  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 117.0k Views 41 Watching
  • U user2684
    @Ivan-Z if you mean an example with DHT22, you need first of all to enable the DHT module in config.h with:
    #define MODULE_DHT 1
    Then just register the sensor in before() with:
    nodeManager.registerSensor(SENSOR_DHT22,6);
    Where 6 is the pin where the sensor is attached to. NodeManager will then create automatically two child ids, one for temperature and the other for humidity.
    As written in the documentation you need the DHT library from https://github.com/adafruit/DHT-sensor-library (or install it by using the arduino IDE). For some unknown (to me) reasons I had issues in using the library from the mysensors example.
    What do you mean by optimization flag?
    As for avoid sending the same value, this is already available, have a look at setTackLastValue() from the documentation. When set to true, the value will not be send if the same as the previous (default is of course false). I also implemented setForceUpdate(), to force to send an update after the configured number of cycles, as many examples here are using this approach.
    dakipro
    @user2684 Hi, i am trying to get started with NodeManager, and I have a question about dht configuration?
    I would like to set it to not update values if temperature is not changed, something like ((SensorLatchingRelay*)nodeManager.getSensor(1))->setTackLastValue(true);
    But how do I select both sensors, are they numbers 1 and 2 (both temp and humidity)?
    I would also like to add these settings to them.
    ((SensorLatchingRelay*)nodeManager.getSensor(1))->setForceUpdate(4);
    ((SensorLatchingRelay*)nodeManager.getSensor(1))->setFloatPrecision(1);
    Sergio RiusS U 2 Replies Last reply
    • ronnyandreR ronnyandre
      @Sergio-Rius I think I understood it correctly. Code goes on the sensors, not on the gateway itself? That means, the MySensors Serial Gateway I use is only a carrier of the messages that NodeManager receives on the sensors I implement the code?
      Sergio RiusS
      Sergio RiusS
      Sergio Rius
      @ronnyandre NodeManager is a code wrapper. It's a collection of libraries, that has been join with a configuration script that automatically picks and does what is needed for your like.
      You can make a common temperature sensor, but if you look at the documentation and the NodeManager.h code or the ino template itself, you have options for gateway configuration.
      So you should be able to configure a gateway sketch and burn into your hardware.
      I hope this gives some light before the dinner ;)
      ronnyandreR U 2 Replies Last reply
      • D dakipro
        Sergio RiusS
        Sergio RiusS
        Sergio Rius
        #79
        @dakipro said in 💬 NodeManager:
        SensorLatchingRelay is wrong here.
        Try:
          int sensorDHT_Id = nodeManager.registerSensor(SENSOR_DHT22, PIN_DHT);
          SensorDHT* sensorDHT = (SensorDHT*)nodeManager.getSensor(sensorDHT_Id);
          sensorDHT->setSamples(5);
          sensorDHT->setSamplesInterval(2001);
          sensorDHT->setTackLastValue(true);
          sensorDHT->setForceUpdate(3);
        Those options refer to the whole device, should be applied also to humidity. There was a bug on this but I think it was already corrected. If not, try with development version.
        • D
          dakipro
          Thanks, right after posting the question, I have found a example on the topic itself (search function on the forum does not search current topic anymore, I had to scroll down to be able to "find in page").
          I am now using this
          int sensorDHT_Id = nodeManager.registerSensor(SENSOR_DHT22,4);
          Will see how it goes :)
          • Sergio RiusS Sergio Rius
            ronnyandreR
            ronnyandreR
            ronnyandre
            @Sergio-Rius Thanks man! I will definitely take a closer look. I just one silly last question....
            Trying to use a simple DS18B20 temperature sensor, and I get the following error:
            error: 'SENSOR_DS18B20' was not declared in this scope
            nodeManager.registerSensor(SENSOR_DS18B20,3);
            Seems like it doesn't like me declaring it. I have installed Dallas Temperature and One Wire through Arduino libraries.
            Newbie with RPi and Domoticz, trying to automate my home.
            U 1 Reply Last reply
              mickecarlsson
              @ronnyandre you need to uninstall those libraries and install those mentioned in the heading: Installing the dependencies: NodeManager
              ronnyandreR 1 Reply Last reply
              • M mickecarlsson
                ronnyandreR
                ronnyandreR
                ronnyandre
                @mickecarlsson Thanks, I will try that later today :smiley:
                  U
                  U
                  user2684
                  @Sergio-Rius @ronnyandre just to add something on top of what already discussed regarding the gateway thing, yes you can use NodeManager for the gateway as well or alternatively a standard gateway sketch, those are fully compatibile since NodeManager adds very little when running as a gateway, it just relies on the standard MySensors library and directives
                  • D dakipro
                    U
                    U
                    user2684
                    @dakipro in addition to what @Sergio-Rius already pointed out correctly, consider when multiple child IDs are created, you would need to call those functions on EACH id. Have a look at https://github.com/mysensors/NodeManager/issues/176 for more details. Thanks
                      U
                      U
                      user2684
                      @ronnyandre ensure MODULE_DS18B20 is enabled in your config.h otherwise SENSOR_DS18B20 will not be made available. Thanks
                      • U user2684
                        Sergio RiusS
                        Sergio RiusS
                        Sergio Rius
                        @user2684 on #176 issue... and the sample I pasted before... then we have to configure Samples, SamplesInterval, TackLastValue and ForceUpdate for Temp and Hum separately?
                        It doesn't make sense to me.
                          U
                          U
                          user2684
                          @Sergio-Rius yes, this is the case, since two different and completely independent child IDs are created, you need to call the methods on both. This is true for any sensor creating multiple IDs. And you're right, it doesn't make sense to me either, it is something I've realized recently. I'm tracking it down with https://github.com/mysensors/NodeManager/issues/198 but I do not expect this to be an easy fix. Thanks
                          • V
                            V
                            vikasjee
                            Hi, what's your calendar for v 1.6.0. I was looking forward to IO-Expander MCP23017 and TTP226/9 support in this release...
                            • V vikasjee
                              U
                              U
                              user2684
                              @vikasjee this was the plan, you're right, but I had to postpone a good number of requests supposed to be part of v1.6 since I wanted to allow this https://forum.mysensors.org/topic/6980/browser-based-firmware-generator which is dependent on NodeManager to come to life asap. So unfortunately I had to move those enhancement requiring some effort to v1.7 even if I already acquired the hardware. Sorry for that
                              V 1 Reply Last reply
                              • U user2684
                                V
                                V
                                vikasjee
                                @user2684 No issues! When are you planning for 1.7.0? Looking forward to an early release especially the IO-Expander MCP23017 support...
                                • V vikasjee
                                  U
                                  U
                                  user2684
                                  @vikasjee v1.7 will be somewhere after summer since v1.6 should be out by the end of this month I guess. But I can promise to start looking into IO-Expander MCP23017 support as the first thing as v1.7 development will start so to make it available first thing into the development branch :)
                                    MCF
                                    Hi, is it possible to add neopixel in the next version? thank you for your work
                                    • A
                                      ArduiSens
                                      Hello, is there an option to use the (fantastic) Node Manager in a RS485 wired set-up?
                                      MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
                                      • M MCF
                                        U
                                        U
                                        user2684
                                        @MCF I've added https://github.com/mysensors/NodeManager/issues/203 to track this request. Feel free to add any relevant comment or code samples to the issue. Thanks!
                                        • A ArduiSens
                                          U
                                          U
                                          user2684
                                          @ArduiSens RS485 should be already there in the development version (https://github.com/mysensors/NodeManager/tree/development). Nothing special, I've just added to config.h some sample directives, commented out by default. Let me know in case this approach can be improved. Thanks!
