  3. nRF5 action!
nRF5 action!
    #317
    OK, I just pried off the lid on a different module and.... the same DEC2 cap is missing. However, according to scalz's new list that shouldn't matter.
    I'll need to check continuity to see if the DEC1 cap is really not there or rather simply appearing elsewhere due to the routing.
      #318
      It turns out DEC1 is connected to a capacitor: it's the one just south of the top left capacitor in the first photo.
      So, unless the cap values are just wrong, it seems that we don't need to add any more.
        What should I check next?
          I saw this in the MDBT42Q module datasheet, and perhaps it explains the relatively poor performance of the nRF52832 Adafruit Feather which uses the MDBT42Q.:
          I believe the Adafruit may have a much smaller ground plane than what is being recommended here by Raytac.
          Mike_Lemo
          @NeverDie I just made the antenna on my PCB stick out so there is no fiber glass under the antenna even.
          Also what is a good library for using NFC and the bluetooth peripheral of that MCU?
          I came across that library:
          https://github.com/sandeepmistry/arduino-BLEPeripheral
          but the page doesn't seem to support the BLE capability of the NRF52832
          and no luck for the NFC
          • d00616D d00616
            Also If I want to change the UART pins to other pins would it work without errors or If I want to use 2 or more UARTS? same with I2C
            The Chip has a lot of periphery on it. You can connect most components to pins. There is only one hardware UART, which can be connected. Please look at the Infocenter The arduino-nrf5 port is limited to things are implemented with arduino-samd by the author. This is the reason I have implemented an extension for hwPinMode() in MySensors.
            Another fine thing is the implementation of Shortcuts and the PPI. You can do a lot without using the CPU.
            Also what are the debugging options available sins the RS232 is not connected to the MCU like in an arduino how would I set stop points or peek at variables values to see if the code runs as expected?
            Debugging depends on your programmer and flashing tool. I think you can start by search for "openocd gdb". OpenOCD is the flashing tool in arduino-nrf5 for all supported programmers.
            Mike_Lemo
            What is that MySensors thing you were talking about?
            • M Mike_Lemo
              #322
              Yeah, that's what I opted for on Version 2 of my breakout board for the Ebyte nRF52832 module. Seems like the cleanest solution.
              The MDBT42Q is a lot smaller than the Ebyte module, so although I was bashing it for its performance on the Adafruit (which in their case may turn out to be ground plane related), that might be an acceptable trade-off for the smaller size.
              You have lots of good questions. Keep asking! I'm hoping to learn from the answers too.
                #323
                OK, here's my plan:
                1. It's possible the connections on my first attempt were a bit dodgy. I'll try again, but this time soldering a fresh new module to a prototype PCB so that they won't be mechanically stressed as I interconnect wires. Not as ideal as my breakout board will be, but I'll have to make do until it arrives.
                2. If it still fails to program after step #1, then I'll check to confirm whether or not the oscillators are, uh, oscillating, at the proper frequency by using an oscilliscope after powering it up. I'm assuming they are, but it's at least easy to check and then cross off the list of suspects.
                3. If still no clues, then what's next? Logic probe on the two SW lines for a compare/contrast against a successful programming of a sparkfun nRF52832 board? That's sure to generate at least some palpable data as to where the problem is occurring.
                I welcome other suggestions though on how to proceed. The above is just my best guess, and I'm sure others here are better at troubleshooting this than I am.
                  Mike_Lemo
                  Yeah well at least I managed to flash a blink program to my pcb and confirm that it works but now I'm planning to abanded from Arduino anyways sins alot of functionality isn't supported.
                  • M Mike_Lemo
                    If your abandoning from Arduino, what will you be abandoning to?
                      Mike_Lemo
                      Probably eclipse
                      • M Mike_Lemo
                        Probably eclipse
                        #327
                        Probably eclipse
                        I'm rather hazy on the differences. I guess that way you can use all the Nordic libraries the way they were intended?
                          #328
                          Eclipse is just an IDE ;) like Arduino IDE, or VS etc.
                          I think he means he wants to leave arduino core (mysensors rely on arduino core) to use nordic sdk with other ide (like eclipse, mbed, keil etc..). Because using eclipse with arduino core won't unlock features. It still needs coding.
                          • scalzS scalz
                            Toyman
                            @scalz arduino.org ble library that's based on sandeepmistry's one seems very extensive.
                            I believe one need pretty substantial reasons to migrate from arduino unless you are a professional developer
                              #330
                              Bluetooth is everywhere, and that's great, but I'm developing the impression that Bluetooth is rather arduous to program in its "native" format. Maybe this is an opportunity to build something simpler/easier that runs on top of Bluetooth, and yet can still interact with normal bluetooth devices in the native bluetooth that they understand? I think the Arduino's wide acceptance more or less proves that "easy is good."
                                Toyman
                                @NeverDie fully agree
                                  OK, here's my plan:
                                  #332
                                  OK, here's my plan:
                                  I executed step #1 of my plan with no change in results on the second attempt of programming. The module is definitely getting 3.3v power on the VCC pin.
                                  So, I executed step #2. I don't see any oscillation at all on the 32.7khz oscillator. The faster oscillator is mostly quiet, but it periodically gives short little bursts of activity--here's a screenshot of one:
                                  Not sure if this is normal or not, but that's what is going on.
                                  • T Toyman
                                    Mike_Lemo
                                    @Toyman what is that libray? I think of you refer to bel peripheral v0.3 it might not support the nrf52832 as I was asking before.
                                      #334
                                      So, for comparison, I measured the Sparkfun nRF52832 board, because (unlike the adafruit with its Raytac module), both oscillators are exposed for measurement. Unfortunately, it is already programmed, so it is not a true apples-to-apples comparison, but, anyway, the measurements were definitely different. First of all, the 32.7Khz oscillator was continuously oscillating at around 32.9Khz:
                                      and the faster oscillator was also continuously oscillating:
                                      I guess to have an apples-to-apples I would have to completely erase the firmware on the Sparkfun board.
                                      Anyhow, I think I'm getting the urge to order some Raytac modules.... It sounds as though they are not such a mystery.
                                        One thing I notice on the Ebyte module is that no RESET pin is exposed. Isn't that a bit odd?
                                        Also, there appears to be a typo on the silkscreen, where there are two pin 7's on the silkscreen, but probably one of them is actually pin 6.
                                          By the way, those short bursts on activity on the Ebyte module's fast oscillator happen pretty regularly, about every 22ms or so:
