  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
    I'm tring to blink an led on a PCB I made not realy knowing how to program the IC before other than connection the SWD pins.
    I've followed the startup guide at github flashed the soft device probably successful using the ST link V2(while flashing the soft device it blinked the on board st link V2 led and at the end the blue led on my PCB stopped being on.)
    So I've got an RGB led connected to my PCB to pins:
    #define RGBL_RED_PIN P0.16
    #define RGBL_GREEN_PIN P0.15
    #define RGBL_BLUE_PIN P0.17
    now for a test to see if I got it right I want to blink each of them how would I do it?
    What is the arduino pin mapping?
    Isn't the arduino mapping generally handled by the boards.txt file? Which board that you're using are you telling the compiler that it is? i.e. which board under the board manager in the Arduino IDE are you selecting?
    Mike_Lemo
    @NeverDie where can that boards.txt file of the NRF52 thing be found?
    • d00616D d00616
      @d00616 It says there NFC is not useable but what if my board is NFC hardware ready? how would I use that?
      It's simple. Use that. NFC isn't enabled or disabled by the board definition. Without SoftDevice, you have to enable the NFC functionality by flashing into the UICR.
      You can define your own Board. Look into the "boards.txt" file and the "variants" folder in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.3.0/ Most pins can be assigned to roles like SPI, I2C, UART.... Pins like NFC, RESET are fixed and analog Pins an be ordered like your needs.
      Mike_Lemo
      @d00616 I meant is there a library or something for that? how do I approach it I'm relatively new for this 3rd party arduino programming thing and I'ts necessary for me sins I already made a PCB for a micro controller I want to use.
      • M Mike_Lemo
        On the Windows platform it's located in this directory: Program Files/Arduino/hardware/arduino/avr
          Mike_Lemo
          @NeverDie I can't see the Generic nrf52 board setting
            #291
            I added the two caps that Scalz suggested for DEC1 and DEC2, but I'm still getting the same error message as before when I try to program it using the DK. Unless someone has further ideas, I may have to wait two weeks for my breakout board to arrive before I do more, as right now I'm just deadbugging this by soldering wires directly to the module.
            • M Mike_Lemo
              #292
              That's all I know, so hopefully someone who knows more can chime in and offer you guidance.
                BTW, here's a picture of how the silkscreen looks and which shows DEC1 in the "DEC5" location:
                  #294
                  Oh, I see now that @d00616 already has. Sorry, my browser didn't refresh, so I missed seeing his post.
                    Mike_Lemo
                    Yeah he did I just preformed a local search for that arduino15 on my PC
                      Mike_Lemo
                      Also If I want to change the UART pins to other pins would it work without errors or If I want to use 2 or more UARTS? same with I2C
                      Also what are the debugging options available sins the RS232 is not connected to the MCU like in an arduino how would I set stop points or peek at variables values to see if the code runs as expected?
                      d00616D 1 Reply Last reply
                      • M Mike_Lemo
                        you should follow this schematic design if you want to get this module working.
                        #297
                        There's a bunch of similar looking schematics in the nRF52832 datasheet for the nRF52832 chip itself, but I'm not sure which of them, if any, is applicable to the Ebyte module. I guess maybe Ebyte needs a demo board schematic like Raytac has. Either that, or we need a schematic of what's on the Ebyte module itself. As it stands, I think maybe there's no enough info with which to move ahead on wiring up the Ebyte module. Am I wrong? Come to think of it, I think some of the other Chinese modules I ordered from Aliexpress may also be similar "mystery" modules. :(
                        • M Mike_Lemo
                          d00616D
                          d00616D
                          d00616
                          The Chip has a lot of periphery on it. You can connect most components to pins. There is only one hardware UART, which can be connected. Please look at the Infocenter The arduino-nrf5 port is limited to things are implemented with arduino-samd by the author. This is the reason I have implemented an extension for hwPinMode() in MySensors.
                          Another fine thing is the implementation of Shortcuts and the PPI. You can do a lot without using the CPU.
                          Debugging depends on your programmer and flashing tool. I think you can start by search for "openocd gdb". OpenOCD is the flashing tool in arduino-nrf5 for all supported programmers.
                            #299
                            It looks as though raytec does make two modules for the nRF52832 that has a PCB antenna rather than a chip antenna: the MDBT42Q-P and the MDBT-42V-P:
                            http://statics3.seeedstudio.com/assets/file/bazaar/product/MDBT42Q-Version_B.pdf
                            The MDBT-42V-P looks nice because of its small size. Anyone know where it can be purchased? All of a sudden, buying a module that comes with a proper datasheet seems appealing.
                              Mike_Lemo
                              @NeverDie I had mine from seeed studio
                              • M Mike_Lemo
                                This one? https://www.seeedstudio.com/MDBT42Q-nRF52832-based-BLE-module-p-2736.html
                                  I was just now noticing that Nordic has a very convenient list of third party modules (and their dimensions) that use the Nordic nRF52832 chips: https://www.nordicsemi.com/eng/Products/3rd-Party-Bluetooth-low-energy-Modules
                                    #303
                                    FWIW, I just now sent an email to support@cdebyte.com requesting either a schematic of their E73-2G4M04S module itself or a schematic for a demo circuit, so that I may be certain about adding the appropriate hardware needed to get their module to work. I'll post if I hear anything back from them.
                                    By the way, in the case of Raytac, they even have their own demo board: https://raytac.blog/2017/01/24/how-to-use-raytac-mdbt42q-nordic-nrf52832-demo-board/
                                    mtiutiuM 1 Reply Last reply
                                      I saw this in the MDBT42Q module datasheet, and perhaps it explains the relatively poor performance of the nRF52832 Adafruit Feather which uses the MDBT42Q.:
                                      I believe the Adafruit may have a much smaller ground plane than what is being recommended here by Raytac.
                                        mtiutiuM
                                        mtiutiuM
                                        mtiutiu
                                        #305
                                        I requested the schematic for the cdebyte module too...but they replied: it's confidential - LOL.
                                        NeverDieN scalzS 2 Replies Last reply
                                        • mtiutiuM mtiutiu
                                          #306
                                          @mtiutiu
                                          How long did it take them to reply to you?
                                          I guess we may have to reverse engineer what they did then--at least roughly--in order to use it. I'll see if I can pry the cover off and photograph what's inside. If I'm successful, then I'll post the photos so we can all look at it together.
