  3. nRF5 action!
nRF5 action!
    Here's a photo with the lid pried off:
    Maybe we can reconstruct what's going on just from looking at the components and the trace lines? At least for now, I'm not so concerned with the RF part.
    JokgiJ 1 Reply Last reply
      Here's a photo taken from the opposite angle:
      Any other photos anyone wants to see?
        #313
        Here's the back:
        So, is it 4 layer as they claim, or only 2? Some of those vias seem rather pointless if it were only 2 layer.
          #314
          So, to Scalz's earlier point, it looks like indeed there is no capacitor already on DEC1. Regarding DEC2, it appears that there are pads and solder paste for a capacitor, but the capacitor appears to be missing! Manufacturing error?
            #315
            cool. well you just have to check continuity.
            Yes this a 4layers. better for compact RF imho, else worse performance, EMI etc.. I think it's also easier to get FCC with 4layers design (not sure if this module is FCC though)
            My bad, i've just reread what i wrote. With nrf52 ic, I've rechecked, I'm using:
            • DEC1: 100nf
            • DEC2: nothing
            • DEC3: 100pf
            • DEC4: 1uF (and you add inductors with DCC, for DC/DC mode but it can decrease 1dB if i remember well)
            • scalzS scalz
              • DEC1: 100nf
              • DEC2: nothing
              • DEC3: 100pf
              #316
              @scalz
              Both DEC3 and DEC4 appear to have capacitors on them. So, maybe it was the missing capacitor on DEC2 that's the reason for the module not seeming to work. I suppose I could crack another one open to see if the missing cap was a fluke or instead likely missing on most/all of them.
              Obviously, short of removing and testing each smd cap, I can't be sure as to what values eByte is using. I hope it doesn't come to that.... On the other hand, I could possibly remove and test the 3 on scalz's list that are of interest.
                #317
                OK, I just pried off the lid on a different module and.... the same DEC2 cap is missing. However, according to scalz's new list that shouldn't matter.
                I'll need to check continuity to see if the DEC1 cap is really not there or rather simply appearing elsewhere due to the routing.
                  #318
                  It turns out DEC1 is connected to a capacitor: it's the one just south of the top left capacitor in the first photo.
                  So, unless the cap values are just wrong, it seems that we don't need to add any more.
                    What should I check next?
                      I saw this in the MDBT42Q module datasheet, and perhaps it explains the relatively poor performance of the nRF52832 Adafruit Feather which uses the MDBT42Q.:
                      I believe the Adafruit may have a much smaller ground plane than what is being recommended here by Raytac.
                      Mike_Lemo
                      @NeverDie I just made the antenna on my PCB stick out so there is no fiber glass under the antenna even.
                      Also what is a good library for using NFC and the bluetooth peripheral of that MCU?
                      I came across that library:
                      https://github.com/sandeepmistry/arduino-BLEPeripheral
                      but the page doesn't seem to support the BLE capability of the NRF52832
                      and no luck for the NFC
                      • d00616D d00616
                        Also If I want to change the UART pins to other pins would it work without errors or If I want to use 2 or more UARTS? same with I2C
                        The Chip has a lot of periphery on it. You can connect most components to pins. There is only one hardware UART, which can be connected. Please look at the Infocenter The arduino-nrf5 port is limited to things are implemented with arduino-samd by the author. This is the reason I have implemented an extension for hwPinMode() in MySensors.
                        Another fine thing is the implementation of Shortcuts and the PPI. You can do a lot without using the CPU.
                        Also what are the debugging options available sins the RS232 is not connected to the MCU like in an arduino how would I set stop points or peek at variables values to see if the code runs as expected?
                        Debugging depends on your programmer and flashing tool. I think you can start by search for "openocd gdb". OpenOCD is the flashing tool in arduino-nrf5 for all supported programmers.
                        Mike_Lemo
                        What is that MySensors thing you were talking about?
                        • M Mike_Lemo
                          #322
                          Yeah, that's what I opted for on Version 2 of my breakout board for the Ebyte nRF52832 module. Seems like the cleanest solution.
                          The MDBT42Q is a lot smaller than the Ebyte module, so although I was bashing it for its performance on the Adafruit (which in their case may turn out to be ground plane related), that might be an acceptable trade-off for the smaller size.
                          You have lots of good questions. Keep asking! I'm hoping to learn from the answers too.
                            #323
                            OK, here's my plan:
                            1. It's possible the connections on my first attempt were a bit dodgy. I'll try again, but this time soldering a fresh new module to a prototype PCB so that they won't be mechanically stressed as I interconnect wires. Not as ideal as my breakout board will be, but I'll have to make do until it arrives.
                            2. If it still fails to program after step #1, then I'll check to confirm whether or not the oscillators are, uh, oscillating, at the proper frequency by using an oscilliscope after powering it up. I'm assuming they are, but it's at least easy to check and then cross off the list of suspects.
                            3. If still no clues, then what's next? Logic probe on the two SW lines for a compare/contrast against a successful programming of a sparkfun nRF52832 board? That's sure to generate at least some palpable data as to where the problem is occurring.
                            I welcome other suggestions though on how to proceed. The above is just my best guess, and I'm sure others here are better at troubleshooting this than I am.
                              Mike_Lemo
                              Yeah well at least I managed to flash a blink program to my pcb and confirm that it works but now I'm planning to abanded from Arduino anyways sins alot of functionality isn't supported.
                              • M Mike_Lemo
                                If your abandoning from Arduino, what will you be abandoning to?
                                  Mike_Lemo
                                  Probably eclipse
                                  • M Mike_Lemo
                                    Probably eclipse
                                    #327
                                    Probably eclipse
                                    I'm rather hazy on the differences. I guess that way you can use all the Nordic libraries the way they were intended?
                                      #328
                                      Eclipse is just an IDE ;) like Arduino IDE, or VS etc.
                                      I think he means he wants to leave arduino core (mysensors rely on arduino core) to use nordic sdk with other ide (like eclipse, mbed, keil etc..). Because using eclipse with arduino core won't unlock features. It still needs coding.
                                      • scalzS scalz
                                        Toyman
                                        @scalz arduino.org ble library that's based on sandeepmistry's one seems very extensive.
                                        I believe one need pretty substantial reasons to migrate from arduino unless you are a professional developer
                                          #330
                                          Bluetooth is everywhere, and that's great, but I'm developing the impression that Bluetooth is rather arduous to program in its "native" format. Maybe this is an opportunity to build something simpler/easier that runs on top of Bluetooth, and yet can still interact with normal bluetooth devices in the native bluetooth that they understand? I think the Arduino's wide acceptance more or less proves that "easy is good."
