  3. Problem when sending or receiving
8 Posts 3 Posters 3.9k Views 1 Watching
  • N
    N
    nono056
    Hello everybody!
    I have a problem :
    I have an arduino nano which is the SerialGateway
    An arduino mini is a node with a ds18b20.
    When i test my sensor with the original arduino library for the ds18b20, it works, i have a good temperature.
    I test too my two nrf24l01 with a ping with the mirf library and this works too.
    My problem is the SerialGateway return me infos like 255;255;5;4; for my temp sensor.
    I have used originals sketchs of the mysensors
    Anyone can tell me why i don't have my temperature in the serial interface?
    PS : Sorry for my bad english...
      wrote on last edited by hek
      "like" is not good enough :smile: .. Is the above exactly what you get?
      By default your sensor will ask controller for format-settings. If you don't have any controller it will ask forever. Try removing the line:
      metric = gw.isMetricSystem();
      • N
        N
        nono056
        Thanks Hek for your answer!
        The really message is :
        0;0;4;11;Arduino startup complete.
        255;255;4;5;
        255;255;4;5;
        255;255;4;5;
        255;255;4;5;
        This is exactly the same thing without metric = gw.isMetricSystem();
        I have another problem (i think...)
        I receive messages every 5 seconds. This is normally 30s?
        An other precision, my ds18b20 is on pin 4 (changed in the sketch). Not a problem?
          Set a static id for for your sensor node. E.g.
          gw.begin(42)
          • N
            N
            nono056
            Thanks Hek!!
            now it works!
            So any idea why the serial gateway doesn't give me an id?
            If i put metric = gw.isMetricSystem(); in the code i give 40;255;4;13; and without, it gives me 40;0;1;0;20.7
            isMetricSystem would give me metric data and not imperial? I don't understand...
              Serial gateway does not hand out ids. The controller behind it does. So either you add a controller or use static ids.
              N 1 Reply Last reply
                N
                N
                nono056
                @hek Ok perfect!
                • epierreE
                  epierreE
                  epierre
                  I have the same issue here with libraries 1.3b3 link text
                  I've setted in the temp sensor the node it, commented the metric line in the sensor too.
                  Now when I flash, I have a receive timeout (they are close within 10cm):
                  0;0;4;11;Relaying message back to gateway.
                  0;0;4;11;Tx: fr=0,to=0,la=0,ne=0,ci=255,mt=4,ty=13,cr=52:
                  0;0;4;11;Ack: receive timeout
                  z-wave - Vera -> Domoticz
