  3. BME280 temp/humidity/pressure sensor
31 Posts 13 Posters 37.1k Views 17 Watching
  • signal15S
    signal15S
    signal15
    wrote on last edited by signal15
    Ah, looks like I just need to add "gw." in front of all of these functions and "MySensor gw;" just after the includes.
    • E
      E
      emc2
      Ah yes sorry, it's for the dev branch (1.6 or now called 2.0)
      signal15S 1 Reply Last reply
      • E emc2
        signal15S
        signal15S
        signal15
        @emc2
        Eh, looks like there's a lot more that I have to do to get this working, like moving the presentation into the setup() function.
        • E
          E
          emc2
          If you are using 1.5 probably a lot more.
          Easier to install 2.0, compile and upload. It will be compatible with your 1.5 gateway anyway.
          • E emc2
            signal15S
            signal15S
            signal15
            @emc2
            Oh, I thought that you had to upgrade the gateway as well. If that's the case, then I'll grab 2.0. Do I just go to the dev branch in github and hit download ZIP?
            • signal15S
              signal15S
              signal15
              Do you have to upgrade the files on the controller to 2.0b as well? I have a vera, and when I added this new sensor on 2.0b, all of my nodes stopped updating and the tiles for them on the Devices screen doesn't list anything about the sensor like it normally does.
              I get these errors in the Vera logs:
              02	05/06/16 18:54:40.167	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduino1 <0x2ac17000>
              02	05/06/16 18:54:40.170	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduinonode1 <0x2ac17000>
              02	05/06/16 18:54:40.171	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduinonode1 <0x2ac17000>```
              Also, the MySensors parent device disappeared from my Devices page in Vera. If I telnet to my gateway on port 5003, I only see the new sensor reporting as well, not any of my other sensors. Did the 2.0b sensor do something bad to my gateway or the Vera plugin?
              Update: I deleted the new devices created from the 2.0b sensor in my Vera. This fixed it so the other node information showed up again, and the MySensors parent device showed up. But, my 1.5 sensors were no longer updating. I restarted them, and they started updating.
              If 2.0 sensors are designed to be backwards compatible with a 1.5 gateway and 1.5 controller code, then there's a problem somewhere. Maybe it's with the Vera code. But, like I said, I telneted to port 5003 on my gateway, and the only thing that the gateway was receiving was the data from my 2.0b sensor. Either the gateway was ignoring the 1.5 sensors, or the 1.5 sensors stopped sending for some reason.
              Thoughts?
                Hmm.. I wonder if this change might have interfered with the Vera plugin.
                https://github.com/mysensors/Arduino/commit/bbc6a221f4c153f41993207e521f5531ba853d1a
                https://github.com/mysensors/Arduino/pull/420
                  signal15S
                  signal15S
                  signal15
                  @hek
                  Let me know if you make a change and need me to test.
                  • signal15S signal15
                    Awesome. I just got it working with a test sketch like 2 minutes ago. If I get a working sketch for MySensors, how can I get it uploaded to the site as an example?
                    Also, if anyone has done it before, I'd appreciate any code you might have to save some time. I only get like 5 minutes here an there to work on this.
                    Y
                    Y
                    yoshida
                    @emc2 or anybody:
                    Does anyone have a working BME280 mysensors arduino sketch? The code above states include mysensor.h now it is mysensorS.h, so I have renamed, but it won't compile, it says:
                    In function 'void setup()':
                    bme280:252: error: 'getConfig' was not declared in this scope
                    I have a MySensors Gateway USB
                    Version: 2.1.1 (arduino nano) with Domoticz, and I would like to use the bme280 for a battery powered outdoor temp/humidity/barometer (as DHT22 does not like battery level below 3.3V, and I would run on 2x1.5V AA)
                    • E
                      E
                      emc2
                      Was modified in 2.1.1, you need to change
                      to
                      metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
                      Y 1 Reply Last reply
                      • A
                        anno
                        wrote on last edited by anno
                        Still a lot of errors in this sketch, did take some out but this is still in it:
                        In file included from C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino:48:0:
                        C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
                        #ifndef __BME280_MOD-1022_H
                        C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
                        #define __BME280_MOD-1022_H
                        In file included from C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:40:0:
                        C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
                        C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
                        C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp: In member function 'BME280Class::readCompensationParams()':
                        C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:276:45: warning: iteration 20 invokes undefined behavior [-Waggressive-loop-optimizations]
                        compParams.compArray[count] = Wire.read();
                        C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:275:3: note: containing loop
                        for (count = 0; count < 28; count++) { // first 28 bytes we can process like this
                        C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino: In function 'loop':
                        • E emc2
                          to
                          Y
                          Y
                          yoshida
                          @emc2 Thanks! With this modification the sketch compiled successfully. Today I had time, so put everything together, and the BME280 works with the 2.4GH radio, temp/hum/pressure all reporting like they should.
                          Using arduino pro mini, bme280, nrf24, 2XAA Batteries. It reports to the mysensors serial gw, and then shown in domoticz.
                          Z 1 Reply Last reply
                          • Y yoshida
                            Z
                            Z
                            Zbigniew Ko
                            @yoshida Hello
                            You can share your sketch.
                            Please
                            I can not make modifications.
                            I still have a lot of errors.
                            • A
                              anno
                              • Z Zbigniew Ko
                                @yoshida Hello
                                Please
                                Y
                                Y
                                yoshida
                                Zbigniew Ko:
                                (2.1.1 mysensors compatible, but first you need to install the BME280_MOD-1022.h library in arduino IDE)
                                 * Version 1.0 - Henrik Ekblad
                                 * Pressure sensor example using BMP085 module
                                 * http://www.mysensors.org/build/pressure
                                // BME280 libraries and variables
                                // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
                                // Written originally by Embedded Adventures
                                // https://github.com/embeddedadventures/BME280
                                #include <BME280_MOD-1022.h>
                                #define BARO_CHILD 0
                                #define TEMP_CHILD 1
                                #define HUM_CHILD 2
                                const float ALTITUDE = 184; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
                                // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
                                const unsigned long SLEEP_TIME = 60000;
                                const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                                enum FORECAST
                                  STABLE = 0,     // "Stable Weather Pattern"
                                  SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
                                  CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
                                  UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
                                  THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
                                  UNKNOWN = 5     // "Unknown (More Time needed)
                                float lastPressure = -1;
                                float lastTemp = -1;
                                float lastHum = -1;
                                int lastForecast = -1;
                                const int LAST_SAMPLES_COUNT = 5;
                                float lastPressureSamples[LAST_SAMPLES_COUNT];
                                // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
                                // get kPa/h by dividing hPa by 10
                                #define CONVERSION_FACTOR (1.0/10.0)
                                int minuteCount = 0;
                                bool firstRound = true;
                                // average value is used in forecast algorithm.
                                float pressureAvg;
                                // average after 2 hours is used as reference value for the next iteration.
                                float pressureAvg2;
                                float dP_dt;
                                boolean metric;
                                MyMessage humMsg(HUM_CHILD, V_HUM);
                                MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
                                float getLastPressureSamplesAverage()
                                  float lastPressureSamplesAverage = 0;
                                  for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                                    lastPressureSamplesAverage += lastPressureSamples[i];
                                  lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                                  return lastPressureSamplesAverage;
                                // Algorithm found here
                                // Pressure in hPa -->  forecast done by calculating kPa/h
                                int sample(float pressure)
                                  // Calculate the average of the last n minutes.
                                  int index = minuteCount % LAST_SAMPLES_COUNT;
                                  lastPressureSamples[index] = pressure;
                                  minuteCount++;
                                  if (minuteCount > 185)
                                    minuteCount = 6;
                                  if (minuteCount == 5)
                                    pressureAvg = getLastPressureSamplesAverage();
                                  else if (minuteCount == 35)
                                    float lastPressureAvg = getLastPressureSamplesAverage();
                                    float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                      dP_dt = change * 2; // note this is for t = 0.5hour
                                      dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                                  else if (minuteCount == 65)
                                      dP_dt = change; //note this is for t = 1 hour
                                      dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                                  else if (minuteCount == 95)
                                      dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                      dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                                  else if (minuteCount == 125)
                                    pressureAvg2 = lastPressureAvg; // store for later use.
                                      dP_dt = change / 2; // note this is for t = 2 hour
                                      dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                                  else if (minuteCount == 155)
                                      dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                      dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                                  else if (minuteCount == 185)
                                      dP_dt = change / 3; // note this is for t = 3 hour
                                      dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                                    pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                                  int forecast = UNKNOWN;
                                    forecast = UNKNOWN;
                                  else if (dP_dt < (-0.25))
                                    forecast = THUNDERSTORM;
                                  else if (dP_dt > 0.25)
                                    forecast = UNSTABLE;
                                    forecast = CLOUDY;
                                    forecast = SUNNY;
                                  else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                                    forecast = STABLE;
                                    forecast = UNKNOWN;
                                  // uncomment when debugging
                                  //Serial.print(F("Forecast at minute "));
                                  //Serial.print(minuteCount);
                                  //Serial.print(F(" dP/dt = "));
                                  //Serial.print(dP_dt);
                                  //Serial.print(F("kPa/h --> "));
                                  return forecast;
                                  Wire.begin(); // Wire.begin(sda, scl)
                                void presentation()  {
                                  sendSketchInfo("BME280 Sensor", "1.6");
                                  // Register sensors to gw (they will be created as child devices)
                                  present(BARO_CHILD, S_BARO);
                                  present(TEMP_CHILD, S_TEMP);
                                  present(HUM_CHILD, S_HUM);
                                // Loop
                                  // need to read the NVM compensation parameters
                                  BME280.readCompensationParams();
                                  /* After taking the measurement the chip goes back to sleep, use when battery powered.
                                  // Oversampling settings (os1x, os2x, os4x, os8x or os16x).
                                  BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient, higher numbers avoid sudden changes to be accounted for (such as slamming a door)
                                  BME280.writeOversamplingPressure(os16x);    // pressure x16
                                  BME280.writeOversamplingTemperature(os8x);  // temperature x8
                                  BME280.writeOversamplingHumidity(os8x);     // humidity x8
                                  BME280.writeMode(smForced);                 // Forced sample.  After taking the measurement the chip goes back to sleep
                                  // Normal mode for regular automatic samples
                                  BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                                  BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                                  BME280.writeMode(smNormal);
                                  while (1) {
                                    // Just to be sure, wait until sensor is done mesuring
                                    while (BME280.isMeasuring()) {
                                  // Read out the data - must do this before calling the getxxxxx routines
                                  BME280.readMeasurements();
                                  float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
                                  float humidity = BME280.getHumidityMostAccurate();
                                  float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
                                  float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
                                  int forecast = sample(pressure);
                                  if (!metric)
                                    // Convert to fahrenheit
                                    temperature = temperature * 9.0 / 5.0 + 32.0;
                                  Serial.println();
                                  Serial.print("Temperature = ");
                                  Serial.print(temperature);
                                  Serial.println(metric ? " °C" : " °F");
                                  Serial.print("Humidity = ");
                                  Serial.print(humidity);
                                  Serial.println(" %");
                                  Serial.print("Pressure = ");
                                  Serial.print(pressure);
                                  Serial.println(" hPa");
                                  Serial.print("Forecast = ");
                                  Serial.println();
                                  if (temperature != lastTemp)
                                    send(tempMsg.set(temperature, 1));
                                    lastTemp = temperature;
                                  if (humidity != lastHum)
                                    send(humMsg.set(humidity, 1));
                                    lastHum = humidity;
                                  if (pressure != lastPressure)
                                    send(pressureMsg.set(pressure, 2));
                                    lastPressure = pressure;
                                  if (forecast != lastForecast)
                                    send(forecastMsg.set(weather[forecast]));
                                    lastForecast = forecast;
                                  sleep(SLEEP_TIME);
                                • Z
                                  Z
                                  Zbigniew Ko
                                  wrote on last edited by Zbigniew Ko
                                  #22
                                  @yoshida Thank you very much.
                                  As soon as I find time I will check it out.
                                  Yes checked, sketch works.
                                  Thanks yoshida.
                                  Please note that the library BME_MOD-1022.h consists of two parts: file-h, and file cpp.
                                    I am using the one from adafruit : what's the difference with this other library?
                                    alexsh1A 1 Reply Last reply
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @gohan I have been using both libraries with a chinese module I bought from Aliexpress. I did not notice any differences apart from size and maybe a module address, which you can change in either library.
                                      • B
                                        B
                                        bluezr1
                                        I used the last sketch posed by Yoshida and for some reason whenever the temp and humidity goes through a stretch where there isn't any change, it's as if the node goes into a deep sleep and doesn't come out of it until I hit the reset on a pro mini.
                                        I have it plunged in and not on batteries, so no need for any deep sleep. Is there anything I can change in the sketch? I'm still fairly new at this, although I'm having a blast.
                                        • B bluezr1
                                          Y
                                          Y
                                          yoshida
                                          @bluezr1 Interesting... :) I used it with a pro mini as well, and my problem was that it ate up the batteries in 2 weeks... :D So I would need more deep sleep for the same sketch :D
                                          But for that 2 weeks, it was working well. Temp/Hum/Baro updated every minute.
