. I use a parallell system (with another channel) where I could test signing before I went on my live system. For now I just use soft signing, it works perfect!
                        Now, I just want to test a node (motionsensor) that include:
                        The gateway has no signing feature (it has not gone thru personalition process) In my head, the node shall reject to connect to this gateway, but after the signing fails, it start to send data to the gateway. Did I miss something here?
                        Debug text on node:
                        0 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0-beta
                        49 SGN:PER:OK
                        83 SGN:INI:BND OK
                        83 TSM:INIT
                        86 TSF:WUR:MS=0
                        94 TSM:INIT:TSP OK
                        96 TSM:INIT:STATID=101
                        98 TSF:SID:OK,ID=101
                        100 TSM:FPAR
                        102 SGN:SGN:NREQ=255
                        139 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        684 TSF:MSG:READ,0-0-101,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        690 SGN:SKP:MSG CMD=3,TYPE=8
                        692 TSF:MSG:FPAR OK,ID=0,D=1
                        2148 TSM:FPAR:OK
                        2148 TSM:ID
                        2150 TSM:ID:OK
                        2152 TSM:UPL
                        2154 SGN:SGN:NREQ=0
                        2158 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2168 TSF:MSG:READ,0-0-101,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2174 SGN:SKP:MSG CMD=3,TYPE=25
                        2177 TSF:MSG:PONG RECV,HP=1
                        2181 TSM:UPL:OK
                        2183 TSM:READY:ID=101,PAR=0,DIS=1
                        2187 SGN:PRE:SGN REQ
                        2189 SGN:PRE:WHI NREQ
                        2191 SGN:SGN:NREQ=0
                        2195 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                        2203 SGN:PRE:XMT,TO=0
                        2205 SGN:PRE:WAIT GW
                        2207 TSF:MSG:READ,0-0-101,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2213 SGN:SKP:MSG CMD=3,TYPE=15
                        2217 SGN:SGN:NREQ=0
                        2222 TSF:MSG:SEND,101-101-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                        2232 SGN:SGN:NREQ=0
                        2234 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        2248 TSF:MSG:READ,0-0-101,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        2254 !SGN:VER:NSG
                        2256 !TSF:MSG:SIGN VERIFY FAIL
                        2258 SGN:SGN:NREQ=0
                        2263 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                        2273 SGN:SGN:NREQ=0
                        2277 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                        2285 SGN:SGN:NREQ=0
                        2289 TSF:MSG:SEND,101-101-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                        2295 MCO:REG:REQ
                        2297 SGN:SGN:NREQ=0
                        2301 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        2310 TSF:MSG:READ,0-0-101,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        2316 !SGN:VER:NSG
                        2318 !TSF:MSG:SIGN VERIFY FAIL
                        2322 MCO:BGN:STP
                        2324 MCO:BGN:INIT OK,TSP=1
                        2326 SGN:SGN:NREQ=0
                        2330 TSF:MSG:SEND,101-101-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                        2338 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
                        2344 TSF:TDI:TSL
                        2347 MCO:SLP:WUP=1
                        2349 TSF:TRI:TSB
                        2351 SGN:SGN:NREQ=0
                        2355 TSF:MSG:SEND,101-101-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                        2363 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
                        2367 TSF:TDI:TSL
                        • gusG gus
                          Hi!
                          Debug text on node:
                          49 SGN:PER:OK
                          83 SGN:INI:BND OK
                          83 TSM:INIT
                          86 TSF:WUR:MS=0
                          94 TSM:INIT:TSP OK
                          100 TSM:FPAR
                          2148 TSM:FPAR:OK
                          2148 TSM:ID
                          2150 TSM:ID:OK
                          2152 TSM:UPL
                          2154 SGN:SGN:NREQ=0
                          2181 TSM:UPL:OK
                          2191 SGN:SGN:NREQ=0
                          2217 SGN:SGN:NREQ=0
                          2232 SGN:SGN:NREQ=0
                          2254 !SGN:VER:NSG
                          2258 SGN:SGN:NREQ=0
                          2273 SGN:SGN:NREQ=0
                          2285 SGN:SGN:NREQ=0
                          2295 MCO:REG:REQ
                          2297 SGN:SGN:NREQ=0
                          2316 !SGN:VER:NSG
                          2322 MCO:BGN:STP
                          2326 SGN:SGN:NREQ=0
                          2344 TSF:TDI:TSL
                          2347 MCO:SLP:WUP=1
                          2349 TSF:TRI:TSB
                          2351 SGN:SGN:NREQ=0
                          2367 TSF:TDI:TSL
                          AnticimexA
                          AnticimexA
                          Anticimex
                          #416
                          @gus what is it that you think is not working? Just because your node require signatures does not prevent the node from sending data to your gateway which does not require signatures.
                          And as you can see in the log you get errors about missing signatures (and hence failed verifications) so it looks as expected to me.
                          You could try to paste your log into the log parser to get a easier to read output.
                          gusG 1 Reply Last reply
                            gusG
                            gusG
                            gus
                            @Anticimex Ok, just thought when signing failed, the node was halted :confused:
                            So that control mechanism need to be implemented in my sketch then?
                            Great, I will use the log parser!
                            • gusG gus
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @gus no, when signing verification fail, the message is just discarded
                                gusG
                                gusG
                                gus
                                @Anticimex Ahh, now I get it!! Thanks for helping me out here!
                                • gusG gus
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @gus always :) nice to hear that you have a fully functional signing rig. Happy signing!
                                  • ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    Hello @Anticimex
                                    Sometimes it happens that the Serial printing is not correct and it is okay when the baud rate is lower to 57600. I guess the default is 115200 when this error happens.
                                    ⸮ M⸮Se⸮so⸮s security p⸮r⸮o⸮alizer ⸮
                                    ⸮ C⸮n⸮igur⸮t⸮on set⸮i⸮g⸮ ⸮
                                    | * G⸮i⸮e⸮ ⸮e⸮s⸮nali⸮ation/⸮t⸮ra⸮e of key⸮ ⸮n AT⸮H⸮204A |
                                    | * ⸮T⸮HA204A based ⸮e⸮s⸮n⸮l⸮z⸮t⸮o⸮ ⸮
                                    ⸮ * Will l⸮ck ATSH⸮204⸮ c⸮n⸮i⸮u⸮atio⸮ |
                                    ⸮ * W⸮ll no⸮ req⸮i⸮e any UA⸮T co⸮fi⸮m⸮ti⸮ns ⸮
                                    | * ⸮i⸮l ⸮to⸮e ⸮MA⸮ key to A⸮SH⸮204A |
                                    | * Will store ⸮ES ke⸮ to ⸮E⸮R⸮M ⸮
                                    AnticimexA magpernM 2 Replies Last reply
                                      Hello @Anticimex
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @ahmedadelhosni yes, this can happen on some targets. It depend on the quality and precision of the oscillator. If output looks garbled, reducing the baud rate is a good place to start.
                                        ahmedadelhosniA
                                        ahmedadelhosniA
                                        ahmedadelhosni
                                        @Anticimex so this has nothing to do with the quality of my overall node ? I mean as a reference that this node will be stable or not during operation.
                                        I ordered my atmega smd from mouser and all passive componets too. Only pcbs are from dirtypcbs. I thought getting high quality from mouser would be better.
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @ahmedadelhosni
                                          That is hard to say. There are many reports of atmega not being really good at handling 115200 at certain oscillator frequencies. So no, I don't think it directly hints at something being wrong with your hardware. But I cannot be sure of course :)
